I brought my car to Firestone to switch from my winter tires to summer sport tires and for an alignment. When they handed me the keys back they told me there were some fault codes but that the car was drivable. Upon starting the car, a barrage of malfunction messages appeared: Distance warning, Stabilization Control Malfunction, Audi Adaptive Light Malfunction, Sport Differential Malfunction, Suspension Malfunction, and several steering and safety system related messages. I ran VCDS and saved the results then cleared DTCs hoping the simplest solution would remedy the problem. Unfortunately the malfunction messages persist. Help! Am I stuck with going to my Audi service shop for them to resolved the problem?
Any assistance would be appreciated! Thanks, Mike
HERE'S THE FULL SCAN RESULTS:
Monday,13,April,2020,12:50:32:35744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 19.6.2.0 (x64)
VIN: WAUC4CF53JA016644 License Plate:
Gateway Installation List: 8W8 907 468 E
13-Auto Dist. Reg -- Status: Malfunction 0110
1B-Active Steering -- Status: Malfunction 0110
29-Left Light -- Status: INTERFACE NOT COMPATIBLE
32-Differential Locks -- Status: Cannot be reached 0100
39-Right Light -- Status: INTERFACE NOT COMPATIBLE
74-Chassis Control -- Status: Malfunction 0010
8B-Adaptive Cruise 2 -- Status: Malfunction 0110
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0110
A9-Struct. Borne Sound -- Status: Cannot be reached 0100
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
D6-Light Ctrl Left 2 -- Status: INTERFACE NOT COMPATIBLE
D7-Light Ctrl Right 2 -- Status: INTERFACE NOT COMPATIBLE
Monday,13,April,2020,12:37:01:35744
VIN: WAUC4CF53JA016644 License Plate: UPTIME
Mileage: 36959km-22965mi Repair Order:
Chassis Type F5-AU49 (8W8)
Scan: 01 02 03 08 09 13 15 16 17 19 1B 29 32 36 39 3C 42 44 46 47
52 5F 6C 6D 74 81 82 8B A5 A9 BB BC CA CF D6 D7
VIN: WAUC4CF53JA016644 Mileage: 36959km-22965miles
1B-Active Steering -- Status: Malfunction 0010
32-Differential Locks -- Status: Malfunction 0010
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CWGD) Labels:. 07K-907-309-V1.clb
Part No SW: 8W0 907 559 H HW: 06M 907 309 D
Component: V6 3.0l TFSI H21 0005
Revision: B2H21000
Coding: 1A2A00322366010E34280000000000000000000000000000
Shop #: WSC 06334 790 00001
ASAM Dataset: EV_ECM30TFS0118W0907559H 001006
ROD: EV_ECM30TFS0118W0907559H.rod
VCID: 4A9BBF8EED34A91F39-801F
17158 - Databus
U1123 00 [047] - Received Error Message
Mileage: 36954 km
Date: 2020.04.13
Time: 11:26:33
Engine speed: 793.00 /min
Normed load value: 1.6 %
Coolant temperature: 101 °C
Intake air temperature: 53 °C
Voltage terminal 30: 11.940 V
Drivetrain coordinator: brake fault status-Bits 0-7: 4
Drivetrain coordinator: brake function status-Bits 0-7: 0
Drivetrain coordinator: brake function status-Bits 0-7: 32
Acceleration: 0.000 m/s²
Readiness: 0110 0101
Address 02: Auto Trans (J217) Labels:* Redir Fail!
