- Jan 31, 2017
- 188
- 119
- Portugal
- C?ID=288561
My car cranks but won't start.
Fuel level is about half but the fuel filter reservoir is empty.
So, I believe that the fuel sender might be broken and I might have ran out of fuel.
I filled the fuel filter reservoir and the tank with a total of about 6 litres.
I primed the fuel system using VCDS for more than 3 times 30 seconds each.
But the car still won't start :|
There are no codes.
Am I doing something wrong?
- Is 6 litres enough?
- Should I prime again the fuel?
- Should I open or close some valve/purge?
- Should I fill some injector hose with fuel?
Thanks
There are no codes.
Thanks
Thursday,09,April,2020,17:37:50:51935
VCDS Version: 20.4.0.1 (x64) HEX-NET CB: 0.4513.4
VIN: WVWZZZ1KZ8W245642 License Plate:
Mileage: 323750km-201168mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ8W245642 Mileage: 323750km-201168miles
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 056 J HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 1785
Revision: --H07--- Serial number: VWX7Z0H13N6913
Coding: 0000071
Shop #: WSC 01392 785 00200
VCID: 2E10DD6AB9DD9AF6A0-807A
Revision: 00H11001
Coding: 0021121
VCID: 73A60C1E127FF71E0F-8026
Part No SW: 1K0 907 044 DD HW: 1K0 907 044 DD
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
VCID: 6C9417624F4128E6CE-8038
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Revision: 00H54000 Serial number: 00000007943357
Coding: F5890F270004150047140000140000001E097F071400010C000000000000
Shop #: WSC 12345 785 00200
VCID: 71AA06166863C50EFD-8024
Component: Wischer 240108 021 0501
Coding: 00038805
Shop #: WSC 12345
Component: RLS 150309 054 0402
Coding: 00209069
Shop #: WSC 12345
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 37 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1SY2N8
Coding: 0013111
Shop #: WSC 01373 785 00200
VCID: 3D32EA2664BB716E29-8068
Subsystem 1 - Serial number: 6332MSME2B236864D
Subsystem 2 - Serial number: 6342MSME3375054ED
Subsystem 3 - Serial number: 6352QSME4C1B234BP
Subsystem 4 - Serial number: 6362QSME4D56342DS
Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
Component: J0527 752 0100
Coding: 0002022
VCID: 014A56D658C3D58E0D-8054
Component: E0221 002 0010
Part No SW: 1K0 920 874 M HW: 1K0 920 874 M
Component: KOMBIINSTRUMENT VDD 1220
Revision: V0002000 Serial number: VWX7Z0H13N6913
Coding: 0003103
Shop #: WSC 01007 261 13533
VCID: 373EF80E46875B3EF3-8062
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 010208F2000033
Coding: E9807F064002020002
VCID: 302CC312A3E98C06B2-8064
Component: IMMO VDD 1220
Part No SW: 1T0 035 680 R HW: 1T0 035 680 S
Component: RNS-MID H27 6276
Revision: AB001001 Serial number: VWZ6Z743114052
Coding: 0C000402040000010000
Shop #: WSC 05314 123 00001
VCID: 3D32EA26A4BB716E29-8068
Component: EU West V14 8477
Component: Tuer-SG 006 1203
Coding: 0000180
VCID: 383CFB324B995446FA-806C
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Shop #: WSC 00000 028 00001
VCID: 3522F2065C8BA92EE1-8060
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Coding: 819002005103487F2D04040DF0084F06F0FC00
Shop #: WSC 01007 261 88724
VCID: 03465CDE42DFC79E1F-8056
Component: Tuer-SG 006 1219
Coding: 0000180
VCID: 393AFE3670934D4E05-806C
00097 - Front Passengers Central Locking (Safe) Motor (V162)
008 - Implausible Signal
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1302
Coding: 0000144
Shop #: WSC 01392 785 1012552
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Component: Tuer-SG 006 1305
Coding: 0000144
End----(Elapsed Time: 01:15, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
