- Feb 12, 2020
- 39
- 10
- Victoria, Australia
- C?ID=370869
I bought a passat with a transmission issue. It starts and runs but the shift lever does not unlock when Bpedal is pressed.
My VIN: WVWZZZ3CZ7P046973. If I unlock the lever manually I still don't get drive or reverse. Has any1 had a similar issue before?
I intend to do the work myself so I need leads to save myself time and labour.
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 76
VIN: WVWZZZ3CZ7P046973 Mileage: 144470km-89769miles
Address 01: Engine Labels: 03G-906-018-BKP.clb
Part No SW: 03G 997 020 T HW: 03G 906 018 CE
Component: R4 2.0l PPD1.5 G 5159
Revision: --H25--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 30024 959 101054
VCID: 393A23FC70FB4D4E05-806C
005714 - Please check DTC Memory of Transmission Controller
P1652 - 008 -
Fault Status: 01101000
Reset counter: 40
Mileage: 144473 km
Date: 2020.04.16
Time: 07:46:29
RPM: 800 /min
Torque: 40.0 Nm
0.00 %
Voltage: 12.54 V
Bin. Bits: 00000001
Bin. Bits: 00000000
P1652 - 008 -
Reset counter: 40
Mileage: 144473 km
Date: 2020.04.16
Time: 07:50:37
RPM: 768 /min
Torque: 72.0 Nm
0.00 %
Voltage: 11.19 V
Bin. Bits: 00000000
Bin. Bits: 00000000
Readiness: N/A
Part No SW: 02E 300 042 S HW: 02E 927 770 AE
Component: GSG DSG 070 1127
Revision: 04507000 Serial number: 00000607260992
Shop #: WSC 00028 028 00001
VCID: 2306E194E277279E3F-8076
28775 - No Communication with Gear Selector Module
U0103 - 000 - - MIL ON
Fault Status: 11100000
Fault Frequency: 255
Reset counter: 40
Mileage: 144473 km
Date: 2020.04.16
Time: 07:44:56
00194 - Ignition Key Removal Lock
008 - Implausible Signal
Reset counter: 1
Mileage: 144473 km
Date: 2020.04.16
Time: 07:44:58
U0103 - 004 -
Reset counter: 0
Mileage: 144473 km
Date: 2020.04.16
Time: 07:45:01
00653 - Selector Lever/Auto Trans Plausibility
Reset counter: 40
Mileage: 144473 km
Date: 2020.04.16
Time: 07:49:29
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0667841377
Coding: 0015653
VCID: 322814D0AD8DBE16C4-8066
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
VCID: 679EB58456CF0BBEA3-8032
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000004316264
Coding: E0808F0700041A00000A00000F00000000085D435C0000
VCID: 302C1ED8A3818C06B2-8064
Subsystem 1 - Part No: 3C2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 260706 014 1201
Coding: 00208933
Shop #: WSC 00028
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 254
Mileage: 144473 km
Date: 2020.04.16
Time: 07:49:00
Voltage: 13.25 V
Reset counter: 254
Mileage: 144473 km
Date: 2020.04.16
Time: 07:49:00
Voltage: 13.25 V
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 16 AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3PDYSKKR
Coding: 0012598
VCID: 2E1000A0B9B59AF6A0-807A
Subsystem 1 - Serial number: 6332MSME123C756EL
Subsystem 2 - Serial number: 6342MSME123B0E5DL
Subsystem 3 - Serial number: 6351HTS6PLL6CPN2F
Subsystem 4 - Serial number: 6361HTS6VARQ8552
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00007000 Serial number: 3C5953507P
Coding: 0001111
Component: E0221 002 0010
02413 - Switch for Selector Lever Position P Lock (F319)
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 HW: 3C0 920 871
Component: KOMBIINSTRUMENT VD1 1614
Revision: X0006000 Serial number: 00000000000000
Coding: 0007705
Shop #: WSC 00921 001 1048576
VCID: 618AAB9CB8EB758E6D-8034
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3620P10126061A
Coding: FD807F0E000202000003
Shop #: WSC 30024 959 101032
VCID: 2F2E1DA4BEBF93FEAB-807A
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Subsystem 1 - Part No: 3C0 905 861 F
Component: ELV 026 0380
3C0905861F ELV 026 0380
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1124
Revision: 12006001 Serial number: 00000514168804
Coding: 0000693
VCID: 3B3639F47AC77F5E17-806E
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.136 H07 1806
VCID: 35222FCC5CE3A92EE1-8060
Component: KSG PQ46 ELV 042 0472
Coding: 00910A0001860E763004941570085F0B007800
Shop #: WSC 30024 959 88134
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1124
Revision: 12006001 Serial number: 00000508968729
Coding: 0000692
VCID: 3C343AE87FC978661E-8068
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000012
VCID: 210AEB9CF86B358E2D-8074
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 HW: 5K0 035 190
Component: Radio RCD510 041 0167
Revision: 00000001 Serial number: VWZ1Z3L5186785
Coding: 0100040004
VCID: 6288A4907DED6E9674-8036
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1113
Revision: 11005001 Serial number: 00000000425747
Coding: 0000144
VCID: 3D3237EC64D3716E29-8068
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1113
Revision: 11005001 Serial number: 00000000524430
Coding: 0000144
VCID: 3E3030E069D56A7630-806A
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 B HW: 3C0 919 283 B
Component: Parkhilfe 8-Kan 004 0011
Revision: 00004000 Serial number: 82930622903028
Coding: 0001014
VCID: 281CF6B89B51C4C66A-807C
End----------(Elapsed Time: 01:22, VBatt start/end: 14.0V/14.1V)-----------
