Results 1 to 6 of 6
Thread: Audi A6 2012 Matrix Headlights BCM Coding lost
    Oct 2018
    Serbia
    Hi everyone I have a audi A6 in my garage client complains that he tried to mod the headlights with fake vcds , he now has messed up coding of the bcm , now there are two fault codes on BCM , I need the correct coding for the BCM (Addres 09), here's the AutoScan i did on it today :
    Thursday,09,April,2020,09:50:15:13767
    VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4508.4
    Dealer/Shop Name: Auto Tech
    VIN: WAUZZZ4G9CN163677   License Plate:
    Mileage: 206645km-128403mi   Repair Order:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 20 28 3B 42 44 46 52 53 55
              5F 62 72
    VIN: WAUZZZ4G9CN163677   Mileage: 206645km-128403miles
    Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 LB    HW: 03L 906 018 JL
       Component: R4 2,0L EDC   H24 3113
       Revision: 45H24---
       Coding: 0A034012232401080000
       ASAM Dataset: EV_ECM20TDI01103L906018LB 003009
       ROD: EV_ECM20TDI01103L906018HA.rod
       VCID: F5A26C7954F4712EA1-80A0
    4881 - EGR Valve (N18)
              P1440 00 [032] - Open Circuit
                        Mileage: 205306 km
                        Date: 2020.02.25
                        Time: 00:38:01
                        Coolant temperature: 80 °C
                        Intake air temperature: 26 °C
                        Ambient air pressure: 950 mbar
                        Voltage terminal 30: 12.560 V
                        Air mass: actual value (mg/stroke): 0.0 mg/stroke
                        EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                        EGR Solen.val.: actual value: 99.35 %
                        EGR valve: offset closed: 1.22 %
                        Actuator for high pressure EGR: status-Bits 0-7: 0
                        Actuator for high pressure EGR: status-Bits 0-7: 55
                        Actuator for high pressure EGR: status-Bits 0-7: 2
                        Actuator for high pressure EGR: status-Bits 0-7: 3
                        High press EGR actuator: actual unconditioned volt val: 679.2 mV
    Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
       Part No SW: 4G0 927 155 T    HW: 0AW 927 156 K
       Component: 0AW 20TDI RdW H04 0005
       Revision: --H04---    Serial number: 0000000543
       Coding: 000001
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_TCMVL381 A02430
       ROD: EV_TCMVL381.rod
       VCID: BC34B95D375EE0669E-80E8
       Coding: 06A187016085E180CB00
       VCID: B620AB7509723A3668-80E2
       Part No SW: 4H0 907 064 BT    HW: 4H0 907 064 BT
       Coding: 01A83006000000000000
       VCID: FCB4795D7FDE2066DE-80A8
    Address 08: Auto HVAC (J255)       Labels:* None
       Part No SW: 4G0 820 043 J    HW: 4G0 820 043 J
       Component: KLIMA 4 ZONEN H12 0064
       Serial number: 10041200040023
       Coding: 34010078A0
       VCID: A6007B35D9D24AB6D8-80F2
       Part No SW: 4H0 907 063 BP    HW: 4H0 907 063
       Component: BCM1 2.0      H12 0111
       Revision: 11012002    Serial number: 00000001455079
       Coding: 0907201009749FE001810080000018000F9CC3082E080101000108542F01
       VCID: F7BE667146F8033EB3-80A2
       Component: WWS57X 120314  H35 0080
       Serial number:         120321165401
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 20137776
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 05 04 2012  00000663
       Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
       Serial number: 00000003041200010834
       Coding: 110000
       Serial number: 00000003041200010133
       Coding: 110000
       Serial number: 9B28C226000000000001
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                        Fault Status: 00101100
                        Reset counter: 80
                        Mileage: 162572 km
                        Date: 2018.05.22
                        Time: 16:57:00
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                        Reset counter: 80
                        Mileage: 162572 km
                        Date: 2018.05.22
                        Time: 16:57:00
       Part No SW: 4H0 919 475 Q    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0060
       Revision: 11001001    Serial number: 55901208903484
