Results 1 to 10 of 17
Thread: B8 Passat BiTDi MIB2.5 Retrofit
    Apr 2020
    England
    Hi all,
    I'm trying to clear up some DTC's left over from my MIB2.5 retrofit. I paid someone to do the coding remotely without really researching what was involved. As such I didn't realise they had only removed component protection with a patch and activated a few things, and had not coded the unit to suit my vehicle. Unfortunately I only realised this after I had posted my old unit off to its new user, before I had even heard of VCDS let alone created an adaptation map or autoscan For what it's worth, the old unit was an MIB2 discover pro.
    Anyway on with the fun! Lets start off with an autoscan of the current situation...
    Wednesday,22,April,2020,20:29:30:58535
    VIN: WVWZZZ3CZFP407282   License Plate:
    Chassis Type: 3C-VW48 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 42 44 52 55 5F
              6C BB BC
    VIN: WVWZZZ3CZFP407282   Mileage: 115180km-71569miles
    Address 01: Engine (J623-CUAA)       Labels:. 03N-906-026-CUA.clb
       Part No SW: 03N 906 026     HW: 03N 907 309
       Component: R4 2,0L EDC   H23 1707
       Revision: A1H23---
       Coding: 01250012036705083000
       Shop #: WSC 65535 000 00000
       ASAM Dataset: EV_ECM20BTD01103N906026 001011
       ROD: EV_ECM20BTD01103N906026.rod
       VCID: 6889BEDE92FD913BFB2-803C
       Part No SW: 0DL 300 011     HW: 0BH 927 711 F
       Component: GSG DQ500     H10 4701
       Revision: 00H10V01
       VCID: 6597B7EA65EF8C53C04-8030
       Part No SW: 3Q0 907 379 N    HW: 3Q0 907 379 G
       Component: ESC           H42 0710
       Revision: 00000000    Serial number: 63394000001047
       Coding: 0EEC938F34200B730779070841C54970C92CD0E0E08292F1186250F8C202
       Shop #: WSC 12345 123 61029
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
       ROD: EV_Brake1UDSContiMK100IPB_034.rod
       VCID: 45D7576AC52FAC53204-8010
       Part No SW: 3Q0 959 435     HW: 3Q0 959 435
       Component: VWKESSYMQB    023 0522
       Revision: 00023000    Serial number: 0355060864
       Coding: 000F0F0703
       Shop #: WSC 00028 028 00026
       ASAM Dataset: EV_KessyHellaMQBAB 004027
       ROD: EV_KessyHellaMQBAB.rod
       VCID: 77ABEDA2CF430EC3628-8022
       Part No SW: 5G2 907 044     HW: 5G2 907 044
       Revision: 00001K10
       Coding: 12120104202100012015500E00101802
       VCID: 6695B0E698E9874BC9E-8032
       Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
       Component: BCM PQ37BOSCH 028 0146
       Revision: --------    Serial number: 86580112141655
       Coding: 03051C66C24102FF0B844084B11C07281880000000000000000000000000
       ROD: EV_BCMBOSCH_014.rod
       VCID: 7DA7FF8AED7F2493384-8028
       Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    141118  043 0607
       Serial number:         141127135615
       Component: RLHS  037 0059
       Serial number: S5Y14M12D11H08M00S22
       Coding: 00A8DD
       Light switch:
       Serial number: 17 10 2014  00001110
       Serial number: 000000000ZY143140F37
       Serial number: 00000000000031313132
       Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0053
       Revision: --------    Serial number: 39391433513904
       Coding: 0071151051
       VCID: 40D9467EDA0D897B132-8014
       Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
       Component: ACC BOSCH MQB H04 0126
       Coding: 3260678110FFC428949C804C
       Shop #: WSC 00028 028 00001
       ASAM Dataset: EV_ACCBOSCHVW48X 001007
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 333319B29BBB22E39E0-8066
       Part No SW: 5Q0 907 376     HW: 5Q0 907 376
       Component: DAEMPFUNGS-SG H16 0115
       Serial number: 02121441350608
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 76B5E0A6C84977CB79E-8022
       Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
       Component: Airbag VW20   012 0195
       Revision: --------    Serial number: 003R1PP7RFWX
       Coding: 98FCC0C0008000005C5400CC008800000065
       Shop #: WSC 00028 028 00011
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 015F837A918740735CC-8054
       Belt Pretensioner left:
       Component: BeltPretRevFL  105 1032
       Serial number: 3G2857705C0336O00113
       Coding: 80000A
       Belt Pretensioner right:
       Component: BeltPretRevFR  105 1032
       Serial number: 3G2857706C0332O00803
       Coding: 80000A
       Subsystem 3 - Part No SW: -----------    HW: 454 000 112 14
       Serial number: 3576U000000C8291C11B
       Subsystem 4 - Part No SW: -----------    HW: 454 000 112 14
       Serial number: 3586U00000009269121$
       Subsystem 5 - Part No SW: -----------    HW: 454 800 112 14
       Serial number: 3516R683B4B050000004
       Subsystem 6 - Part No SW: -----------    HW: 454 800 312 14
       Serial number: 3526RCE254B05000000A
       Subsystem 7 - Part No SW: -----------    HW: 454 800 112 14
       Serial number: 3556VA4EE3F05000000T
       Part No SW: 3Q0 953 521 AM    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0185
       Revision: FF033033    Serial number: 20141205500792
       Coding: 0410
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
       ROD: EV_SMLSVALEOMQBLRH.rod
       VCID: 7BA3F192F36B2AA3060-802E
       Part No SW: 3G0 920 951     HW: 3G0 920 951
       Component: KOMBI         308 4311
       Coding: 27A40818BF80260001886A001000000000000000
       VCID: 6491AAEE6ED5F55BD7A-8030
       Revision: --------    Serial number: 29111410800786
       Coding: 030300044F017300EF00025E9C0F00010001070000000000000000000000
       ROD: EV_GatewConti_011.rod
       VCID: 72BDDCB6A4216BEB556-8026
       Component: E221__MFL-DC1  H16 0038
       Serial number: 27140003024800124484
       Coding: 2FFFFF
       Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
       Serial number: 9750484803
       Analog clock:
       Component: Analoguhr  111 1004
       Serial number: 0212201400010305
              U1101 00 [009] - Active
                        Reset counter: 66
                        Mileage: 115092 km
                        Date: 2020.04.17
                        Time: 16:27:48
                        Terminal 15: On
       Serial number: HA1-00018.10.14
       Coding: 0301
       ROD: EV_AllWheelContrHA1VW37X_002.rod
       VCID: 46D55066F829A74B29E-8012
       Serial number: 14000257178010
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BFD3BAA12750F3ACC-8024
       Part No SW: 5Q4 959 593 D    HW: 5Q4 959 593 B
       Component: TSG FS        009 0016
       Serial number: 0000127477955
       Coding: 003F0A20D001028000001000
       Shop #: WSC 00028 028 00038
       Component: EPS_MQB_ZFLS  125 1061
       Coding: 8103
       VCID: 43D34972CB1B92630E0-8016
       Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
       Component: TSG BFS       009 0015
       Serial number: 0000128808641
       Coding: 003F0020D001028000001000
       VCID: 44D14A6ECE15955B37A-8010
       Coding: 03A602000F210200
       Shop #: WSC 39239 001 1048576
       ROD: EV_HeadlRegulAFSMQBMLB.rod
       VCID: 3FDB4582A7F3F6836A8-806A
       Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 0001
       Coding: E02400
       Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H07 0001
       Coding: E02400
       Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 0003
       Coding: E02400
       Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 0003
       Coding: E02400
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 5NA 035 042 D    HW: 5NA 035 042
       Component: MU-H-LN-EU    H51 1367
       Serial number: A847A0HB001646
       Coding: 02840101FF00000051111101C08808101F0002C601208400CF
       VCID: 363520A688C937CBB9E-8062
       Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
       Component: ABT_High-2  H50 9130
       Serial number: VWZ6ZJT3280316
       Subsystem 2 - Part No SW: V03 959 806 FL    HW: -----------
       Component: ECE 2019  --- 0175
       Component: Gracenote2  --- 1015
    6 Faults Found:
    1543 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 66
                        Mileage: 115180 km
                        Date: 2020.04.22
                        Time: 20:22:00
                        Voltage terminal 30: 11.9 V
                        Byte_Coding_Condition-byte_0_condition: OK
                        Byte_Coding_Condition-byte_1_condition: OK
                        Byte_Coding_Condition-byte_10_condition: ERROR
                        Byte_Coding_Condition-byte_11_condition: ERROR
                        Byte_Coding_Condition-byte_12_condition: ERROR
                        Byte_Coding_Condition-byte_13_condition: ERROR
                        Byte_Coding_Condition-byte_14_condition: ERROR
                        Byte_Coding_Condition-byte_15_condition: ERROR
                        Byte_Coding_Condition-byte_16_condition: ERROR
                        Byte_Coding_Condition-byte_17_condition: ERROR
                        Byte_Coding_Condition-byte_18_condition: ERROR
                        Byte_Coding_Condition-byte_19_condition: ERROR
                        Byte_Coding_Condition-byte_2_condition: OK
                        Byte_Coding_Condition-byte_20_condition: ERROR
                        Byte_Coding_Condition-byte_21_condition: ERROR
                        Byte_Coding_Condition-byte_22_condition: ERROR
                        Byte_Coding_Condition-byte_23_condition: ERROR
                        Byte_Coding_Condition-byte_24_condition: ERROR
                        Byte_Coding_Condition-byte_25_condition: ERROR
                        Byte_Coding_Condition-byte_26_condition: ERROR
                        Byte_Coding_Condition-byte_27_condition: ERROR
                        Byte_Coding_Condition-byte_3_condition: OK
                        Byte_Coding_Condition-byte_4_condition: OK
                        Byte_Coding_Condition-byte_5_condition: OK
                        Byte_Coding_Condition-byte_6_condition: OK
                        Byte_Coding_Condition-byte_7_condition: OK
                        Byte_Coding_Condition-byte_8_condition: OK
                        Byte_Coding_Condition-byte_9_condition: OK
    15360768 - Component Protection
              [Anti-theft protection - component protection active (0xEA6300)]
                        Reset counter: 66
                        Mileage: 115180 km
                        Date: 2020.04.22
                        Time: 20:21:59
    3073 - Cellular Antenna
              B1053 13 [009] - Open Circuit
              [GSM/UMTS aerial - open circuit]
                        Reset counter: 66
                        Mileage: 115180 km
                        Date: 2020.04.22
                        Time: 20:22:00
    3084 - GSM antenna 2
              B1533 13 [009] - Open Circuit
                        Reset counter: 66
                        Mileage: 115180 km
                        Date: 2020.04.22
                        Time: 20:22:00
    7193 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 66
                        Mileage: 115180 km
                        Date: 2020.04.22
                        Time: 20:22:01
                        BAP-BAP_Function_ID: 02
    7194 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 66
                        Mileage: 115180 km
                        Date: 2020.04.22
                        Time: 20:22:01
       Component: RVC Compact   H18 0231
       Coding: 0184020162002017000040
       ROD: EV_CamSysRVRVCPANAMQBAB.rod
       VCID: 392F2B9AB9D7D8B354C-806C
    9591827 - Video Signal Line
              B125C 13 [009] - Open Circuit
                        Reset counter: 66
                        Mileage: 115180 km
                        Date: 2020.04.22
                        Time: 18:23:57
                        passive
    13705478 - Databus
              [message Parkhilfe_01 not received]
                        Reset counter: 66
                        Mileage: 115180 km
                        Date: 2020.04.22
                        Time: 18:23:55
                        passive
       Part No SW: 5Q4 959 595 C    HW: 5Q4 959 595 B
       Component: TSG HFS       010 0015
       Serial number: 0000124974966
       Coding: 000E00200101028000001000
       ASAM Dataset: EV_DCURearDriveMAXCONT 006001
       VCID: 47CB5D62FF23BE43D28-8012
       Component: TSG HBFS      010 0015
       Serial number: 0000127211398
