Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: 2010 Polo ABS Off-Line
    Mar 2020
    Hi All,
    My first post on this forum. My nieces VW Polo 6R 1.2s has an issue. The red ABS light, amber steering wheel light and red exclamation symbols are lit up in the instrument cluster. Also, the speedometer does not move always at zero. The rev counter is okay and the car drives and brakes perfectly fine. I have changed the ABS module but still have the following errors after running VCDS.
    I have (in chronological order):
    (a) Firstly cleaned the fuse plate on top of the battery of any oxidation and checked all fuses
    (b) Replaced the fuse plate on top of the battery
    (c) Cleaned all the earth points (Battery negative, and the two earth points with brown wires below the airbox)
    (d) Changed the battery for a new Varta E44 Silver Dynamic 77ah
    (e) Checked for oxidation on the ABS wiring loom connector to the ABS module/controller
    (f) Checked for oxidation on the two connectors to the ECU
    (g) Checked the connector at the back of the instrument cluster
    (h) Changed the ABS control module for a second-hand part
    The first time that I experienced a problem with this car, the speedometer was working intermittently and the ABS and above warning lights were lit intermittently too. However, they are always on now when the car is used and the speedometer does not work at all.
    Can anyone help with providing any further advice please? I cannot seem to find a wiring diagram as I would like to check the power feed into the ABS module - any hints on how to fault find the wiring would be greatly appreciated!
    Sunday,05,April,2020,16:37:23:01140
    VCDS Version: 20.4.0.1 (x64)
    VIN: WVWZZZ6RZAU042526   License Plate: FV10ZVH
    Mileage: 137230km-85270mi   Repair Order: 20200405a
    Chassis Type: 6R-VW25 (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 44 56
    VIN: WVWZZZ6RZAU042526   Mileage: 137230km-85270miles
    03-ABS Brakes -- Status: Cannot be reached 1100
    Address 01: Engine (CGP)       Labels: 03E-906-033-AZQ.lbl
       Part No SW: 03E 906 023 L    HW: 03E 906 023 L
       Component: SIMOS91 1.2l 4V     4489
       Revision: --H04---    Serial number:
       Coding: 0000071
       Shop #: WSC 31414 790 31414
       VCID: 285FF51798F76FC66A-5140
    18057 - Powertrain Data Bus
                P1649 - 009 - Missing Message from ABS Controller
    Readiness: 0010 0000
    Address 03: ABS Brakes
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
       Part No SW: 6R0 820 045 H    HW: 6R0 820 045 H
       Component: Climatic       24 0660
       Revision: 00 10 24
       VCID: 3365127B92311C1ECF-8066
    01316 - ABS Control Module
                        Reset counter: 187
                        Mileage: 137231 km
                        Date: 2014.08.12
                        Time: 23:10:38
       Part No SW: 6R0 937 085 B    HW: 6R0 937 085 B
       Component: BCM PQ25 M+   H46 0207
       Revision: BB046001    Serial number: 0143 047100238
       Coding: 64B02BBF08A10048002000003D2B0C900040410F60060000200000000000
       VCID: 3A7B3F5FB55BED560C-806E
       Subsystem 1 - Part No SW: 6R0 959 802 R    HW: 6R0 959 802 R  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  006 0903
       Serial number: KU0-KU008.01.1013907
       Coding: 18BC30
       Subsystem 2 - Part No SW: 6R0 959 801 T    HW: 6R0 959 801 T  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  006 0902
       Serial number: KU0-KU021.01.1010764
       Coding: 08BC30
       Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
       Component: VW10Airbag00B H09 0018
       Revision: --------    Serial number: 003DW00CBGDE
       Coding: 003042
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 428B47BFD58BA59654-8016
       Serial number: 3572SRB40000AC149925
       Serial number: 3582SRB40000AC1919AB
       Serial number: 3516GRB402LCT8IUPRI5
       Serial number: 3526GRB40279MGGL6SI4
    12656896 - Databus
                        Reset counter: 187
                        Mileage: 137231 km
                        Date: 2020.03.21
                        Time: 23:11:16
       Part No SW: 6R0 920 960 C    HW: 6R0 920 960 C
       Component: KOMBI         H03 0207
       Coding: 440200
       Shop #: WSC 31414 790 50316
       VCID: 35612C639445022EE1-8060
    12656896 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 187
                        Mileage: 137231 km
                        Date: 2020.03.21
                        Time: 23:09:29
       Part No SW: 6N0 909 901     HW: 6R0 937 085 B
       Component: GW-K-CAN TP20 0207
       Coding: 002300
       VCID: 70EFDD77A3A76706F2-8024
                        Reset counter: 187
                        Mileage: 137231 km
                        Date: 2014.08.12
                        Time: 23:11:26
       Component: IMMO          H03 0207
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
       VCID: 6ADBCF1F8D7B9DD6BC-803E
       Part No: 6R0 423 156 B
       Coding: 11250
       Shop #: WSC 31414
       VCID: 2F6D1E0BEA1938FEAB-807A
       Part No SW: 5M0 035 156 B    HW: 5M0 035 156 B
       Component: Radio         510 0521
       Revision: R0510002    Serial number: VWZ5Z1K0260340
       Coding: 0000020002
       Shop #: WSC 00000 000 31414
       VCID: 285FF5175BF76FC66A-807C
    End-------------------------(Elapsed Time: 02:26)--------------------------
    Address 17: DTCs cleared
    Address 01: DTCs cleared
    Address 08: DTCs cleared
    Address 09: DTCs cleared
    Address 15: DTCs cleared
    Address 19: DTCs cleared
    Address 25: DTCs cleared
    Address 44: DTCs cleared
    Address 56: DTCs cleared
    Split from this thread.