Part No SW: 8W0 927 158 C HW: 0D5 927 156 H
Component: 0D5 30TSIUSA H05 1003
Revision: --H05---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011.rod
VCID: 428B97AED504715FF1-8017
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PRE-V1.clb
Part No SW: 8W0 907 379 M HW: 8W0 907 379 D
Component: ESP9 Premium H13 0767
Coding: 1CAA149A30A30A9C11A44895408158A2E4259A38280C508812021A4527A459
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: 4FADAE9A16568C376E-801B
12851462 - Implausible Data Received from Steering Effort Control Module
U0419 00 [175] - -
Mileage: 36954 km
Date: 2020.04.13
Time: 11:14:53
7B 00 82 00 C2 24 00 00 00 00
Unlearning counter according OBD-OBD unlearning counter: 28
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H55 0205
Coding: 1608050D5544010D10020100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 448791B6CF107F6FC3-8011
Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A
Component: J126 FLuftV H08 0003
Serial number: 00000000000001603260
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0006
Serial number: 16915CA880PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07500363E0691CCD050D511918AC9CB9110B3D040000000000000000200016010A69012B825709
VCID: 020B57AE9584B15FB1-8057
Subsystem 1 - Part No SW: 8W6 955 119 HW: 8W6 955 119 Labels: 1KX-955-119.CLB
Component: 494 LL 050417 036 0471
Serial number: 00000001704030303602
Coding: 5FC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 20455999X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 T HW: 4M0 941 531 T
Component: E1 - LDS H06 0008
Serial number: 24 02 2017 00793706
Subsystem 4 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H04 0050
Serial number: 0000009600335Z0CQ602
Coding: 350000
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20170427095627 00273
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE123031723610109
Interior Light Module:
Subsystem 7 - Part No SW: 8W0 947 135 CS HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: Q00291848
Subsystem 8 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2617000031920006
Subsystem 9 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J873 MKS_FSv H03 0033
Serial number: 7008174235B171434596
Coding: BF0500
Subsystem 10 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J872 MKS_BFSv H03 0033
Serial number: 7008174235B171433231
Coding: B30500
131945 - Databus
Fault Frequency: 15
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:03
average_Voltage_terminals: 12.30 V
Outside air temperature sensor-Resistance: 0.00 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 14.50 °C
interior_temperature: 22.50 °C
Vehicle speed: 0.00 km/h
196758 - Databus
Fault Frequency: 13
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:04
196761 - Databus
Fault Frequency: 13
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:04
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 8W0 907 561 C HW: 8W0 907 561
Component: LRR4 H10 0330
Coding: B4779FF258FFEC05757A61A1
ASAM Dataset: EV_ACCBOSCHAU49X 003022
ROD: EV_ACCBOSCHAU49X.rod
VCID: 3E73E35EA1FC15BF95-806B
9 Faults Found:
2179 - Databus
U1122 00 [009] - Implausible Message
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:18:19
Control Module temperature: 37 °C
Voltage terminal 15: 11.8 V
Status_ACC_System: ACC_irreversible error
2106 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:18:18
0852 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:07
Control Module temperature: 36 °C
Voltage terminal 15: 12.3 V
2101 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:07
2153 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:07
2115 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:07
1392 - Databus
Fault Frequency: 7
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:07
0800 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:07
2068 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:07
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 J HW: 8W0 959 655 J
Component: Airbag10.44 H09 0104
Serial number: 003US0006CPI
Coding: BFCCF0C000800000A0000033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005015
ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
VCID: 50AFADE60B6893CF77-8005
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2033
Serial number: 8W0857705G0149R00679
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2033
Serial number: 8W0857706J0144R01614
Coding: 80000D
Occupant Detection:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J170007BBLG0A
Subsystem 4 - Part No SW: ----------- HW: 442 061 305 17
Serial number: 3577Y009F2414141236M
Subsystem 5 - Part No SW: ----------- HW: 442 061 305 17
Serial number: 3587Y009F2414143218P
Subsystem 6 - Part No SW: ----------- HW: 442 0B1 305 17
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700A52674E13E09C
Subsystem 7 - Part No SW: ----------- HW: 442 0B1 305 17
Serial number: 35277009B2674E142334
Subsystem 8 - Part No SW: ----------- HW: 442 0C1 105 17
Component: FrontSensor_D 1C5 014A
Serial number: 3557500AB22BF493612F
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 442 0C1 105 17
Component: FrontSensor_P 1C5 014A
Serial number: 3567500AB22BF495909R
6 Faults Found:
9682162 - Multiple collision brake
B13BC F2 [137] - No function
Reset counter: 39
Mileage: 36952 km
Date: 2020.04.13
Time: 10:39:04
1061893 - Databus
Fault Frequency: 14
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:15
1060613 - Databus
Fault Frequency: 13
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:15
1060614 - Databus
Fault Frequency: 13
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:15
1060615 - Databus
Fault Frequency: 13
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:15
1060617 - Databus
Fault Frequency: 13
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:15
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 GG HW: 4M0 907 129 GG
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 7BF52A4AF26EC097F2-802F
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 890 D HW: 8W5 920 890 D
Component: FBenUSA H18 0371
Coding: 09CF49CB7CA8CF0502B3E9601800400008000000
ASAM Dataset: EV_DashBoardAU736 001027
Part No SW: 8W8 907 468 E HW: 8W8 907 468 E
Component: Gateway H42 0116
Revision: 6D020002 Serial number: 0286D045917531
Coding: 03010001000006405407000000590010FC980007920000000175078E10000000
ASAM Dataset: EV_CGateCONTIAU491 003092
ROD: EV_CGateCONTIAU491_003_AU49.rod
VCID: 4E93B39E115C853F65-801B
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20170526005031 20075
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 4775024004
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8W0 907 144 E HW: 8W0 907 144 C
Component: SCU_MLBevo H03 0706
Coding: 40
ASAM Dataset: EV_SCUZFLSAU49X 002014
ROD: EV_SCUZFLSAU49X_002.rod
VCID: 3D71E452ACFA0EA78C-8069
18432 - Control Module for Active Steering
C115C 54 [009] - Missing Calibration / Basic Setting
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:20
Address 29: Left Light
Interface not compatible.
