IE 11
ch1z64
C?ID=316572
i seem to be having problems with the new vcds update 20.4 . When i try to access forum through About Vcds in app it doesn't come up ,IE 11 says not connected, have tried on 2 laptops but still same problem .even having same problem when trying to Access site from IE 11 address bar , but funnily enough site eorks on Chrome and Fiefox Browser, any idea ehy this is hsppening thanls are there bugs in new update
Mari
C?ID=150535
... simple solution, make Chrome or Firefox your default browser!
ch1z64
C?ID=316572
Can chrome be used i thought vcds doesn't qork with chrome or is that just the Chromebook
VCDS just launches your default browser with the URL of the forum. This hasn't changed with the update.
My understanding is that IE 11 is no longer supported by Microsoft.
Solution, as Mari has stated, make a different browser your default. I would recommend Firefox or Brave (Brave is a fork of Chrome with a built-in ad-blocker and minus the Google spyware), but Chrome or even Microsoft Edge should work.
ch1z64
C?ID=316572
Any reason to why my vcds crashes when i enter module 17 instrument cluster long coding helper , never did it before and i am clueless to why . Plus took ur advice and now using Brave
Any reason to why my vcds crashes when i enter module 17 instrument cluster long coding helper , never did it before and i am clueless to why.
What car? Got an Auto-Scan?
ch1z64
C?ID=316572
here you go Uwe , have popped a link in for youtube video i did off the problem i have , hope you get the just off video
, here is new autoscan
Thursday,16,April,2020,14:23:34:03294
VIN: WAUZZZ8P5AA039310   License Plate:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 37 42 44 46 52 55 56 77
VIN: WAUZZZ8P5AA039310   Mileage: 164810km-102408miles
Address 01: Engine (CDL)       Labels:. 06F-907-115-CDL.clb
   Part No SW: 8P0 907 115 AP    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: AUX7Z0I6FNN0S8
   Coding: 0103000C180F0160
   Shop #: WSC 23056 238 00000
   VCID: 005875B5F603CEEB532-8054
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
008852 - Fuel Pressure Regulator Valve (N276)
               P2294 - 004 - Open Circuit - Intermittent - MIL ON
                    Fault Status: 10100100
                    Mileage: 164810 km
                    Date: 2020.04.12
                    Time: 00:12:27
                    RPM: 260 /min
                    Load: 60.0 %
                    Temperature: 34.0°C
                    Temperature: 22.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.176 V
Readiness: 0110 0000
   Revision: 00H45001
   Coding: 1642801249250003680E01E5921900813800
   Shop #: WSC 00857 210 11996
   VCID: 005875B5FA03CEEB532-8054
01487 - System Function Test
                    Reset counter: 185
                    Mileage: 164810 km
                    Date: 2020.04.12
                    Time: 18:32:50
                    Count: 12800
                    Count: 321
                    Count: 51210
                    Count: 12079
                    Reset counter: 145
                    Mileage: 164810 km
                    Date: 2020.04.12
                    Time: 18:25:10
                    Count: 2
                    Count: 12800
                    Count: 320
                    Count: 51200
                    Count: 1
   Part No SW: 8U0 820 043 G    HW: 8U0 820 043 G
   Component: E87  Klimavoll      0210
   Revision: 00H05000    Serial number: 8U0820043G
   VCID: 3536D461F941BB43B04-8060
                    Reset counter: 183
                    Mileage: 164774 km
                    Date: 2020.04.09
                    Time: 06:07:23
                    Reset counter: 185
                    Fault Frequency: 7
                    Reset counter: 134
Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
   Part No SW: 8P0 907 063 A    HW: 8P0 907 063 A
   Component: BCM PQ35  M   104 0575
   Revision: 00104 AH
   Coding: 06000AAFB017F080207241E00100094C437E25AA315DD929E40008840040
   Shop #: WSC 00561 210 89589
   VCID: 323CEF7D042FAC7B956-8066
   Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H10 0040
   Coding: 00DD13
   Subsystem 2 - Part No: 8P0 951 177
   Component: Innenraumuebe  H04 0020
   Subsystem 4 - Part No: 1K0 907 719 C
