I've done a 3G to 3G+ retrofit on my 2010 A6 and I'm stuck on a few problems. I'm out of ideas at the moment. I haven't ruled out a hardware issue, but everything worked fine before the retrofit. The radio unit is from a 2014 A8 and all other hardware is original to the A6.
First, what does work. All audio and NAV features appear to be functioning ok. I did a firmware update today to the latest available and I also now have the Audi Connect icon on the settings menu. I'm still working out fitting a GSM antenna to the head unit, so SIM/network features are still TBD.
Now, the problems. My steering wheel controls no longer work, I'm missing the MMI info at the top of the gauge cluster display, a bunch of MMI menu items are grayed out, I can't set the time on the clock, and I have several persistent faults in the MMI module. Latest scan below along with some screen shots.
I did disconnect the MMI panel a few times and actually tried a panel from a 2013 Q7 as well, but abandoned that when I got the original panel working. I didn't modify any harness or connectors, so I'd be surprised if I did any damage to the wiring, but I guess anything is possible.
Wednesday,08,April,2020,20:12:28:58743
VCDS Version: 20.4.0.1 (x64) HEX-NET CB: 0.4508.4
Dealer/Shop Name: HOME
VIN: WAU4GBFBXAN045143 License Plate: A6
Mileage: 147240km-91490mi Repair Order: 20200408-02
Chassis Type: FB-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 47 4C 4F 52 53 55
56 5F 62 6C 6D 72
VIN: WAU4GBFBXAN045143 Mileage: 147240km-91490miles
Address 01: Engine (CCA) Labels:. 06E-907-551-CAJ.clb
Part No SW: 4F1 910 551 D HW: 4F1 907 551
Component: 3.0l V6 TFSI 0020
Revision: --H06--- Serial number:
Coding: 010D000A190F0120
Shop #: WSC 02325 785 00200
VCID: A40444E3673E08A6C6-80F0
Readiness: 1110 1101
Part No SW: 4F9 910 156 A HW: 09L 927 156 C
Component: AG6 09L 3,0TFSI USA 0020
Revision: --H05--- Serial number: 4560765
Shop #: WSC 41184 001 1048576
VCID: AA18AADB051ADED6FC-80FE
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AL HW: 4F0 614 517 BA
Component: ESP8 quattro H03 0060
Coding: 0020921
VCID: EE9066CBF972F2F660-80BA
Part No SW: 4F0 910 852 B HW: 4F0 905 852 E
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602501435678
Coding: 0000135
Shop #: WSC 02324 785 00200
VCID: A50259E76C04F1AED1-80F0
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
Part No SW: 4F0 910 043 B HW: 4F1 820 043 AL
Component: KLIMABETAETIGUNGH30 0080
Revision: 00000074 Serial number: 00000000687979
Coding: 0524582
VCID: 9D7271074454396E89-80C8
Part No SW: 4F0 910 279 M HW: 4F0 907 279 A
Component: ILM Fahrer H22 0320
Coding: 0139123
Shop #: WSC 02335 785 00200
VCID: B326B7BFD2D09F1E4F-80E6
Subsystem 1 - Part No: 4F1 910 113 D Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H10 0040
Coding: 00056595
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4F0 035 110 A HW: 4F0 035 110
Component: CDC-MP3-Alp H44 0140
Revision: AA001001
VCID: 956269277C64612E41-80C0
Address 15: Airbags (J234) Labels:* 4F0-910-655-10.clb
Part No SW: 4F0 910 655 R HW: 4F0 959 655 H
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FA0013YUA
Coding: 303142373034303030324A55304C34463053
ROD: EV_Airba10AURB4.rod
VCID: B6208EAB09A28A3668-80E2
Subsystem 1 - Part No SW: 4F0 910 339 B HW: 4F0 959 339 B
Component: BF-Gewichtss. H03 0060
Serial number: 5810000R0000003CTX
Serial number: 3574SRB40000A21D11A+
Serial number: 3584SRB40000A340622V
Serial number: 3516HRB402J9KI9ISKMO
Serial number: 3526HRB402T9LBCGU4C6
Serial number: 3554NRB400005217DCC5
Serial number: 3564NRB4000052B063AY
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0530
Revision: 00H06000 Serial number: 90055093140014
Coding: 0012342
VCID: A71E53EF1608E3BEE3-80F2
Component: E0221 H02 0030
Address 17: Instruments (J285) Labels:. 4F0-920-xxx-17.clb