       ASAM Dataset: EV_DCURearPasseMAXCONT 006001
    End----(Elapsed Time: 02:15, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
    So concentrating on the 5F module for now...
    1543 - Control Module Incorrectly Coded is confusing me slightly - I've been through the long coding and can't see anything obviously amiss, but I'm very much new to this. Any pointers?
    15360768 - Component Protection I'll ignore - as soon as the lockdown allows I'll go and get the unit registered to the car.
    3073 - Cellular Antenna and 3084 - GSM antenna 2 I'm expecting to go away when I receive and install the FAKRA adapter, currently the antenna is unplugged as the connector was physically different to my old MIB2 unit.
    7193 - Function Restricted due to Missing Message(s) and 7194 - Function Restricted due to Missing Message(s) I presume these mean I've got lane/side assist activated somewhere in the adaptations but I'm damned if I can find it, any pointers?
    Until earlier this evening I also had a 1555 - Check Software Version Management fault but I managed to clear that using a bitwise XOR calculator and some info from a Gold MK7 forum, I was rather pleased with myself Now if I could just get these other faults cleared...
    I've done an adaptations map and have a .csv file available, but with nothing to compare it to I don't really know how much use it will be?
    The other topic is the reversing camera which used to work before the retrofit but now not so much - I presume I've dislodged a pin in the connector causing the 9591827 - Video Signal Line error but not so sure about 13705478 - Databus yet I presume the MIB2.5 uses the same pins for the video signal?
    Any pointers on any of these would be much appreciated, thanks!
    Mar 2015
    Australia
    Post the admap up.
    A lot of the configuration is in the adaptation channels.
    Yes the CP fault can be ignored - its a symptom of the modification of the unit from it's original state. Yes you can have the CP fault removed using the correct dealer procedure.
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist|BCM Retrofit|HBA/FLA
  3. Likes jhnbssll, PetrolDave liked this post
    Apr 2020
    England
    okeydoke. Heres the admap:
    ;SW:5NA-035-042-D   HW:5NA-035-042 ---  Information Electr.
    ;Component:MU-H-LN-EU    H51 1367	 Coding:02840101FF00000051111101C08808101F0002C601208400CF
    ;EV_MUHig4CGen2HBAS	1001	EV_MUHig4CGen2HBAS_VW37.rod
    ;Wednesday	22	April
    ;VCDS Version: Release 20.4.0 (x64)  Data version: 20200331 DS317.0
    ;VCID: 363520A688C937CBB9E-8062
    IDE00001-Production mode	00 00 00 	3
    IDE00346-Summertime-automatic	Europe 	1
    IDE00759-Base volume of speech output	50%	1
    IDE00760-Microphone sensitivity	0 dB	1
    IDE00768-Country identification: country of sale	-- 	2
    IDE00769-Number 1 for Info call	5E 07 A1 80 00 68 55 97 42 63 FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
    IDE00770-Number 1 for roadside assistance	5E 07 A1 80 00 98 37 87 24 F3 FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
    IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages	OFF 	1
    IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages	OFF 	1
    IDE00845-Wheel circ.	0 mm	2
    IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module	Yes 	3
    IDE01996-MAS00839-Installation list: specified installations-TV Tuner	No 	3
    IDE01996-MAS00844-Installation list: specified installations-Radio	Yes 	3
    IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module	No 	3
    IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1	Yes 	3
    IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2	No 	3
    IDE01996-MAS04300-Installation list: specified installations-DVD changer	No 	3
    IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module	No 	3
    IDE01996-SFT271943-Installation list: specified installations-Multimedia Operating Unit	No 	3
    IDE01996-ENG154341-Installation list: specified installations-Reserved_8	No 	3
    IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1	No 	3
    IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2	No 	3
    IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1	No 	3
    IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2	No 	3
    IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1	No 	3
    IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2	No 	3
    IDE02121-CD eject button	Enabled 	1
    IDE02122-Developer mode	not activated 	1
    IDE02330-Number 2 for Info call	5E 08 91 94 81 20 68 55 97 42 63 FF FF FF FF FF FF FF FF FF FF FF FF 	23
    IDE02331-Number 2 for roadside assistance	5E 06 91 94 81 60 11 21 31 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
    IDE02332-Deactivate production mode	0	3
    IDE02476-MAS03001-Electrical test of loudspeakers-Mode	automatic 	49
    IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency	19000 Hz	49
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume	22	49
    IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency	19000 Hz	49
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume	22	49
    IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency	19000 Hz	49
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume	22	49
    IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency	19000 Hz	49
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume	22	49
    IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency	19000 Hz	49
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume	22	49
    IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency	19000 Hz	49
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume	22	49
    IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency	19000 Hz	49
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume	22	49
    IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency	19000 Hz	49
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume	22	49
    IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency	19000 Hz	49
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume	22	49
    IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency	19000 Hz	49
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume	22	49
    IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency	19000 Hz	49
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume	22	49
    IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency	19000 Hz	49
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume	22	49
    IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency	19000 Hz	49
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume	22	49
    IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency	19000 Hz	49
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume	22	49
    IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency	19000 Hz	49
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume	22	49
    IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency	19000 Hz	49
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume	22	49
    IDE02502-Confirmation of installation change	27 20 	2
    IDE02506-MAS03229-Copy multimedia data-Data medium	On 	1
    IDE02506-MAS03230-Copy multimedia data-Optical drive	On 	1
    IDE02607-Wheel pulse	0	2
    IDE02699-Number 1 for roadside assistance	5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
    IDE02701-Number 1 (roaming) for roadside assistance	5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
    IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo	0	8
    IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP	15	8
    IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo	0	8
    IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP	15	8
    IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo	0	8
    IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP	11	8
    IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo	0	8
    IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP	8	8
    IDE03471-ENG117847-Vehicle configuration-advanced_range_display	OFF 	30
    IDE03471-ENG249824-Vehicle configuration-AliBox	OFF 	30
    IDE03471-ENG142146-Vehicle configuration-allow_message_editing	OFF 	30
    IDE03471-ENG130249-Vehicle configuration-Apple_DIO	On 	30
    IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless	OFF 	30
    IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life	OFF 	30
    IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios	OFF 	30
    IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless	OFF 	30
    IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless	OFF 	30
    IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb	blocked 	30
    IDE03471-ENG142151-Vehicle configuration-conditioning_variant	0	30
    IDE03471-ENG263540-Vehicle configuration-correction_e_mileage	0	30
    IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call	On 	30
    IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support	OFF 	30
    IDE03471-ENG185778-Vehicle configuration-FoD	SWaP 	30
    IDE03471-ENG130248-Vehicle configuration-Google_GAL	On 	30
    IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless	OFF 	30
    IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts	On 	30
    IDE03471-ENG117851-Vehicle configuration-gracenote_local_other	On 	30
    IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts	OFF 	30
    IDE03471-ENG117849-Vehicle configuration-gracenote_online_other	OFF 	30
    IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data	not activated 	30
    IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender	Deactivated 	30
    IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting	OFF 	30
    IDE03471-ENG125049-Vehicle configuration-Joker_button_1	Not Present 	30
    IDE03471-ENG125050-Vehicle configuration-Joker_button_2	Not Present 	30
    IDE03471-ENG127492-Vehicle configuration-LGI	OFF 	30
    IDE03471-ENG130246-Vehicle configuration-LTE_modul	activated 	30
    IDE03471-ENG142142-Vehicle configuration-map_email_support	OFF 	30
    IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support	OFF 	30
    IDE03471-ENG142141-Vehicle configuration-map_sms_support	OFF 	30
    IDE03471-ENG142152-Vehicle configuration-Map_Style	1	30
    IDE03471-ENG152537-Vehicle configuration-media_control	not activated 	30
    IDE03471-ENG138662-Vehicle configuration-Mirror_link	On 	30
    IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code	MIB_EU 	30
    IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference	RGB888 	30
    IDE03471-ENG117843-Vehicle configuration-my_audi	OFF 	30
    IDE03471-ENG117845-Vehicle configuration-online_dictation	OFF 	30
    IDE03471-ENG127495-Vehicle configuration-online_media	OFF 	30
    IDE03471-ENG117840-Vehicle configuration-online_navigation	OFF 	30
    IDE03471-ENG117837-Vehicle configuration-online_POI	OFF 	30
    IDE03471-ENG117838-Vehicle configuration-online_POI_voice	OFF 	30
    IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services	OFF 	30
    IDE03471-ENG152553-Vehicle configuration-online_radio	Deactivated 	30
    IDE03471-ENG117841-Vehicle configuration-online_street_view	OFF 	30
    IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit	OFF 	30
    IDE03471-ENG167521-Vehicle configuration-perso_v_threshold	0	30
    IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis	0	30
    IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy	0	30
    IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode	only data service act. 	30
    IDE03471-ENG117844-Vehicle configuration-picture_navi	On 	30
    IDE03471-ENG167523-Vehicle configuration-Pilot_Parking	not activated 	30
    IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use	not activated 	30
    IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest	0	30
    IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi	OFF 	30
    IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo	OFF 	30
    IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version	PSD_1.5 	30
    IDE03471-ENG117846-Vehicle configuration-remote_HMI	OFF 	30
    IDE03471-ENG138661-Vehicle configuration-RSE_software_component	activated 	30
    IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open	not activated 	30
    IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold	not activated 	30
    IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe	not activated 	30
    IDE03471-ENG126143-Vehicle configuration-RVC_video_input	LVDS 	30
    IDE03471-ENG152556-Vehicle configuration-scon_telephony	not activated 	30
    IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation	no restriction 	30
    IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag	REGION_EU 	30
    IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch	not activated 	30
    IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch	present 	30
    IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support	OFF 	30
    IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi	activated 	30
    IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode	1	30
    IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold	OFF 	30
    IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling	OFF 	30
    IDE03471-ENG130247-Vehicle configuration-Support_second_phone	On 	30
    IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location	OFF 	30
    IDE03471-ENG126994-Vehicle configuration-TPEG_availability	OFF 	30
    IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving	blocked 	30
    IDE03471-ENG137647-Vehicle configuration-UOTA	OFF 	30
    IDE03471-ENG167532-Vehicle configuration-UOTA_2	OFF 	30
    IDE03471-ENG117852-Vehicle configuration-UPnP	On 	30
    IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound	not activated 	30
    IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound	not activated 	30
    IDE03471-ENG152558-Vehicle configuration-voice_over_lte	not activated 	30
    IDE03471-ENG117836-Vehicle configuration-VZAPro	OFF 	30
    IDE03471-ENG127494-Vehicle configuration-VZO	OFF 	30
    IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI	On 	30
    IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot	On 	30
    IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch	not activated 	30
    IDE03580-Country code for mobile network	44	2
    IDE03902-Automatic ring break diagnostic	No automatic start 	1
    IDE04295-Bluetooth: Preferred connection profile for phone book data	PBAP 	1
    IDE04298-MAS01779-Vehicle dimensions-Length	0 mm	6
    IDE04298-MAS01780-Vehicle dimensions-Width	0 mm	6
    IDE04298-MAS02230-Vehicle dimensions-Height	0 mm	6
    IDE04331-Selection of release codes for a SWaP function	FF FF FF FF 	4
    IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code	2	2
    IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code	2	2
    IDE04521-Sporadic ring break detection	Visual 	1
    IDE04522-Awakening ability on optical databus	OFF 	1
    IDE04549-Telephone data services	On 	1
    IDE04550-Bluetooth: Sniff mode	OFF 	1
    IDE05111-Fee-based traffic information (TMC)	32768	2
    IDE05113-Infotainment Recorder	activated 	1
    IDE06425-Roller test bench mode: functional-	not activated 	1
    IDE06425-ENG98891-Roller test bench mode: functional-Reserved	0	1
    IDE06697-Audio management mute function	Muting of audio sources 	1
    IDE07399-ENG142045-Engine type-Engine_type_adaption_1	Petrol_diesel 	1
    IDE07399-ENG142046-Engine type-Engine_type_adaption_2	Petrol_diesel 	1
    IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass	On 	1
    IDE08814-MAS01570-Navigation receiver GNSS configuration-Default	On 	1
    IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS	On 	1
    IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo	On 	1
    IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass	On 	1
    IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1	OFF 	1
    IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2	OFF 	1
    IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G	0	16
    IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G	0	16
    IDE10082-MAS09813-Telephone functions configuration-Entering Access Point Name	On 	1
    IDE10082-MAS09814-Telephone functions configuration-Call Center Function	On 	1
    IDE10082-MAS13846-Telephone functions configuration-Internet access via WiFi	Available 	1
    IDE10082-MAS13847-Telephone functions configuration-Call center function on MIB: roadside assistance call	On 	1
    IDE10082-MAS13848-Telephone functions configuration-Call center function on MIB: POI call	On 	1
    IDE10082-MAS16726-Telephone functions configuration-Call center function on MIB: POI call regions	OFF 	1
    IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner	-128	40
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio	5	40
    IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM)	-128	40
    IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM)	-128	40
    IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB)	-128	40
    IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB	-128	40
    IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP	-128	40
    IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay	-128	40
    IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter	-128	40
    IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN	-128	40
    IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray	-128	40
    IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice	-128	40
    IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA	-128	40
    IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud	-128	40
    IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD	-128	40
    IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI	-128	40
    IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP	-128	40
    IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP	-128	40
    IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink	-128	40
    IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP	-128	40
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB	-3	40
    IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice	-128	40
    IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM	-128	40
    IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep	-128	40
    IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging	-128	40
    IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen	6	40
    IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning	-128	40
    IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav	-128	40
    IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS	-128	40
    IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online	-128	40
    IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal	-128	40
    IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI	-128	40
    IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN	-128	40
    IDE10480-MAS10741-Interface for external media: activation-Connection 1	activated 	4
    IDE10480-MAS10742-Interface for external media: activation-Connection 2	not activated 	4
    IDE10480-MAS10743-Interface for external media: activation-Connection 3	not activated 	4
    IDE10480-MAS10744-Interface for external media: activation-Connection 4	not activated 	4
    IDE10604-Menu entries for mobile online services	activated 	1
    IDE10668-Internal SIM card: use	Never 	1
    IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold	37 dBµV	3
    IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation	32 dB	3
    IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo	15.0 s	3
    IDE11105-Brand-specific display of connect application	 	256
    IDE11122-Country identification: country of sale HMI	DE 	2
    IDE11153-ENG152487-Surroundings display: virtual camera positions-focallength	4294967295	330
    IDE11153-ENG152457-Surroundings display: virtual camera positions-Pitchangle	65535	330
    IDE11153-ENG152445-Surroundings display: virtual camera positions-Rollangle	65535	330
    IDE11153-ENG147432-Surroundings display: virtual camera positions-xpos	32767	330
    IDE11153-ENG152451-Surroundings display: virtual camera positions-Yawangle	65535	330
    IDE11153-ENG147433-Surroundings display: virtual camera positions-ypos	32767	330
    IDE11153-ENG147434-Surroundings display: virtual camera positions-zpos	32767	330
    IDE11502-ENG127601-Locked menu contents-FB_CAR_0	non_blocked 	21
    IDE11502-ENG127602-Locked menu contents-FB_CAR_1	non_blocked 	21
    IDE11502-ENG127611-Locked menu contents-FB_CAR_10	non_blocked 	21
    IDE11502-ENG127612-Locked menu contents-FB_CAR_11	non_blocked 	21
    IDE11502-ENG127613-Locked menu contents-FB_CAR_12	non_blocked 	21
    IDE11502-ENG127614-Locked menu contents-FB_CAR_13	non_blocked 	21
    IDE11502-ENG127615-Locked menu contents-FB_CAR_14	non_blocked 	21
    IDE11502-ENG127616-Locked menu contents-FB_CAR_15	non_blocked 	21
    IDE11502-ENG127617-Locked menu contents-FB_CAR_16	non_blocked 	21
    IDE11502-ENG127618-Locked menu contents-FB_CAR_17	non_blocked 	21
    IDE11502-ENG127619-Locked menu contents-FB_CAR_18	non_blocked 	21
    IDE11502-ENG127620-Locked menu contents-FB_CAR_19	non_blocked 	21
    IDE11502-ENG127603-Locked menu contents-FB_CAR_2	non_blocked 	21
    IDE11502-ENG127621-Locked menu contents-FB_CAR_20	non_blocked 	21
    IDE11502-ENG127622-Locked menu contents-FB_CAR_21	non_blocked 	21
    IDE11502-ENG127623-Locked menu contents-FB_CAR_22	non_blocked 	21
    IDE11502-ENG127624-Locked menu contents-FB_CAR_23	non_blocked 	21
    IDE11502-ENG127604-Locked menu contents-FB_CAR_3	non_blocked 	21
    IDE11502-ENG127605-Locked menu contents-FB_CAR_4	non_blocked 	21
    IDE11502-ENG127606-Locked menu contents-FB_CAR_5	non_blocked 	21
    IDE11502-ENG127607-Locked menu contents-FB_CAR_6	non_blocked 	21
    IDE11502-ENG127608-Locked menu contents-FB_CAR_7	non_blocked 	21
    IDE11502-ENG127609-Locked menu contents-FB_CAR_8	non_blocked 	21
    IDE11502-ENG127610-Locked menu contents-FB_CAR_9	non_blocked 	21
    IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0	non_blocked 	21
    IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1	non_blocked 	21
    IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10	non_blocked 	21
    IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11	non_blocked 	21
    IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12	non_blocked 	21
    IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13	non_blocked 	21
    IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14	non_blocked 	21
    IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15	non_blocked 	21
    IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16	non_blocked 	21
    IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17	non_blocked 	21
    IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18	non_blocked 	21
    IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19	non_blocked 	21
    IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2	non_blocked 	21
    IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20	non_blocked 	21
    IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21	non_blocked 	21
    IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22	non_blocked 	21
    IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23	non_blocked 	21
    IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3	non_blocked 	21
    IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4	non_blocked 	21
    IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5	non_blocked 	21
    IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6	non_blocked 	21
    IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7	non_blocked 	21
    IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8	non_blocked 	21
    IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9	non_blocked 	21
    IDE11502-ENG127625-Locked menu contents-FB_MISC_0	non_blocked 	21
    IDE11502-ENG127626-Locked menu contents-FB_MISC_1	non_blocked 	21
    IDE11502-ENG127635-Locked menu contents-FB_MISC_10	non_blocked 	21
    IDE11502-ENG127636-Locked menu contents-FB_MISC_11	non_blocked 	21
    IDE11502-ENG127637-Locked menu contents-FB_MISC_12	non_blocked 	21
    IDE11502-ENG127638-Locked menu contents-FB_MISC_13	non_blocked 	21
    IDE11502-ENG127639-Locked menu contents-FB_MISC_14	non_blocked 	21
    IDE11502-ENG127640-Locked menu contents-FB_MISC_15	non_blocked 	21
    IDE11502-ENG127641-Locked menu contents-FB_MISC_16	non_blocked 	21
    IDE11502-ENG127642-Locked menu contents-FB_MISC_17	non_blocked 	21
    IDE11502-ENG127643-Locked menu contents-FB_MISC_18	non_blocked 	21
    IDE11502-ENG127644-Locked menu contents-FB_MISC_19	non_blocked 	21
    IDE11502-ENG127627-Locked menu contents-FB_MISC_2	non_blocked 	21
    IDE11502-ENG127645-Locked menu contents-FB_MISC_20	non_blocked 	21
    IDE11502-ENG127646-Locked menu contents-FB_MISC_21	non_blocked 	21
    IDE11502-ENG127647-Locked menu contents-FB_MISC_22	non_blocked 	21
