POLO 6R RETROFIT MULTIFUNCTION STEERING WHEEL
jettabill
Pirate
Walking the Plank
Sparti, Greece
LP/IP
Hey guys, I have a Polo 6R TDI blue motion with BCM:6R0 937 088F.I have programmed BiXenon and cruise control on this BCM and it works.I have putted a multifunction steering wheel from Polo GTi,but I haven't achieved to make it work right...On the left side the only button's that work are volume up, volume down and pause.On the right side none of the buttons work.Also the red leds work to both sides. Is this module the ideal to program it or not?Let me know if has someone done this particular retrofit.... Thanks....
jettabill
Pirate
Walking the Plank
Sparti, Greece
LP/IP
I did. Do you have an autoscan?
Yes I do....this is my long code of module:24-B0-2B-BF-08-A1-00-00-08-38-0E-91-6E-6B-0C-D0-FF-C0-67-CF-7E-85-10-41-20-00-00-00-00-00. Which byte-s do you think I have to change? Is there anything else that I have to change? extra wires maybe? Thanks for your interest!
iichel
Netherlands, eastern part
C?ID=284912
That's not an autoscan. Please post one. See below how to post one.
jettabill
Pirate
Walking the Plank
Sparti, Greece
LP/IP
Removed.  Data from a clone/pirate copy of VCDS is not acceptable here.
jettabill
Pirate
Walking the Plank
Sparti, Greece
LP/IP
Do you mean that I have an old version?Maybe I can find a newer one....is that necessary?
Jacek
Poland
C?ID=360566
Oh Jack Sparrow?:dzięki:
jettabill
Pirate
Walking the Plank
Sparti, Greece
LP/IP
ok guys....just give me some time....yes my vcds is old and I was using it just to delete some error's...
PetrolDave
Westbury, UK
C?ID=1423
yes my vcds is old
8 YEARS old is silly, especially as updates to owners of genuine Ross-Tech cables are free for as long as your own the cable - so there really is no good reason to not keep your VCDS updated :popcorn:
jettabill
Pirate
Walking the Plank
Sparti, Greece
LP/IP
Hi again....a friend of mine helped me and this is auto scan of a newer version.Can we do something with it?
Nope. That's still not from a legitimate VCDS system.
