Results 1 to 10 of 14
Thread: I bought a touareg 4.2tdi riddled with fault codes
    Apr 2020
    I bought it with some front damage, but there are more problems. I made an autoscan, tried te delete as much codes as possible and ended up with still a lot of fault codes. Some worry me like the DPF error. Any advise where to start?
    I already tried to do a service regen on the DPF but with no luck, it sais it cannot continue due to fault. I made sure all requirements were met, so coolant temp above 70C, handbrake deployed, hood closed, all consumers on. the dpf counters did get reset, dont know how that happened.
    Also tried to recalibrate the parking brake with no luck. The coding was wrong, so I searched the forum for parking brake coding on the touareg and found this one. Now the parking brake works again, but it has to be recalibrated, but it will not do that.
    I ordered a new steering angle sensor because it would not recalibrate anymore. Found a topic over here with the same issues, the ts solved it with a new steering angle sensor so fingers crossed..
    Dinsdag,07,April,2020,16:53:30:11641
    VCDS -- VAG/VAS Emulator onder Windows Loopt op Windows 10 x64
    VCDS Versie: PRI 19.6.2.1
    Data versie: 20191020 DS308.0
    Chassisnummer: WVGZZZ7PZBD025545   Kenteken:
    Chassis Type: 7P-VW52 (7P6)
    Scan: 01 02 03 05 06 08 09 0E 10 11 31 13 15 16 17 18 19 20 28 34
              36 3C 42 46 52 53 55 56 5F 62 65 69 6C 6D 72 85 8B 8E 8F 90
    Chassisnummer: WVGZZZ7PZBD025545   KM-stand: 80407km
    01-Motor -- Status: Functioneert niet 0010
    02-Autom. Transm. -- Status: OK 0000
    03-ABS Remmen -- Status: Functioneert niet 0010
    04-Stuurhoeksensor -- Status: OK 0000
    05-Toegang/Start Id. -- Status: OK 0000
    06-Stoel Geheugen,R -- Status: OK 0000
    08-Airco/Verwarming -- Status: Functioneert niet 0010
    09-Cent. Elect. -- Status: Functioneert niet 0010
    0E-Media Speler 1 -- Status: OK 0000
    10-Park/Stuurassist -- Status: Functioneert niet 0010
    11-Motor II -- Status: Functioneert niet 0010
    31-Motor Verbinding -- Status: Functioneert niet 0010
    13-Auto Afst. Reg. -- Status: Wordt niet bereikt 0100
    15-Airbags -- Status: Functioneert niet 0010
    16-Stuurwiel -- Status: Functioneert niet 0010
    17-Instrumenten -- Status: Functioneert niet 0010
    18-Extr. Verwarming -- Status: Functioneert niet 0010
    19-CAN Gateway -- Status: Functioneert niet 0010
    20- 20-Groot Licht Ass. -- Status: Wordt niet bereikt 0100
    28-Airco/Verw. achter -- Status: Functioneert niet 0010
    34-Niveau Regeling -- Status: Functioneert niet 0010
    36-Stoel Geheugen,L -- Status: OK 0000
    3C-Baanwisselass. -- Status: OK 0000
    42-Deur Electr. LV -- Status: Functioneert niet 0010
    46-Comfortsysteem -- Status: Functioneert niet 0010
    52-Deur Electr. RV -- Status: OK 0000
    53-Handrem -- Status: Functioneert niet 0010
    55-Xenon Niveau -- Status: Functioneert niet 0010
    5F-Info Electr. -- Status: Functioneert niet 0010
    62-Deur Electr. LA -- Status: OK 0000
    65-Bandenspanning -- Status: Functioneert niet 0010
    69-Aanhanger -- Status: OK 0000
    6C-Achteruit Camera -- Status: Functioneert niet 0010
    6D-Electr. Kofferd. -- Status: OK 0000
    72-Deur Electr. RA -- Status: OK 0000
    85-Camera -- Status: Functioneert niet 0010
    8B-Adaptieve Cruise 2 -- Status: Functioneert niet 0010
    8E-Beeldverwerking -- Status: Functioneert niet 0010
    8F-Voorspan. Linksvoor  -- Status: Functioneert niet 0010
    90-Voorspan. Rechtsvoor -- Status: Functioneert niet 0010
    Adres 01: Motor (J623-CKDA)       Labels:. 057-907-409-CKD.clb
       Onderdeelnr. SW: 7P0 907 409     HW: 7P0 907 409
       Component: 4.2TDI EDC17  H17 0007
       Revisie: 52H17---
       Codering: 292A401A437E00020000
       Dealer #: WSC 59434 001 104857
       ASAM Dataset: EV_ECM42TDI1117P0907409 001016
       ROD: EV_ECM42TDI1117P0907409.rod
       VCID: 74E70023DF9656EFB2-8020
    4 foutcodes gevonden:
    11279 - Roetfilter cilinderrij 2
              P24A3 00 [167] - Roetbelasting te hoog
              MIL AAN - Niet Bevestigd - Getest sinds Wissen Geheugen
                 Freeze frame:
                        Fout Status: 00000001
                        Fout Prioriteit: 2
                        Fout Frequentie: 1
                        KM-stand: 80407 km
                        Datum: 2020.04.07
                        Tijd: 16:28:41
                        Motortoerental: 700.50 /min
                        Genorm. bel.waarde: 21.6 %
                        Rijsnelheid: 0 km/h
                        Koelvloeistoftemperatuur: 74 °C
                        Aanzuigluchttemperatuur: 29 °C
                        Buitenluchtdruk: 1020 mbar
                        Spanning contact 30: 14.620 V
                        Verleerteller na OBD: 40
                        Roetfilter: roetmassa gemeten: 3.43 g
                        Roetfilter: roetmassa berekend: 0.78 g
                        Roetfilter: afstand sinds laatste regeneratie: 0 m
                        Uitlaatgasvolumestroom in roetfilter: 51.3 m³/h
                        Uitlaatgastemperatuurvoeler 3: 122.3 °C
