Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: 2010 Audi Q7 3.0 TDI - P0087
    Sep 2015
    Lidingö, Sweden
    Hello all,
    I'm hoping you can help me avoid an expensive trip to the repair shop. Huge thanks in advance. Beginning yesterday, the flashing glow-plug light started coming on and putting the Q7 in limp mode. It did this for the first three consecutive trips yesterday morning. It ran fine otherwise during those trips, even though it was in limp mode, limiting me to about 80km/hr. The next three trips later that day, it ran normally, no glow plug light came on at all. One of those trips was to the auto parts store, because I knew that three of the glow plugs were already throwing error codes regularly and I had the same issue with my previous Q7. Then, last night (before I had a chance to install the glow plugs), my wife took it out, and both the check engine and the flashing glow plug light came on, so she returned home and took a different vehicle.
    Today, before even scanning for codes, I took it for a long drive to warm it up, but never drove too fast. The flashing glow plug light eventually came on again, but no check engine light. It ran remarkably smooth and well. I took it home, replaced all six glow plugs, and also, since I was working on it anyway I also replaced the fuel filter.
    The old fuel filter looked very good, the fuel inside the fuel filter canister was remarkably clean, and there was no grime or deposits in the bottom of the canister.
    I ran VCDS to collect a new log and to clear the codes. I didn't pay much attention to the codes that were coming up because the first three codes were all old glow plug codes and I thought this work would clear them. I cleared all the codes, and proceeded to take it out for the verification test drive. Within one block, the flashing glow plug light came back on again (but no check engine light). I ran the codes again, checked with the previous codes before clearing it, and saw that a low fuel pressure failure P0087 appeared in both the before and after. But at least the glow plug errors are gone.
    I've been doing a lot of research, and it seems that there are many possible culprits. Worst case scenario would be the HPFP, but as clean as the fuel filter canister was (I rechecked the filter and don't see any specs of metal at all), it didn't seem as if the HPFP was self-destructing or anything. I removed the pressure control valve from the top of the HPFP because I saw several pictures that showed metal underneath it when an HPFP fails, but it was perfectly clean inside, and surprisingly this valve already has the strainer mounted on it, so another good sign that the HPFP is probably not eating itself as I've seen in so many of the pictures online - but I understand that doesn't mean I can rule it out.
    Other possible culprits would seem to be the high pressure sensor or the fuel pump(s) in the tank. Maybe the fuel pump pressure control valve mounted on the HPFP? I don't know, but I haven't found any other examples of that being the problem.
    How should I approach this diagnostic - without a mechanical fuel pressure gauge?
    Here's the latest scan. Thanks in advance for your help!
    Thursday,09,April,2020,17:30:33:49964
    VCDS Version: 19.6.2.2 (x64)
    VIN: WAUZZZ4L3AD0#####   License Plate:
    Mileage: 158560km-98524mi   Repair Order:
    Chassis Type: 4L (4F0)
    Scan: 01 02 03 05 08 09 13 15 16 17 18 19 20 28 34 36 3C 42 46 47
              4F 52 55 56 5F 62 69 6C 6D 6F 72 76
    VIN: WAUZZZ4L3AD0#####   Mileage: 158560km-98524miles
    Address 01: Engine (CAS)       Labels:. 059-907-401-CAT1.clb
       Part No SW: 4L1 910 401 D    HW: 4L0 907 401 A
       Component: 3.0TDI EDC17A104AG  0080
       Revision: --H02---    Serial number:
       Coding: 0121002C191F0A68
       Shop #: WSC 40970 222 94360
       VCID: 2447ED83E718D36FE1-8070
                   P0087 - 003 - Too Low
                        Fault Status: 01100011
                        Mileage: 158567 km
                        Date: 2020.04.09
                        Time: 17:21:32
                        RPM: 1575 /min
                        Speed: 3.4 km/h
                        Mass Air / Rev.: 36.0 mg/str
                        Temperature: 48.6°C