    IDE11502-ENG127648-Locked menu contents-FB_MISC_23	non_blocked 	21
    IDE11502-ENG127649-Locked menu contents-FB_MISC_24	non_blocked 	21
    IDE11502-ENG127650-Locked menu contents-FB_MISC_25	non_blocked 	21
    IDE11502-ENG127651-Locked menu contents-FB_MISC_26	non_blocked 	21
    IDE11502-ENG127652-Locked menu contents-FB_MISC_27	non_blocked 	21
    IDE11502-ENG127653-Locked menu contents-FB_MISC_28	non_blocked 	21
    IDE11502-ENG127654-Locked menu contents-FB_MISC_29	non_blocked 	21
    IDE11502-ENG127628-Locked menu contents-FB_MISC_3	non_blocked 	21
    IDE11502-ENG127655-Locked menu contents-FB_MISC_30	non_blocked 	21
    IDE11502-ENG127656-Locked menu contents-FB_MISC_31	non_blocked 	21
    IDE11502-ENG127657-Locked menu contents-FB_MISC_32	non_blocked 	21
    IDE11502-ENG127658-Locked menu contents-FB_MISC_33	non_blocked 	21
    IDE11502-ENG127659-Locked menu contents-FB_MISC_34	non_blocked 	21
    IDE11502-ENG127660-Locked menu contents-FB_MISC_35	non_blocked 	21
    IDE11502-ENG127661-Locked menu contents-FB_MISC_36	non_blocked 	21
    IDE11502-ENG127662-Locked menu contents-FB_MISC_37	non_blocked 	21
    IDE11502-ENG127663-Locked menu contents-FB_MISC_38	non_blocked 	21
    IDE11502-ENG127664-Locked menu contents-FB_MISC_39	non_blocked 	21
    IDE11502-ENG127629-Locked menu contents-FB_MISC_4	non_blocked 	21
    IDE11502-ENG127665-Locked menu contents-FB_MISC_40	non_blocked 	21
    IDE11502-ENG127666-Locked menu contents-FB_MISC_41	non_blocked 	21
    IDE11502-ENG127667-Locked menu contents-FB_MISC_42	non_blocked 	21
    IDE11502-ENG127668-Locked menu contents-FB_MISC_43	non_blocked 	21
    IDE11502-ENG127669-Locked menu contents-FB_MISC_44	non_blocked 	21
    IDE11502-ENG127670-Locked menu contents-FB_MISC_45	non_blocked 	21
    IDE11502-ENG127671-Locked menu contents-FB_MISC_46	non_blocked 	21
    IDE11502-ENG127672-Locked menu contents-FB_MISC_47	non_blocked 	21
    IDE11502-ENG127630-Locked menu contents-FB_MISC_5	non_blocked 	21
    IDE11502-ENG127631-Locked menu contents-FB_MISC_6	non_blocked 	21
    IDE11502-ENG127632-Locked menu contents-FB_MISC_7	non_blocked 	21
    IDE11502-ENG127633-Locked menu contents-FB_MISC_8	non_blocked 	21
    IDE11502-ENG127634-Locked menu contents-FB_MISC_9	non_blocked 	21
    IDE11502-ENG127561-Locked menu contents-FB_NAV_0	non_blocked 	21
    IDE11502-ENG127562-Locked menu contents-FB_NAV_1	non_blocked 	21
    IDE11502-ENG127571-Locked menu contents-FB_NAV_10	non_blocked 	21
    IDE11502-ENG127572-Locked menu contents-FB_NAV_11	non_blocked 	21
    IDE11502-ENG127573-Locked menu contents-FB_NAV_12	non_blocked 	21
    IDE11502-ENG127574-Locked menu contents-FB_NAV_13	non_blocked 	21
    IDE11502-ENG127575-Locked menu contents-FB_NAV_14	non_blocked 	21
    IDE11502-ENG127576-Locked menu contents-FB_NAV_15	non_blocked 	21
    IDE11502-ENG127577-Locked menu contents-FB_NAV_16	non_blocked 	21
    IDE11502-ENG127578-Locked menu contents-FB_NAV_17	non_blocked 	21
    IDE11502-ENG127579-Locked menu contents-FB_NAV_18	non_blocked 	21
    IDE11502-ENG127580-Locked menu contents-FB_NAV_19	non_blocked 	21
    IDE11502-ENG127563-Locked menu contents-FB_NAV_2	non_blocked 	21
    IDE11502-ENG127581-Locked menu contents-FB_NAV_20	non_blocked 	21
    IDE11502-ENG127582-Locked menu contents-FB_NAV_21	non_blocked 	21
    IDE11502-ENG127583-Locked menu contents-FB_NAV_22	non_blocked 	21
    IDE11502-ENG127584-Locked menu contents-FB_NAV_23	non_blocked 	21
    IDE11502-ENG127585-Locked menu contents-FB_NAV_24	non_blocked 	21
    IDE11502-ENG127586-Locked menu contents-FB_NAV_25	non_blocked 	21
    IDE11502-ENG127587-Locked menu contents-FB_NAV_26	non_blocked 	21
    IDE11502-ENG127588-Locked menu contents-FB_NAV_27	non_blocked 	21
    IDE11502-ENG127589-Locked menu contents-FB_NAV_28	non_blocked 	21
    IDE11502-ENG127590-Locked menu contents-FB_NAV_29	non_blocked 	21
    IDE11502-ENG127564-Locked menu contents-FB_NAV_3	non_blocked 	21
    IDE11502-ENG127591-Locked menu contents-FB_NAV_30	non_blocked 	21
    IDE11502-ENG127592-Locked menu contents-FB_NAV_31	non_blocked 	21
    IDE11502-ENG127593-Locked menu contents-FB_NAV_32	non_blocked 	21
    IDE11502-ENG127594-Locked menu contents-FB_NAV_33	non_blocked 	21
    IDE11502-ENG127595-Locked menu contents-FB_NAV_34	non_blocked 	21
    IDE11502-ENG127596-Locked menu contents-FB_NAV_35	non_blocked 	21
    IDE11502-ENG127597-Locked menu contents-FB_NAV_36	non_blocked 	21
    IDE11502-ENG127598-Locked menu contents-FB_NAV_37	non_blocked 	21
    IDE11502-ENG127599-Locked menu contents-FB_NAV_38	non_blocked 	21
    IDE11502-ENG127600-Locked menu contents-FB_NAV_39	non_blocked 	21
    IDE11502-ENG127565-Locked menu contents-FB_NAV_4	non_blocked 	21
    IDE11502-ENG127566-Locked menu contents-FB_NAV_5	non_blocked 	21
    IDE11502-ENG127567-Locked menu contents-FB_NAV_6	non_blocked 	21
    IDE11502-ENG127568-Locked menu contents-FB_NAV_7	non_blocked 	21
    IDE11502-ENG127569-Locked menu contents-FB_NAV_8	non_blocked 	21
    IDE11502-ENG127570-Locked menu contents-FB_NAV_9	non_blocked 	21
    IDE11502-ENG127545-Locked menu contents-FB_PHONE_0	non_blocked 	21
    IDE11502-ENG127546-Locked menu contents-FB_PHONE_1	non_blocked 	21
    IDE11502-ENG127555-Locked menu contents-FB_PHONE_10	non_blocked 	21
    IDE11502-ENG127556-Locked menu contents-FB_PHONE_11	non_blocked 	21
    IDE11502-ENG127557-Locked menu contents-FB_PHONE_12	non_blocked 	21
    IDE11502-ENG127558-Locked menu contents-FB_PHONE_13	non_blocked 	21
    IDE11502-ENG127559-Locked menu contents-FB_PHONE_14	non_blocked 	21
    IDE11502-ENG127560-Locked menu contents-FB_PHONE_15	non_blocked 	21
    IDE11502-ENG127547-Locked menu contents-FB_PHONE_2	non_blocked 	21
    IDE11502-ENG127548-Locked menu contents-FB_PHONE_3	non_blocked 	21
    IDE11502-ENG127549-Locked menu contents-FB_PHONE_4	non_blocked 	21
    IDE11502-ENG127550-Locked menu contents-FB_PHONE_5	non_blocked 	21
    IDE11502-ENG127551-Locked menu contents-FB_PHONE_6	non_blocked 	21
    IDE11502-ENG127552-Locked menu contents-FB_PHONE_7	non_blocked 	21
    IDE11502-ENG127553-Locked menu contents-FB_PHONE_8	non_blocked 	21
    IDE11502-ENG127554-Locked menu contents-FB_PHONE_9	non_blocked 	21
    IDE11502-ENG127505-Locked menu contents-FB_TUNER_0	non_blocked 	21
    IDE11502-ENG127506-Locked menu contents-FB_TUNER_1	non_blocked 	21
    IDE11502-ENG127515-Locked menu contents-FB_TUNER_10	non_blocked 	21
    IDE11502-ENG127516-Locked menu contents-FB_TUNER_11	non_blocked 	21
    IDE11502-ENG127517-Locked menu contents-FB_TUNER_12	non_blocked 	21
    IDE11502-ENG127518-Locked menu contents-FB_TUNER_13	non_blocked 	21
    IDE11502-ENG127519-Locked menu contents-FB_TUNER_14	non_blocked 	21
    IDE11502-ENG127520-Locked menu contents-FB_TUNER_15	non_blocked 	21
    IDE11502-ENG127507-Locked menu contents-FB_TUNER_2	non_blocked 	21
    IDE11502-ENG127508-Locked menu contents-FB_TUNER_3	non_blocked 	21
    IDE11502-ENG127509-Locked menu contents-FB_TUNER_4	non_blocked 	21
    IDE11502-ENG127510-Locked menu contents-FB_TUNER_5	non_blocked 	21
    IDE11502-ENG127511-Locked menu contents-FB_TUNER_6	non_blocked 	21
    IDE11502-ENG127512-Locked menu contents-FB_TUNER_7	non_blocked 	21
    IDE11502-ENG127513-Locked menu contents-FB_TUNER_8	non_blocked 	21
    IDE11502-ENG127514-Locked menu contents-FB_TUNER_9	non_blocked 	21
    IDE11524-ENG249835-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57	not activated 	192
    IDE11524-ENG249836-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57_msg_bus	Comfort data bus 	192
    IDE11524-ENG142156-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42	not activated 	192
    IDE11524-ENG142157-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42_msg_bus	not activated 	192
    IDE11524-ENG142158-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47	not activated 	192
    IDE11524-ENG142159-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47_msg_bus	not activated 	192
    IDE11524-ENG249837-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C	not activated 	192
    IDE11524-ENG249838-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C_msg_bus	Comfort data bus 	192
    IDE11524-ENG152529-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51	not activated 	192
    IDE11524-ENG152530-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51_msg_bus	not activated 	192
    IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45	not activated 	192
    IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus	Databus Infotainment 	192
    IDE11524-ENG185772-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D	not activated 	192
    IDE11524-ENG185773-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D_msg_bus	Comfort data bus 	192
    IDE11524-ENG142168-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D	not activated 	192
    IDE11524-ENG142169-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D_msg_bus	not activated 	192
    IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41	activated 	192
    IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus	not activated 	192
    IDE11524-ENG152535-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50	not activated 	192
    IDE11524-ENG152536-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50_msg_bus	not activated 	192
    IDE11524-ENG248719-Vehicle function list BAP 2nd generation: expansion-ITM_0x65	not activated 	192
    IDE11524-ENG248720-Vehicle function list BAP 2nd generation: expansion-ITM_0x65_msg_bus	Comfort data bus 	192
    IDE11524-ENG249902-Vehicle function list BAP 2nd generation: expansion-lift_0x64	not activated 	192
    IDE11524-ENG249903-Vehicle function list BAP 2nd generation: expansion-lift_0x64_msg_bus	Comfort data bus 	192
    IDE11524-ENG185787-Vehicle function list BAP 2nd generation: expansion-mascot_0x83	not activated 	192
    IDE11524-ENG185788-Vehicle function list BAP 2nd generation: expansion-mascot_0x83_msg_bus	Comfort data bus 	192
    IDE11524-ENG152569-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E	not activated 	192
    IDE11524-ENG152570-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E_msg_bus	not activated 	192
    IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44	not activated 	192
    IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus	not activated 	192
    IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40	not activated 	192
    IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus	not activated 	192
    IDE11524-ENG142162-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A	not activated 	192
    IDE11524-ENG142163-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A_msg_bus	not activated 	192
    IDE11524-ENG142164-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B	not activated 	192
    IDE11524-ENG142165-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B_msg_bus	not activated 	192
    IDE11524-ENG142166-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C	not activated 	192
    IDE11524-ENG142167-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C_msg_bus	not activated 	192
    IDE11524-ENG185817-Vehicle function list BAP 2nd generation: expansion-vas_0x54	activated 	192
    IDE11524-ENG185818-Vehicle function list BAP 2nd generation: expansion-vas_0x54_msg_bus	Databus Infotainment 	192
    IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48	not activated 	192
    IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus	not activated 	192
    IDE11638-Bluetooth Audio Codec	FF 	1
    IDE12266-Follow on time for telephone	activated 	1
    IDE12353-Configuration of traffic light online functions	On 	1
    IDE12434-ENG249906-Vehicle menu operation: second generation: extension-menu_chassis_control	not activated 	60
    IDE12434-ENG249907-Vehicle menu operation: second generation: extension-menu_chassis_control_after_disclaimer	not activated 	60
    IDE12434-ENG249908-Vehicle menu operation: second generation: extension-menu_chassis_control_clamp_15_off	not activated 	60
    IDE12434-ENG249909-Vehicle menu operation: second generation: extension-menu_chassis_control_over_threshold_high	not activated 	60
    IDE12434-ENG249910-Vehicle menu operation: second generation: extension-menu_chassis_control_stillstand	not activated 	60
    IDE12434-ENG152495-Vehicle menu operation: second generation: extension-menu_connection_manager	not activated 	60
    IDE12434-ENG152499-Vehicle menu operation: second generation: extension-menu_connection_manager_after_disclaimer	not activated 	60
