Results 1 to 6 of 6
Thread: Fabia III 2016 - Rear electric window retrofit problem
    Apr 2020
    Slovakia
    hello,
    i retrofited rear electric window (from mechanical to electric pulling). the rear windows work fine for me. driver motor window is also changing (from 5JA 959 811 K to 6V1 959 801 B), modified I have a complete wiring according to the diagram. and there is a problem
    coding changed according to another car with electric rear windows:
    I already have a visible motor for the driver's door (left-hand drive) in the list of units:
    the problem is that the driver's window reacts in the opposite way (if I press "up", the window goes down. if I press "down", the window goes up. I don't know where the error is. I don't have another engine to test yet. buttons I tried from another car - no change. I also tried my buttons in another car - the other car works properly ...
    is it still possible to modify the encoding somewhere? in unit 09 for FHSG DRV, despite the original cable, I do not have a description of bytes and bits. coding is the same as another car with the original engine
    full scan (errors unit 17 and 5F is from another modifiing):
    Saturday,18,April,2020,20:32:00:21987
    VCDS Version: 20.4.0.1  HEX-V2 CB: 0.4513.4
    VIN: TMBJN6NJ7GZ173417   License Plate:
    Mileage: 98956km-61488mi   Repair Order:
    Chassis Type: NJ-SK26 (6C0)
    Scan: 01 03 08 09 10 15 17 19 20 44 5F
    VIN: TMBJN6NJ7GZ173417   Mileage: 98956km-61488miles
    Address 01: Engine (J623-CJZD)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 BC    HW: 04E 907 309 AF
       Component: R4 1.2l TFS   H23 9086
       Revision: R4H23---
       Coding: 01190012232415080000
       Shop #: WSC 65048 003 104857
       ASAM Dataset: EV_ECM12TFS01104E906027BC 001009
       ROD: EV_ECM12TFS01104E906027BC.rod
       VCID: 669446AD08E2930BC9E-8032
       CAN Converter 01:
       Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
       Component: ESP9.0i       H03 0004
       Serial number: 08514048160314
       Coding: 41F5487D492A33C30918106A0058821292CC9008000DD7098F00
       Shop #: WSC 13765 031 00063
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
       VCID: 372ADBE91FC8DA83A28-8062
    Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
       Part No SW: 6V0 820 045 A    HW: 6V0 820 045 A
       Component: AC Manuell    H01 0202
       Serial number:  1603091B-1445
       Coding: 100000001000100000
       Shop #: WSC 73430 031 00063
       ROD: EV_ACManueKMMValeoPQ26_SK26.rod
       VCID: 3038E0F5FAA60DBBE32-8064
    Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-090-V1.clb
       Part No SW: 6C0 937 090 D    HW: 6C0 937 090
       Component: BCM PQ26 HiKR H10 0094
       Serial number: 006318037927
       Coding: 1C00095042158A7B43804000412F87080001D100D30A3500000000000000
       ASAM Dataset: EV_BCMA0 006002
       ROD: EV_BCMA0_006_VW26.rod
       VCID: 290E0D91D97C7C7324C-807C
       Subsystem 1 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S2Y15M09D15H00M44S58
       Coding: 00185E
       Drivers Door Control Module:
       Subsystem 2 - Part No SW: 6V1 959 801 B    HW: 6V1 959 801 B
       Component: FHSG DRV  007 0001
       Serial number: 00000000000009255270
       Coding: 011200
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 7K  H03 0048
       Revision: --------    Serial number: 39331431407392
       Coding: 0031151041
       Shop #: WSC 73430 790 00021
       ROD: EV_EPHVA18AU3700000_VW26.rod
       VCID: 3D26C9C13DF4F0D3784-8068
    Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
       Part No SW: 6C0 959 655 K    HW: 6C0 959 655 K
       Component: VW20Airbag743 002 0380
       Revision: --------    Serial number: 003TJ00313GV
       Coding: 88CCC000000000005C5400CF000800000000
       Shop #: WSC 73430 790 00063
       ROD: EV_AirbaVW20BPAVW26X.rod
       VCID: 3B22C7D923E0FEE3460-806E
       Subsystem 1 - Part No SW: -----------    HW: 410 822 503 16
       Component: SideSensor_Df  151 0800
       Serial number: 3575H000E2957E71B11N
       Subsystem 2 - Part No SW: -----------    HW: 410 822 503 16
       Component: SideSensor_Pf  151 0800
       Serial number: 3585H00162957E74138J
       Subsystem 3 - Part No SW: -----------    HW: 442 152 103 16
       Component: SideSensor_Dr  1CA 0148
       Serial number: 3517A00A31F93E220223
       Subsystem 4 - Part No SW: -----------    HW: 442 152 103 16
       Component: SideSensor_Pr  1CA 0148
       Serial number: 3527A00B31F93E33232A
       Part No SW: 6V0 920 740 A    HW: 6V0 920 740 A
       Component: KOMBI         205 1420
       Coding: 0BAD0900218000080108B6001C00000000000000
       Shop #: WSC 65517 001 104857
       ROD: EV_DashBoardVDDMQBAB_SK25.rod
       VCID: 3332EFF90BB036A39E0-8066
    16777024 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_BCME_0x23 keine Kommunikation]
                        Reset counter: 42
                        Mileage: 98482 km
                        Date: 2020.04.14
                        Time: 17:56:11
    16777051 - Databus
              [TCO_01 keine Kommunikation]
                        Reset counter: 252
                        Mileage: 98405 km
                        Date: 2020.04.12
                        Time: 14:24:28
    Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
       Part No SW: 6C0 909 901 A    HW: 6C0 937 090
       Component: GW MQB A0     H10 0094
       Revision: --------    Serial number: 006318037927
       Coding: 030100042F0A640000000000000300010001000000000000000000000000
       Shop #: WSC 73430 790 12345
       ASAM Dataset: EV_GatewA0Lear 013020
       ROD: EV_GatewA0Lear_013_SK25.rod
       VCID: 261406ADC862530B09E-8072
       Subsystem 1 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
       Component: E221__MFL-PR6  H02 0160
       Serial number: 000000000D2251200218
       Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
       Component: J367-BDM  H08 0223
       Serial number: 53079716042821739041
    Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
       Part No SW: 3G0 857 511 AG    HW: 3G0 857 511 AG
       Component: FLA           H08 0001
       Revision: AA001001
       Coding: 010100E500000000000000
       ASAM Dataset: EV_HighBeamAssisAU33X 001016
       ROD: EV_HighBeamAssisAU33X_VW37.rod
       VCID: 6D8639812D14A053884-8038
       Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
       Component: EPS_TRW_ALow  312 3232
       Serial number: CG460016
       Coding: 800700
       ASAM Dataset: EV_SteerAssisUDSTRW 016026
       ROD: EV_SteerAssisUDSTRW.rod
       Part No SW: 6V0 035 871 J    HW: 6V0 035 871 J
       Component: MU-E--US      690 8740
       Serial number: 24081800021394
       Coding: 03620200BE0000001111000401000A00AF0003D40000010004
       ASAM Dataset: EV_MUEnt4CGen2LGE 001041
       ROD: EV_MUEnt4CGen2LGE_VW32.rod
       VCID: 3E24CECD30F2EBCB61E-806A
    1543 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 252
                        Mileage: 98405 km
                        Date: 2020.04.12
                        Time: 14:23:53
                        Voltage terminal 30: 11.9 V
                        Byte_Coding_Condition-byte_0_condition: OK
                        Byte_Coding_Condition-byte_1_condition: OK
                        Byte_Coding_Condition-byte_10_condition: ERROR
                        Byte_Coding_Condition-byte_11_condition: ERROR
                        Byte_Coding_Condition-byte_12_condition: ERROR
                        Byte_Coding_Condition-byte_13_condition: ERROR
                        Byte_Coding_Condition-byte_14_condition: ERROR
                        Byte_Coding_Condition-byte_15_condition: ERROR
                        Byte_Coding_Condition-byte_16_condition: ERROR
                        Byte_Coding_Condition-byte_17_condition: ERROR
                        Byte_Coding_Condition-byte_18_condition: ERROR
                        Byte_Coding_Condition-byte_19_condition: ERROR
                        Byte_Coding_Condition-byte_2_condition: OK
                        Byte_Coding_Condition-byte_20_condition: ERROR
                        Byte_Coding_Condition-byte_21_condition: ERROR
                        Byte_Coding_Condition-byte_22_condition: ERROR
                        Byte_Coding_Condition-byte_23_condition: ERROR
                        Byte_Coding_Condition-byte_24_condition: ERROR
                        Byte_Coding_Condition-byte_25_condition: ERROR
                        Byte_Coding_Condition-byte_26_condition: ERROR
                        Byte_Coding_Condition-byte_27_condition: ERROR
                        Byte_Coding_Condition-byte_3_condition: OK
                        Byte_Coding_Condition-byte_4_condition: OK
                        Byte_Coding_Condition-byte_5_condition: OK
                        Byte_Coding_Condition-byte_6_condition: OK
                        Byte_Coding_Condition-byte_7_condition: OK
                        Byte_Coding_Condition-byte_8_condition: OK
                        Byte_Coding_Condition-byte_9_condition: OK
    1564 - Microphone 1
              B129B 13 [008] - Open Circuit
                        Reset counter: 44
                        Mileage: 98504 km
                        Date: 2020.04.15
                        Time: 05:47:47
                        Voltage terminal 30: 11.7 V
    7195 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 252
                        Mileage: 98405 km
                        Date: 2020.04.12
                        Time: 14:23:56
                        BAP-BAP_Function_ID: 00
    End----------(Elapsed Time: 00:44, VBatt start/end: 12.3V/12.3V)-----------
    thanks for any solutions and sorry for my english
    Aug 2016
    Eindhoven, NB, NL
    is 6V1 959 801 B the correct part according to ETKA for a Fabia III with 4x electric window?
    Apr 2020
    Slovakia
    Yes
    May 2016
    Wrong dataset
    Apr 2020
    Slovakia
    I probably won't change it at home via VCDS?
    A friend was watching sets for VCP and there's nothing there. ODIS will try out tonight
    Apr 2020
    Slovakia
    A friend also watched the dataset in ODIS, he didn't find anything there. Is there an alternative? Or would anyone know how to do it remotely for a small fee? I've been here briefly, I don't know exactly how it goes. I have VCDS, a friend of VCP and ODIS
    An alternative according to another forum is possible in adjusting the connection of the buttons. I haven't looked at it yet, it's supposed to change 2 resistors and it will work