                        Roetfilter cilinderrij 2: roetmassa gemeten: 2.42 g
                        Uitlaatgastemp.voeler 3: cilinderrij 2: -273.1 °C
    7150 - Stuurkolomelektronica
              P1698 00 [039] - Storinggeheugen afvragen
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        KM-stand: 80407 km
                        Datum: 2020.04.07
                        Tijd: 16:28:41
                        Motortoerental: 688.50 /min
                        Genorm. bel.waarde: 27.8 %
                        Rijsnelheid: 0 km/h
                        Spanning contact 30: 14.640 V
                        CAN TimeOut teller - accuregelaar-Bits 0-7: 00000000
                        CAN status - motorregelapparaat-Bits 0-7: 00000000
                        Snelheidsregelsysteem: status-Bits 0-7: 11010100
                        CAN TimeOut teller - gateway-Bits 0-7: 00000000
                        CAN TimeOut teller - stuurinslag-Bits 0-7: 00001001
                        CAN TimeOut teller - parkeerrem-Bits 0-7: 00000000
                        CAN TimeOut teller - versn.bak-Bits 0-7: 00000000
    4709 - Afstandsregeling
              U0235 00 [039] - Geen communicatie
              [Nieuwe functie! Uitgebreide UDS fout informatie is alleen beschikbaar bij de nieuwe interfaces]
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        KM-stand: 80407 km
                        Datum: 2020.04.07
                        Tijd: 16:28:41
                        Motortoerental: 692.00 /min
                        Genorm. bel.waarde: 27.5 %
                        Rijsnelheid: 0 km/h
                        Begrenzing: gaspedaal: 0.0 Nm
                        CAN status - versn.bakregelapparaat-Bits 0-7: 00000000
                        CAN status - regelapparaat remmen 1-Bits 0-7: 00000000
                        CAN status - regelapparaat remmen 2-Bits 0-7: 00000000
                        ingeschakelde versnelling-Bits 0-7: 00000000
    11281 - Roetfilter cilinderrij 2
              P2003 00 [039] - Onjuiste werking
                 Freeze frame:
                        Fout Prioriteit: 2
                        Fout Frequentie: 1
                        KM-stand: 80407 km
                        Datum: 2020.04.07
                        Tijd: 16:28:41
                        Rijsnelheid: 0 km/h
                        P Flt Ld dvol P Flt EG Flt B1 mp: 60.9 m³/h
                        Roetfilter cilinderrij 2: roetmassa berekend: 48.20 g
                        Exh p P Flt Diff B1: 8 hPa
                        Exh p P Flt Diff B2: 6 hPa
    Gereedheid: 0 0 0 0 1
    Adres 02: Autom. Transm. (J217)       Labels:| 0C8-927-750.clb
       Onderdeelnr. SW: 0C8 927 750 J    HW: 0C8 927 750 J
       Component: AL1000 AISIN  001 1822
       Serienummer:
       Codering: 001168
       Dealer #: WSC 99999 999 83333
       ASAM Dataset: EV_TCMAL991031 001001
       ROD: EV_TCMAL991031_001_VW52.rod
       VCID: 3365C33F9A1811D76B-8066
    Geen foutcodes gevonden.
    Adres 03: ABS Remmen (J104)       Labels:* 7P0-907-379.clb
       Onderdeelnr. SW: 7P0 907 379 E    HW: 7P0 907 379 A
       Component: MK25A         H33 0416
       Revisie: --------    Serienummer: 432100010EC010
       Codering: 5B6B53C30B262F58DAF9CA97D0D7F4407700
       Dealer #: WSC 31414 790 00001
       ASAM Dataset: EV_MK25AXT 007001
       ROD: EV_ESPMK25A00700.rod
       VCID: 3F8D9F0FA650C5B79F-806A
    199176 - Sensor voor stuurhoek
              B1168 29 [137] - Signaal ongeldig
              MIL AAN - Bevestigd - Getest sinds Wissen Geheugen
                 Freeze frame:
                        Fout Prioriteit: 2
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 13:49:09
                        Standard Freeze  Frame Dynamic: 00 3B 00 00 00 00 00 07 00 00 01 20 18
    199182 - Sensor voor stuurhoek
              B1168 04 [137] - Interne systeemfout
                 Freeze frame:
                        Fout Prioriteit: 2
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 13:49:09
                        Standard Freeze  Frame Dynamic: 00 3B 00 00 00 00 00 07 00 00 01 01 24
    818436 - Databus ontbrekende info
              U1121 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 2
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 13:48:39
                        Standard Freeze  Frame Dynamic: 00 3C 00 00 00 00 00 00 00 00 01 20 34
    337668 - Databus ontbrekende info
              U1121 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 2
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 13:48:39
                        Standard Freeze  Frame Dynamic: 00 3C 00 00 00 00 00 00 00 00 01 20 0E
    Adres 05: Toegang/Start Id. (J393)       Labels:. 8K0-907-064-05.clb
       Onderdeelnr. SW: 4H0 907 064 AH    HW: 4H0 907 064 AH
       Component: BCM2 2.0      H23 0208
       Revisie: 00002001
       Codering: 05860000000000000000
       VCID: 6FED0F4FBEB075374F-803A
       Subsysteem 1 - Onderdeelnr. SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Component: J764 ELV MLB  H38 0044
       Serienummer: 2310000032123013
    Adres 06: Stoel Geheugen,R (J521)       Labels: Geen
       Onderdeelnr. SW: 4H0 959 760 D    HW: 4H0 959 760 D