    IDE12434-ENG152496-Vehicle menu operation: second generation: extension-menu_connection_manager_clamp_15_off	not activated 	60
    IDE12434-ENG152497-Vehicle menu operation: second generation: extension-menu_connection_manager_over_threshold_high	not activated 	60
    IDE12434-ENG152498-Vehicle menu operation: second generation: extension-menu_connection_manager_standstill	not activated 	60
    IDE12434-ENG249911-Vehicle menu operation: second generation: extension-menu_convertible_top	not activated 	60
    IDE12434-ENG249912-Vehicle menu operation: second generation: extension-menu_convertible_top_after_disclaimer	not activated 	60
    IDE12434-ENG249913-Vehicle menu operation: second generation: extension-menu_convertible_top_clamp_15_off	not activated 	60
    IDE12434-ENG249914-Vehicle menu operation: second generation: extension-menu_convertible_top_over_threshold_high	not activated 	60
    IDE12434-ENG249915-Vehicle menu operation: second generation: extension-menu_convertible_top_stillstand	not activated 	60
    IDE12434-ENG152548-Vehicle menu operation: second generation: extension-menu_daf_profile	not activated 	60
    IDE12434-ENG152549-Vehicle menu operation: second generation: extension-menu_daf_profile_after_disclaimer	not activated 	60
    IDE12434-ENG152550-Vehicle menu operation: second generation: extension-menu_daf_profile_clamp_15_off	not activated 	60
    IDE12434-ENG152551-Vehicle menu operation: second generation: extension-menu_daf_profile_over_threshold_high	not activated 	60
    IDE12434-ENG152552-Vehicle menu operation: second generation: extension-menu_daf_profile_stillstand	not activated 	60
    IDE12434-ENG185793-Vehicle menu operation: second generation: extension-menu_engine_functions	not activated 	60
    IDE12434-ENG185794-Vehicle menu operation: second generation: extension-menu_engine_functions_after_disclaimer	not activated 	60
    IDE12434-ENG185795-Vehicle menu operation: second generation: extension-menu_engine_functions_clamp_15_off	not activated 	60
    IDE12434-ENG185796-Vehicle menu operation: second generation: extension-menu_engine_functions_over_threshold_high	not activated 	60
    IDE12434-ENG185797-Vehicle menu operation: second generation: extension-menu_engine_functions_stillstand	not activated 	60
    IDE12434-ENG152515-Vehicle menu operation: second generation: extension-menu_fas_profile	not activated 	60
    IDE12434-ENG152519-Vehicle menu operation: second generation: extension-menu_fas_profile_after_disclaimer	not activated 	60
    IDE12434-ENG152516-Vehicle menu operation: second generation: extension-menu_fas_profile_clamp_15_off	not activated 	60
    IDE12434-ENG152517-Vehicle menu operation: second generation: extension-menu_fas_profile_over_threshold_high	not activated 	60
    IDE12434-ENG152518-Vehicle menu operation: second generation: extension-menu_fas_profile_standstill	not activated 	60
    IDE12434-ENG185798-Vehicle menu operation: second generation: extension-menu_fod	not activated 	60
    IDE12434-ENG185799-Vehicle menu operation: second generation: extension-menu_fod_after_disclaimer	not activated 	60
    IDE12434-ENG185800-Vehicle menu operation: second generation: extension-menu_fod_clamp_15_off	not activated 	60
    IDE12434-ENG185801-Vehicle menu operation: second generation: extension-menu_fod_over_threshold_high	not activated 	60
    IDE12434-ENG185802-Vehicle menu operation: second generation: extension-menu_fod_stillstand	not activated 	60
    IDE12434-ENG248744-Vehicle menu operation: second generation: extension-menu_ITM	not activated 	60
    IDE12434-ENG248745-Vehicle menu operation: second generation: extension-menu_ITM_after_disclaimer	not activated 	60
    IDE12434-ENG248746-Vehicle menu operation: second generation: extension-menu_ITM_clamp_15_off	not activated 	60
    IDE12434-ENG248747-Vehicle menu operation: second generation: extension-menu_ITM_over_threshold_high	not activated 	60
    IDE12434-ENG248748-Vehicle menu operation: second generation: extension-menu_ITM_stillstand	not activated 	60
    IDE12434-ENG249916-Vehicle menu operation: second generation: extension-menu_lift	not activated 	60
    IDE12434-ENG249917-Vehicle menu operation: second generation: extension-menu_lift_after_disclaimer	not activated 	60
    IDE12434-ENG249918-Vehicle menu operation: second generation: extension-menu_lift_clamp_15_off	not activated 	60
    IDE12434-ENG249919-Vehicle menu operation: second generation: extension-menu_lift_over_threshold_high	not activated 	60
    IDE12434-ENG249920-Vehicle menu operation: second generation: extension-menu_lift_stillstand	not activated 	60
    IDE12434-ENG184478-Vehicle menu operation: second generation: extension-menu_mascot	not activated 	60
    IDE12434-ENG184479-Vehicle menu operation: second generation: extension-menu_mascot_after_disclaimer	not activated 	60
    IDE12434-ENG184480-Vehicle menu operation: second generation: extension-menu_mascot_clamp_15_off	not activated 	60
    IDE12434-ENG184481-Vehicle menu operation: second generation: extension-menu_mascot_over_threshold_high	not activated 	60
    IDE12434-ENG184482-Vehicle menu operation: second generation: extension-menu_mascot_stillstand	not activated 	60
    IDE12434-ENG152562-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile	not activated 	60
    IDE12434-ENG152563-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_after_disclaimer	not activated 	60
    IDE12434-ENG152564-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_clamp_15_off	not activated 	60
    IDE12434-ENG152565-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_over_threshold_high	not activated 	60
    IDE12434-ENG152566-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_stillstand	not activated 	60
    IDE12434-ENG152505-Vehicle menu operation: second generation: extension-menu_statistic	not activated 	60
    IDE12434-ENG152509-Vehicle menu operation: second generation: extension-menu_statistic_after_disclaimer	not activated 	60
    IDE12434-ENG152506-Vehicle menu operation: second generation: extension-menu_statistic_clamp_15_off	not activated 	60
    IDE12434-ENG152507-Vehicle menu operation: second generation: extension-menu_statistic_over_threshold_high	not activated 	60
    IDE12434-ENG152508-Vehicle menu operation: second generation: extension-menu_statistic_standstill	not activated 	60
    IDE12434-ENG152510-Vehicle menu operation: second generation: extension-menu_sunroof	not activated 	60
    IDE12434-ENG152514-Vehicle menu operation: second generation: extension-menu_sunroof_after_disclaimer	not activated 	60
    IDE12434-ENG152511-Vehicle menu operation: second generation: extension-menu_sunroof_clamp_15_off	not activated 	60
    IDE12434-ENG152512-Vehicle menu operation: second generation: extension-menu_sunroof_over_threshold_high	not activated 	60
    IDE12434-ENG152513-Vehicle menu operation: second generation: extension-menu_sunroof_standstill	not activated 	60
    IDE12434-ENG185803-Vehicle menu operation: second generation: extension-menu_vas	not activated 	60
    IDE12434-ENG185804-Vehicle menu operation: second generation: extension-menu_vas_after_disclaimer	not activated 	60
    IDE12434-ENG185805-Vehicle menu operation: second generation: extension-menu_vas_clamp_15_off	not activated 	60
    IDE12434-ENG185806-Vehicle menu operation: second generation: extension-menu_vas_over_threshold_high	not activated 	60
    IDE12434-ENG185807-Vehicle menu operation: second generation: extension-menu_vas_stillstand	not activated 	60
    IDE12434-ENG152500-Vehicle menu operation: second generation: extension-menu_wireless_charging	not activated 	60
    IDE12434-ENG152504-Vehicle menu operation: second generation: extension-menu_wireless_charging_after_disclaimer	not activated 	60
    IDE12434-ENG152501-Vehicle menu operation: second generation: extension-menu_wireless_charging_clamp_15_off	not activated 	60
    IDE12434-ENG152502-Vehicle menu operation: second generation: extension-menu_wireless_charging_over_threshold_high	not activated 	60
    IDE12434-ENG152503-Vehicle menu operation: second generation: extension-menu_wireless_charging_standstill	not activated 	60
    IDE13183-Deactivation/activation of the pop-up for active tracking services	00 00 00 00 	4
    MAS00951-Bluetooth	On 	1
    MAS02809-MAS02870-Check tone frequency-High note frequency range	4000 Hz	6
    MAS02809-MAS02871-Check tone frequency-Medium note frequency range	1000 Hz	6
    MAS02809-MAS02872-Check tone frequency-Low note frequency range	100 Hz	6
    MAS03690-Telephone	Data & language service active 	1
    MAS03782-WLAN	On 	1
    ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off	OFF 	12
    ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time	0.00 ms	12
    ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off	OFF 	12
    ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time	0.00 ms	12
    ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off	OFF 	12
    ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time	0.00 ms	12
    ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off	OFF 	12
    ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time	0.00 ms	12
    ENG117920-Audio_Managment_Soundset_Menu	OFF 	1
    ENG117917-BAP_Debug_Mode_Release	not_released 	1
    ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization	not activated 	60
    ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer	not activated 	60
    ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off	not activated 	60
    ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high	not activated 	60
    ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill	not activated 	60
    ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation	not activated 	60
    ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer	not activated 	60
    ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off	not activated 	60
    ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high	not activated 	60
    ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill	not activated 	60
    ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent	not activated 	60
    ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer	not activated 	60
    ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off	not activated 	60
    ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high	not activated 	60
    ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill	not activated 	60
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC	activated 	60
    ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer	not activated 	60
    ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off	not activated 	60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high	activated 	60
    ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill	not activated 	60
    ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key	not activated 	60
    ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer	not activated 	60
    ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off	not activated 	60
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high	not activated 	60
    ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill	not activated 	60
    ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue	not activated 	60
    ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer	not activated 	60
    ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off	not activated 	60
    ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high	not activated 	60
    ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill	not activated 	60
    ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper	not activated 	60
    ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer	not activated 	60
    ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off	not activated 	60
    ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high	not activated 	60
    ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill	not activated 	60
    ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination	activated 	60
    ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer	not activated 	60
    ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off	not activated 	60
    ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high	activated 	60
    ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill	not activated 	60
    ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope	not activated 	60
    ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer	not activated 	60
    ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off	not activated 	60
    ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high	not activated 	60
    ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill	not activated 	60
    ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification	not activated 	60
    ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer	not activated 	60
    ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off	not activated 	60
    ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high	not activated 	60
    ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill	not activated 	60
    ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating	not activated 	60
    ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer	not activated 	60
    ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off	not activated 	60
    ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high	not activated 	60
    ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill	not activated 	60
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv	activated 	60
    ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer	not activated 	60
    ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off	not activated 	60
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high	activated 	60
    ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill	not activated 	60
    ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management	not activated 	60
    ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer	not activated 	60
    ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off	not activated 	60
    ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high	not activated 	60
    ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill	not activated 	60
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE	activated 	60
    ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer	not activated 	60
    ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off	not activated 	60
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high	activated 	60
    ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill	not activated 	60
    ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer	activated 	60
    ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer	not activated 	60
    ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off	not activated 	60
    ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high	activated 	60
    ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill	not activated 	60
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function	activated 	60
    ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer	not activated 	60
    ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off	not activated 	60
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high	activated 	60
    ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill	not activated 	60
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror	activated 	60
    ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer	not activated 	60
    ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off	not activated 	60
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high	activated 	60
    ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill	not activated 	60
    ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking	activated 	60
    ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer	not activated 	60
    ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off	not activated 	60
    ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high	activated 	60
    ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill	not activated 	60
    ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master	activated 	60
    ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer	not activated 	60
    ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off	not activated 	60
    ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high	activated 	60
    ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill	not activated 	60
    ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma	activated 	60
    ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer	not activated 	60
    ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off	not activated 	60
    ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high	activated 	60
    ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill	not activated 	60
    ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration	activated 	60
    ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer	not activated 	60
    ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off	not activated 	60
    ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high	activated 	60
    ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill	not activated 	60
    ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock	activated 	60
    ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer	not activated 	60
    ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off	not activated 	60
    ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high	activated 	60
    ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill	not activated 	60
    ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass	not activated 	60
    ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer	not activated 	60
    ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off	not activated 	60
    ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high	not activated 	60
    ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill	not activated 	60
    ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist	not activated 	60
    ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer	not activated 	60
    ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off	not activated 	60
    ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high	not activated 	60
    ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill	not activated 	60
    ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration	not activated 	60
    ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer	not activated 	60
    ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off	not activated 	60
    ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high	not activated 	60
    ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill	not activated 	60
    ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school	not activated 	60
    ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer	not activated 	60
    ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off	not activated 	60
    ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high	not activated 	60
    ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill	not activated 	60
    ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall	not activated 	60
    ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer	not activated 	60
    ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off	not activated 	60
    ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high	not activated 	60
    ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill	not activated 	60
    ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist	not activated 	60
    ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer	not activated 	60
    ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off	not activated 	60
    ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high	not activated 	60
    ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill	not activated 	60
    ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI	not activated 	60
    ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer	not activated 	60
    ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off	not activated 	60
    ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high	not activated 	60
    ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill	not activated 	60
    ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination	activated 	60
    ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer	not activated 	60
    ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off	not activated 	60
    ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high	activated 	60
    ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill	not activated 	60
    ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display	not activated 	60
    ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer	not activated 	60
    ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off	not activated 	60
    ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high	not activated 	60
    ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill	not activated 	60
    ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid	not activated 	60
    ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer	not activated 	60
    ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off	not activated 	60
    ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high	not activated 	60
    ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill	not activated 	60
    ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant	not activated 	60
    ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer	not activated 	60
    ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off	not activated 	60
    ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high	not activated 	60
    ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill	not activated 	60
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning	not activated 	60
    ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer	not activated 	60
    ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off	not activated 	60
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high	not activated 	60
    ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill	not activated 	60
    ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker	not activated 	60
    ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer	not activated 	60
    ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off	not activated 	60
    ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high	not activated 	60
    ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill	not activated 	60
    ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision	not activated 	60
    ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer	not activated 	60
    ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off	not activated 	60
    ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high	not activated 	60
    ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill	not activated 	60
    ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level	not activated 	60
    ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer	not activated 	60
    ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off	not activated 	60
    ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high	not activated 	60
    ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill	not activated 	60
    ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc	activated 	60
    ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer	not activated 	60
    ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off	not activated 	60
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high	activated 	60
    ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill	not activated 	60
    ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist	not activated 	60
    ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer	not activated 	60
    ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off	not activated 	60
    ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high	not activated 	60
    ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill	not activated 	60
    ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk	activated 	60
    ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer	not activated 	60
    ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off	not activated 	60
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high	activated 	60
    ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill	not activated 	60
    ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment	not activated 	60
    ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer	not activated 	60
    ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off	not activated 	60
    ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high	not activated 	60
    ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill	not activated 	60
    ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load	not activated 	60
    ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer	not activated 	60
    ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off	not activated 	60
    ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high	not activated 	60
    ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill	not activated 	60
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification	not activated 	60
    ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer	not activated 	60
    ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off	not activated 	60
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high	not activated 	60
    ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill	not activated 	60
    ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration	not activated 	60
    ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer	not activated 	60
    ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off	not activated 	60
    ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high	not activated 	60
    ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill	not activated 	60
    ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic	not activated 	60
    ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer	not activated 	60
    ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off	not activated 	60
    ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high	not activated 	60
    ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill	not activated 	60
    ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia	activated 	60
    ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer	not activated 	60
    ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off	not activated 	60
    ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high	activated 	60
    ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill	not activated 	60
    ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view	not activated 	60
    ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer	not activated 	60
    ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off	not activated 	60
    ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high	not activated 	60
    ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill	not activated 	60
    ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions	not activated 	60
    ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer	not activated 	60
    ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off	not activated 	60
    ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high	not activated 	60
    ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill	not activated 	60
    ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler	not activated 	60
    ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer	not activated 	60
    ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off	not activated 	60
    ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high	not activated 	60
    ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill	not activated 	60
    ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI	not activated 	60
    ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer	not activated 	60
    ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off	not activated 	60
    ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high	not activated 	60
    ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill	not activated 	60
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons	activated 	60
    ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer	not activated 	60
    ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off	not activated 	60
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high	activated 	60
    ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill	not activated 	60
    ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant	not activated 	60
    ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer	not activated 	60
    ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off	not activated 	60
    ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high	not activated 	60
    ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill	not activated 	60
    ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner	not activated 	60
    ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer	not activated 	60
    ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off	not activated 	60
    ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high	not activated 	60
    ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill	not activated 	60
    ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo	not activated 	60
    ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer	not activated 	60
    ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off	not activated 	60
    ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high	not activated 	60
    ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill	not activated 	60
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating	activated 	60
    ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer	not activated 	60
    ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off	not activated 	60
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high	activated 	60
    ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill	not activated 	60
    ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin	activated 	60
    ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer	not activated 	60
    ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off	not activated 	60
    ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high	activated 	60
    ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill	not activated 	60
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition	activated 	60
    ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer	not activated 	60
    ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off	not activated 	60
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high	activated 	60
    ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill	not activated 	60
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows	activated 	60
    ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer	not activated 	60
    ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off	not activated 	60
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high	activated 	60
    ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill	not activated 	60
    ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper	activated 	60
    ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer	not activated 	60
    ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off	not activated 	60
    ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high	activated 	60
    ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill	not activated 	60
    ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol	not activated 	60
    ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer	not activated 	60
    ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off	not activated 	60
    ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high	not activated 	60
    ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill	not activated 	60
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05	activated 	64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus	Databus extended 	64
    ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06	not activated 	64
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus	Suspension data bus 	64
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D	not activated 	64
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus	Databus Infotainment 	64
    ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24	not activated 	64
    ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus	not activated 	64
    ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03	not activated 	64
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus	Comfort data bus 	64
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B	activated 	64
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus	Terminal 15 	64
    ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25	not activated 	64
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus	Databus drivetrain 	64
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23	activated 	64
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus	Databus Infotainment 	64
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26	activated 	64
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus	Suspension data bus 	64
    ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D	activated 	64
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus	Comfort data bus 	64
    ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17	activated 	64
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus	Databus Infotainment 	64
    ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16	not activated 	64
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus	Comfort data bus 	64
    ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01	activated 	64
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus	Comfort data bus 	64
    ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02	not activated 	64
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus	Comfort data bus 	64
    ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11	activated 	64
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus	Comfort data bus 	64
    ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15	not activated 	64
    ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus	not activated 	64
    ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10	not activated 	64
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus	Comfort data bus 	64
    ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33	not activated 	64
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus	Comfort data bus 	64
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C	not activated 	64
    ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C	not activated 	64
    ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37	not activated 	64
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus	Comfort data bus 	64
    ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38	not activated 	64
    ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus	Comfort data bus 	64
    ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09	activated 	64
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus	Comfort data bus 	64
    ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04	not activated 	64
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus	Comfort data bus 	64
    ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D	not activated 	64
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus	Databus drivetrain 	64
    ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08	activated 	64
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus	Comfort data bus 	64
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19	activated 	64
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus	Databus extended 	64
    ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F	activated 	64
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus	Comfort data bus 	64
    ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34	not activated 	64
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34	Databus Infotainment 	64
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E	activated 	64
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus	Comfort data bus 	64
    ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18	not activated 	64
    ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus	not activated 	64
    ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A	activated 	64
    ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus	Terminal 15 	64
    ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20	not activated 	64
