Hi all,
I'm trying to clear up some DTC's left over from my MIB2.5 retrofit. I paid someone to do the coding remotely without really researching what was involved. As such I didn't realise they had only removed component protection with a patch and activated a few things, and had not coded the unit to suit my vehicle. Unfortunately I only realised this after I had posted my old unit off to its new user, before I had even heard of VCDS let alone created an adaptation map or autoscan For what it's worth, the old unit was an MIB2 discover pro.
Anyway on with the fun! Lets start off with an autoscan of the current situation...
So concentrating on the 5F module for now...
1543 - Control Module Incorrectly Coded is confusing me slightly - I've been through the long coding and can't see anything obviously amiss, but I'm very much new to this. Any pointers?
15360768 - Component Protection I'll ignore - as soon as the lockdown allows I'll go and get the unit registered to the car.
3073 - Cellular Antenna and 3084 - GSM antenna 2 I'm expecting to go away when I receive and install the FAKRA adapter, currently the antenna is unplugged as the connector was physically different to my old MIB2 unit.
7193 - Function Restricted due to Missing Message(s) and 7194 - Function Restricted due to Missing Message(s) I presume these mean I've got lane/side assist activated somewhere in the adaptations but I'm damned if I can find it, any pointers?
Until earlier this evening I also had a 1555 - Check Software Version Management fault but I managed to clear that using a bitwise XOR calculator and some info from a Gold MK7 forum, I was rather pleased with myself Now if I could just get these other faults cleared...
I've done an adaptations map and have a .csv file available, but with nothing to compare it to I don't really know how much use it will be?
The other topic is the reversing camera which used to work before the retrofit but now not so much - I presume I've dislodged a pin in the connector causing the 9591827 - Video Signal Line error but not so sure about 13705478 - Databus yet I presume the MIB2.5 uses the same pins for the video signal?
Any pointers on any of these would be much appreciated, thanks!
Wednesday,22,April,2020,20:29:30:58535
VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWZZZ3CZFP407282 License Plate:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 42 44 52 55 5F
6C BB BC
VIN: WVWZZZ3CZFP407282 Mileage: 115180km-71569miles
Address 01: Engine (J623-CUAA) Labels:. 03N-906-026-CUA.clb
Part No SW: 03N 906 026 HW: 03N 907 309
Component: R4 2,0L EDC H23 1707
Revision: A1H23---
Coding: 01250012036705083000
Shop #: WSC 65535 000 00000
ASAM Dataset: EV_ECM20BTD01103N906026 001011
ROD: EV_ECM20BTD01103N906026.rod
VCID: 6889BEDE92FD913BFB2-803C
Part No SW: 0DL 300 011 HW: 0BH 927 711 F
Component: GSG DQ500 H10 4701
Revision: 00H10V01
ROD: EV_TCMDQ500021_001_VW36.rod
VCID: 6597B7EA65EF8C53C04-8030
Part No SW: 3Q0 907 379 N HW: 3Q0 907 379 G
Component: ESC H42 0710
Revision: 00000000 Serial number: 63394000001047
Coding: 0EEC938F34200B730779070841C54970C92CD0E0E08292F1186250F8C202
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 45D7576AC52FAC53204-8010
Part No SW: 3Q0 959 435 HW: 3Q0 959 435
Component: VWKESSYMQB 023 0522
Revision: 00023000 Serial number: 0355060864
Coding: 000F0F0703
Shop #: WSC 00028 028 00026
ASAM Dataset: EV_KessyHellaMQBAB 004027
ROD: EV_KessyHellaMQBAB.rod
VCID: 77ABEDA2CF430EC3628-8022
Part No SW: 5G2 907 044 HW: 5G2 907 044
Component: Climatronic H03 1001
Revision: 00001K10
Coding: 12120104202100012015500E00101802
VCID: 6695B0E698E9874BC9E-8032
Air quality sensor:
Part No SW: 5Q0 937 086 BD HW: 5Q0 937 086 BD
Component: BCM PQ37BOSCH 028 0146
Revision: -------- Serial number: 86580112141655
Coding: 03051C66C24102FF0B844084B11C07281880000000000000000000000000
ROD: EV_BCMBOSCH_014.rod
VCID: 7DA7FF8AED7F2493384-8028
Subsystem 1 - Part No SW: 3G2 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 141118 043 0607
Serial number: 141127135615
Component: RLHS 037 0059
Serial number: S5Y14M12D11H08M00S22
Coding: 00A8DD
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 17 10 2014 00001110
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY143140F37
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000031313132
Part No SW: 5Q0 919 294 H HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0053
Revision: -------- Serial number: 39391433513904
Coding: 0071151051
VCID: 40D9467EDA0D897B132-8014
Part No SW: 3Q0 907 572 A HW: 3Q0 907 572 A
Component: ACC BOSCH MQB H04 0126
Coding: 3260678110FFC428949C804C
Shop #: WSC 00028 028 00001
ASAM Dataset: EV_ACCBOSCHVW48X 001007
ROD: EV_ACCBOSCHVW48X.rod
VCID: 333319B29BBB22E39E0-8066
Part No SW: 5Q0 907 376 HW: 5Q0 907 376
Component: DAEMPFUNGS-SG H16 0115
Serial number: 02121441350608
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 76B5E0A6C84977CB79E-8022
Part No SW: 3Q0 959 655 AE HW: 3Q0 959 655 AE
Component: Airbag VW20 012 0195
Revision: -------- Serial number: 003R1PP7RFWX
Coding: 98FCC0C0008000005C5400CC008800000065
Shop #: WSC 00028 028 00011
