Results 1 to 10 of 20
Thread: P0106 Fault Code Help
    Apr 2020
    My 2009 Q5 is throwing a engine check light at start up every time i drive it
    Tried resetting the fault but it always comes back the next time I start the engine after it’s been driven
    It’s running fine no noticeable changes other than the constant check engine light
    here is the VAG dump
    6010 - Manifold / Barometric Pressure Sensor (G71) / (F96)
    P0106 00 [237] - Implausible Signal
    Mileage: 197881 km
    Time: 00:00:00
    Coolant temperature: 44 °C
    Intake air temperature: 27 °C
    Ambient air pressure: 910 mbar
    Voltage terminal 30: 12.390 V
    Engine speed: actual: 0 /min
    MAF_ENVD: 397.63528 mg/stroke
    Coolant temperature (unfiltered): 96.0 °C
    Engine: operating status: ES
    Battery voltage: 12.492188 V
    Vehicle speed: actual: 0 km/h
    i replaced the MAP sensor (03C906051F) with a Bosch 261230234 , Confirmed no Vacuum leaks (propane tank and hose) ,
    cleaned the throttle body (it was dirty) , Ran the TBA with the engine at temp Adapt moved from 6 to 2
    Still getting the same error at engine start up after a drive but not if I just start and stop the engine
    noticed my accelerator sensor values were a bit strange but I’m guessing this is just a new rabbit hole I should avoid
    Any one able to confirm the values below are normal
    Engine OFF Key ON Accelerator pedal not depressed
    IDE00025 Coolant temperature 76 °C
    IDE00078 Time since engine start 689 s
    IDE00083 Throttle valve position (absolute) 11.8 %
    IDE00086 Accelerator position 15 %
    IDE00349 Throttle valve position: normed 2 %
    ENG102297 Accelerator Pedal Position E 14.5 %
    ENG103226 Accelerator pedal sender 1: voltage ratio 0.752 V
    ENG103029 Accelerator pedal sender 2: voltage ratio 0.381 V
    ENG103042 Accelerator pedal sender: learned end stop 4.126 V
    ENG103719 Accelerator position 0.00 %
    is it normal for the ENG and IDE values to be so far apart 0 vs 15%
    Any ideas or suggestions would be welcome
    thanks in advance
    Mark
    Welcome OP
    It's an incomplete movement.
    http://wiki.ross-tech.com/wiki/index.php/16490/P0106/000262
    JPPSG
  3. Likes DrPeter, Uwe liked this post
    Apr 2020
    Here is the full scan per your request
    thanks again for an and all suggestions and help resolving this error
    all the best
    Mark
    Wednesday,01,April,2020,19:51:52:14281
    VIN: WA1KK78R19A055752   License Plate:
    Mileage: 197880km-122956mi   Repair Order:
    Chassis Type: 8R-AU48 (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 52 53 55 56 5F 62
              65 6C 6D 72
    VIN: WA1KK78R19A055752   Mileage: 197880km-122956miles
    Address 01: Engine (J623-CALB)       Labels:| 06E-907-559-CAL.clb
       Part No SW: 8R0 907 559 A    HW: 8T0 907 559 B
       Component: 3.2 SIMOS8.2  H04 0006
       Revision: --------
       Coding: 0121000A190F0121
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_ECM32FSI8R0907559A A01012
       ROD: EV_ECM32FSI8R0907559A.rod
       VCID: 3E253818C0F4C96B61E-806A
                        Mileage: 197731 km
                        Time: 00:00:00
                        Coolant temperature: 43 °C
                        Intake air temperature: 25 °C
                        Ambient air pressure: 920 mbar
                        Voltage terminal 30: 12.187 V
                        Coolant temperature (unfiltered): 91.5 °C
                        Battery voltage: 12.085938 V
    Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
       Part No SW: 8R0 927 158     HW: 0B6 927 156
       Component: 0B6 32FSIUSA  H05 0010
       Revision: --H05---
       Coding: 001002
       ASAM Dataset: EV_TCMAL651 A01004
       ROD: EV_TCMAL651.rod
       VCID: 7AADF4089C5C254B1D6-802E
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
       Part No SW: 8R0 907 379 C    HW: 8R0 907 379 C
       Component: ESP8 quattro  H06 0230
       Coding: 041500
       VCID: 40D946E0BA80BF9B132-8014
       Part No SW: 8K0 907 064 AS    HW: 8K0 907 064 AS
       Component: BCM2 1.1      H80 0145
       Coding: 090500
       VCID: 015F83E4F10A76935CC-8054
       Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
       Serial number: 0509000018021013
       Component: J764 ELV MLB  H36 0042
       Serial number: 0209000029169002
       Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
       Component: KLIMA 3 ZONEN H06 0150
       Revision: C1000000    Serial number: 01080520091645
       Coding: 46112000
       VCID: 72BDDC28C4AC5D0B556-8026
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Component: BCM1 1.0      H26 0253
       Revision: 05026001    Serial number: 00000000262096
       Coding: 26001091063CAF010000080300001D0D0F1C460800010161000000
       VCID: 303916200A202F1BE32-8064
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 090429  H10 0041
       Serial number: 90243014090423195000
       Coding: 01DD13
       Component: RLS  H04 0003
       Serial number: 10465913
       Coding: 024D25
       Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
       Component: E1 - LDS  H07 0090
       Serial number: 00000000000405090268
       Component: HOMELINK  H01 0010
       Part No SW: 8K0 919 475 G    HW: 8K0 919 475 A
       Component: PARKHILFE 8K  H06 0040
       Revision: 11001001    Serial number: 40040912800653
       Coding: 300105
       VCID: 3D273F14CD72D273784-8068
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 A    HW: 8R0 959 655 A
       Component: AirbagVW-AU10 H13 0320
       Serial number: 003BRD053NWV
       Coding: 303633313432303030304A55304C38523053
       ASAM Dataset: EV_AirbaAU10SMEAU416 001001
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 42DD4CE8B40CAD8B056-8016
       Subsystem 1 - Part No SW: 8R0 959 339     HW: 8R0 959 339
       Component: BF-Gewichtss.  H01 0030
       Serial number: 5810000R0900004703
       Serial number: 6334MSME474123093
       Serial number: 6344MSME470555459
       Serial number: 6352QSME2B28242CK
       Serial number: 6362QSME372C4314E
       Serial number: 63732SME0E270634Z
       Serial number: 63832SME36274E2C7
       Revision: --------    Serial number: 90319IE4000F7
       Coding: 000017
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 980 A    HW: 8R0 920 980 A
       Component: KOMBIINSTR.   H08 0224
       Revision: 00200000    Serial number: 9EP532A59
       Coding: 8B1622000300D705020000
       VCID: 372B2D3CEF4EF823A28-8062
       Part No SW: 8T0 907 468 P    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0095
       Revision: EB500046    Serial number: 4600E094238123
       Coding: 000303
       VCID: 4EC568D870D459EB91E-801A
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0107
       Serial number: 00000000004140509680
       Part No SW: 8R0 959 760     HW: 8R0 959 760
       Component: MEM-FS        H05 0043
       Revision: AA000000    Serial number: 00001001272358
       Coding: 00581300000044440000
       VCID: 7EA5F81880F4096B21E-802A
       Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
       Revision:             Serial number: 0000008837890
       Coding: 011D03205E00440004
       VCID: 41DF43E4B18AB6931CC-8014
                        Reset counter: 213
                        Mileage: 194456 km
                        Date: 2020.01.17
                        Time: 12:49:25
       Revision: 00002001    Serial number: 0118393261
       Coding: 0126023A207A749404B005
       Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0050
       Serial number: 00000000000000132507
       Component: J245EE19SKB12  H01 0220
       Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J394EE19SKB12  H01 0220
       Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
       Revision:             Serial number: 0000008886195
       Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
       Component: EPB Audi B8   H08 0080
       Revision: 00000003    Serial number: 00000000364206
       VCID: 3333192CFB3614039E0-8066
       Part No: 8K0 907 357 B
       Component: Dynamische LWR  H01 0030
       Coding: 0000006
       Shop #: WSC 06334 000 00000
       VCID: 34311A30F238133B87A-8060
       Part No SW: 4F0 035 082 A    HW: 4F0 035 082
       Component: Radio U SIRIU H45 0021
       Revision: AB001007    Serial number: 335DX097512919
