VW TRANSPORTER T5 NEED SECURITY ACCESS CODE FOR AUX HEATER SETTINGS CHANGE
invisiblee
New Member
HC739240 (NRRT)
Monday,13,April,2020,19:20:42:18239
VCDS Version: 19.6.2.0
VIN: WV2ZZZ7HZCH124468   License Plate: AG12KHB
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 18 19 25 56
Address 01: Engine (J623-CAAA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CB    HW: 03L 907 309 K
   Component: R4 2,0L EDC   X43 9116
   Revision: 26X43---    Serial number: 00000000000000
   Coding: 0111401A230400080000
   Shop #: WSC 26214 051 00000
   ASAM Dataset: EV_ECM20TDI01103L906022CB 002012
   ROD: EV_ECM20TDI01103L906022CB_002.rod
   VCID: 67DA7F379E2AEB7706-8032
5172 - Boost Pressure Regulation
          P0234 00 [096] - Limit Exceeded (Overboost Condition)
                    Mileage: 73697 km
                    Date: 2089.14.07
                    Time: 05:02:32
                    Engine speed: 3423.00 /min
                    Normed load value: 99.6 %
                    Vehicle speed: 104 km/h
                    Coolant temperature: 94 °C
                    Intake air temperature: 57 °C
                    Voltage terminal 30: 14.380 V
                    Charge air pressure specified value: 2398 hPa
                    Charge air pressure: actual value: 2743.2 hPa
                    Air mass: actual value (mg/stroke): 1290.4 mg/stroke
                    Air cleaner degree of soiling: 0.56 %
                    Throttle valve adapter: actual value: 99.79 %
                    Charge Pressure Actuator: acknowledgment: 23.97 %
                    Mean injection quantity: 73.73 mg/stroke
9531 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0105 00 [032] - Malfunction
                    Mileage: 73375 km
                    Time: 00:00:00
                    Coolant temperature: 15 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 11.980 V
                    Unlearning counter according OBD: 25
                    Charge air pressure: actual value: 1015.0 hPa
                    Intake air pressure sensor after air cleaner: raw value: 1150 hPa
                    Engine status: COENG_STANDBY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 J    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0109
   Revision: 00H43001
   Coding: 108724AD09A6089924A690776A6610
   Shop #: WSC 02736 790 49152
   VCID: 397EE94FB01EAD87A0-806C
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 7E5 907 047 BB    HW: 7E5 907 047 BB
   Component: Climatic-T5   H19 0404
   Revision: 00001009
   Coding: 0000000002
   Shop #: WSC 02736 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 70E8146BABE42CCF57-8024
   Part No SW: 7H0 937 086 H    HW: 7H0 937 086
   Component: BCM T5GP M++4 H47 0254
   Revision: BM047001    Serial number: 0428 077120225
   Coding: A8A0393A0E212013000808102C2B8C940000430F60060000300000000000
   Shop #: WSC 02736 790 12345
   VCID: 3878EC4B8B14B48F5F-806C
03303 - Response Closing Status of Rear Left Door
                    Fault Frequency: 39
                    Reset counter: 185
                    Mileage: 68757 km
                    Date: 2021.14.02
                    Time: 04:02:46
03304 - Response Closing Status of Rear Right Door
                    Fault Frequency: 208
                    Reset counter: 181
                    Mileage: 68471 km
                    Date: 2020.14.27
                    Time: 09:40:32
00447 - Function Limitation due to Over-Voltage
                    Fault Status: 00100001
                    Reset counter: 171
Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
   Part No SW: 7E0 919 475 D    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361206900766
   Coding: 108001
   ASAM Dataset: EV_VW75XParkAssis4K A01006
   ROD: EV_VW75XParkAssis4K_A01.rod
   VCID: 3362DB679A7257D76A-8066
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag003 H07 0013
   Revision: --------    Serial number: 003HL00B402F
   Coding: 000000000000000000000000000000003033
   Shop #: WSC 02734 790 50316
   VCID: 3566E57F940649E744-8060
Address 17: Instruments (J285)       Labels:. 5K0-920-xxx-17.clb
   Part No SW: 7E0 920 860 E    HW: 7E0 920 860 E
   Component: KOMBI         H04 0305
   Coding: 160001
   ASAM Dataset: EV_Kombi_cÿ_VDD_RM09 A04113
   ROD: N/A
   VCID: 2A5CC6034DB8161FD9-807E
No ASAM data for: "EV_Kombi_cÿ_VDD_RM09" (VW36 *)
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 B
   Component: J737__Standheizung  0605
   Revision: 00085000    Serial number: 09019275F00000
   Coding: 0000031
   Shop #: WSC 02737 790 00000
   VCID: 2440283BE79CC06FE3-8070
01414 - Combustion-Air Blower (V6)
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 12
                    Mileage: 67373 km
                    Date: 2019.14.29
                    Time: 04:44:44
                        Start
                    Temperature: 26.0°C
                    Voltage: 14.21 V
                    Temperature: 3.0°C
02251 - Heater Unit Locked
                    Mileage: 68366 km
                    Date: 2020.14.25
                    Time: 04:54:27
                        Malfunction
                    Temperature: 32.0°C
                    Voltage: 14.28 V
                    Temperature: 3.0°C
   Part No SW: 6N0 909 901     HW: 7H0 937 086
   Component: GW-K-CAN TP20 H47 0254
   Revision: BM047001
   Coding: 042200
   VCID: 70E8146BA3E42CCF57-8024
   Component: IMMO          H04 0305
   VCID: 6ADC06038D38D61F19-803E
   Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
   Component: Radio RCD310  042 0082
   Revision: 01000001    Serial number: VWZ1Z2M4068428
   Coding: 05000200020014
   Shop #: WSC 02734 790 00000
   VCID: 3362DB67927257D76A-8066
00856 - Radio Antenna
                    Reset counter: 237
                    Mileage: 68471 km
                    Date: 2020.14.27
                    Time: 09:12:30
End-------------------------(Elapsed Time: 02:24)--------------------------
NEtech
C?ID=56995
No you don't need an Security Access.
Adaptation, Channel 03
New Value: 1 > [Test] > [Save]
But you need to fix the error, or it just lock again.
invisiblee
New Member
HC739240 (NRRT)
Thanks will check on the weekend 👍
