Results 1 to 7 of 7
Thread: Fitting Cruise Control MK6 2010 VW Golf
    Apr 2020
    Nothing is ever as simple as it seems eh?
    I've tried to fit Crusie Control to my MK6 1.6 TDI Golf. I followed a guide online using VCDS to amend my coding on the engine and steering wheel modules and fitting a new indicator stalk. The coding seemed to be accepted no problem using the standard BCM and I had no major issues fitting the new stalk.
    Once it was all back together I cleared any fault codes and took it for a test drive. straight away on the dash, a cruise control error came up and the cruise control itself didn't function.
    I plugged back in when I got in and the fault code 00895 (cruise control switch defective) had popped up. I took the whole thing apart again and make sure I hadn't screwed something up. everything seemed fine, but the fault code is still there.
    Has anyone come across this problem before? The stalk is brand new so maybe I got a broken one? or am I making a mistake with the coding?
    Any help would be gratefully received. I've added a few photos and my Autoscan below:
    Chassis Type: 1K-VW36 (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: WVWZZZ1KZAP142332   Mileage: 203270km-126306miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 B    HW: 03L 906 023 A
       Component: 1,6l R4 CR td H23 5863
       Revision: --------    Serial number: 00000000000000
       Coding: 00114014032500080000
       Shop #: WSC 00028 028 00023
       ASAM Dataset: EV_ECM16TDI02103L906023B 001005
       ROD: EV_ECM16TDI02103L906023A_001.rod
       VCID: 2517F7E0556CDDD3004-8070
    6116 - Function Restriction due to Faults in Other Modules
              U1113 00 [047] - -
                        Mileage: 203279 km
                        Date: 2020.04.09
                        Time: 00:18:03
                        Engine speed: 832.75 /min
                        Normed load value: 15.7 %
                        Coolant temperature: 58 °C
                        Intake air temperature: 25 °C
                        Voltage terminal 30: 12.424 V
                        Environmental conditions-PV_AV_ENVD: 0.0 %
                        Environmental conditions-FRF_STATE_CRU_SWI_POS: 2
    6118 - Cruise Control Switch (E45)
              P0568 00 [036] - Implausible Signal
                        Time: 00:00:00
                        Coolant temperature: 55 °C
                        Intake air temperature: 27 °C
                        Voltage terminal 30: 12.649 V
    Readiness: 1010 0000
       Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
       Revision: 00H30001
       Coding: 133B200D092600FCC80E04E7901B0081300000
       Shop #: WSC 00028 028 00001
       VCID: 78A9EE94B2DE903B6B2-802C
       Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000000002
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 6D87CFC0CD1C2593884-8038
              B10AB F0 [009] - Too Low
                        Reset counter: 54
                        Mileage: 154521 km
                        Date: 2018.06.08
                        Time: 15:41:57
       Part No SW: 1K0 937 084 B    HW: 1K0 937 084 B
       Component: BCM PQ35  B   103 0575
       Revision: 00103 AG
       Coding: 40180A3A9025180044000080000000E443010088524D8160648000200000
       VCID: 2D070FC00D1CE593C84-8078
       Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 25021  21  0512
       Coding: 009795
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 131
                        Mileage: 203279 km
                        Date: 2014.08.31
                        Time: 00:09:32
                            Term 15 On
                        Voltage: 13.90 V
                            Term 50 Off
                        Reset counter: 131
                        Mileage: 203279 km
                        Date: 2014.08.31
                        Time: 00:09:32
                            Term 15 On
                        Voltage: 13.90 V
                            Term 50 Off
                        Reset counter: 131
                        Mileage: 203279 km
                        Date: 2014.08.31
                        Time: 00:09:46
                            Term 15 On
                        Voltage: 13.90 V
                            Term 50 Off
                        Reset counter: 131
                        Mileage: 203279 km
                        Date: 2014.08.31
                        Time: 00:09:46
                            Term 15 On
                        Voltage: 13.90 V
                            Term 50 Off
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 131
                        Mileage: 203279 km
                        Date: 2014.08.31
                        Time: 00:09:46
                            Term 15 On
                        Voltage: 13.90 V
                            Term 50 Off
       Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
       Component: AirbagVW10    037 0606
       Serial number: 003FKD04J4XP
       Coding: 00003133
       Shop #: WSC 01383 790 00063
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3B233198C3E87B23460-806E
       Serial number: 3572MSME31186350ZZZK
       Serial number: 3582MSME626F6150ZZZZ
       Serial number: 3512QSME3E22520AZZZT
       Serial number: 3522QSME1A22517DZZZX
       Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
       Component: J0527           053 0111
       Coding: 0000034
       VCID: 03538978F718C3E34E0-8056
    00895 - Cruise Control Switch (E45)
                014 - Defective
       Part No SW: 5K0 920 960 N    HW: 5K0 920 960 N
       Component: KOMBI         H04 0308
       Coding: 470B00
       VCID: 38292E94F2DE503BAB2-806C
       Component: J533  Gateway   H07 0112
       Revision:   H07 01    Serial number: 020310F2001592
       Coding: E9801F06000202000001
       VCID: 698FBBD0F57439B3E4C-803C
       Component: IMMO          H04 0308
       VCID: 6A8DC4DCFCF232ABED6-803E
       Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
       Component: Tuer-SG         009 2138
       Coding: 0000564
       VCID: 333319B8E738B3639E0-8066
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 69     3001
       Revision: 00H17000
       VCID: 313F13B01D248173ECC-8064
       Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
       Coding: 0000564
       VCID: 34311AA4E236B45B87A-8060
    Address 56: Radio
    End----------(Elapsed Time: 00:44, VBatt start/end: 14.0V/14.0V)-----------
    Tartu, Estonia
    I'm guessing not OE stalk?
    Non-oe stalks have 2 major issues. One is the slider not making contact to pcb. Other is the signal wire needs to be soldered to fit 2008+ swcm-s.
    The world is my oyster...
  3. Likes Uwe, NZDubNurd, Dana liked this post
    United States
    Your photos aren't loading. This thread should be helpful: https://forums.ross-tech.com/showthr...-Post-Pictures
  5. Likes Uwe liked this post
    Apr 2020
    I've just had a look into the stalk I bought. It could be that I haven't got the right one. I've ordered a different one from 'Meyle' who seems to be a decent brand. we'll see if it fixes it
    Cheers for the help
    Tartu, Estonia
    How can it be different?
    If it physically fits, it is correct one. Sometimes minor fixes need to be done to cheaper alternatives.
    Apr 2020
    Ah, I wondered whether the one I had may have been incompatible. The listing wasn't the clearest what models it worked with. Either way the new one is ordered now so i'll give it a go. Would you mind explaining those two common faults a bit more? I'll be honest I don't know what SWCM-S is
    Cheers
    Tartu, Estonia
    Quote Originally Posted by SilentService View Post
    Cheers
    I don't have any pictures of the defective slider, but just open the rear cover of the stalk. You can pull it apart with Your fingernail.
    Second issue You can read here: https://forums.ross-tech.com/showthr...sues&styleid=5
  10. Likes Dana, Uwe liked this post