       Component: MEM-BFS       H08 0153
       Revisie: AA000000    Serienummer: 00001002082708
       Codering: 0018330000004201000001010101202020202121202020
       VCID: 3467C023971616EF72-8060
    Adres 08: Airco/Verwarming (J255)       Labels:| 7P6-907-040.clb
       Onderdeelnr. SW: 7P6 907 040 AJ    HW: 7P6 907 040 AJ
       Component: Klima 4 Zonen H18 0613
       Codering: 38D6007E60
       VCID: 7CF72803F7C61EAFFA-8028
    3 foutcodes gevonden:
    0267 - Sensor voor koelmediumdruk en -temperatuur
              B10C2 21 [008] - Signaal Amplitude < minimum
              Geregeld - Bevestigd - Getest sinds Wissen Geheugen
                 Freeze frame:
                        Fout Prioriteit: 7
                        Fout Frequentie: 4
                        Reset Teller: 115
                        KM-stand: 80407 km
                        Datum: 2020.04.06
                        Tijd: 13:43:38
    0410 - Functiebeperking wegens ongeldige informatie
              U1112 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 11:08:37
    0519 - Stelmotor voor indirecte ventilatieklep links
              B12A1 31 [009] - Geen signaal
                 Freeze frame:
                        Fout Prioriteit: 3
                        Fout Frequentie: 14
                        Reset Teller: 75
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 11:08:37
    Adres 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V1.clb
       Onderdeelnr. SW: 4H0 907 063 D    HW: 4H0 907 063 D
       Component: BCM1 2.0      H12 0083
       Revisie: 15012002    Serienummer: 00000000709595
       Codering: 22001011D1B45D010021000380005D0C431C67080A000241800000020000
       Dealer #: WSC 59434 001 1048576
       VCID: 2959215740D45B07D1-807C
       Subsysteem 1 - Onderdeelnr. SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
       Component: WWS    101113  31  0020
       Serienummer: 90243400101116055000
       Codering: 004DBD
       Subsysteem 2 - Onderdeelnr. SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
       Component: RLFS  H09 0011
       Serienummer: 10089124
       Codering: 035223
       Subsysteem 3 - Onderdeelnr. SW: 7P6 941 431 D    HW: 7P6 941 431 D
       Component: E1 - LDS  H04 0031
       Serienummer: 00000000002910100508
       Subsysteem 4 - Onderdeelnr. SW: 4H0 907 705 H    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0275
       Serienummer: WA101803000000119127
       Codering: 010300
    2 foutcodes gevonden:
    00466 - Regelapparaat voor stuurkolomelektronica (J527)
                013 - AUB Storingsgeheugen afvragen
                 Freeze frame:
                        Fout Status: 01101101
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Tijd Indicatie: 0
                        Datum: 2020.04.05
                        Tijd: 11:08:00
    01771 - Regelapp. lichtbundelhoogteverstelling (J431)
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 8
                        Reset Teller: 75
                        KM-stand: 80407 km
                        Tijd Indicatie: 0
                        Datum: 2020.04.06
                        Tijd: 16:49:00
    Adres 0E: Media Speler 1 (R161)       Labels: Geen
       Onderdeelnr. SW: 4H0 035 108 B    HW: 4H0 035 108
       Component: DVDCAlpine    H42 0140
       Revisie: AA001001
       Codering: 010000
       VCID: 1F4D3F8F0E90A5B7BF-804A
    Adres 10: Park/Stuurassist (J446)       Labels:| 7P6-919-475.clb
       Onderdeelnr. SW: 7P6 919 475     HW: 7P6 919 475
       Component: PARKHILFE 8K  H03 0016
       Revisie: --------    Serienummer: 38931031402002
       Codering: 518501
       ASAM Dataset: EV_VW526ParkiAssis2 001008
       ROD: EV_VW526ParkiAssis2.rod
       VCID: 55A15DA7342C2FE7A5-8000
    1112596 - Sensor voor parkeerhulp rechtsvoor
              B10FA 14 [009] - Onderbreking/kortsluiting met massa
                 Freeze frame:
                        Fout Prioriteit: 3
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 11:07:01
    1112340 - Sensor voor parkeerhulp rechtsvoor midden
              B10F9 14 [009] - Onderbreking/kortsluiting met massa
                 Freeze frame:
                        Fout Prioriteit: 3
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 11:07:01
    Adres 11: Motor II (J624)       Labels:. 057-907-409-CKD.clb
       Revisie: 52H17---
       ASAM Dataset: EV_ECM42TDI2117P0907409 001016
       ROD: EV_ECM42TDI2117P0907409.rod
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        KM-stand: 80407 km
                        Datum: 2020.04.07
                        Tijd: 16:28:41
                        Motortoerental: 689.00 /min
                        Genorm. bel.waarde: 27.1 %
                        Rijsnelheid: 0 km/h
                        Buitenluchtdruk: 1030 mbar
                        Snelheidsregelsysteem: status-Bits 0-7: 00000000
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        KM-stand: 80407 km
                        Datum: 2020.04.07
                        Tijd: 16:28:41
                        Motortoerental: 694.50 /min
                        Genorm. bel.waarde: 23.1 %
                        Rijsnelheid: 0 km/h
    Adres 13: Auto Afst. Reg.
