Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
Thread: Lost ABS coding on a 2012 VW Polo
  1. #31
    Jun 2019
    Algeria
    Wow..Thank you for the prompt reply...I really appreciate it..
    I will get the scan for you as soon as possible.
    Thank you so much..
  2. #32
    Jun 2019
    Algeria
    Hi Uwe..
    As requested, this is the full auto scan from my car. Kindly let me know if there is anything else needed..thank you so much.
    Monday,27,May,2019,08:28:04:00007
    VCDS Version: 18.9.0.2 (x64)
    VIN: WVWZZZ6RZAY051894   License Plate:
    Chassis Type: 6R-VW25 (6N0)
    Scan: 01 03 08 09 15 17 19 25 44 56
    VIN: WVWZZZ6RZAY051894   Mileage: 199900km-124212miles
    Address 01: Engine        Labels: 03C-906-024-BXW.lbl
       Part No SW: 03C 906 024 BR    HW: 03C 906 024 BH
       Component:       CGGB  MM4HV   4806
       Revision: --H09---    Serial number:
       Coding: 0000071
       Shop #: WSC 00000 000 163936
       VCID: 6FED65BD7D9D0B323C-513C
    28793 - No Communication with ABS Brake Control Module
                U0121 - 000 -  - Intermittent
                        Reset counter: 106
                        Mileage: 199699 km
                        Date: 2013.09.16
                        Time: 00:04:34
                        Bin. Bits: 00000000
                        Load: 0.0 %
                        Lambda: 0.0 %
                        Temperature: 95.0C
                        Absolute Pres.: 918.0 mbar
    18711 - Leak in Air Intake System
                P2279 - 000 -  - Intermittent
                        Reset counter: 104
                        Mileage: 199895 km
                        Date: 2013.10.13
                        Time: 02:38:22
                        Bin. Bits: 00000000
                        Load: 32.9 %
                        Lambda: 4.0 %
                        Speed: 2.0 km/h
                        Temperature: 61.0C
                        Absolute Pres.: 375.9 mbar
                        RPM: 708 /min
    17912 - Intake Air System
                P1504 - 000 - Leak Detected - Intermittent
                        Reset counter: 104
                        Mileage: 199895 km
                        Date: 2013.10.13
                        Time: 02:38:23
                        Bin. Bits: 00000000
                        Load: 32.9 %
                        Lambda: 4.0 %
                        Speed: 2.0 km/h
                        Temperature: 61.0C
                        RPM: 714 /min
    16885 - Vehicle Speed Sensor
                P0501 - 000 - Implausible Signal - Intermittent
                        Reset counter: 106
                        Bin. Bits: 00000000
                        Load: 0.0 %
                        Lambda: 0.0 %
                        Temperature: 31.0C
                        Absolute Pres.: 907.8 mbar
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
       Part No SW: 6R0 907 379 AD    HW: 6R0 907 379 AB
       Component: ABS8.2 front  H03 0001
       Revision: --------
       Shop #: WSC 04941 000 00000
       VCID: 000F36019703044AD5-8054
                000 -  -
                        Fault Frequency: 18
                        Reset counter: 68
                        Mileage: 199896 km
                        Date: 2013.10.15
                        Time: 21:57:42
                        Hex Value: 0x0005
                        Hex Value: 0x0000
                        Hex Value: 0x3013
                        Hex Value: 0x1499
                        Hex Value: 0x00FF
                        Hex Value: 0x007F
                        Hex Value: 0x7F00
                        Hex Value: 0x0000
    00285 - ABS Wheel Speed Sensor; Front Right (G45)
                        Fault Status: 00101100
                        Reset counter: 107
                        Mileage: 199896 km
                        Date: 2013.10.15
                        Time: 22:26:30
                        Hex Value: 0x0001
                        Hex Value: 0x0000
                        Hex Value: 0x30B1
                        Hex Value: 0x07A1
                        Hex Value: 0x00FF
                        Hex Value: 0x007F
                        Hex Value: 0x7E00
                        Hex Value: 0x0000
    03306 - Coding Not Valid
                000 -  -  - Intermittent
                        Reset counter: 107
                        Mileage: 199903 km
                        Date: 2013.10.15
                        Time: 23:39:41
                        Hex Value: 0x0001
                        Hex Value: 0x0000
                        Hex Value: 0x3027
                        Hex Value: 0x149C
                        Hex Value: 0x00FF
                        Hex Value: 0x007F
                        Hex Value: 0x7E00
                        Hex Value: 0x0000
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
       Part No SW: 6R0 820 045     HW: 6R0 820 045
       Component: Climatic       23 0500
       Revision: 00 09 23
       VCID: 6BD571AD8A85F71210-803E
    16372 - Control Module; Unspecified Internal Error
                014 - Defective
                        Fault Status: 01101110
                        Mileage: 8737 km
                        Date: 2010.10.14
                        Time: 16:17:08
    01316 - ABS Control Module
                        Fault Frequency: 6
                        Reset counter: 106
                        Mileage: 199699 km
                        Date: 2013.09.16
                        Time: 00:04:34
    00705 - Relay for Coolant Fan; Stage 1 (J279)
                        Fault Status: 00101001
                        Reset counter: 95