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 015F837A918740735CC-8054
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 105 1032
Serial number: 3G2857705C0336O00113
Coding: 80000A
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 105 1032
Serial number: 3G2857706C0332O00803
Coding: 80000A
Subsystem 3 - Part No SW: ----------- HW: 454 000 112 14
Serial number: 3576U000000C8291C11B
Subsystem 4 - Part No SW: ----------- HW: 454 000 112 14
Serial number: 3586U00000009269121$
Subsystem 5 - Part No SW: ----------- HW: 454 800 112 14
Component: SideSensor_Dr 111 0148
Serial number: 3516R683B4B050000004
Subsystem 6 - Part No SW: ----------- HW: 454 800 312 14
Component: SideSensor_Pr 111 0148
Serial number: 3526RCE254B05000000A
Subsystem 7 - Part No SW: ----------- HW: 454 800 112 14
Component: FrontSensor_D 114 0149
Serial number: 3556VA4EE3F05000000T
Part No SW: 3Q0 953 521 AM HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0185
Revision: FF033033 Serial number: 20141205500792
Coding: 0410
ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
ROD: EV_SMLSVALEOMQBLRH.rod
VCID: 7BA3F192F36B2AA3060-802E
Part No SW: 3G0 920 951 HW: 3G0 920 951
Component: KOMBI 308 4311
Coding: 27A40818BF80260001886A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009043
VCID: 6491AAEE6ED5F55BD7A-8030
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 29111410800786
Coding: 030300044F017300EF00025E9C0F00010001070000000000000000000000
ROD: EV_GatewConti_011.rod
VCID: 72BDDCB6A4216BEB556-8026
Component: E221__MFL-DC1 H16 0038
Serial number: 27140003024800124484
Coding: 2FFFFF
Subsystem 3 - Part No SW: 3Q0 915 181 A HW: 3Q0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 9750484803
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 0212201400010305
U1101 00 [009] - Active
Reset counter: 66
Mileage: 115092 km
Date: 2020.04.17
Time: 16:27:48
Terminal 15: On
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7082
Serial number: HA1-00018.10.14
Coding: 0301
ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
ROD: EV_AllWheelContrHA1VW37X_002.rod
VCID: 46D55066F829A74B29E-8012
Component: ELV-MQBB H05 0031
Serial number: 14000257178010
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BFD3BAA12750F3ACC-8024
Part No SW: 5Q4 959 593 D HW: 5Q4 959 593 B
Component: TSG FS 009 0016
Serial number: 0000127477955
Coding: 003F0A20D001028000001000
Shop #: WSC 00028 028 00038
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: 8103
VCID: 43D34972CB1B92630E0-8016
Part No SW: 5Q4 959 592 C HW: 5Q4 959 592 B
Component: TSG BFS 009 0015
Serial number: 0000128808641
Coding: 003F0020D001028000001000
VCID: 44D14A6ECE15955B37A-8010
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Coding: 03A602000F210200
Shop #: WSC 39239 001 1048576
VCID: 3FDB4582A7F3F6836A8-806A
Subsystem 1 - Part No SW: 7PP 941 572 A HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 0001
Coding: E02400
Subsystem 2 - Part No SW: 7PP 941 572 A HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 0001
Coding: E02400
Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0003
Coding: E02400
Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0003
Coding: E02400
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 042 D HW: 5NA 035 042
Component: MU-H-LN-EU H51 1367
Serial number: A847A0HB001646
Coding: 02840101FF00000051111101C08808101F0002C601208400CF
VCID: 363520A688C937CBB9E-8062
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H50 9130
Serial number: VWZ6ZJT3280316
Subsystem 2 - Part No SW: V03 959 806 FL HW: -----------
Component: ECE 2019 --- 0175
Component: Gracenote2 --- 1015
U1014 00 [009] - -
Reset counter: 66
Mileage: 115180 km
Date: 2020.04.22
Time: 20:22:00
Voltage terminal 30: 11.9 V
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
[Anti-theft protection - component protection active (0xEA6300)]
Reset counter: 66
Mileage: 115180 km
Date: 2020.04.22
Time: 20:21:59
B1053 13 [009] - Open Circuit
[GSM/UMTS aerial - open circuit]
Reset counter: 66
Mileage: 115180 km
Date: 2020.04.22
Time: 20:22:00
B1533 13 [009] - Open Circuit
Reset counter: 66
Mileage: 115180 km
Date: 2020.04.22
Time: 20:22:00
U1111 00 [009] - -
[Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 66
Mileage: 115180 km
Date: 2020.04.22
Time: 20:22:01
BAP-BAP_Function_ID: 02
U1111 00 [009] - -
[Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 66
Mileage: 115180 km
Date: 2020.04.22
Time: 20:22:01
Component: RVC Compact H18 0231
Coding: 0184020162002017000040
ROD: EV_CamSysRVRVCPANAMQBAB.rod
VCID: 392F2B9AB9D7D8B354C-806C
B125C 13 [009] - Open Circuit
Reset counter: 66
Mileage: 115180 km
Date: 2020.04.22
Time: 18:23:57
passive
13705478 - Databus
[message Parkhilfe_01 not received]
Reset counter: 66
Mileage: 115180 km
Date: 2020.04.22
Time: 18:23:55
passive
Part No SW: 5Q4 959 595 C HW: 5Q4 959 595 B
Component: TSG HFS 010 0015
Serial number: 0000124974966
Coding: 000E00200101028000001000
ASAM Dataset: EV_DCURearDriveMAXCONT 006001
VCID: 47CB5D62FF23BE43D28-8012
Component: TSG HBFS 010 0015
Serial number: 0000127211398
ASAM Dataset: EV_DCURearPasseMAXCONT 006001
End----(Elapsed Time: 02:15, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
