Thursday,09,April,2020,12:37:49:04233
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWZZZ1KZ5W216532 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WVWZZZ1KZ5W216532 Mileage: 229600km-142666miles
44-Steering Assist -- Status: Sporadic communication error 1000
46-Central Conv. -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 016 CB HW: 028 101 190 0
Component: R4 1,9L EDC 0000SG 6176
Revision: 12345678 Serial number: VWZ7Z0E1705766
Coding: 0003031
Shop #: WSC 01286 386 08256
VCID: 6597B62AB960CEBF5A3-8030
6 Faults Found:
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
RPM: 63 /min
Torque: 106.0 Nm
Voltage: 10.11 V
Bin. Bits: 00000100
Temperature: 7.2°C
Bin. Bits: 01110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
RPM: 63 /min
Torque: 106.0 Nm
Voltage: 10.11 V
Bin. Bits: 00000100
Temperature: 7.2°C
Bin. Bits: 01110000
17054 - Glow Plug Module 1; Glow Plug Circuit
P0670 - 000 - Electrical Malfunction - Intermittent
RPM: 903 /min
Torque: 70.0 Nm
Voltage: 12.31 V
Bin. Bits: 11000100
Temperature: 7.2°C
Bin. Bits: 10110000
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
RPM: 882 /min
Torque: 76.0 Nm
Voltage: 14.29 V
Bin. Bits: 11000100
Temperature: 7.2°C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
RPM: 882 /min
Torque: 76.0 Nm
Voltage: 14.29 V
Bin. Bits: 11000100
Temperature: 7.2°C
Bin. Bits: 10110000
19794 - Control Circuit for Glow Plug Controller 1
P3338 - 000 - Electrical Malfunction - Intermittent
RPM: 126 /min
Torque: 0.0 Nm
Voltage: 10.34 V
Bin. Bits: 00000100
Temperature: 27.0°C
Bin. Bits: 11000000
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
Shop #: WSC 00046 000 40960
VCID: 3FDB44427B7CB46FF0F-806A
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 M HW: 1K0 937 049 M*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001482760
Coding: A0880F0600041832001400001400000000097A075C
VCID: 392F2A5A65589A5FCEB-806C
Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 12345
01506 - Bulb for Rear Fog; Right (L47)
Part No SW: 1K0 909 605 C HW: 1K0 909 605 C
Component: 34 AIRBAG VW8 013 2100
Revision: 02013000 Serial number: 0033HD06N8J6
Coding: 0013108
Shop #: WSC 01269 785 00200
VCID: 2C01030E9A0A3FF745D-8078
Subsystem 1 - Serial number: 6332MSME094540250
Subsystem 2 - Serial number: 6342MSME0945400D7
Subsystem 3 - Serial number: 6351HSME0630052F+
Subsystem 4 - Serial number: 6361HSME26361C356
Part No SW: 1K0 953 549 BF HW: 1K0 953 549 BF
Component: J0527 752 0101
Coding: 0000011
VCID: 77ABEC6213CC4C2FF8F-8022
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective
Part No: 1K0 920 851 H
Component: KOMBIINSTRUMENT VDD 0716
Coding: 0003103
Shop #: WSC 00000 785 00200
VCID: 2D070E0AA11036FF523-8078
00003 - Control Module
014 - Defective
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 29001052140663
Coding: 3D0F0940070001
Shop #: WSC 01279 785 00200
VCID: 290FFA1A95F82ADFBEB-807C
Reset counter: 103
Mileage: 219893 km
Time: 12:09:10
01304 - Radio
Reset counter: 103
Mileage: 219919 km
Time: 12:58:15
Reset counter: 103
Mileage: 220479 km
Time: 12:57:58
Reset counter: 103
Mileage: 225276 km
Time: 23:44:59
Component: IMMO VDD 0716
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0122
Coding: 0000052
VCID: 3039177EB6225B17795-8064
Part No: 1K2 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 333318724734600F047-8066
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AJ
Component: KSG 0401
Coding: 00C802087F2D8404085A018010CC
Shop #: WSC 00046 046 52295
VCID: 78A9EF5E1ED24357F15-802C
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
VCID: 313F127ABD28521F76B-8064
Part No: 1K0 035 186 L
Component: Radio GR0 012 0018
Revision: 0001201S Serial number: VWZ2Z2D1084182
Coding: 0020200
Shop #: WSC 35110 377 08192
VCID: 2F3B1402AB1C44EF60F-807A
00856 - Radio Antenna
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
014 - Defective
End----------(Elapsed Time: 00:55, VBatt start/end: 13.3V/12.8V)-----------