Part No SW: 4F0 920 983 H HW: 4F0 920 983 H
Component: KOMBIINSTR. H08 0144
Revision: 00100000 Serial number: CN406ELC9
Coding: 8BD712050B00D705020201
Shop #: WSC 02391 823 56573
VCID: B12ABDB7E8CCAD0E3D-80E4
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 M HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0035
Revision: LB100029 Serial number: 2900L09B068181
Coding: 000303
VCID: B93A859730BC654E85-80EC
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0125
Serial number: 00000000002790803328
Part No SW: 4F0 959 760 C HW: 4F0 959 760 C
Component: MEM-FS H08 0062
Revision: AA000000 Serial number: 00001010033638
Coding: 00581B00004011110000
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000102348829
Coding: 011F57204E40410001
VCID: C6C0FE6B71421AB6F8-8092
Part No SW: 4F0 910 289 K HW: 4F0 907 289 K
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01238052570000
Coding: 8288925
VCID: B228B2BB2DCA961644-80E6
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 035 223 P HW: 4F0 035 223 P
Component: BOSE G3 C6 H01 0100
Revision: AG001300 Serial number: 00000000049144
Coding: 05010000
VCID: A91A55D7C01CD5CEF5-80FC
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 A HW: 4F0 907 274
Component: J793 RKA+ H02 0100
Revision: 00000506 Serial number: 00005061084500
Coding: 0623301
VCID: A20842FB7D2A0696B4-80F6
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H13 0100
Revision: Serial number: 00000000534329
Coding: 0002014
VCID: DEF0360B09D26276D0-808A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000102365237
VCID: C5C2F9674C4411AEF1-8090
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000222
Shop #: WSC 02145 785 00200
VCID: A10A4DF7782C1D8EAD-80F4
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0060
Coding: 0000026
VCID: E99A15D7C09C15CE35-80BC
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335KZ097540373
Coding: 020000010000000000
VCID: 9D7271078454396E89-80C8
Part No SW: 4H0 035 746 M HW: 4H0 035 746 C
Component: H-BNT-NA H50 1038
Revision: -------- Serial number: 183BY0D7506544
Coding: 020200010002E1EE4112831E00000403140001000000000000
Shop #: WSC 02391 785 00200
VCID: B228B2BBEDCA961644-80E6
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356KH091130021
Subsystem 3 - Part No: 8R0 060 961 E
Component: CD-Database 4949
00658 - Control Head
Reset counter: 199
Mileage: 147249 km
Date: 2009.06.09
Time: 08:41:39
Voltage: 11.90 V
Fault Frequency: 7
Reset counter: 199
Mileage: 147249 km
Date: 2009.06.09
Time: 08:41:55
Bin. Bits: 00110011 00000010
Bin. Bits: 00000000 00010001
Bin. Bits: 00000000 00000000
01043 - Control Module; Incorrect Software Version
Reset counter: 199
Mileage: 147249 km
Date: 2009.06.09
Time: 08:41:55
Bin. Bits: 10000000 00000000
Bin. Bits: 00000000 00000010
01524 - Antenna for Telephone
Fault Status: 01101011
Reset counter: 199
Mileage: 147249 km
Date: 2009.06.09
Time: 08:41:49
Voltage: 11.90 V
Reset counter: 199
Mileage: 147249 km
Date: 2009.06.09
Time: 08:41:48
Bin. Bits: 00000000 00001000
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000102379026
Coding: 010E57204040220001
VCID: C3C6E77F42702F9EDF-8096
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 D HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H03--- Serial number: 525PA8-J9Y21HR
Coding: 1000305
Address 6D: Trunk Elect. Labels: Redir Fail!
Part No SW: 4F9 910 591 HW: 4F9 827 851 G
Component: ValeoHeckdeckel H29 0410
Revision: --H29001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: EC946CC3CF6E00E64E-80B8
Subsystem 1 - Part No: 4F9 910 592
Subsystem 3 - Serial number: RD23.11.09--H29001001B0190ÿ
Subsystem 4 - Serial number: 1B0190ÿ
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000102378995
End----(Elapsed Time: 01:59, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
