Currently looking at a 2017 A3 with DPF issues. ive tried static and driving regens but neither raise the exhaust temp enough. sensor 1 rises to about 400-450C then falls again soon after reaching that temp.
Thursday,23,April,2020,20:45:42:58568
VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8VXHA041210 License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 29 39 42 44 52 55 5F BB BC D6 D7
VIN: WAUZZZ8VXHA041210 Mileage: 34459km-21411miles
Address 01: Engine (2D2D2-CXXB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 056 D HW: 04L 907 445 B
Component: R4 1.6l TDI H06 2510
Revision: 22004001
Coding: 02194012432501092000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM16TDI03004L906056D 002006
ROD: EV_ECM16TDI03004L906056_002_VW37.rod
VCID: 2E04F75B509909FBF1E-807A
23902 - Diesel Particle Filter
P2463 00 [163] - Excessive Soot Accumulation
Mileage: 34459 km
Date: 2020.04.23
Time: 20:35:04
Coolant temperature: 77 °C
Intake air temperature: 20 °C
Voltage terminal 30: 12.687 V
Zähler der Regenerationszeit des Partikelfilters: 10801 s
Particle filter: kilometers since last regeneration: 1201.5
Particle filter: soot mass measured: 1.45 g
Particle filter: soot mass calculated: 54.11 g
Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 9.0 mbar
Particle filter: field regeneration lock status: 0
23967 - Diesel Particulate Filter
P2458 00 [163] - Regeneration Duration
Mileage: 34459 km
Date: 2020.04.23
Time: 20:35:04
Voltage terminal 30: 12.671 V
Particle filter: field regeneration lock status: 227
Readiness: N/A
Part No SW: 5Q0 614 517 AR HW: 5Q0 614 517 AG
Component: ESC H62 0642
Revision: 00000000 Serial number: 62296000002885
Coding: 12F18AA224240A6D49790E0140C32548512450927002A472024100788008420000000012121212B835351919323200
VCID: 015E7CE7B18746835CC-8054
Part No SW: 8V0 820 043 M HW: 8V0 820 043 M
Component: AC Automat H03 0110
Revision: 20001000 Serial number: 00000001013586
Coding: 03100104002000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
VCID: 3C20CD1396E5EB6B4FA-8068
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: 0459044800PAG0MUFU03
328963 - Motor for Front Air Distribution Flap
B1091 13 [008] - Open Circuit
Reset counter: 86
Mileage: 33493 km
Date: 2020.03.13
Time: 12:53:13
Voltage terminal 30: 14.0 V
Interior temperature: 23.8 °C
Outside air temperature: 11 °C
Front air distribution flap: actual value: 0
Front air distribution flap: actual value: 97.0 %
Front air distribution flap: specified value: 103
Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H34 0236
Serial number: 02001623101154
ROD: EV_BCMBOSCH_017.rod
VCID: 7EA4071BC079397B21E-802A
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 160809 043 0580
Serial number: 160816094131
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 62158394
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Serial number: 30 06 2016 00001350
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY16202123L
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000066831176
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 HW: 5QA 919 283
Component: PDC 4 KanalH07 0031
Serial number: 000308419616217
Coding: 0700040001
ASAM Dataset: EV_EPHVA14AU3700000 009027
ROD: EV_EPHVA14AU3700000_009_AU37.rod
VCID: 074A62FF9FA378B3128-8052
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0315
Serial number: 003TDR21WXFQ
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
VCID: 107849A3EAED3F0BC32-8044
Subsystem 1 - Part No SW: ----------- HW: 480 001 908 16
Serial number: 35700000000F0260FD1O
Subsystem 2 - Part No SW: ----------- HW: 480 001 908 16
Serial number: 35800000000112B0CD1E
Subsystem 3 - Part No SW: ----------- HW: 480 402 208 16
Serial number: 3510001C921DBA054742