                        Pressure: 795.2 bar
                        (no units): 5.0
                        Bin. Bits: 00110100
       Part No SW: 09D 927 750 KC    HW: 09D 927 750 KC
       Component: AL 750 6A           1470
       Revision: 00H78000    Serial number:
       Coding: 0000504
       Shop #: WSC 31414 790 00001
       VCID: 79F9ECF7301A7E87E2-802C
       Part No SW: 4L0 910 517 K    HW: 4L0 614 517 K
       Revision: 00H30001
       Coding: 0627841
       VCID: 326B1BDBADEC4DDF63-8066
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
       Component: FBSAUDIC6 ELV   H05 0100
       Revision: 00H05000    Serial number: 10602601405096
       Coding: 0000135
       VCID: 2541F087EC222A67F6-8070
       Subsystem 1 - Part No: 4F0 910 132 G
       Subsystem 3 - Part No: 4F0 910 220 K
       Component: FBSAUDIC6 IDG   H01 0040
       Part No SW: 4L0 910 043 C    HW: 4L0 820 043 AB
       Component: KLIMA 4 ZONEN H12 0030
       Revision: 00---017    Serial number: 00000000212367
       Coding: 040816
       VCID: 2447ED832718D36FE1-8070
       Part No SW: 4F0 910 279 R    HW: 4F0 907 279
       Component: ILM Fahrer      H25 0330
       Coding: 0033221
       VCID: 387F29F34B90A78F5D-806C
       Component: Wischer AU716   H17 0100
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
    Address 13: Auto Dist. Reg        Labels: None
       Part No SW: 4L0 910 561 A    HW: 4L0 907 561
       Component: ABSTANDSREGELUNGH06 0160
       Coding: 0031161
       VCID: 275DFA8F962E3877C4-8072
       Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
       Component: 70 AIRBAG AUDI8RH43 0230
       Revision: 04H43000    Serial number: 00399D065B3G
       Coding: 0014128
       VCID: 2E530FABB9D4693F07-807A
       Subsystem 1 - Serial number: 6332QSME623A191AH
       Subsystem 2 - Serial number: 6342QSME703A32067
       Subsystem 3 - Serial number: 6352QSME4338322CE
       Subsystem 4 - Serial number: 6362QSME623A143AH
       Subsystem 5 - Serial number: 63734SME3136050EX
       Subsystem 6 - Serial number: 63834SME2F364400-
       Component: J0527               0530
       Revision: 00H05000    Serial number: 90026092380094
       Coding: 0002052
       Part No SW: 4L0 920 931 J    HW: 4L0 920 931 J
       Component: KOMBIINSTR.   H08 0144
       Revision: 00000000    Serial number: CNN432799
       Coding: 0F5E63040C010008000000
       VCID: 326B1BDB6DEC4DDF63-8066
    Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
       Part No SW: 4L0 910 105     HW: 4L0 265 105 M
       Component: Heizgeraet      H08 0120
       Revision: 0000000E    Serial number: 00000009014264
       Coding: 0000101
       VCID: 60CFA193B3808F4FC5-8034
       Part No SW: 4F0 907 468 N    HW: 4F0 907 468 G
       Component: GW-BEM 5CAN-M H06 0035
       Revision: MB200030    Serial number: 3000M098308025
       Coding: 000303
       VCID: 3A7B33FBB59CB59FAB-806E
       Component: J367-BDM  H07 0107
       Serial number: 00000000004140159397
                        Reset counter: 110
                        Mileage: 158567 km
                        Date: 2020.04.09
                        Time: 17:03:54
                        Bin. Bits:    11111
                        Voltage: 14.60 V
                        Count: 7
                        Bin. Bits:    10011
       Part No SW: 4F0 857 511 J    HW: 4F0 857 511 G
       Revision: AA001002
       Coding: 02019064747464545425363E
       VCID: 2F6D12AF7EDE60370C-807A
       Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
       Revision: 00---010    Serial number: 00000000352325
       Coding: 0000006
       VCID: 68DFB9B35BB0F70F0D-803C
    Address 34: Level Control        Labels: 4L0-910-553.lbl
       Part No SW: 4L0 910 553 H    HW: 4L0 907 553
       Component: LUFTFDR.-CDC    H03 7870
       Revision: --H03001    Serial number: 15.1528-0123.2
       Coding: 0015520
       VCID: 2F6D12AFBEDE60370C-807A
       Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
       Component: MEM-FS        H08 0062
       Revision: AA000000    Serial number: 00001001346979
       Coding: 00581B00000011110000
       VCID: 316914D768EA76C71A-8064
       Component: J0769_SWA_MasterH01 0040
       Revision: 00H01000    Serial number: 6PZ 009 014-10