       Coding: 080306
       ASAM Dataset: EV_EPHVA18AU57X0000 004005
       VCID: C0CCCDAD5BB68486C2-8094
       Revision: --------    Serial number: 003JG0081C0G
       Coding: 30323436313230303032554A304C34473053
       Serial number: 3575HRB405517UE2FPFQ
       Serial number: 3585HRB405117UE2AOIK
       Serial number: 3515JRB401I4UHL8L1S9
       Serial number: 3525JRB405P184CO7PO$
       Serial number: 3554VRB400Q4UHPKCHD$
       Serial number: 3564VRB400O4UHPKEOH8
       Revision: 00000000    Serial number: 20120410001261
       Coding: 000014
       VCID: B02C9D6DE316140632-80E4
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Component: E221 - MFL  H08 0009
       Part No SW: 4G8 920 900 H    HW: 4G8 920 900 H
       Component: MDieRdw       H34 0209
       Revision: 26450208    Serial number: 658260312592036
       Coding: 132708000B010008010000
       ASAM Dataset: EV_RBC7KMID 004045
       ROD: EV_RBC7KMID.rod
       VCID: AF2E9E11F6280BFE2B-80FA
       Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
       Component: J533--Gateway H10 0028
       Revision: --------    Serial number: 00000000459721
       Coding: 00CD074400
       ASAM Dataset: EV_GatewPkoUDS 001013
       VCID: F0AC5D6D2B96540672-80A4
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790783297
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
       Serial number: 150112000000000003DF
       Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
       Revision: AA001002
       Coding: 04018264747464545425363E
       VCID: B326926112002F1E4F-80E6
       Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
       Component: KLIMA FOND    H07 0064
       Serial number: 04041200040304
       Coding: 00
    0075 - Button or Switch in Operating Unit
              B10C7 07 [008] - Mechanical Failure
                        Reset counter: 78
                        Mileage: 165247 km
                        Date: 2018.06.19
                        Time: 13:25:59
                        Outside air temperature: 32.0 °C
                        Left rear vent temperature: 25.8 °C
       Part No SW: 4G0 907 637     HW: 4G0 907 637
       Component: SARA 3D       H02 0009
       Revision: --------    Serial number: EJ1BPA320226S.0
       ASAM Dataset: EV_SARA 009017
       ROD: EV_SARA_009.rod
       VCID: EB964A0102B0B7DE47-80BE
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011C16204000620002080002
       VCID: C2C8C7A55DBA9696D4-8096
                        Fault Frequency: 38
                        Reset counter: 38
                        Mileage: 163456 km
                        Date: 2018.06.06
                        Time: 23:06:54
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0026468056
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: B2289765E51A261644-80E6
       Revision: 00002001    Serial number: 0174485034
       Coding: 0104062000B9040083200804000103000000000000000000000000000000
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       Coding: 011C16204400620002080002
       VCID: C1CAC8A958BC8D8ECD-8094
       Revision: --------    Serial number: 00000000306571
       ROD: EV_ParkiBrake_VW51.rod
       VCID: AA188F05CDCA6ED6FC-80FE
    460800 - Function Restriction due to Faults in Other Modules
              U1113 00 [000] - -
              [FC_SIGNAL_GE_UEFKT_ERROR_VALUE]
       Serial number: 120405-0002-052
       Coding: 112196601002A300
       ROD: EV_HeadlRegulBasic.rod
       VCID: AC14891DC73E70E60E-80F8
    764928 - Left/Right Driving Switch-Over Active
              C1080 00 [009] - -
                        Reset counter: 245
                        Mileage: 162567 km
                        Date: 2018.05.22
                        Time: 13:47:34
       Part No SW: 4G0 035 180 F    HW: 4G0 035 180 E
       Component: RMC           H52 0775
       Coding: 0100000101411B47002B060001010000000000
       VCID: A2086725BDFAB696B4-80F6
       Subsystem 1 - Part No SW: 4G0 919 603     HW: 4G0 919 603
       Component: DU6 Basic  H42 0084
       Serial number: 9464CR0C2521148
       Subsystem 2 - Part No SW: 4G1 919 610 B    HW: 4G1 919 610 B
       Serial number: 90349LDC000EP
    02444 - Disk Drive Load / Eject Malfunction
                        Reset counter: 70