    Wordt niet bereikt
    Adres 15: Airbags (J234)       Labels:| 7P0-959-655.clb
       Onderdeelnr. SW: 7P0 959 655 B    HW: 7P0 959 655 B
       Component: VW10Airbag007 H05 0023
       Revisie: --------    Serienummer: 003JX000SDKU
       Codering: 000000000000000000000000000000003037
       ROD: EV_AirbaVW10BPAVW526_001.rod
       VCID: 408F9CF3DBAEBA4FE6-8014
       Ongevalsensor voor zij-airbag: bestuurderszijde:
       Serienummer: 3575LRB404P07EHK589K
       Ongevalsensor voor zij-airbag: bijrijderszijde:
       Serienummer: 3585LRB405R085FME8AQ
       Ongevalsensor voor zij-airbag achterin: bestuurderszijde:
       Serienummer: 3515RRB404T053R4CHO-
       Ongevalsensor voor zij-airbag achterin: bijrijderszijde:
       Serienummer: 3525RRB404T053R4B140
       Ongevalsensor voorairbag: bestuurderszijde:
       Serienummer: 3555NRB405T0QBGIEOOZ
       Ongevalsensor voorairbag: bijrijderszijde:
       Serienummer: 3565NRB405P0QBGIL16+
    1 Fout Gevonden:
    9437211 - Ontsteker voor bestuurdersairbag
              B1000 1B [137] - Weerstand te hoog
                 Freeze frame:
                        Fout Prioriteit: 2
                        Fout Frequentie: 1
                        KM-stand: 80407 km
                        Datum: 2020.04.06
                        Tijd: 15:25:07
    Adres 16: Stuurwiel (J527)       Labels:. 4H0-953-568.clb
       Onderdeelnr. SW: 4H0 953 568 B    HW: 7P6 953 507 G
       Component: Lenks.Modul   H08 0007
       Revisie: --------    Serienummer: 90815JK50002N
       Codering: 000C9D
       VCID: 326BC63B6D0218DF60-8066
    00778 - Sensor stuurhoek (G85)
                014 - defekt
                 Freeze frame:
                        Fout Status: 01101110
                        Fout Prioriteit: 2
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Tijd Indicatie: 0
                        Datum: 2020.04.06
                        Tijd: 16:48:50
                 Freeze frame:
                        (geen eenh.): 53.0
                        Tekst: 35950000461FFC1FFF
                        Temperatuur: -0.0°C
                        Zijdel. accel.: 195.84 m/s*2
                        Tekst: 3B95FF5F12F4042413
                        Temperatuur: -127.5°C
                        Absolute druk: 39.0 mbar
                        KM-stand: 51160 km
    01426 - Bedieningseenheid in stuurwiel (E221)
                004 - Geen Signaal/Communicatie
                 Freeze frame:
                        Fout Status: 01100100
                        Fout Prioriteit: 2
                        Fout Frequentie: 19
                        Reset Teller: 0
                        KM-stand: 80407 km
                        Tijd Indicatie: 0
                        Datum: 2020.04.06
                        Tijd: 16:48:50
    Adres 17: Instrumenten (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
       Onderdeelnr. SW: 7P6 920 881 A    HW: 7P6 920 881 A
       Component: Kombi         H12 0235
       Revisie: 10240060    Serienummer: 658211110593004
       Codering: 131733007F080008000004
       ASAM Dataset: EV_KombiUDSRBVW526 001013
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 3A7BEE1BBD72E09FA8-806E
    16776960 - Functiebeperking wegens ontbrekende informatie
              U1111 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 11:04:52
    16776961 - Functiebeperking wegens ontbrekende informatie
              U1111 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 11:04:52
    Adres 18: Extr. Verwarming (J364)       Labels:. 8R0-265-105.clb
       Onderdeelnr. SW: 7P0 963 272 B    HW: 7P0 963 272 B
       Component: Standheizung  H23 0240
       Revisie: 56005006    Serienummer: 20101105111326
       Codering: 594200
       VCID: 3663FA2B816A04FF4C-8062
    1 Fout Gevonden:
    02251 - Kachel vergrendeld
                 Freeze frame:
                        Fout Status: 01100000
                        Fout Prioriteit: 5
                        Fout Frequentie: 1
                        Reset Teller: 255
                        KM-stand: 79873 km
                        Tijd Indicatie: 0
                        Datum: 2018.02.14
                        Tijd: 14:44:26
                 Freeze frame:
                        Temperatuur: 84.0°C
                        Temperatuur: 87.0°C
                        Voltage: 12.60 V
                            Regelpauze
                        Foutcode: 8
                        Temperatuur: 4.0°C
                        t/min: 654 /min
                            Nee
    Adres 19: CAN Gateway (J533)       Labels:* Geen
       Onderdeelnr. SW: 7P6 907 530 D    HW: 7P6 907 530
       Component: GW-CAN-L-FR-M H08 5202
       Revisie: --------    Serienummer: 00000000056177
       Codering: 0001037D00
       Dealer #: WSC 131071 1023 2097151
       ASAM Dataset: EV_GatewVW526UDS 001006
       ROD: EV_GatewUDS_VW52.rod
       VCID: 3979F117B874EB87A1-806C
       Regelapparaat voor accubewaking:
       Subsysteem 1 - Onderdeelnr. SW: 7P0 915 181 A    HW: 7P0 915 181
       Component: Batt_Sensor  H07 0140
       Serienummer: 00000000005659328394
    5701 - Regelapparaat voor grootlichthulp
              U1070 00 [009] - Geen communicatie
                 Freeze frame:
                        Fout Prioriteit: 2
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 11:03:42
                        Spanning contact 30: 12.3 V
                        Spanning contact 15: 12.2 V
                        Regelapparaattemperatuur: 30 °C
                        Systeemstatus: Contact 15 aan
                        IN ESP_Stillstandsflag: no standstill detected
                        Motor draait: uit
                        IN ZAS_Kl_X: aan
                        status contact 15 via CAN: aan
                        Status contact 15: aan
                        Datenfeld: 0
    4365 - Afstandsregeling
              U0235 00 [009] - Geen communicatie
                 Freeze frame:
                        Fout Prioriteit: 2
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 11:03:42
                        Motor draait: uit
                        IN ZAS_Kl_X: aan
                        Datenfeld: 0
    15360512 - Componentenbescherming actief
              U1101 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 1
                        Fout Frequentie: 9
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 11:15:01
                        Spanning contact 30: 12.2 V
                        Spanning contact 15: 12.1 V
                        Regelapparaattemperatuur: 33 °C
                        Motor draait: uit
                        IN ZAS_Kl_X: aan
                        Datenfeld: 0
    Adres 20:  20-Groot Licht Ass.