       Coding: 0010101
       Component: J0770_SWA_Slave_H01 0040
       Subsystem 3 - Serial number: 5F21.07.0900H010003C910745˙
       Subsystem 4 - Serial number: 910745˙
       Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
       Revision:             Serial number: 0000101820752
       Coding: 011F52205E40440004
       VCID: 4683570BF164C17FDF-8012
       Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
       Component: Komfortgeraet   H09 0100
       Revision: 0100 ---    Serial number: 01219373360000
       Coding: 3549361
       VCID: 356120C75C825AE746-8060
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 4L0 035 223 E    HW: 4L0 035 223 E
       Component: BOSE G3 AU716 H01 0100
       Revision: AH001500    Serial number: 00000000008395
       Coding: 0D000000
       Part No SW: 4F0 910 280     HW: 4F0 907 280 E
       Component: ILM Beifahrer   H13 0100
       Revision:             Serial number: 00000000139275
       Coding: 0011101
       VCID: 5EB39F6B89F4B9BFF7-800A
       Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
       Revision:             Serial number: 0000101847220
       VCID: 45815007CC62CA67D6-8010
                        Reset counter: 110
                        Mileage: 158567 km
                        Date: 2020.04.09
                        Time: 17:05:00
       Part No SW: 4L0 910 357 A    HW: 4L0 907 357 A
       Component: AFS 1           H01 0030
       Coding: 0000032
       VCID: 2A5B03BB853C051FDB-807E
       Component: AFS-Modul links H07 0004
       Component: AFS-Modul rechtsH07 0004
       Part No SW: 4F0 035 053 K    HW: 4F0 035 053
       Component: Radio U Basic H45 0074
       Revision: AB001007    Serial number: 341IZ097634851
       Coding: 010003010000000000
       VCID: 2541F0872C222A67F6-8070
       Part No SW: 4L0 035 670 H    HW: 4L0 035 670
       Component: H-BNT-EU      H41 0187
       Revision: --------    Serial number: 474I6097515869
       Coding: 010100060004DBEF71000715EF6300030000
       VCID: 2D5108A774D212273E-8078
       Subsystem 1 - Part No: 8R0 060 884 ED
       Component: EUR 2017  2402
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356IZ091064728
       Subsystem 3 - Part No SW: 4L0 910 609     HW: 4L0 919 611 C
       Component: E0380 Bedient  H05 0060
       Serial number: 00000001400099
       Subsystem 4 - Part No: 8R0 906 961 A
       Component: CD-Database  1293
       Revision:             Serial number: 0000101862201
       Coding: 010E50204040230004
       VCID: 43854E1FC256F457F8-8016
    Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
       Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
       Revision: 2A001001    Serial number: 00008200327685
       Coding: 0100000000000000
       Shop #: WSC 80093 222 69422
       Revision: --H03---    Serial number: 525PA8-J9940CA
       Coding: 1021001
       Part No SW: 4L0 910 945     HW: 4L0 827 851 D
       Component: ValeoHeckdeckel H29 0410
       Revision: --H29001    Serial number: 8K9827852  B
       Shop #: WSC 98765 666 38354
       VCID: 6CD7C5A34F48DB2F69-8038
       Subsystem 3 - Serial number: RD16.09.09--H29001001A0322˙
       Subsystem 4 - Serial number: 1A0322˙
       Revision: AAH05061    Serial number: 003881240-----
       Coding: 0003587
       VCID: 2643F78B9124217FFF-8072
       Component: J_245_EE16_SKB09H10 0200
       Component: J_394_EE16_SKB09H10 0200
       Component: J_392_EE16_SKB09H10 0200
       Revision:             Serial number: 0000101862200
                        Reset counter: 110
                        Mileage: 158567 km
                        Date: 2020.04.09
                        Time: 17:06:36
       Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
       Component: Parkhilfe 8-Kan H02 0100
       Revision: 00H02000    Serial number: 85130925303084
       Coding: 0231166
       VCID: 2C5705A38FC81B2F29-8078
    End-------------------------(Elapsed Time: 03:50)--------------------------
    Johnathon M. Jones
    2010 Audi Q7 TDI
    I guess I would try to see what's going on in MVB Group 020, where you should find:
    Engine Speed
    Specified Pressure
    Actual Pressure
    Pressure Control Valve duty cycle
    MVBs 018, 019, and 021 all have pressure-related info as well.