Address 32: Differential Locks (J187) Labels: None
Part No SW: 8W0 907 163 HW: 8W0 907 163
Component: QSP QCU Gen2 H07 0040
Revision: 5WK12700 Serial number: 605721701252007
Coding: 0001
ASAM Dataset: EV_TVDCQSP22 001007
ROD: EV_TVDCQSP22.rod
VCID: 79F93042F852F287E0-802D
33263 - Databus
Fault Frequency: 12
Reset counter: 79
Mileage: 36954 km
Date: 2020.04.13
Time: 11:26:32
Active Backup Function: TEMPORARY SHUTDOWN 20
Status of QSP: Temp_Shutdown
Program Counter: 00 00 00 00
Reset Fault Code: SCM_E_NONE
Number of resets: 0
Active fault: SCM_E_NONE
Active extended fault: SCM_E_EXTENT_NONE
SCM_E_PFM_NOK: inactive
SCM_E_ASIL_RAM_PROT: inactive
SCM_E_ASIL_RAM_DEFECT: inactive
SCM_E_ASIL_ROM: inactive
SCM_E_MC_SUPPLIES: inactive
SCM_E_HW_TSBC_RST_UNLIMITED: inactive
SCM_E_MPT_AUDI: inactive
SCM_E_BSW: inactive
SCM_E_TRAP_X2: inactive
SCM_E_TRAP_X3: inactive
SCM_E_TRAP_NMI: inactive
SCM_E_TRAP_ECC_FLASH: inactive
SCM_E_TRAP_UNKNOWN: inactive
SCM_E_PCP: inactive
SCM_E_HW_MU_RST: inactive
SCM_E_OS_TASK_NOK: inactive
SCM_E_HW_BIST: inactive
SCM_E_HW_MU_CFG: inactive
SCM_E_HW_MU_INVALID_QUESTION: inactive
SCM_E_HW_MU_WRONG_BEHAVIOR: inactive
SCM_E_INT_RST: inactive
SCM_E_HW_TSBC_RST: inactive
SCM_E_LVL2: inactive
SCM_E_TRAP_X1: inactive
Reserved: inactive
SCM_E_SW_RESTART: inactive
SCM_E_SOPC: inactive
SCM_E_VSOUTx: inactive
SCM_E_ADC_REF: inactive
SCM_E_ADC_STUCK_AT__MULTIPLEX: inactive
SCM_E_VDD5: inactive
SCM_E_HW_DEV_ID: inactive
Occurrence_counter_over_length_of_life: 22
FR_ESP_VL_VR_HL_HR_FR_QBit: 0
Front left wheel speed: 0.0 km/h
Front right wheel speed: 0.0 km/h
Left rear wheel speed: 0.0 km/h
Right rear wheel speed: 0.0 km/h
State EFP: 5
FR_FDR_TV_SollRadDiff_Moment: 0.0 Nm
FR_KBI_Standzeit_02: 173 s
Engine speed: 1159.50 /min
Lateral acceleration sensor 1: -0.04000 m/s²
Lateral acceleration sensor 1: status: 0
Lateral acceleration sensor 2: -0.02000 m/s²
Lateral acceleration sensor 2: status: 0
FR_KBI_Reifenumfang: 2003 mm
FR_Motor_Code_01: 2
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M1 959 760 HW: 4M1 959 760
Component: MEM-FS 008 0031
Serial number: 00000259079390
Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
VCID: 76E33B7EC94C9DFF8D-8023
Address 39: Right Light
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 D HW: 4M0 907 566
Component: MRR1Rear H18 0410
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
ROD: EV_RearRadarS1BoschAU736.rod
VCID: 3663FB7E89CCDDFF4D-8063
1192224 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:27
Control Module temperature: 41 °C
Voltage terminal 30: 12.20 V
Terminal 15 status: On
Voltage terminal 15: Measured value not available
1192210 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:27
267010 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:27
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 H HW: 4M0 959 793 F
Component: TSG FS 005 0125
Serial number: 0000260007158
Coding: 005D5B625E001080000104B2
VCID: 438592AACA1E7857FA-8017
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 8W0 909 144 G HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0409
Coding: 85008380008080
ASAM Dataset: EV_EPSZFAU49X 003018
ROD: EV_EPSZFAU49X_003.rod
VCID: 418998A2D0026A47E8-8015
26112 - Databus
Fault Frequency: 10
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:34
Expanded ambient data 1-Engine running: Engine_not_running
Expanded ambient data 1-Supply voltage: 0.00 V
Expanded ambient data 1-Temperature: -70 °C
Expanded ambient data 1-System status: 4
Expanded ambient data 1: 00
Expanded ambient data 1-driving_direction: 0
Expanded ambient data 1-KFA: 0
Expanded ambient data 1-KFC: 102
Expanded ambient data 1-Ready_To_Drive_Bit: 0
Expanded ambient data 1-StartStop Info: 0
Expanded ambient data 1-Steering_Angle_Calculated: 0 °
Expanded ambient data 1-Steering_Angle_Calculated_Sign: 0
Expanded ambient data 1-Steering_torque: 0.00 Nm
Expanded ambient data 1-Steering_Torque_Sign: 1
Expanded ambient data 14-KFA_FAST_RESET: 0
Expanded ambient data 14-KFC_FAST_RESET: 0
Expanded ambient data 14-Switched_voltage_terminal_30_unfiltered: 12.23 V
Expanded ambient data 14-Voltage_terminal_30_unfiltered: 12.39 V
17664 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:34
Expanded ambient data 1-KFC: 69
Address 46: Central Conv.
