Results 1 to 5 of 5
Thread: 7spd dsg into B8 A4
    Apr 2020
    Jacksonville, FL, USA
    7spd dsg into B8 A4
    I'm attempting to install Audi S4 dsg gear box into a B8 A4. I purchased a HEX-V2 several months back to see if it the
    A4 showed a coding option for a dsg unit and it did. I repinned the TCM connector for the dsg gearbox (the connector is a completely different style and an additional wire needed to be routed to the ECM). Installed the transmission and plugged it in. Attempted to change the ECM coding from the convetional automatic unit to the dsg option but when I attempt to load it I receive a "coding rejected error 31:request out of range" message. Oddly the ECM isn't setting any dtcs related to an issue with the TCM even though the coding has not been changed but I do have faults for TCM incorrect software versions. I was wonder if anyone can send me in a direction... lol
    Chassis Type: FL-AU48 (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 72 77
    VIN: WAUBFAFL6AN015134   Mileage: 294770km-183161miles
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Component: 2.0l R4/4V TF H15 0001
       Revision: E1H15---
       Coding: 0104010A190F0160
       Shop #: WSC 03129 444 105140
       VCID: 79AFEDD4195F5A5314C-802C
    Readiness: 1110 0101
       Part No SW: 8K5 927 156 D    HW: 0B5 927 156 K
       Component: 0B5 30TFSINAR H01 0002
       Revision: --H01---
       Shop #: WSC 06325 000 00000
       ROD: EV_TCMDL501021.rod
       VCID: 3A2D32D85CD9914B5D6-806E
    8445 - Transmission Control Module
              P0614 00 [167] - Incorrect Software Version
                        Reset counter: 40
                        Mileage: 294775 km
                        Date: 2020.04.22
                        Time: 20:07:11
                        Engine speed: 0 /min
                        Transmission input speed: 0 /min
                        Engine torque: -44 Nm
                        Transmission fluid temperature: 27 °C
                        Accelerator position: 0.0 %
                        Clutch status: Beide Kupplungen offen
                        Voltage terminal 30: 12.400 V
                        Voltage_5V_CAN_pressuresensors-Param to DOP: 4.916 V
    8446 - Transmission Control Module
                        Reset counter: 40
                        Mileage: 294775 km
                        Date: 2020.04.22
                        Time: 20:07:11
       Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
       Component: ESP8 quattro  H04 0010
       Coding: 150D10
       Shop #: WSC 02391 823 56573
       VCID: 7AADF2D81CD9514B1D6-802E
       Part No SW: 8K0 907 064 DF    HW: 8K0 907 064 DF
       Component: BCM2 1.1      H02 0321
       Coding: 090100
       Shop #: WSC 02399 823 56573
       VCID: 77ABEBEC2FCB4C23628-8022
       Serial number: 0509000039647009
       Serial number: 0209000053026002
       Part No SW: 8T1 820 043 AN    HW: 8T1 820 043 AN
       Component: KLIMA 1 ZONE  H08 0171
       Revision: A1000000    Serial number: 01210720091842
       Coding: 64002000
       VCID: 7DA7F9C40DF76673384-8028
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H25 0380
       Revision: 10025001    Serial number: 00000000432250
       Coding: 690000B1063C00010000080300007F5F0F14520800000021000000
       VCID: 3C2134C0566DAF7B4FA-8068
       Component: WWS 200709  H06 0070
       Serial number: SWF09070205534
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 941 531 AK    HW: 8K0 941 531 AK
       Component: E1 - LDS  H08 0090
       Serial number: 00000000001507091803
    02258 - Door Opener Transmitter
                        Reset counter: 110
                        Mileage: 294775 km
                        Date: 2020.04.22
                        Time: 20:07:00
       Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
       Component: AirbagVW-AU10 H37 0520
       Serial number: 003EGD02ABN6
       Shop #: WSC 02135 785 00200
       VCID: 42DD4A383409D98B056-8016
       Serial number: 5810000R0900004HT5
       Serial number: 6334MSME4946260CG
       Serial number: 6344MSME4946060BE
       Serial number: 6352QSME26332B1AF
       Serial number: 6362QSME69343412A
       Serial number: 63732SME370D140A.
