Results 1 to 8 of 8
Thread: VW UP! 2013 Cruise Control and BCM Installation
    Verified VCDS User andyhall2171's Avatar
    Feb 2019
    Hi Guys,
    Ive just installed cruise control on my VW UP which involved installing some new stalks, changing the BCM and also installing some additional wiring. With the current lock down it definitely gave me something to take up my time!
    This is a spare car we all use in the house as a run around so being off the road while I installed wasn't a problem.
    I used a couple of websites to do my research mainly
    https://www.team-bhp.com/forum/diy-d...e-control.html
    UP Owners Forum
    I obtained all the equipment and took logs of the fault logs before and after along with snap shots of the coding so I could transfer to the new BCM that has the functionality for the cruise control.
    Its worth mentioning out of the VW range the UP being the smallest brings its challenges. I made a few mistakes and have learnt loads which is why I do it. I also now have a greater knowledge of using my vcds and have the confidence to take on some more projects! But it has left me with a few faults on the vcds, mainly in the BCM Module 09 and also engine 01 with cruise control. That being said everything is working as it should so I am guessing it is just coding?
    I did in the process break the headlamp switch and have replaced this with an identical genuine VW. But the electrics 09 does seem to show faults with the lights? The BCM is a higher spec with coming home lights and cornering lights which mine doesn't have?
    I still also need to code the key to the BCM which it wont allow me to do as it stands?
    thanks in advance for any help :thumbs:
    Here is the VCDS Log after install
    Wednesday,15,April,2020,15:48:58:56417
    VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4508.4
    VIN: WVWZZZAAZED018817   License Plate: GK63SMU AFTER CC
    Mileage: 146510km-91037mi   Repair Order:
    Chassis Type: AA-VW12 (6N0)
    Scan: 01 03 09 10 15 17 19 25 44 47 56
    VIN: WVWZZZAAZED018817   Mileage: 146510km-91037miles
    Address 01: Engine (------CHYB)       Labels:. 04C-906-020-CHY.clb
       Part No SW: 04C 906 020 AL    HW: 04C 907 309 N
       Component: 1.0l R3 MPI   H23 5972
       Revision: UOH23---
       Coding: 00110012022400000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM10MPI01104C906020AL 001005
       ROD: EV_ECM10MPI01104C906020AK_VW12.rod
       VCID: 6582400664BDA7AE91-8030
    4481 - Cruise Control Switch (E45)
              P0568 00 [039] - Implausible Signal
                        Mileage: 146511 km
                        Date: 2020.04.15
                        Time: 01:44:12
                        Engine speed: 782.50 /min
                        Normed load value: 18.4 %
                        Coolant temperature: 98 C
                        Intake air temperature: 56 C
                        Voltage terminal 30: 14.088 V
                        Cruise Control System (CCS): status-Bits 0-7: 200
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 1
                        Cruise control switch-off: reversible-Bits 0-7: 255
                        Cruise control switch-off: irreversible-Bits 0-7: 0
                        Acceleration: 0.000 m/s
    Readiness: 1110 0001
    Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
       Part No SW: 1S0 614 517 E    HW: 1S0 614 517 E
       Component: EBC 460 ESP   H08 0012
       Serial number: A00CTPU
       Coding: 11BF247189AE02F9880224F691B04080590100
       ASAM Dataset: EV_Brake1ESPMP1TRWVW120 016035
       ROD: EV_Brake1ESPMP1TRWVW120.rod
       VCID: 312AE45660F53B0EBD-8064
    Address 09: Cent. Elect. (J519)       Labels:. 1S0-937-09x-V1.clb
       Part No SW: 1S0 937 090 B    HW: 1S0 937 090 B
       Component: PQ25 BCM      H59 0563
       Revision: -8------    Serial number: --------------
       Coding: 74B82B0000010000000008042F28ACD000C0400C60020000200000400000
       VCID: 3228EB5A6DF30016C4-8066
    03431 - Activation of Left Parking Light
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 248
                        Mileage: 146511 km
                        Date: 2014.09.06
                        Time: 01:41:38
    03432 - Activation of Right Parking Light
                        Reset counter: 248
                        Mileage: 146511 km
                        Date: 2014.09.06
                        Time: 01:41:38
    03433 - Terminal 30 for Backup Lights and Adaptive Lights
                        Reset counter: 248
                        Mileage: 146511 km
                        Date: 2014.09.06
                        Time: 01:41:38
    01516 - Terminal 30; Left
                        Reset counter: 248
                        Mileage: 146511 km
                        Date: 2014.09.06
                        Time: 01:41:38
                        Reset counter: 248
                        Mileage: 146511 km
                        Date: 2014.09.06
