Does the order matter when both coding and Vehicle Data Learning a HVAC control unit is required?
I've installed a used Climate Control unit in the dash. This fixed my AC except the rear window defroster no longer works. A VCDS-Lite scan shows Incorrect VIN and no comms to Converable Top in the HVAC module.
I've located the fix, I think, in the VCDS WIKI:
So I need to correct the coding and "teach" the car's VIN to the HVAC unit, or is it the other way around?
Audi A4 (8E) Heating/Air Conditioning
Contents
1 Coding
2 Adaptation
2.1 Channel 081: Vehicle Data Learning
Coding
00?xx: Chassis
0 = Sedan/Avant
1 = Cabrio
00x?x: Heated Windshield
0 = Heated Windshield not installed
1 = Heated Windshield installed
00xx?: Sunroof
0 = No Sunroof OR Normal Sunroof
1 = Sunroof with Solar Cells
Adaptation
To start the process for vehicle data (VIN) learning, enter/save 26467 as new value.
Contents
1 Coding
2 Adaptation
Coding
00?xx: Chassis
0 = Sedan/Avant
1 = Cabrio
00xx?: Sunroof
Adaptation