       Serial number: 63832SME670C261A1
       Component: Lenks.Modul   H16 0014
       Revision: --------    Serial number: 90304IGN0007T
       Coding: 000034
       VCID: 3D2739C44D77A673784-8068
       Component: E221 - MFL  H02 0010
       Part No SW: 8K0 920 950 E    HW: 8K0 920 950 E
       Component: KOMBIINSTR.   H19 0253
       Revision: 00100000    Serial number: BWX24KE79
       Coding: 8B1709000300D705020001
       VCID: 313F15F4812F5213ECC-8064
       Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0105
       Revision: GB600050    Serial number: 5000G09716849D
       Coding: 00C303
       Shop #: WSC 08185 444 92442
       VCID: 50F97070EAE53B1B832-8004
       Component: J367-BDM  H06 0160
       Serial number: 19087011060709
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0280
       Revision: 00000000
       Coding: 020302
       VCID: 392F2DD4595F9A5354C-806C
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000009130395
       Coding: 011C03204000410001
       VCID: 45D7512425A7EEB3204-8010
       Revision: 00002001    Serial number: 0120029048
       Coding: 0106023A007A400400B0010000000000
       Component: GTO BF  H06 0050
       Serial number: 00000000000000155540
       Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J245 PS037  H06 0041
       Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
       Component: DSP STD       H07 0230
       Revision: S2200000
       Coding: 0203010102
       VCID: 74B1DCE03EBD273B47A-8020
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000009109221
       VCID: 44D14C202E9DD7BB37A-8010
       Component: EPB Audi B8   H09 0090
       Revision: 00000003    Serial number: 10000000287277
       VCID: 34311CE07E3D673B87A-8060
       Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
       Component: Con3 Sirius   H03 0351
       Revision: 00000005    Serial number: AUZ5Z6I1249835
       Coding: 04020002010185004119070800
       VCID: 46D5562818A1E5AB29E-8012
       Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
       Component: Display
                        Reset counter: 110
                        Mileage: 294775 km
                        Date: 2020.04.22
                        Time: 20:07:16
       Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000101552850
       Coding: 010C03204000210001
       VCID: 42DD4A383489D98B056-8016
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000101552847
       Part No SW: 8T0 862 336 D    HW: 8T0 862 336 D
       Component: FSE_256x BT     H37 0600
       Revision: 00000000    Serial number: 00000005041298
       Coding: 0010370
       VCID: 3C2134C05A6DAF7B4FA-8068
    End----------(Elapsed Time: 01:34, VBatt start/end: 12.3V/12.3V)-----------
    Just because an ECU has coding bits defined for certain options like transmission type does not mean that the software in that ECU supports the all those options. We see this with considerable regularity when people try to replace failed auto boxes with manual. There are quite a few ECUs that have transmission-specific software versions in them, and the only solution is to flash them with software that supports a manual. Of course that gets quite difficult when someone is doing an MT conversion for an engine that was never sold with an MT and there is no MT software for that ECU.
    I suspect you might be in a similar situation here, except you're trying to fit a DSG rather than an MT. Moreover, the DSG itself quite clearly expects a 3.0 supercharged V6 and will probably never be entirely happy with a turbocharged 4-banger.
    I think your best bet is to talk to a tuner who knows these engines and DSGs to see if he can come up with ECU and TCU software that will work properly together. Please note that even if he does, the combo you're putting together was never certified by the EPA and is thus technically not legal to operate upon the public roads in the USA.
  3. Likes Dana liked this post
    Apr 2020
    Understood. Thank you for the input. Can you think of anyone you could possible point me towards in regards to doing software like that? Thanks
    Jul 2014
    Tallinn, Estonia
    As a side note, the act of replacing the ZF 6HP28 slushbox with the DL501 DSG made me chuckle a bit. You see, on this side of the pond, the DL501 DSG is prevalent in larger Audis and has a reputation for not being very smooth, wearing clutch packs and failing mechatronics. Meanwhile, the ZF slushbox (8HP55A) that comes with the the higher powered (230+ kW) models is revered as the king of reliability and smoothness.
  6. Likes Uwe, Eric liked this post
    Apr 2020
    I REALLY hated the way the 6HP28 felt. I briefly had a Jetta with the front wheel drive dsg and didn’t mind the occasional buck or kick just because pretty much every vehicle I’ve had up to these past two have been a manual transmission. I was able to pick up one of the later dsg units because they seemed to suffer less then the earlier gen units. I like the idea around how the dsg works vs a conventional automatic unit. 🤷*♂️ I was hopeful it wasn’t going to be as complicated as it’s becoming. Lol