                        Mileage: 199699 km
                        Date: 2013.09.16
                        Time: 00:00:18
                        Fault Status: 00101101
                        Reset counter: 106
                        Mileage: 199896 km
                        Date: 2013.10.15
                        Time: 04:51:51
       Part No SW: 6R0 937 086 B    HW: 6R0 937 086 B
       Component: PQ25 BCM      H09 0025
       Revision: BD009001    Serial number: 9953A209090803
       Coding: 35B02BB808E10D00002000C03C2B0CD0F04841FF600000002000
       Shop #: WSC 124697 483 00190
       VCID: 3B7581EDBA65A792C0-806E
       Subsystem 1 - Part No SW: 6R0 959 801 H    HW: 6R0 959 801 H  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  002 0803
       Serial number: KU0-KU030.07.0911184
       Coding: 08BC30
       Subsystem 2 - Part No SW: 6R0 959 802 K    HW: 6R0 959 802 K  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  005 0803
       Serial number: KU0-KU021.09.0915450
       Coding: 08BC30
    9 Faults Found:
    00968 - Right Turn Signals
                        Fault Status: 00100110
                        Reset counter: 103
                        Mileage: 199891 km
                        Date: 2013.09.25
                        Time: 13:37:51
                        Fault Status: 00101011
                        Fault Frequency: 46
                        Reset counter: 103
                        Mileage: 199891 km
                        Date: 2013.09.25
                        Time: 00:48:13
    01758 - Bulbs for Brake Lamps
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 63
                        Mileage: 199892 km
                        Date: 2013.10.06
                        Time: 20:18:17
    03302 - Response Closing Status of Passenger's Door
                        Reset counter: 103
                        Mileage: 199892 km
                        Date: 2013.10.01
                        Time: 21:18:04
    03304 - Response Closing Status of Rear Right Door
                        Reset counter: 101
                        Mileage: 199824 km
                        Date: 2013.09.17
                        Time: 15:47:08
    03579 - Terminal 30 for Rear Window Heating
                        Fault Status: 01101011
                        Reset counter: 254
                        Mileage: 57726 km
                        Date: 2012.06.18
                        Time: 18:16:31
    00538 - Reference Voltage
                        Reset counter: 95
                        Date: 2013.09.16
                        Time: 00:00:01
                        Reset counter: 108
                        Mileage: 199892 km
                        Date: 2013.10.01
                        Time: 20:24:20
                        Fault Frequency: 36
       Part No SW: 6R0 959 655 E    HW: 6R0 959 655 E
       Component: VW10Airbag006 H09 0018
       Revision: --------    Serial number: 003DY000DF1-
       Coding: 003036
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4487FA11CF9BD86AB1-8010
    12850432 - Databus
                        Fault Frequency: 6
                        Reset counter: 106
                        Mileage: 199896 km
                        Date: 2019.05.25
                        Time: 04:51:01
    12656896 - Databus
                        Reset counter: 106
                        Mileage: 199896 km
                        Date: 2019.05.25
                        Time: 05:10:30
       Part No SW: 6R0 920 860 A    HW: 6R0 920 860 A
       Component: KOMBI         H23 0110
       Coding: 140000
       VCID: 326BACC9652F66DA13-8066
    9453842 - Oil Level Thermal Sensor
              B1041 35 [009] - Signal high time > maximum
                        Reset counter: 66
                        Mileage: 199896 km
                        Date: 2019.05.25
                        Time: 22:25:06
       Part No SW: 6N0 909 901     HW: 6R0 937 086 B
       Component: GW-K-CAN TP20 0025
       Coding: 002200
       VCID: 70EF66C1A3A314CA25-8024
                        Fault Frequency: 6
                        Reset counter: 106
                        Mileage: 199699 km
                        Date: 2013.09.16
                        Time: 00:04:33
    01304 - Radio
                        Reset counter: 234
                        Date: 2011.07.30
                        Time: 17:36:22
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H23 0110
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
    9456128 - Engine Control Module (ECM) not authorized
              B104A 00 [008] -  -
                        Fault Frequency: 6
                        Date: 2012.03.10
                        Time: 00:00:00
    9456681 - Key
              B104C 29 [008] - Implausible Signal
                        Mileage: 107387 km
                        Date: 2014.05.24
                        Time: 15:00:22
       Part No: 6R0 423 156 A
       Component: LenkhilfeTRW        V275
       Coding: 10150
       VCID: 2E53B8B9ED17423A77-807A
    Address 56: Radio
    End-------------------------(Elapsed Time: 02:21)--------------------------
  3. Likes Uwe liked this post
  4. #33
    Mar 2019
    210224C2217200B3842D24EB84D500400000
    16 Byte, define additional functions: 10 – default
    Bit 0 – Hill Hold Control (HHC) activation
    Bit 1 – Tire Pressure Monitoring (RKA) activation
    Bit 2 – XDS activation
  5. Likes Tea1925 liked this post
  6. #34
    Jun 2019
    Algeria
    Thank you so much Jacek, I will try this code as soon as possible and let you know.
    Just one question, I don't have any of these additional functions, so I should put 10 on byte 16, is that correct?
    Thanks again.