   Component: Neigungssenso  005 0003
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 G    HW: 8P0 919 475
   Component: PARKHILFE 4K  H06 0120
   Revision: 11001001    Serial number: 93640920206918
   Coding: 000002
   Shop #: WSC 06314 123 12345
   VCID: 42DCBFBDB48F1CFB056-8016
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
   Component: Airbag AU1042 H06 0140
   Revision: --------    Serial number: 003FB002DSVH
   Coding: 303142413039303030384A55305238503053
   Shop #: WSC 06314 000 00000
   ROD: EV_Airba10AURB4.rod
   VCID: 4FFA8689775DE1939A8-801A
   Serial number: 34928RB400004F10F9D$
   Serial number: 35028RB400004F2618AK
   Serial number: 35128RB400004F10B84I
   Serial number: 35228RB400004F2618DP
   Serial number: 35547RB400004EF08A8$
   Serial number: 35647RB400004EF08A7$
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0004042
   VCID: 46D4A3AD94A720DB29E-8012
   Component: E0221           H06 0030
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
   Part No SW: 8P0 920 982 K    HW: 8P0 920 982 K
   Component: KOMBIINSTR. VDO H02 0980
   Revision: D0H02002    Serial number: 2246I002000289
   Coding: 0005428
   Shop #: WSC 00561 067 57207
   VCID: 41DEB0B1BD8907E31CC-8014
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H16 5223
   Revision:   H16       Serial number: 4120K097200630
   Coding: E9A31F06400602004101
   Shop #: WSC 80093 222 69422
   VCID: 6694432DF46700DBC9E-8032
   Part No SW: 0BR 907 554 A    HW: 0BR 907 554 A
   Component: Haldex 4Motion      3016
   Coding: 0000005
   VCID: 43D2BAB9A79515F30E0-8016
   Revision: D0H02002    Serial number: AUX7Z0I6FNN0S8
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8P0 035 193 G    HW: 8P0 035 193 G
   Component: RNS-E PU EU     H07 0220
   Revision: 0000013S    Serial number: AUZBZ7MD218544
   Coding: 0259755
   Shop #: WSC 19428 000 104857
   VCID: 3430E965F23BA24B87A-8060
02005 - Coding Pin
                    Reset counter: 145
                    Mileage: 164810 km
                    Date: 2020.04.12
                    Time: 18:25:29
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
   Part No SW: 8P0 959 801 P    HW: 8P0 959 801 P
   Component: Tuer-SG         H04 0101
   Coding: 0135932
   VCID: 48C8AD959EB336ABDB2-801C
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 234    3001
   Revision: 00H17000
   Shop #: WSC 00561 210 91540
   VCID: 313EE0710D299763ECC-8064
   Part No SW: 8P0 959 802 P    HW: 8P0 959 802 P
   Coding: 0004734
   VCID: 49CEA89185B9CFA3C4C-801C
   Part No: 8P3 907 357
   Coding: 0000013
   VCID: 7AAC075D90DF943B1D6-802E
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0259755
02005 - Coding Pin
                    Reset counter: 145
                    Mileage: 164810 km
                    Date: 2020.04.12
                    Time: 18:25:29
   Part No SW: 8P0 862 335 AA    HW: 8P0 862 335 S
   Component: FSE_256x BT     H34 0600
   Revision: 00000000    Serial number: 00000005109446
   Coding: 0011492
   VCID: 75B61461B9C1FB43704-8020
End----(Elapsed Time: 01:20, VBatt start/end: 11.6V/11.6V. VIgn 11.7V)-----
Minor point: That doesn't appear to be the instrument cluster.
We'll see if we can reproduce that.
ch1z64
C?ID=316572
I tried 17 and that seemed ok today so i tried 19 and it done that , so is that a common problem or is there something to worry about , still can't get the basic setting to reset
Santos
What are you trying to accomplish? Do you have a battery charger? your voltages are really low and may cause communication errors.
ch1z64
C?ID=316572
I am trying to work out if a new door module recoded using Eprom is causing this problem as you can see in video i can't access 19 correctly as Vcds wants to close all the time and only foes it to certain modules at certain times . Battery voltage low could be to do with Dashcam on and computer
PetrolDave
Westbury, UK
C?ID=1423
With battery voltage that low some modules will not operate correctly, you really need to attach a battery charger - and try again when the battery voltage is back within the normal range.
ch1z64
C?ID=316572
Have sorted out this issue now as i downloaded 20.4.1 and seems to work fine after first attempt , but will try more times and sre what app does
