- Jul 24, 2017
- 11
- 4
- South Africa
- C?ID=311443
Hi All
I have a 2007 VW Touareg 3.0 V6 TDi (BKS engine), and sometimes when the car has standed for a few days it really takes time to start. Maybe a good 10 seconds of cranking to start.
I would like to change the time that the glowplugs stays on before starting. I know that it will only glow if the temperature is below 20 deg Celcius (or somewhere there). I saw another thread on TDiClub how to do it but I cannot get to the same adaptation block as mentioned in the thread.
Does anyone know how to do this? If at all possible.
Here is my Autoscan for the same car.
Tuesday,21,April,2020,15:19:25:53384
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVGZZZ7LZ7D081342 License Plate:
Mileage: 279980km-173971mi Repair Order:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 34 46 47 55 56 68 69 76
VIN: WVGZZZ7LZ7D081342 Mileage: 279980km-173971miles
68-Wiper Electr. -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 7L0 907 401 F HW: 7L0 907 401 D
Component: 3.0L V6TDI G000AG 0040
Revision: --H04--- Serial number: VWX3Z0G1602456
Coding: 0011775
Shop #: WSC 31414 790 00001
VCID: 2E04FF265C0A4DFBF17-5184
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 FA HW: 09D 927 750 FA
Component: AL 750 6A 0992
Revision: 00H61000 Serial number:
Coding: 0004456
VCID: 72BC2B5688B2291B55F-5160
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 K HW: 7L0 907 379 K
Component: ESP ALLRAD MK25E1 0302
Revision: 00H53001
Coding: 0004482
VCID: 41DEB49AFDC4C2831C5-8014
Reset counter: 109
Mileage: 276704 km
Date: 2020.02.23
Time: 05:46:14
Count: 64
Count: 6145
Count: 128
Count: 1
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 139 B HW: 5WK 485 04
Component: Kessy 6840
Revision: 68406418 Serial number: VWX3Z0G1602456
Coding: 0000232
VCID: 2808093E7EBE13CB3BB-807C
Component: ELV XXXX
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 AD
Component: CLIMAtronic R/L 4326
Coding: 0020520
VCID: 72BC2B5688E2291B55F-8026
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V2.clb
Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
Component: J519 2000
Revision: -0004--- Serial number: --------------
Coding: 600004003B201C000000000000000000
VCID: 0058719EB64E0B8B53B-8054
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 HW: 7L0 959 655
Component: J234 36 VW8T 0250
Revision: 92011025 Serial number: 0039P001B61D
Coding: 0013110
VCID: 7AAC0376D092515B1DF-802E
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 F
Component: Lenksaeulenmodul 3501
Coding: 0010011
VCID: 42DCBB96F8C2D99B05F-8016
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 890 K HW: 7L6 920 890 K
Component: J285 KOMBI-INST. 9733
Revision: KHH06X62
Coding: 0007101
Shop #: WSC 61743 001 104857
VCID: 40D8B19EF68ECB8B13B-8014
Fault Frequency: 10
Reset counter: 109
Mileage: 276195 km
Date: 2020.01.18
Time: 15:50:32
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 890 K
Component: J533 GW-K-CAN TP20 9733
Coding: 7FE2E78B42046003
VCID: 70B8215E86AE1B0BA3B-8024
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0119
VCID: 7F5AF262CBE074732A1-5184
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 G
Component: LUFTFDR.-CDC- 3C3P1 3112
Coding: 0015521
VCID: 372ADA42A3508C33A21-5184
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L6 959 933
Component: 12 HSG 7124
Coding: 0000065
Shop #: WSC 30127 001 1048576
VCID: 7F5AF262CBE074732A1-4B3C
Subsystem 1 - Part No: 7L0 959 701 R
Component: Tuersteuergeraet FS 6302
Subsystem 2 - Part No: 7L0 959 702 R
Component: Tuersteuergeraet BF 6302
Subsystem 3 - Part No: 7L6 959 703
Component: Tuersteuergeraet HL 0202
Subsystem 4 - Part No: 7L6 959 704
Component: Tuersteuergeraet HR 0202
Subsystem 5 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
Subsystem 6 - Part No: 7L6 951 171 B
Component: Innenraumsensor 0020
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No SW: 7L6 035 456 B HW: 7L6 035 456 B
Component: 08K Audioverst. 0008
Revision: 00006000 Serial number: 00000008103370
VCID: 323CEB564822691B95F-8066
Address 55: Headlight Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 A HW: 7L6 907 357 A
Component: AFS-Steuergeraet X014
Revision: H01 Serial number:
Coding: 1288451
VCID: 392EDC7A95149A43545-806C
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l X008
Coding: 00000019
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r X008
Coding: 00000019
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No SW: 7L6 035 195 B HW: 7L6 035 195 B
Component: Radio DE2 0008
Revision: 00004000 Serial number: VWZ4Z4G1014642
Coding: 0001012
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L6 955 119 A
Component: J400__ Front Wiper 5101
Coding: 0000341
VCID: 3828D97EAE5E834BABB-806C
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 190407 020 0105
Coding: 00208933
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
Coding: 0000001
VCID: 3828D97EAE1E834BABB-806C
02564 - Trailer; Left Tail Lamps (M60)
02563 - Trailer; Right Tail Lamps (M61)
02562 - Trailer; Brake Lamps
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
End----------(Elapsed Time: 01:51, VBatt start/end: 12.3V/12.3V)-----------