    Wordt niet bereikt
    Adres 28: Airco/Verw. achter (E265)       Labels:* Geen
       Onderdeelnr. SW: 7P6 907 049 F    HW: 7P6 907 049 F
       Component: Klima Fond    H13 0613
       Dealer #: WSC 00000 000 00000
       ASAM Dataset: EV_AirCondiHeck 001007
       ROD: EV_AirCondiHeck.rod
    1 Fout Gevonden:
    0092 - Lokale databus
              U1030 00 [009] - Elektrische storing
                 Freeze frame:
                        Fout Prioriteit: 2
                        Fout Frequentie: 14
                        Reset Teller: 75
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 11:02:03
    Adres 34: Niveau Regeling (J197)       Labels:. 7P0-907-553.clb
       Onderdeelnr. SW: 7P0 907 553 K    HW: 7P0 907 553 K
       Component: PASM          H01 1110
       Revisie: 00000000    Serienummer: 00000103130040
       Codering: 15210001
       ASAM Dataset: EV_PASMConti 001004
       ROD: EV_PASMConti.rod
    0807 - Beperkte werking
              C10C2 00 [137] - -
                 Freeze frame:
                        Fout Frequentie: 75
                        Reset Teller: 1
                        KM-stand: 524544 km
                        Datum: 2055.11.01
                        Tijd: 06:28:60
                        Default: 00
                        Default: 83
                        Default: 00
    12656777 - Databus ontvangen storingswaarde
              U1123 00 [009] - -
                 Freeze frame:
                        Fout Frequentie: 75
                        Reset Teller: 1
                        KM-stand: 524544 km
                        Datum: 2055.11.01
                        Tijd: 06:28:60
                        Default: 00
                        Default: 83
                        Default: 00
    12656679 - Databus ontbrekende info
              U1121 00 [009] - -
                 Freeze frame:
                        Fout Frequentie: 75
                        Reset Teller: 1
                        KM-stand: 524544 km
                        Datum: 2055.11.01
                        Tijd: 06:28:60
                        Default: 00
                        Default: 83
                        Default: 00
    Adres 36: Stoel Geheugen,L (J136)       Labels: Geen
       Revisie: AA000000    Serienummer: 00001002194790
       Codering: 00183B0000004201000001010101202020202121202020
    Adres 3C: Baanwisselass.        Labels: Redir Fout!
       Onderdeelnr. SW: 7P6 907 566     HW: 4H0 907 566
       Component: J769  SWA MasterH03 0110
       Revisie: 00H03000    Serienummer: 6PZ 010 316-01
       Codering: 0010151
       VCID: 7EF3220B29DA0CBFD4-802A
       Subsysteem 1 - Onderdeelnr.: 7P6 907 568
       Component: J770  SWA Slave H01 0110
       Subsysteem 2 - Serienummer: 6PZ 010 316-21
       Subsysteem 3 - Serienummer: 5F28.10.1000H010003C520137˙
       Subsysteem 4 - Serienummer: 520137˙
    Adres 42: Deur Electr. LV (J386)       Labels:. 4H0-959-793.clb
       Onderdeelnr. SW: 4H0 959 793 E    HW: 4H0 959 793 E
       Component: TSG FA        H02 0162
       Revisie: --------    Serienummer: 0000107831282
       Codering: 011D1620DE00459205080003
       VCID: 3B75EB1FBA48D997B3-806E
    03297 - Contactschakelaar in slotcilinder; bestuurderszijde
                008 - Onaannemelijk signaal
                 Freeze frame:
                        Fout Status: 01101000
                        Fout Prioriteit: 3
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Tijd Indicatie: 0
                        Datum: 2020.04.05
                        Tijd: 11:00:05
    02115 - Sloteenheid voor centr. vergrendeling
                 Freeze frame:
                        Fout Prioriteit: 3
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Tijd Indicatie: 0
                        Datum: 2020.04.06
                        Tijd: 11:54:51
    Adres 46: Comfortsysteem (J393)       Labels:. 4H0-907-064-46.clb
       Revisie: 00002001    Serienummer: 0137645683
       Codering: 019A1E2028B91095832006202F0000000000000000000000000000000000
       Subsysteem 1 - Onderdeelnr.: 7P6 951 171
       Component: DWA-Sensor  002 0204
       Subsysteem 2 - Onderdeelnr.: 1K0 951 605 C
       Subsysteem 3 - Onderdeelnr. SW: 7P0 959 591     HW: 7P0 959 591
       Component: J245 PS30.050  H05 0006
       Serienummer:     WOO1083540
       Codering: 191100
       Subsysteem 4 - Onderdeelnr. SW: 7P0 959 591 A    HW: 4H0 959 591
       Component: J394 PS30.050  H06 0006
       Serienummer:     WOO1073381/
       Codering: 191100
    1 Fout Gevonden:
    01319 - Regelapparaat voor afstandsregeling (J428)
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Tijd Indicatie: 0
                        Datum: 2020.04.05
                        Tijd: 10:59:28
    Adres 52: Deur Electr. RV (J387)       Labels:. 4H0-959-792.clb