Address 47: Sound System (J525) Labels:* None
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAHJA01L3XH
Coding: 0194030800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI.rod
Part No SW: 4M0 959 792 H HW: 4M0 959 792 F
Component: TSG BFS 005 0125
Serial number: 0000259889911
Coding: 005D5B225E001080000104B0
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 880 A HW: 8W5 035 880
Component: MU-P-LNS-US 034 1118
Serial number: A798E0HB032395
Coding: 019453020000000053220002041A00102F0012E501700904BE
Subsystem 1 - Part No SW: V03 959 801 PS HW: -----------
Component: NAR 2018 --- 0063
Subsystem 2 - Part No SW: 8W1 919 605 HW: 8W1 919 605
Component: DU High AU49x H32 0160
Serial number: TPO00124041700820201
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK127041700020808
Component: Gracenote2 --- 3012
B11CF 53 [009] - Deactivated
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:26:51
Voltage terminal 30: 14.8 V
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4M0 907 428 E HW: 4M0 907 428
Component: Areaview 2 H13 0315
Serial number: C854607JG017333
Coding: 02940302BA0FA10008404000
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
VCID: 3467C1769FB0CFEF73-8061
13705996 - Databus
Reset counter: 39
Mileage: 36959 km
Date: 2020.04.13
Time: 12:26:45
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: 31391870800000
Coding: 0630
VCID: 489F8586F3385B0F2F-801D
Address 74: Chassis Control
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 F HW: 4M1 713 041 F
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 20170529000543
ROD: EV_GSMWaehlZFAU736.rod
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 8W6 919 617 HW: 8W6 919 617
Component: HeadUpDisplay H09 1640
Coding: 4F01E0
ASAM Dataset: EV_HudNSEIKAU736 001017
ROD: EV_HudNSEIKAU736.rod
VCID: 06034BBEB9AC8D7F9D-8053
Address 8B: Adaptive Cruise 2 (J850) Labels: None
Part No SW: 8W0 907 541 C HW: 8W0 907 541
ASAM Dataset: EV_ACC2BOSCHAU49X 003022
ROD: EV_ACC2BOSCHAU49X.rod
VCID: 3C77E956B7E007AFBB-8069
0852 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:51
Control Module temperature: 32 °C
Voltage terminal 15: 12.2 V
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W6 907 217 A HW: 8W6 907 217 A
Component: BVS H15 0050
Coding: 0404090300000204012023A6AD0000FCB0F0C020C020
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: 408F9DA6DB08634FE7-8015
7 Faults Found:
1123714 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:16:00
Control Module temperature: 34 °C
Voltage terminal 15: 12.20 V
1123157 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:56
Voltage terminal 15: 12.30 V
1123159 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:56
1123173 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:56
1123733 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:56
4195330 - Databus
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:15:56
4195335 - Databus
Fault Frequency: 13
Reset counter: 39
Mileage: 36954 km
Date: 2020.04.13
Time: 11:18:19
Control Module temperature: 35 °C
Voltage terminal 15: 12.00 V
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 8W0 907 159 E HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0007
Serial number: 170503201061
Part No SW: 4M0 959 795 H HW: 4M0 959 795 F
Component: TSG HFS 005 0125
Serial number: 0000259679280
Coding: 000D5B2200001080400000A0
VCID: 45818CB2C42A4667D4-8011
Address BC: Door Rear Pass
Address CA: Sunroof
Address CF: Lane Chge Asst 2
Address D6: Light Ctrl Left 2
Address D7: Light Ctrl Right 2
End-------------------------(Elapsed Time: 08:28)--------------------------