    Your ABS is off-line completely. Coding isn't going to fix that.
    Where do I get a Wiring Diagram?
    How to Read Wiring Diagrams
  3. Likes Dana, anar288 liked this post
    Aug 2016
    Eindhoven, NB, NL
    https://drive.google.com/folderview?...QDKsgBD82IpwuP
    Suggest to check all positive connections including the T38/35 (terminal 15)
  5. Likes Uwe, Dana, anar288 liked this post
    United States
    When the communication issue is sorted the coding from the original unit should be accepted. Per an earlier e-mail (when the original ABS was occasionally communicating) it was:
            Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
            Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
            Revision: --------
            Coding: 230224E3216D00B2C42624E684D100801100
    6R0 907 379 AJ was revised 5 times .. so if the wiring is OK you may want to consider the possibility that the 2nd hand module may be flaky. I hope not - but we encounter that with used MK60EC1 modules often and it can make someone second guess their original diagnosis because the replacement was used with the same (old) part number.
  7. Likes anar288, Uwe, Fredrick Awuor liked this post
  8. #5
    Mar 2020
            Revision: --------
    Hi Dana, Many thanks for your email support and reply to my post. Was hoping that the abs module replacement was going to sort out the communication. Like you say, it could be that the second hand part may also be faulty. Just thought to check the power, grounds and canbus for the abs module to try narrow down further. Kind Regards, Andrew
  9. #6
    Mar 2020
    Many thanks, just downloaded the wiring diagrams that you kindly posted ��
  10. #7
    Mar 2020
    Many thanks Uwe!
  11. #8
    Aug 2016
    Eindhoven, NB, NL
    There is an ESP9.0i for the 6R. When a 9.0i is connected to 8.2i wiring (2010 has 8.2) the +15 contact and CAN wires are in a different location. Make sure you don't have this situation
    If so, change wiring or ABS module
  12. #9
    Mar 2020
    Hi iichel,
    Do you have the pinout for the abs module wiring loom connector? With power and earth pins labelled?
    Kind Regards,
    Andrew
  13. #10
    Mar 2020
    Here was my auto-scan when the ABS module was working:
    Wednesday,20,November,2019,12:42:27:01140
    VCDS Version: 19.6.2.0 (x64)
    VIN: WVWZZZ6RZBU000140   License Plate:
    VIN: WVWZZZ6RZBU000140   Mileage: 106860km-66399miles
       Component: SIMOS91 1.2l 4V     8394
       Revision: --H05---    Serial number:
       Coding: 0000071
       Shop #: WSC 00490 210 84728
       VCID: 285FF51798F76F0FCF-5122
    Readiness: N/A
       Revision: --------
       VCID: 06039BAFB523597F9D-8052
       Part No SW: 6R0 820 045 J    HW: 6R0 820 045 J
       Component: Climatic       25 0660
       Revision: 00 11 25
       VCID: 35612C639C4502E744-8060
       Part No SW: 6R0 937 086 F    HW: 6R0 937 086
       Component: BCM PQ25 M++4 H46 0221
       Revision: BD046001    Serial number: 0343 134100043
       Coding: 24B02BBF08A10000003000003D2B0CD00040410F60060000200000000000
       VCID: 3F8D4E4BAE79C8B79E-806A
       Serial number: KU0-KU005.05.1014534
       Coding: 18BC30
       Serial number: KU0-KU005.05.1012142
       Coding: 08BC30
       Subsystem 3 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
       Component: J388__TSG_HL  006 0902
       Serial number: KU0-KU010.05.1013892
       Coding: 08BC32
       Subsystem 4 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
       Component: J389__TSG_HR  006 0902
       Serial number: KU0-KU016.05.1010284
       Coding: 08BC32
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10Airbag00N H08 0020
       Revision: --------    Serial number: 003GX002KT5M
       Coding: 00304E
       VCID: 4A9B6F9FEDBB7D1F39-801E
       Serial number: 3572SRB40000B6D1325%
       Serial number: 3582SRB40000B7C099FM
       Serial number: 3515RRB40616SD5OFGTB
       Serial number: 3525RRB40616SD5O2H1F
       Part No SW: 6R0 920 960 F    HW: 6R0 920 960 F
       Component: KOMBI         H04 0304
       Coding: 440200
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
       VCID: 387F25578357FF8F5F-806C
       Part No SW: 6N0 909 901     HW: 6R0 937 086
       Component: GW-K-CAN TP20 0221
       Coding: 002300
       VCID: 70EFDD77A3A767CF57-8024
       Component: IMMO          H04 0304
       VCID: 6ADBCF1F8D7B9D1F19-803E
       Coding: 11250
       Shop #: WSC 31414
       VCID: 2F6D1E0BEA1938370E-807A
       Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
       Component: Radio RCD310  016 0049
       Revision: 01000000    Serial number: VWZ1Z2K7094338
       Coding: 0500040002
       VCID: 6BD5CA1B8A81841762-803E
    End-------------------------(Elapsed Time: 02:34)--------------------------
    The second hand part that I purchased was also 6R0 907 379 AJ and 6R0 907 379 AF H05 (does this signify that it is still 8.2?)
  14. Likes Dana liked this post