       Onderdeelnr. SW: 4H0 959 792 F    HW: 4H0 959 792 F
       Component: TSG BF        H07 0162
       Revisie: --------    Serienummer: 0000110083759
       Codering: 011D1620DE00459205080000
    Adres 53: Handrem (J540-)       Labels:| 7P0-907-801.clb
       Onderdeelnr. SW: 7P0 907 801 D    HW: 7P0 907 801 D
       Component: EPB           H51 1000
       Revisie: 00000000    Serienummer: A10A2000368
       Codering: 01040000
       ROD: EV_ParkbA7.rod
       VCID: 3467C0239F1616EF72-8060
       Slave 1:
       Slave 3:
    0025 - Geen basisafstelling
              B2010 F0 [008] - Afwijking ligt buiten verwachte gebied
                 Freeze frame:
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.07
                        Tijd: 16:10:53
                        Voltage: 14.4 V
    0024 - Geen basisafstelling
              B2010 00 [009] - -
                 Freeze frame:
                        Fout Frequentie: 1
                        Voltage: 12.2 V
              U1121 00 [009] - -
                 Freeze frame:
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.07
                        Tijd: 15:56:15
                        Voltage: 12.2 V
    Adres 55: Xenon Niveau (J745)       Labels:. 7P6-907-357.clb
       Onderdeelnr. SW: 7P6 907 357     HW: 7L6 907 357 C
       Revisie: --------    Serienummer: --------------
       Codering: 012A00104F000200
       Subsysteem 1 - Onderdeelnr. SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 0010
       Codering: 190000
       Subsysteem 2 - Onderdeelnr. SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0002
       Codering: 130000
    13636608 - Regelapparaat verkeerd gecodeerd
              U1014 00 [137] - -
                 Freeze frame:
                        Fout Prioriteit: 1
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 17:22:39
    5276401 - Vermogensmodule koplamp rechts
              C1082 F1 [137] - Verkeerd gecodeerd
                 Freeze frame:
                        Fout Prioriteit: 2
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 17:22:39
    13705992 - Databus ontvangen storingswaarde
              U1123 00 [137] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 17:22:39
    13705995 - Databus ontvangen storingswaarde
              U1123 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 30
                        Reset Teller: 75
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 17:22:39
    Adres 56: Radio (R)       Labels: Redir Fout!
       Onderdeelnr. SW: 4G0 035 053 A    HW: 4G0 035 053
       Component: Radio U Basic H52 0050
       Revisie: AB001007    Serienummer: 050K-0A7529641
       Codering: 010005020100000001
       VCID: 1C3708831F86BEAF5A-8048
    Adres 5F: Info Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
       Onderdeelnr. SW: 7P6 035 670     HW: 7P6 035 670
       Component: H-BNT-EU      H43 0203
       Revisie: --------    Serienummer: 478KB0A7526649
       Codering: 010100050040EBEF79102B0E00000003F0040101
       VCID: 72EB063BAD8258DFA0-8026
       Subsysteem 1 - Onderdeelnr.: 8R0 060 884 R
       Component: EUR 2010  1106
       Subsysteem 2 - Onderdeelnr. SW: 7P6 919 603     HW: 7P6 919 603
       Component: DU8 SV Touch  H24 0045
       Serienummer: VWZ8Z9K2800GBJ
       Subsysteem 3 - Onderdeelnr. SW: 7P6 919 603     HW: 7P6 919 603
       Subsysteem 4 - Onderdeelnr.: 8R0 060 961
       Component: CD-Database  1886
    1 Fout Gevonden:
    03157 - Beperkte werking wegens communicatiestoring
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 2
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Tijd Indicatie: 0
                        Datum: 2020.04.05
                        Tijd: 10:55:02
                 Freeze frame:
                        Bin. bits: 00000000 00100000
                        Bin. bits: 00001000 00000000
                        Bin. bits: 00000000 00000000
    Adres 62: Deur Electr. LA (J388)       Labels:. 4H0-959-795.clb
       Onderdeelnr. SW: 4H0 959 795 B    HW: 4H0 959 795 B
       Component: TSG HL        H09 0162
       Revisie: --------    Serienummer: 0000110119070
       Codering: 011C16200000259005080000
       VCID: 3A7BEE1BB572E09FA8-806E
    Adres 65: Bandenspanning (J502)       Labels: 3Y0-907-273.clb
       Onderdeelnr. SW: 7P6 907 273 F    HW: 7P6 907 273 F
       Component: RDKBERU25     H09 0008
       Serienummer: 10000000016059
       ROD: EV_RDKBERU25_VW52.rod
    1 Fout Gevonden:
    8402177 - Systeem uitgeschakeld
              C106D 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 7
                        Fout Frequentie: 1
                        Reset Teller: 39
                        KM-stand: 79872 km
                        Datum: 2018.03.14
                        Tijd: 12:24:58
    Adres 69: Aanhanger (J345)       Labels: Redir Fout!