                        Time: 01:41:40
    Address 10: Park/Steer Assist (J446)       Labels:| 1Sx-919-475.clb
       Part No SW: 1S0 919 475 A    HW: 1Q0 919 475
       Component: PARKHILFE 3K  H03 0009
       Revision: --------    Serial number: 32961520902402
       Coding: 100001
       ASAM Dataset: EV_EPHVA14VW1200000 001008
       ROD: EV_EPHVA14VW1200000.rod
       VCID: 383CD972838FEA46FA-806C
       Part No SW: 1S0 959 655 B    HW: 1S0 959 655 B
       Component: VW10Airbag00R H02 0006
       Revision: --------    Serial number: 003MY003H9JL
       Coding: 000000000000000000000000000000003052
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
       ROD: EV_AirbaVW10BPAVN750.rod
       VCID: 3D32C866ACADCF6E29-8068
       Serial number: 3495RRB401450KB8CGNI
       Serial number: 3505RRB401650KB8JI64
       Serial number: 3555NRB400250JHI698
    Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
       Part No SW: 1S0 920 960 N    HW: 1S0 920 960 N
       Component: KOMBI         H31 0205
       Revision: X0031012    Serial number: 00000000000000
       Coding: 414220
       Shop #: WSC 59897 001 1048576
       ASAM Dataset: EV_KombiUDSMM9RM10 A04752
       ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
       VCID: 3C34C562B7B7C6661E-8068
       Part No SW: 6N0 909 901     HW: 1S0 937 090 B
       Component: GW-K-CAN TP20 H59 0563
       Revision: -8------
       Coding: 001300
       VCID: 70AC2152A37F7206F2-8024
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Part No SW: 5K0 953 234     HW: 1S0 920 960 N
       Component: IMMO          H31 0205
       ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
       ROD: EV_ImmoUDSMM9RM10_VW12.rod
       VCID: 6A98333A8DA388D6BC-803E
    Address 44: Steering Assist (J792)       Labels:| 1Sx-909-144-44.clb
       Part No SW: 1S2 909 144 L    HW: 1S2 909 144 G
       Component: EPS_ECU       H45 1503
       Coding: 0001000101000000
       ASAM Dataset: EV_SteerAssisNSK 009004
       ROD: EV_SteerAssisNSK_009_VW12.rod
       Part No SW: 5K0 035 456 D    HW: 5K0 035 456 D
       Component: KonzernAmp 8K H07 6615
       Revision: --------    Serial number: EAA101A0005113
       ASAM Dataset: EV_AudioVerst8KanalSTT3 001003
       ROD: EV_AudioVerst8KanalSTT3.rod
       VCID: 2B16F63E42D951DE87-807E
       Part No SW: 1S0 035 156 J    HW: 1S0 035 156 J
       Component: Radio         H35 0063
       Revision: R0000000    Serial number: VWZAZ1N0375816
       Coding: 0001000801
    End----------(Elapsed Time: 00:34, VBatt start/end: 14.2V/14.1V)-----------
    VCDS Log Before
    Tuesday,31,March,2020,14:38:51:56417
    VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
    VIN: WVWZZZAAZED018817   License Plate: GK63SNU
    Mileage: 146500km-91030mi   Repair Order:
    VIN: WVWZZZAAZED018817   Mileage: 146500km-91030miles
       Revision: UOH23---
       Coding: 00110012020400000000
       ROD: EV_ECM10MPI01104C906020AK.rod
       VCID: 6582400664BDA76736-8030
    4629 - ECM Power Relay Load Circuit
              P068A 00 [096] - Opens Too Early
                        Mileage: 145874 km
                        Coolant temperature: 39 C
                        Intake air temperature: 12 C
                        Voltage terminal 30: 11.332 V
                        Mass flow through throttle valve: 0.0 kg/h
                        Effective_injection_duration: 0.000 ms
    4514 - Engine Speed Sensor (G28)
              P0321 00 [096] - Implausible Signal
       VCID: 312AE45660F53BC71A-8064
    Address 09: Cent. Elect. (J519)       Labels:. 1S0-937-08x-V1.clb
       Part No SW: 1S0 937 086 D    HW: 1S0 937 086 D
       Component: PQ25 BCM      H30 0561
       Revision: -A------    Serial number: --------------
       Coding: 74B82B0000010000000008042C28ACD00040400C60020000200000400000
       Shop #: WSC 00199 210 82297
       VCID: 393ADC76B085F387A2-806C
       Coding: 100001
       VCID: 383CD972838FEA8F5D-806C
    13636352 - Control module not coded
              U1013 00 [008] - -
                        Reset counter: 196
                        Mileage: 142940 km
                        Date: 2019.08.03
                        Time: 16:35:11
       VCID: 3D32C866ACADCFA78E-8068
       Coding: 414220
       VCID: 3C34C562B7B7C6AFB9-8068
       Part No SW: 6N0 909 901     HW: 1S0 937 086 D
       Component: GW-K-CAN TP20 H30 0561
       Revision: -A------
       Coding: 001300
       VCID: 70AC2152A37F72CF55-8024
       VCID: 6A98333A8DA3881F1B-803E
       ROD: EV_SteerAssisNSK_009.rod
       VCID: 2B16F63E42D9511720-807E
       Coding: 0001000801
       VCID: 3228EB5A6DF300DF63-8066
    End----(Elapsed Time: 00:33, VBatt start/end: 11.4V/11.4V. VIgn 11.4V)-----
    Aug 2016
    Eindhoven, NB, NL
    well, the BCM you installed is a BCM max. This includes lights controlled by BCM. Have a look here: https://uk-polos.net/viewtopic.php?t=71456
    Long story short, you'll need to re-wire a log of wires from light swtich to BCM and from BCM to lights.
