Results 1 to 5 of 5
Thread: 2017 NAR Jetta disable traction control (ESC)
    Mar 2020
    Is it possible to use VCDS to disable traction control/ESC on a NAR 2017 Jetta 1.8t ?
    I know some kits are available to install a button to turn off ESC but can VCDS turn off traction control (without a button or wire)?
    Thanks!
    Auto-Scan:
    Saturday,04,April,2020,23:53:03:39190
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
    VCDS Version 20.4.0.1 (x64)  HEX-V2 CB: 0.4508.4
    VIN: 3VWL17AJ2HM299863   License Plate: REFRENCE_SCAN
    Mileage: 61170km-38009mi   Repair Order:
    Chassis Type: AJ-VW36 (7E0)
    Scan: 01 02 03 04 05 08 09 13 15 17 19 25 2B 3C 44 5F 61 75
    VIN: 3VWL17AJ2HM299863   Mileage: 61170km-38009miles
    Address 01: Engine (J623-CPRA)       Labels:. 06K-907-425-V2.clb
       Part No SW: 06K 906 071 BE    HW: 06K 907 425 C
       Component: R4 1.8l TFS   H13 4889
       Revision: --H13---
       Coding: 001A0092244400175000
       Shop #: WSC 00066 790 00015
       ASAM Dataset: EV_ECM18TFS02006K906071BE 001009
       ROD: EV_ECM18TFS02006K906071BE.rod
       VCID: 6FBBD54837149D13BA8-803B
    Readiness: 1110 1101
       Part No SW: 09G 927 158 BC    HW: 09G 927 158
       Component: AISIN AG6 G3  202 3114
       ROD: EV_TCMAQ250031_002_VW26.rod
       VCID: 75B7E7205548A7C3704-8021
       Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
       Component: ESP MK60EC1   H46 0175
       Revision: 00H46001
       Coding: A14B400C492B0003851302EA921C004100F0F01A
       Shop #: WSC 00066 790 00295
       VCID: 75B7E72055C8A7C3704-8021
       Part No SW: 5K0 959 434 G    HW: 5K0 959 434
       Component: VWKESSYPQ35GP 092 1305
       Revision: 00092000    Serial number: 0418626241
       Coding: 032C0C
       Shop #: WSC 12345 123 61029
       VCID: 392F2B1039D003A354C-806D
       Part No SW: 1K8 907 044 CL    HW: 1K8 907 044 CL
       Component: Climatronic   H08 0405
       Revision: 00001K05
       Coding: 0050019002
       VCID: 7BA3F118736CF1B3060-802F
       Part No SW: 7E0 937 190 B    HW: 7E0 937 190
       Component: BCM PQ25 Max3 H81 0744
       Revision: B8081001    Serial number: 88003324160043
       Coding: 7B994B9A08AB0B000939268024C886C54BC6720E60A571F0B0A050032844
       VCID: 2B030158C30CA133D60-807F
       Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
       Component: RLS 051016 04  42  0106
       Coding: 0228DD
       Subsystem 2 - Part No SW: 6R0 959 801 DF    HW: 6R0 959 801 DF  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  022 1467
       Serial number: 14102743161111040253
       Coding: 820000
       Subsystem 3 - Part No SW: 6R0 959 802 DJ    HW: 6R0 959 802 DJ  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  022 1467
       Serial number: 14102742161107144632
       Coding: 820000
       Subsystem 4 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
       Component: J245 PS41.402  H03 0004
       Serial number: 0000FST00183XGP00000
       Coding: 180000
       Subsystem 5 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B
       Serial number: 2771623205202400AF1B
       Coding: 2C0000
       Subsystem 6 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
       Component: J388__TSG_HL  022 1467
       Serial number: 14102745161111130501
       Subsystem 7 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
       Component: J389__TSG_HR  022 1467
       Serial number: 14202744161107074551
       Part No SW: 7N0 907 572 C    HW: 7N0 907 572
       Component: ACC Bosch PQx H03 0211
       Serial number: 24111604380638
       Coding: 01005002FE0779
       ASAM Dataset: EV_ACCBEGVW361 001006
       ROD: EV_ACCBEGVW361.rod
       VCID: 3635202C08CEECDBB9E-8063
    Address 15: Airbags (J234)       Labels:* 561-959-655.clb
       Part No SW: 561 959 655     HW: 561 959 655
       Component: AirbagVW11    008 0210
       Serial number: 003RXM09RC9D
       Coding: 8CCCF000000000005000001AC20800000065
       ASAM Dataset: EV_AirbaVW11SMEVW411 001002
       ROD: EV_AirbaVW11SMEVW411.rod
       VCID: 6393A978EBDC29732E0-8037
       Serial number: IBH0000000000063C6NA
       Coding: 303146
       Subsystem 2 - Part No SW: -----------    HW: 480 002 510 16
       Serial number: 3570000000075D84DE1.
