Results 1 to 4 of 4
Thread: 2004 Touareg - KESSY module replacement
    Mar 2014
    Brighton, MI
    My KESSY module failed due to corrosion.
    I bought a good used one with matching numbers.
    Before swapping the modules: do I need to adapt the new module to the car?
    If so, link to the procedure?
    Scan from old module:
    Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
    Part No SW: 3D0 909 135 P HW: 5WK 470 25
    Component: Kessy 6610
    Revision: 66105312 Serial number: VWZ3Z0D5286731
    Coding: 0000161
    Shop #: WSC 31414 000 00000
    VCID: 326A972FAE21D0DF57-5140
    New module is 3D0 909 135 P and 5WK47025 and H12 S6610
    Dallas (McKinney) ,TX ,USA
    You want be able to adopt it just like that , Some data has to be swap manually then you would need both SKC (Pin) form Used and original one .VCDS can not do any of those .
    Immobilizer/ECU
    /Cluster Programing (Used or NEW)
    email: marinmm2001@gmail.com , info@advancedcarelectronics.com
    https://www.advancedcarelectronics.com/
  3. Likes Uwe liked this post
    Mar 2014
    Brighton, MI
    What hardware/software is needed?
    Feb 2019
    You could also read the EEPROM from the old one and transfer the data to the replacement module.