       Onderdeelnr. SW: 7P0 907 383 F    HW: 7P0 907 383 B
       Component: Anhaenger     H11 0110
       Revisie: 5A001001    Serienummer: 00008200796325
       Codering: 0100000000000000
    Adres 6C: Achteruit Camera (J928)       Labels:| 7P6-907-441-V1.clb
       Onderdeelnr. SW: 7P6 907 441 D    HW: 7P6 907 441 D_
       Component: TopView       H05 0097
       Revisie: 11001001    Serienummer: 82330010114871
       Codering: 0100000001010000010102000000
       ASAM Dataset: EV_CamerSysteTopViewVW 001014
       ROD: EV_CamerSysteTopViewVW.rod
    5 foutcodes gevonden:
    13701890 - Databus ontvangen storingswaarde
              U1123 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 10:51:55
                        Spanning contact 30: 12.1 V
                        Status contact 15: Contact 15 aan
    9616922 - Voedingsspanning afstandscontrolecamera voor
              B1284 14 [009] - Onderbreking/kortsluiting met massa
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 42
                        Reset Teller: 75
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 10:51:55
    9616433 - Kabel voor videosignaal van afstandscontrolecamera voor
              B1278 01 [009] - Electrische storing
                 Freeze frame:
                        Fout Prioriteit: 3
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 10:51:55
    9616790 - Afstandscontrolecamera voor
              B127C 54 [009] - Kalibratie niet aanwezig
                 Freeze frame:
                        Fout Prioriteit: 5
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 10:51:56
    10489856 - Geen basisafstelling
              B2010 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 2
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 10:51:56
    Adres 6D: Electr. Kofferd. (----)       Labels:| 7N0-959-107.clb
       Onderdeelnr. SW: 7P6 959 107     HW: 7P6 959 107
       Component: HDSG-Modul    H10 0611
       Revisie: 09145444    Serienummer: 310000028
       Codering: 0533314003
       ASAM Dataset: EV_HeckkTouar 202135
       ROD: EV_HeckkTouar.rod
    Adres 72: Deur Electr. RA (J389)       Labels:. 4H0-959-795.clb
       Component: TSG HR        H09 0162
       Revisie: --------    Serienummer: 0000110119376
    Adres 85: Camera (J852)       Labels:| 7P6-907-217.clb
       Onderdeelnr. SW: 7P6 907 217 A    HW: 7P6 907 217
       Component: DPC-SG        H22 0033
       Revisie: --------    Serienummer: 262130025421000
       Codering: ED070000
       ASAM Dataset: EV_OnBoardCamerDTR 001001
       ROD: EV_OnBoardCamerDTR.rod
       VCID: 387FF413837EF28F5E-806C
       Slave 1:
       Subsysteem 1 - Onderdeelnr.: 7P6 907 658
       Component: NICKRATENSENS  H02 0001
       Serienummer: 000000003020741_1011
    0723 - Functiebeperking door ontvangen storingwaarde
              U1113 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 10:57:09
                        Buitentemperatuur: -41.5 °C
                        Regelapparaattemperatuur: 31.0 °C
    0724 - Functiebeperking wegens ontbrekende informatie
              U1111 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 10:57:09
    Adres 8B: Adaptieve Cruise 2        Labels:. 4H0-907-561.clb
       Onderdeelnr. SW: 7P6 907 541 A    HW: 7P6 907 541
       Revisie: J428     Serienummer: 00000000000000
       Codering: 05
       ASAM Dataset: EV_AdaptCruisContr2VW526 001004
       ROD: EV_AdaptCruisContr2VW526_001.rod
    10 foutcodes gevonden:
    94720 - Functiebeperking door ontvangen storingwaarde
              U1113 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 75
                        KM-stand: 80407 km
                        Datum: 2020.04.07
                        Tijd: 16:43:45
    95232 - Functiebeperking door ontvangen storingwaarde
              U1113 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 3
                        Reset Teller: 75
                        KM-stand: 80407 km
                        Datum: 2020.04.07
                        Tijd: 16:47:36
                        Regelapparaattemperatuur: 28 °C
                        Spanning contact 15: 0.000 V
    38912 - Functiebeperking wegens ontbrekende informatie
              U1111 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 75
                        KM-stand: 80407 km
                        Datum: 2020.04.07
                        Tijd: 16:41:11
                        Regelapparaattemperatuur: 24 °C
    38656 - Functiebeperking wegens ontbrekende informatie
              U1111 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 115
                        KM-stand: 80384 km
                        Datum: 2000.00.00
                        Tijd: 00:00:00
    21760 - Functiebeperking wegens ontbrekende informatie
              U1111 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 115
                        KM-stand: 80407 km
                        Datum: 2020.04.06
                        Tijd: 16:48:16
    77312 - Functiebeperking wegens ontbrekende informatie
              U1111 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 75
                        KM-stand: 80407 km
                        Datum: 2020.04.07
                        Tijd: 16:41:10
    77568 - Functiebeperking wegens ontbrekende informatie
              U1111 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 75
                        KM-stand: 80407 km
                        Datum: 2020.04.07
                        Tijd: 16:41:11
    105472 - Functiebeperking door ontvangen storingwaarde
              U1113 00 [000] - -
              Geregeld - Niet Bevestigd - Getest sinds Wissen Geheugen
                 Freeze frame:
                        Fout Status: 00000000
                        Fout Prioriteit: 0
                        Fout Frequentie: 0
                        Reset Teller: 0
                        KM-stand: 23 km
                        Datum: 2020.04.07
                        Tijd: 16:43:45
    0000 - ROD - Onbekende Fout Code
              - 00 [000]
              - 00 [009]
    Adres 8E: Beeldverwerking (J851)       Labels:| 7P6-907-107.clb
       Onderdeelnr. SW: 7P6 907 107 A    HW: 7P6 907 107
       Component: BV-SG         H28 0031
       Serienummer: 000040192709107
       Codering: 0AA03E000000
       ASAM Dataset: EV_BTR 002001
       ROD: EV_BTR_002.rod
       VCID: 3663FA2B896A04FF4C-8062
    0012 - Beperkte werking
              U1400 00 [008] - door onderspanning
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 3