       Subsystem 3 - Part No SW: -----------    HW: 480 002 510 16
       Serial number: 3580000000094784DE1X
       Subsystem 4 - Part No SW: -----------    HW: 480 020 810 16
       Component: SideSensor_Dr  000 0148
       Serial number: 3510001B72303C93847-
       Subsystem 5 - Part No SW: -----------    HW: 480 020 810 16
       Component: SideSensor_Pr  000 0148
       Serial number: 3520001B72303C93883.
       Subsystem 6 - Part No SW: -----------    HW: 480 022 710 16
       Component: FrontSensor_D  000 0189
       Serial number: 3550001C1223536345FW
       Subsystem 7 - Part No SW: -----------    HW: 480 022 710 16
       Component: FrontSensor_P  000 0189
       Serial number: 35600019D22AFFC6626R
       Part No SW: 5C6 920 976 D    HW: 5C6 920 976 D
       Component: KOMBI         H02 1104
       Coding: 221A010000
       ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
       VCID: 333319381BBCF9F39E0-8067
       Part No SW: 7E0 909 901     HW: 7E0 937 190
       Component: GW-K-CAN TP20 H81 0744
       Revision: B8081001
       Coding: 102203
       VCID: 6889BE54127A4A2BFB2-803D
       Component: IMMO          H02 1104
       Coding: 000007
       Shop #: WSC 00066 790 00318
       VCID: 6A8DC45C0CF6783BED6-803F
       Revision: 00000000    Serial number: 16000164262007
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X_VW31.rod
       VCID: 313F1330E1A0CBE3ECC-8065
       Serial number: 0419928869
       Coding: 01011101
       ROD: EV_HREntryHella_VW32.rod
       VCID: 3C21320436E2368B4FA-8069
       Component: HRE_Slave  H12 0071
       Serial number: 0417102021
       Coding: 010111
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 306    3501
       Revision: 00H22000
       Shop #: WSC 02069 000 90108
       VCID: 392F2B10355003A354C-806D
       Part No SW: 5C0 035 684 B    HW: 5C0 035 684 B
       Component: MU-S-NS-US    H31 0359
       Serial number: VWZAZ2S0626354
       Coding: 02630102BE00000051220001001808009F0100D400200105C6
       ROD: EV_MUStd4CTSAT_VW32.rod
       VCID: 2411EA64AE526E4B17A-8071
       Subsystem 1 - Part No SW: 3G0 919 866 BB    HW: -----------
       Component: NAR 2017  --- 0525
       Part No SW: 7E0 907 534     HW: 7E0 937 190
       Component: Batt.regelung H81 0744
       Coding: 01240859
       Shop #: WSC 45359 001 1048576
       Part No SW: 561 035 285 A    HW: 561 035 285 A
       Component: OCULowUSA     020 0160
       Serial number: 000003554140557
       Coding: 02630102C24232107F1606000000
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_OCULow 002010
       ROD: EV_OCULow_002.rod
       VCID: 1471BAA47EF21ECBE7A-8041
    End----------(Elapsed Time: 01:39, VBatt start/end: 13.9V/13.9V)-----------
    Dec 2016
    DE
    Uhm, I don't think this is possible. There are tweaks to disable the ESC upon long-pressing the according button. But I don't see any way to disable the ESC without said button.
  3. Likes Uwe, gokarty liked this post
    Dallas (McKinney) ,TX ,USA
    I hope this can help you :
    https://www.youtube.com/watch?v=xOtEbmhnT94
    Immobilizer/ECU
    /Cluster Programing (Used or NEW)
    email: marinmm2001@gmail.com , info@advancedcarelectronics.com
    https://www.advancedcarelectronics.com/
  5. Likes Uwe, Dana liked this post
    Mar 2020
    Jetta,97
    Thanks for the video however disabling ESC via the gas pedal only allows you to drive a few feet before it reengages. According to some sources online, VW gives that "feature" so that you can disable traction control if you're stuck in snow but it automatically re-enables after 5 feet of movement
    I was looking more for a longer lasting solution (without a traction control button retrofit)
    However, thanks for the help!
    Regards,
    gokarty
    Mar 2020
    TBAx,
    There are videos online that show recoding the ABS control unit when retrofitting the traction control button. Is it possible that there could be a coding that allows for traction control to be disabled?
    Some people are indicating that pulling the ABS fuse is an option but that's not what I would want to drive around with