Subsystem 4 - Part No SW: ----------- HW: 480 402 208 16
Serial number: 3520001C921DBA0492EC
Subsystem 5 - Part No SW: ----------- HW: 480 402 507 16
Serial number: 35500029D211FA33B322
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 401 908 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001C121DBA0481C2
Subsystem 7 - Part No SW: ----------- HW: 480 401 908 16
Component: PedP_Sensor_P 000 6149
Serial number: 2290001BB21A81F51755
Subsystem 8 - Part No SW: ----------- HW: 480 003 007 16
Component: PedPSensor_D2 001 0887
Serial number: I0M00000000BAB1D6D1K
Subsystem 9 - Part No SW: ----------- HW: 480 003 007 16
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000226B80D1+
Part No SW: 8V0 953 521 HB HW: 5Q0 953 549 E
Revision: -------- Serial number: 08081604400567
Coding: A408
ROD: EV_SMLSKLOMQB_019_AU37.rod
Part No SW: 8V0 920 972 L HW: 8V0 920 972 L
Component: KOMBI H04 8316
Coding: 27A40A002B8026000100E8001001000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009054
VCID: 47CAA2FFDF23B8B3D28-8012
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_Audio_0x31 keine Kommunikation]
Reset counter: 98
Mileage: 33461 km
Date: 2020.03.12
Time: 13:32:00
16777022 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_NAV SD_0x32 keine Kommunikation]
Reset counter: 103
Mileage: 33499 km
Date: 2020.03.13
Time: 15:36:13
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 13081610800295
Coding: 030100041F0873005B000248080B00000001010000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 7CA00D13D6652B6B0FA-8028
Subsystem 2 - Part No SW: 81A 951 523 HW: 81A 951 523
Component: J453 MFL H04 0003
Serial number: 20160804122003 00253
Serial number: 75410803001608171360
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 8S0 907 397 D HW: 8S0 907 397 D
Component: LCM_MQB H06 0016
ASAM Dataset: EV_LCMLeftCONTIAU426 001008
VCID: 42DCB3EBF4019D9B056-8016
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
ASAM Dataset: EV_LCMRightCONTIAU426 001008
Component: TSG FS 020 0041
Serial number: 300716EGT04156
Coding: 001C8A204001040000001002
VCID: 43D2B6EFEB1B94930E0-8016
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 128 1072
Coding: 8107
ROD: EV_SteerAssisMQB_013.rod
VCID: 45D6A8F7E52FAAA3204-8010
Component: TSG BFS 020 0041
Serial number: 060816EH504277
Coding: 001C82204001040000001002
Address 55: Headlight Range (J745) Labels:* None
Part No SW: 8V0 907 357 A HW: 7P6 907 357 B
Component: MxB-ECU 001 0230
Coding: 0ECE00102B230200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
VCID: 3E24C71B80F9F97B61E-806A
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 81A 035 192 HW: 81A 035 192
Component: MU-HS-LND-EU 045 0148
Coding: 01730301FF00000011111101000A00102F002AC601F00100CE
ASAM Dataset: EV_MUHigScl6C3DELP 001011
ROD: EV_MUHigScl6C3DELP.rod
VCID: 5EE4679B60B9D97B01E-800A
Subsystem 1 - Part No SW: 8W0 919 866 C HW: -----------
Component: ECE 2016 --- 0009
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9GY20797C
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BE HW: 8V0 919 614 BE
Component: ControlUnit_B H50 0103
Serial number: ALJAL119051600010479
2562 - Navigation System
B126C F0 [008] - Navigation Database Faulty
Fault Frequency: 11
Reset counter: 69
Mileage: 29347 km
Date: 2019.10.26
Time: 13:44:45
Voltage terminal 30: 12.4 V
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 280716EGS07269
Coding: 000C82204001040000001002
Component: TSG HBFS 020 0041
Serial number: 280716EGS07265
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
ROD: EV_LEDModLeftMELCOAU736_AU37.rod
VCID: 176A32BFCF03E833828-8042
Component: LED1R H09 0008
End----------(Elapsed Time: 01:25, VBatt start/end: 12.4V/12.4V)-----------