                        Mileage: 201068 km
                        Date: 2019.12.15
                        Time: 15:21:22
                        ON Time: 5915 h
    00658 - Control Head
                        Reset counter: 42
                        Bin. Bits:      001
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010814204000620002080002
       VCID: C4C4C1BD47AE98A6E6-8090
       Component: TSG HR        H04 0212
    End----------(Elapsed Time: 01:43, VBatt start/end: 12.2V/12.2V)-----------
  2. Likes Dana liked this post
  3. #2
    United States
    Thanks for the history. Even though he was using a clone there's a chance that the laptop has a saved scan and/or Debugs that will help you help him. If that was English VCDS make sure he checks:
    C:\Ross-Tech\VCDS\Logs
    C:\Ross-Tech\VCDS\Scans
    C:\Ross-Tech\VCDS\Debug
    This thread explains the Debug folder contents:
    https://forums.ross-tech.com/showthread.php?1029
    If it wasn't English VCDS the folder structure is nearly identical. For instance, this is the German path: C:\Ross-Tech\VCDS-DRV
    Moving forward, I'll try to find scans from similar cars and report back with any coding suggestions for 09 or 55.
  4. Likes erion97 liked this post
  5. #3
    United States
    As far as baseline scans are concerned we only have one scan from a gasoline Chinese market A6L (Long wheel bases are common there) with 8Q4 Headlight range control with cornering light PR code and #55 coding: 112296101002A300
    I'm not very confident that this will help much due to the market, presence of electrically adjustable steering column 09 slave and lack-of options such as 20-High Beam Assist but that car had this 09 info:
    Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.CLB
       Coding: 0907201009349FE281810084A0001800CF9CC30826080201800108546F00
    Next, in an attempt to locate a similar FWD CVT TDI I searched for 03L 906 018 LB & 4H0 907 063 BP. There was one result from a Polish market A6 Wagon/Avant that was in a bad way. Someone had retrofitted various modules resulting in Component Protection Active DTCs so it isn't ideal either. It lacked Component: AQ_Hum_Sensor, used 8Q3 Dynamic headlight range control (self-adjusting while driving) PR-Code and was a wagon but used:
    >     Coding: 0907201009749FE28181008380001800CF9CC7082E080101000108542F01
    >     Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
    >     Component: ....LWR12.... H02 0010
    >     Coding: 112296101002A300
    I don't believe that either of those are correct and I would NOT recommend pasting the entire string into this module but we can use them as templates to see which bits may have been modified if the customer can't provide you with an earlier scan or coding logs. The current version of VCDS has our newest coding info for this 4H0-907-063-V1 BCM1 so most functions should be labeled.
    Do let us know if those old logs aren't available and I can try to make a vehicle specific 09 coding suggestion.
    Last edited by Dana; 04-10-2020 at 09:20 AM. Reason: [CODE].. [/CODE] to fix spacing in coding strings
  6. Likes Uwe, erion97 liked this post
  7. #4
    Oct 2018
    Serbia
    Hi thank you for replying , i tried these two codes lately and none didn't work , also checked his laptop for pre saved scans didnt find one , so I guess I need a complete new coding for this car.
    I appreciate your help , regards.
  8. Likes Dana liked this post
  9. #5
    United States
    OK, I'll try to build something for you to try.
  10. #6
    United States
    I came up with BCM1 coding this but there weren't any extremely significant changes:
    0907201009749FE001810080800018000F9CC3082E08010100 0108546F01
    I'm not extremely confident that is going to fix the car so it may end up at the dealer for SVM coding.
    However, he may have missing fuses or actual problems. For that reason it might not hurt to check all of the exterior lights after coding and clearing faults to see which codes return -and- let us know which lights aren't functioning properly. For instance both of the Supply Voltage for LED Module for DRL and Parking Light Electrical Fault in Circuit faults were flagged Intermittent so it would be interesting to see if those return or function properly.
  11. Likes Uwe, DV52 liked this post