       Coding: 020000020100000001
       VCID: 1D67DF946DB2B273584-8048
       Part No SW: 8T1 035 664 A    HW: 8T1 035 664
       Component: H-BN-NA       H63 0042
       Revision: --------    Serial number: 328EX097511908
       Coding: 010200060005A1EF41000B0E000000030000
       VCID: 36352038E844012BB9E-8062
       Subsystem 1 - Part No: 8R0 060 884 A
       Component: NAR 2008  5203
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356D-091093966
       Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
       Component: E0380 Bedient  H08 0100
       Serial number: 00000000280884
       Revision:             Serial number: 0000101063834
       Coding: 010C03204000240004
       VCID: 43D349ECAB96A4830E0-8016
    Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
       Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
       Component: J502-RDK      H03 0250
       Revision: 00001001    Serial number: 13374790430563
       Coding: 0CD153
    02214 - Tire Pressure Warning
                        Reset counter: 222
                        Mileage: 196595 km
                        Date: 2020.03.04
                        Time: 17:47:13
                        Bin. Bits: 00000000 00100011
                        Voltage: 14.50 V
                        Text:  16,0°C; -0,45bar;3444547831;00h; 14°C
       Part No SW: 8R0 907 441     HW: 4L0 907 441 A
       Component: J772__Rearview      0070
       Revision: --H12---    Serial number: 525PA8-J93A0L3
       Coding: 1020010
       VCID: 73B3D92CB7B654035E0-8026
       Part No SW: 8R0 827 851 A    HW: 8R0 827 851
       Component: J605  Master  H27 0290
       Revision: --------    Serial number: 8R0827851
       VCID: 3A2D3408DC5CE54B5D6-806E
       Subsystem 1 - Part No SW: 8R0 827 852 A    HW: 8R0 827 852
       Component: J756  Slave  H27 0290
       Serial number: 8R0827852
       Revision:             Serial number: 0000101063811
    End----(Elapsed Time: 01:55, VBatt start/end: 11.5V/11.7V. VIgn 11.8V)-----
    all the best
    Mark
    Thank you for posting the auto-scan.......
    In addition to aforementioned link.
    Why not have a look at battery, freewheel pulley/alternator and belt plus charging system as a whole for connections & function yet?
    Terrible........
    16.4905° S, 151.7375° W
    I would suggest to check the Advanced Measuring Values for the F96 and the G31(G71) pressures with the key on and the engine off.
    These values should be equal or very close.
    [*ENG99319*],083,,Ambient pressure,LINEAR,hPa
    [*ENG101388*],336,,Intake manifold pressure: absolute,LINEAR,hPa
    The fault will set when there is a difference of about 210-230 hPa (+/-), according to some of the Audi repair information.
    We do have a Ross-Tech wiki page for the fault code page, P0106 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
    Hope this helps,
    drpeter
  7. Likes Jack@European_Parts, Uwe liked this post
    Sep 2016
    Riga, Latvia
    Mileage: 197731 km
    Time: 00:00:00
    I think fault code and FF data together are self-explaining.
    Use RTFB and WD, find where F96 barometric pressure sensor is located and find out why it is measuring incorrectly.
    Of course, if You are not high above sea level. At sea level barometric pressure 920 mbar is not correct measurement.
    P.S. Dr Peter was faster with the same suggestions
  9. Likes Jack@European_Parts, DrPeter, Uwe liked this post
  10. #7
    Apr 2020
    Thanks for all the tips and suggestions
    I replaced the MAP sensor mounted right behind and above the TB
    Anyone have any ideas where the second MAP sensor is physically located
    I’ll look into the battery and the charging system ASAP didn’t notice that one
    I’ll post the MAP sensor deltas from the advanced measurement values ASAP
    hopefully that’s the issue causing the P0106 fault code
    Mark
  11. #8
    Second MAP sensor?
  12. #9
    Apr 2020
    Did I misunderstand DrPeters suggestion to compare the sensor data readings Don his post ?
    Dr Peters post follows
  13. Likes Uwe liked this post
  14. #10
    Do you have a RTFB and WD so you can observe it because that is what you need?