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus	Comfort data bus 	64
    ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A	not activated 	64
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A	Databus extended 	64
    ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39	not activated 	64
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39	Databus Infotainment 	64
    ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E	not activated 	64
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus	Comfort data bus 	64
    ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F	not activated 	64
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus	Databus drivetrain 	64
    ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B	not activated 	64
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B	Comfort data bus 	64
    ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F	not activated 	64
    ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F	Comfort data bus 	64
    ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E	not activated 	64
    ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E	Comfort data bus 	64
    ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12	activated 	64
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus	Comfort data bus 	64
    ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E	not activated 	64
    ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus	not activated 	64
    ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35	not activated 	64
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35	Comfort data bus 	64
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27	activated 	64
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus	Databus Infotainment 	64
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A	activated 	64
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus	Databus extended 	64
    ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07	activated 	64
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus	Suspension data bus 	64
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21	not activated 	64
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus	Databus extended 	64
    ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36	not activated 	64
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36	Comfort data bus 	64
    ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C	not activated 	64
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus	Comfort data bus 	64
    ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14	not activated 	64
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus	Terminal 15 	64
    ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13	activated 	64
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus	Comfort data bus 	64
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B	not activated 	64
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus	not activated 	64
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22	activated 	64
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus	Databus Infotainment 	64
    ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C	activated 	64
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus	Comfort data bus 	64
    ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key	Not available 	8
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus	Comfort data bus 	8
    ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school	Not available 	8
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus	Databus Infotainment 	8
    ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL	Available 	8
    ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus	Databus Infotainment 	8
    ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level	Not available 	8
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus	Databus drivetrain 	8
    ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering	Available 	8
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus	Suspension data bus 	8
    ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved	Not available 	8
    ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1	Comfort data bus 	8
    ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2	Comfort data bus 	8
    ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3	Not available 	8
    ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN	Available 	8
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus	Comfort data bus 	8
    ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps	OFF 	10
    ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture	On 	10
    ENG122230-ENG122341-Dashboard_Display_Configuration-coverart	On 	10
    ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode	RLE 	10
    ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution	resolution_1 	10
    ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode	OFF 	10
    ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon	0	10
    ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most	OFF 	10
    ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode	H264 	10
    ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution	resolution_1 	10
    ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode	MOST_streaming 	10
    ENG122230-ENG122342-Dashboard_Display_Configuration-stationart	On 	10
    ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1	0	6
    ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2	50	6
    ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3	100	6
    ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1	0	6
    ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2	50	6
    ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3	100	6
    ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1	0	6
    ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2	50	6
    ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3	100	6
    ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1	0	6
    ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2	50	6
    ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3	100	6
    ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1	0	12
    ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2	10	12
    ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3	50	12
    ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4	100	12
    ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5	150	12
    ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6	253	12
    ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1	1%	12
    ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2	1%	12
    ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3	3%	12
    ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4	6%	12
    ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5	44%	12
    ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6	100%	12
    ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07	FF 	32
    ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F	FF 	32
    ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17	FF 	32
    ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F	FF 	32
    ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27	FF 	32
    ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F	FF 	32
    ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37	FF 	32
    ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F	FF 	32
    ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47	FF 	32
    ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F	FF 	32
    ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57	FF 	32
    ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F	FF 	32
    ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67	FF 	32
    ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F	FF 	32
    ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77	FF 	32
    ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F	FF 	32
    ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87	FF 	32
    ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F	FF 	32
    ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97	FF 	32
    ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F	FF 	32
    ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7	FF 	32
    ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF	FF 	32
    ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7	FF 	32
    ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF	FF 	32
    ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7	FF 	32
    ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF	FF 	32
    ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7	FF 	32
    ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF	FF 	32
    ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7	FF 	32
    ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF	FF 	32
    ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7	FF 	32
    ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF	FF 	32
    ENG107658-ENG126192-mobile phone voice control availability-apple_device	not installed 	1
    ENG107658-ENG126193-mobile phone voice control availability-other_devices	not installed 	1
    ENG167428-ENG167502-nhtsa_properties-limitation_dependency	gear_selection 	5
    ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length	not activated 	5
    ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration	not activated 	5
    ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input	not activated 	5
    ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback	not activated 	5
    ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input	not activated 	5
    ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists	not activated 	5
    ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists	not activated 	5
    ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps	not activated 	5
    ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard	not activated 	5
    ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad	not activated 	5
    ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation	01 01 28 02 50 02 50 02 28 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 48 	40
    ENG117809-p_damping_Display	5 ms	1
    ENG117808-p_HMI_Display	13%	1
    ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset	0	2
    ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset	0	2
    ENG117919-Startup_Screen_Sticker_HMI	00 00 	2
    ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN	0	3
    ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit	0 km/h	3
    Elapsed Time: 00:48
    Mar 2015
    Australia
    Try these adaptations:
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19 --> not activated
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A --> not activated
    Also try byte 19 coding and enable RVC low
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist|BCM Retrofit|HBA/FLA
  6. Likes jhnbssll liked this post
    Mar 2015
    Australia
    Also your video input is set to LVDS, try FBAS:
    IDE03471-ENG126143-Vehicle configuration-RVC_video_input LVDS
    Apr 2020
    England
    Quote Originally Posted by kamold View Post
    Excellent, thanks for the suggestions. I'll try them tomorrow morning and feedback. Does it make any difference that my reversing camera is the highline model?
    I wonder if the blue connector has popped out of the quadlock, I'll check that too.
    Apr 2020
    England
    Ah yes, that was the last change I made whilst experimenting and clearly forgot to switch it back. Thanks, I'll correct it when I make the next changes!
  10. #8
    Apr 2020
    England
    I've just noticed in the admap that IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41 is activated but the line underneath it IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus is not activated - Should every active feature have a data bus set? I believe the car should have front traffic assist, so should I set a databus and if so which one?
  11. #9
    May 2017
    You car does not even have A5 front assist camera so it definitely does NOT have front traffic assist. You can ignore the adaptation channel you posted.
  12. Likes jhnbssll liked this post
  13. #10
    VCDS Distributor AINils's Avatar
    Apr 2020
    Germany (AIB)
    It looks like a bad service. Unit is badly reworked. I think CP off is no deal, but restore FEC could be problem
