Results 1 to 6 of 6
Thread: Start no run very well. T5 Transporter engine code BNZ 2.5 five cylinder
    Verified VCDS User johne's Avatar
    Mar 2020
    Southampton, UK
    Hi All. Symptoms starts fine from cold and revs up fine but when warm you have to keep the key on until it catches very sluggish from rest, you have to wait for the turbo to spool up and off we go runs ok.
    Did have a 000833 - Camshaft Position Sensor (G40) P0341 - 000 - Implausible Signal.. before i striped and retimeed the cam. any idea what 48.0 Start Synchronisation means ??
    so far.
    new moo valve
    rebuild turbo {not by me}
    Many thanks for sharing my problems. john {jack iam ok for soup}
    Address 01: Engine  (070 906 016 DS)
    11:18:51 Group 004: Unit Injector
      798 /min  Engine Speed (G28)
      3.1 BTDC  Injection Start (specified)
      7.7KW  Injection Duration (specified)
      -6.9KW  Torsion Value
    11:18:51 Group 013: Idle Stabilization (Injection Quantity Deviation - Cylinder 1-4)
      2.16 mg/str  Injection Quantity Deviation Cyl. 1
      0.92 mg/str  Injection Quantity Deviation Cyl. 2
      -0.31 mg/str  Injection Quantity Deviation Cyl. 3
      -0.64 mg/str  Injection Quantity Deviation Cyl. 4
    11:18:51 Group 051: Speed Recording
      399 /min  Camshaft Speed
      00010000  Inject. Sequence Shut-Off Status
    Wednesday,08,April,2020,11:54:18:62543
    VIN: WV2ZZZ7HZ8H015277   License Plate: HKOI
    Mileage: 496720km-308647mi   Repair Order: 8/5/20
    Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
    Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
              57 6E 76 77 78 7D
    VIN: WV2ZZZ7HZ8H015277   Mileage: 496720km-308647miles
    Address 01: Engine        Labels: 070-906-016-BPC.clb
       Part No SW: 070 906 016 DS    HW: 070 906 016 DS
       Component: R5 2,5L EDC  000SG  1585
       Revision: --H05---    Serial number: VWZ7Z0G5463049
       Coding: 0001072
       Shop #: WSC 80093 222 69422
       VCID: 6491AC44A244FBDBD7A-5184
    008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
                   P2185 - 000 - Signal too High
                        Mileage: 496720 km
                        RPM: 777 /min
                        Voltage: 14.36 V
                        Bin. Bits: 00000000
                        Temperature: 66.6C
                        Temperature: 55.8C
    Address 03: ABS Brakes        Labels:. 7H0-907-37x-ABS.clb
       Part No SW: 7H0 907 379 S    HW: 7H0 907 379 S
       Component: (M)ABS MK25E        0103
       Revision: 00H21001
       Coding: 0000552
       Shop #: WSC 02756 790 00000
       VCID: 45D751C009BEA2D3204-5160
    Address 08: Auto HVAC        Labels: Redir Fail!
       Part No: 7H0 820 045 AL
       Component: CLIMA/AC            0303
       VCID: 6FBBD3687B824883BA8-5160
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
       Part No: 7H0 937 049 T
       Component: BORDNETZ SGVER 1.0  2001
       Coding: 0000101
       VCID: 43D34FD8078A9CE30E0-513C
       Part No: 1C0 909 605 A
       Component: 3C AIRBAG VW51      0010
       Coding: 13123
       Shop #: WSC 02756
       VCID: 221DEA5CFDD0B5EB656-513C
    Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
       Part No: 7H0 920 951 T
       Component: KOMBI+WEGFAHRSP VDO V02
       Coding: 00413
       Shop #: WSC 77824
       VCID: 3D273920646EEA13784-513C
       WV2ZZZ7HZ8H015277     VWZ7Z0G5463049
    01304 - Radio
                49-00 - No Communications
    Address 18: Aux. Heat        Labels: 7H0-819-008.lbl
       Part No: 7H0 815 071 F
       Component: Standheizung        0209
       VCID: 2B0307788F1A74A3D60-513C
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 02756
       VCID: 70B9D01463BC577BA32-513C
    01304 - Radio
    Address 45: Inter. Monitor        Labels: 7Hx-951-171.lbl
       Part No: 7H0 951 171 B
       Component: Innenraumueberw.    2920
       Coding: 0000022
       Shop #: WSC 02757 790 00000
       VCID: 290FFD7085E666B324C-51CE
       Subsystem 1 - Part No: 7H5 951 178
       Component: Innenraumueberw.    1607
    Address 46: Central Conv.        Labels: 7H0-959-433.lbl
       Part No: 7H0 959 433 B
       Component: C11 Komfortgert     0004
       Coding: 00030
       Shop #: WSC 02756
       VCID: 323D1A1CAD30256B956-4B1E
    End----------(Elapsed Time: 05:48, VBatt start/end: 14.5V/12.4V)-----------
    The RTFB will tell you and how to check belt timing since appears out is that right?
    Pardon me retarded........
    Mar 2020
    Southampton, UK
    This engine is gear driven ....so you saying its retarded ?
    Compound run on sentence questions away, with self evident answers okay?
    All depends on you and your observations compared to RTFB, huh?
    Don't you see what I'm asking in general, is that you should query the RTFB and check timing, since that is recent work history right and torsion value is what it is & yes it's gear driven, "gear chain belt" same crap different shovel for cam position & that vehicle isn't in the USA, so criticizing me for information you should already have a baseline on and choose not too, isn't wise when seeking a hand out, well is it?
    You say no free soup needed, well no crackers either........
    The forum is not a substitute for VCDS or RTFB procedures, it is to elaborate on it based on test data, anything contrary in this section would be considered reckless and unqualified as a repair process.
    What are conditions of PD and cam lifters + mechanical's for leak down and lash settings of injector train?
    Mar 2020
    Southampton, UK
    ...i only meant it being gear driven moving the gear one tooth would i think be more then 6 degrees .
    Sorry man I cant guess what you did or didn't do but I can advise that you get the RTFB.