    OR
    find a 087 BCM and put that in. That will support cruise control and is more or less plug and play.
  3. Likes Uwe, andyhall2171 liked this post
    Feb 2019
    OR
    Ok Thanks, I had to put some wiring in for the cruise and that works fine. I didn't want any other functionality but my OCD cant deal with the errors!! Is there a way I can disable them?
    Feb 2019
    @iichel just ready your link. So its sounds like the BCM I have installed was the highest spec and more than likely why I'm getting errors as terminal 30 most likely doesn't have wires to it.
    Do you think with these errors it may prevent me from coding my remote?
    Quote Originally Posted by andyhall2171 View Post
    Is the BCM new ?
    Have you deactivated Factory mode, in Adaptation, Channel 99
    Have you tried to remove Byte 12 Bit 0 And Bit 1 ?
  7. Likes andyhall2171, Uwe liked this post
    Feb 2019
    Is the BCM new ?
    It was a used bcm
    I pasted the exact same codes in the replacement as original but will have a look in the morning and feedback. Thank you..
    May 2016
    Why use 090 bcm? Just use 087 bcm. Beter no need extra rewire.
  10. #8
    Feb 2019
    Quote Originally Posted by vastechnics View Post
    ive now replaced with a 087 bcm and its still giving me problems. I think im messing something up?
    I originally fitted the new 087 bcm and got some errors on terminal 30 and 31 and the central locking wouldn't work? I removed the bcm and refitted the 090 to check if that still worked and it did with the original errors.
    I then refitted the 087 and central locking works and some errors have gone? Ironically the 09 module is now error free and I have others?? My cruise doesn't work either??
    Only positive is I can change the BCM rapid now, Im just hoping im not disturbing wires that are causing faults?
    As always its a learning exercise and thanks in advance!
    heres the latest log....
    Sunday,05,April,2020,14:24:05:56417
                    Address 09: Cent. Elect.       Labels: 1S0-937-09x-V1.clb
    Control Module Part Number: 1S0 937 090 B    HW: 1S0 937 090 B
      Component and/or Version: PQ25 BCM      H59 0563
               Software Coding: 74B82B3820010000000008042C28ACD000C0400C60020000200000400000
                Work Shop Code: WSC 31414 790 00001
    Fault Codes have been Erased
    Saturday,02,May,2020,13:32:20:56417
    Gateway Installation List:  1S0 909 901
    Chassis Type: AA-VW12 (1S0)
    VIN: WVWZZZAAZED018817   Mileage: 146580km-91080miles
       Revision: UOH23---
              P0568 00 [047] - Implausible Signal
                        Mileage: 146511 km
                        Date: 2020.04.16
                        Time: 01:44:12
                        Coolant temperature: 13 C
                        Intake air temperature: 13 C
                        Voltage terminal 30: 11.944 V
                        Cruise Control System (CCS): status-Bits 0-7: 9
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
                        Cruise control switch-off: irreversible-Bits 0-7: 255
    4482 - Function Restriction due to Implausible Message(s)
              U1112 00 [047] - -
                        Mileage: 146582 km
       Part No SW: 1S0 937 087 F    HW: 1S0 937 087 F
       Component: PQ25 BCM      H31 0583
       Revision: -9------    Serial number: --------------
       Coding: 74B82B0000010000000008042C28ACD000C0400C60020000200000400000
       VCID: 3C34C562BFB7C6661E-8068
       Coding: 100001
       Coding: 414220
       Part No SW: 1S0 909 901     HW: 1S0 937 087 F
       Component: GW-K-CAN TP20 H31 0583
       Revision: -9------
       Coding: 001300
                        Reset counter: 36
                        Mileage: 146582 km
                        Date: 2014.09.23
                        Time: 00:00:26
    0067 - Terminal 30
              U140A 00 [009] - Open Circuit
              [Failure monitoring terminal 31]
                        Voltage terminal 15: 11.640 V
                        Voltage terminal 30: 12.226 V
                        Vehicle speed: 50 km/h
                        Status: Initializing
       Coding: 0001000801
    End----------(Elapsed Time: 00:33, VBatt start/end: 14.2V/14.1V)-----------
