Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: I bought a touareg 4.2tdi riddled with fault codes
    Apr 2020
    another question, in adress 34 level control there are faults with very high milage reading and 50 years in the future, if I erase those they come back immediately. The air suspension seems to work fine. Any idea how to get rid of those?
  2. #12
    Quote Originally Posted by Joris View Post
    The second one ("Missing Messages") is due to the ACC being off-line. I would assume this is also triggering the first one.
  3. #13
    Apr 2020
    I tried to get ACC back online, no luck yet. Did get the parking assist fixed, including topview.
    Today I receive the goods to change de brake pads front and rear, so the parking brake error should be history too. Found a youtube video how to grind the pads in and recalibrate the airgap for het parking brake. Hopfully it works.
  4. #14
    Apr 2020
    Made a log with various sensors, are de 02 sensor readings strange? Does not matter if the engine runs or not, unplugging them while running makes no difference at all.
                    Address 01: Engine  (7P0 907 409 )
    12:24:23
      IDE00558   Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor) 0.350 Lambda / 0.000 V
      IDE03582   Temperature sensor for engine temperature management 24.7 C
      IDE04369   Exhaust temperature sensor 3: bank 2 48.6 C
      IDE04395   Exhaust temperature sensor 1: bank 2 105.9 C
      IDE04675   O2 sensor 1 bank 1: air flow volume 0.0 g
      IDE04824   O2 sensor 1 bank 2: air flow volume 3276.7 g