    There are also some tips here:
    http://wiki.ross-tech.com/wiki/index...1/P0087/000135
  3. Likes Jack@European_Parts, jmjq7tdi liked this post
    Sep 2015
    Lidingö, Sweden
    I've taken a brief look at the pressures in those MVB's, but not while driving around, just idling and revving the engine. In those cases, the specified pressure and actual pressure were always in sync. How should I go about getting useful information from these? I saw another post about low fuel pressure where he did some type of logging in VCDS, but I haven't tried that yet. Do I need to start logging and drive around?
    Johnathon M. Jones
    2010 Audi Q7 TDI
    Did you know you should not attempt such an approach with exception of rail isolation caps & while logging with VCDS to manage injector zones for comparison of actual PSI reported or a fuel filter changed?
    RTFB should be observed for safe testing procedures fuel system and mechanicals cross referenced to log data.
    Sep 2015
    Lidingö, Sweden
    That's what I'm concerned about - not being able to do much without any mechanical testing tools. I saw another post of yours where you posted a pic of these isolation caps. I don't even have a mechanical gauge for these kinds of pressures, so if it gets to a point where the diagnostics require that, I'm going to have to take it in to a shop. I'm hoping we can collect enough clues to narrow down the culprit.
    Johnathon M. Jones
    2010 Audi Q7 TDI
  7. Likes Dana liked this post
    Did you know caps can be installed and PSI compared in logs of rail and if DTC goes away for PSI after cleared and PSI jumps up, than you know that's the respective problem injector like leaking down now don't you?
  9. Likes Dana liked this post
  10. #7
    Quote Originally Posted by jmjq7tdi View Post
    I suspect so. No-load conditions simply don't use much fuel.
  11. Likes jmjq7tdi, Dana liked this post
  12. #8
    Sep 2015
    Lidingö, Sweden
    Okay, I hear you. We need to add the possibility of a leaky injector to the list of potential problems. Short of capping-off the supply lines for injectors, is there another way to determine if 'any' of the injectors are leaking? Since it's CR, if just one is leaking, the entire system should depressurize, right? I saw a diagnostic test where you monitor fuel pressure in VCDS after engine cutoff, and due to heat soak, it should theoretically rise a little bit. Would that same type of test apply to the 3.0 TDI?
    Also, if I had an injector that was leaking that badly, i.e. exhibiting low fuel pressure by 2k RPM's, wouldn't I see smoke out of one side from the extra fuel? At least a little bit?
    If 'any' of the injectors are leaking, is there any value in determining exactly which one, i.e. is it okay to only replace a single injector in a car with 98k miles and leave the rest alone, or should they all be removed and sent off?
    About to head out now to start logging fuel pressures.
    Johnathon M. Jones
    2010 Audi Q7 TDI
  13. #9
    Sep 2015
    Lidingö, Sweden
    When starting it this morning for the first time, it seemed to have to crank over longer than unusual, maybe 5-6 seconds instead of the normal ~2 seconds of cranking before start. Every start after that, it starts right up. There was a slight hint of smoke from the right side exhaust of the car, but it was very, very light, probably just morning condensation burning off. It really didn't seem to be excess fuel.
    So, I drove around for a while and logged 018, 019 and 020. Here's the logging info for MVB 020 at the specific point of failure. Not too surprising. When RPM's start to rise above 2000, fuel pressure can't keep up. At over 2500, the computer catches it and puts it in limp mode.
    https://www.dropbox.com/s/tu2w632um9...dData.jpg?dl=0
    Here's the graph for the entire drive. It seems that the fuel pressure generally keeps up with all demands except when RPM's go above 2000, or fuel pressure above 1250 bar.
    https://www.dropbox.com/s/16j83maqcp...Drive.jpg?dl=0
    Johnathon M. Jones
    2010 Audi Q7 TDI
  14. Likes Dana liked this post
  15. #10
    United States
    Using the gas Fuel Rail Pressure Test testing/logging method can be applied to a TDI however the failed part would need to be bad enough that you saw a complete leakdown under key on, engine off conditions. Since yours runs and just can't keep up under high RPM I'm not sure it will reveal problems. If this was a no-start or constant long-crank on startup that would be easier to spot.
  16. Likes Uwe liked this post
