jayrapbb
New Member
I have a 2006 passat 3.2
Ive just had a new timing chain kit installed but now that car still isn't 100%
It will get you A to B, but not very comfortably.
The code reader displays...
Idle rpm level too high
Cylinder 3 misfire
Cylinder 1 misfire
Fuel rail pressure sensor circuit
The misfires do change in terms of which cylinder but 3 and 1 seem to be permanent.
The car whilst idle revs on its own between 1 and 2000 revs and shudders and hesitates on acceleration, sometimes it feels it comes back to life and throws uou back on your seat so surely nothing major.
A mechanic told me it has something to do with the breather pipe going into the inlet manifold. When he took it off, he found that there was a blocker put inside, now he took it out but then the car just built up oil pressure howevdr the engine quietened down and wasn't rough, so he put the blocker back in but screwed a small hole into the blocker to prevent it building pressure but it's still not right! Any suggestions are much appreciated
Cylinder 3 misfire
Cylinder 1 misfire