                        Reset Teller: 111
                        KM-stand: 80262 km
                        Datum: 2018.08.29
                        Tijd: 05:11:32
                        Buitentemperatuur: 11.0 °C
                        Spanning contact 15: 7.9 V
                        Regelapparaattemperatuur: 12.0 °C
    0045 - Functiebeperking door ontvangen storingwaarde
              U1113 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 19
                        Reset Teller: 71
                        KM-stand: 80175 km
                        Datum: 2018.07.08
                        Tijd: 09:26:51
                        Buitentemperatuur: 11.5 °C
                        Spanning contact 15: 11.8 V
                        Regelapparaattemperatuur: 24.0 °C
    0046 - Functiebeperking wegens ontbrekende informatie
              U1111 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 19
                        Reset Teller: 71
                        KM-stand: 80175 km
                        Datum: 2018.07.08
                        Tijd: 09:26:51
    Adres 8F: Voorspan. Linksvoor  (J854)       Labels: 4H0-980-94x-RGS.clb
       Onderdeelnr. SW: 4H0 980 945 B    HW: 4H0 980 945 B
       Codering: 006606000317037F00033811594097000000
       Dealer #: WSC 00001 790 00001
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 3169C937600423C719-8064
    12583680 - Functiebeperking wegens ontbrekende informatie
              U1111 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 10:50:12
    12583693 - Functiebeperking wegens ontbrekende informatie
              U1111 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 10:50:12
    12584197 - Functiebeperking door ontvangen storingwaarde
              U1113 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 10:50:12
    15360768 - Componentenbescherming actief
              U1101 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 1
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 10:50:12
    Adres 90: Voorspan. Rechtsvoor (J855)       Labels: 4H0-980-94x-RGS.clb
       Onderdeelnr. SW: 4H0 980 946 B    HW: 4H0 980 946 B
       Codering: 00660600031F037F00033811594097000000
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 326BC63B650218DF60-8066
              U1111 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 10:49:33
              U1111 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 10:49:33
              U1113 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 6
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 10:49:33
              U1101 00 [009] - -
                 Freeze frame:
                        Fout Prioriteit: 1
                        Fout Frequentie: 1
                        Reset Teller: 74
                        KM-stand: 80407 km
                        Datum: 2020.04.05
                        Tijd: 10:49:33
    Einde----------------------(Tijd verstreken: 07:19)------------------------
    I hope it is not a problem that it is in Dutch, My vcds version is in Dutch.
    Thanx!
    Quote Originally Posted by Joris View Post
    For the purpose of posting data in this forum, you can download the standard English version from this page. It will happily co-exist on with the Dutch translation you are currently using.
    In addition, please Get Verified.
    PS: Moving from General VW/Audi Repair (which is for questions that don't involve VCDS) to New User section.
    Apr 2020
    filled out the form, installed english version
    I will post a new scan later
  4. Likes Uwe, Jack@European_Parts liked this post
    Apr 2020
    Got verified..
    Steering angle sensor came in and it calibrated, so that works.
    New scan in English:
    Wednesday,08,April,2020,15:08:32:11641
    VCDS Version: 20.4.0.1 (x64)
    VIN: WVGZZZ7PZBD025545   License Plate:
    VIN: WVGZZZ7PZBD025545   Mileage: 80407km-49962miles
    11-Engine II -- Status: Malfunction 0010
    31-Engine other -- Status: Malfunction 0010
    13-Auto Dist. Reg -- Status: Cannot be reached 0100
    20-High Beam Assist. -- Status: Cannot be reached 0100
    8F-Pretens. Frt Left -- Status: Malfunction 0010
    90-Pretens. Frt Right -- Status: Malfunction 0010
    Address 01: Engine (J623-CKDA)       Labels:. 057-907-409-CKD.clb
       Part No SW: 7P0 907 409     HW: 7P0 907 409
       Revision: 52H17---
       Coding: 292A401A437E00020000
       Shop #: WSC 59434 001 104857
       VCID: 74E70023DF96562616-8020
    11279 - Particle Filter (Bank 2)
              P24A3 00 [167] - Excessive Soot Accumulation
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:46:18
                        Coolant temperature: 20 °C
                        Intake air temperature: 21 °C
                        Voltage terminal 30: 12.020 V
                        Particle filter: soot mass measured: 2.89 g
                        Particle filter: soot mass calculated: 1.14 g
                        Particle filter: kilometers since last regeneration: 0 m
                        Exhaust gas jet volume in particle filter: 150.0 m³/h
                        Exh.gas temp.sen 3: 21.9 °C
                        Particle filter bank 2: soot mass measured: 2.14 g
                        Exhaust temperature sensor 3: bank 2: -273.1 °C
    4709 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [039] - -
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:46:18
                        CAN status - engine control module-Bits 0-7: 00000000
                        Cruise Control System (CCS): status-Bits 0-7: 11010100
                        CAN status - transmission control module-Bits 0-7: 00000000
                        CAN status - brake control module 1-Bits 0-7: 00000000
                        CAN status - brake control module 2-Bits 0-7: 00000000
                        selected gear-Bits 0-7: 00000000
    11281 - Particulate Trap Bank 2
              P2003 00 [039] - Efficiency Below Threshold
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:46:18
                        P Flt Ld dvol P Flt EG Flt B1 mp: 45.0 m³/h
                        Particle filter bank 2: soot mass calculated: 48.55 g
                        Exh p P Flt Diff B1: 4 hPa
                        Exh p P Flt Diff B2: 2 hPa
       Part No SW: 0C8 927 750 J    HW: 0C8 927 750 J
       Coding: 001168
       Shop #: WSC 99999 999 83333
       VCID: 3365C33F9A18111ECF-8066
    Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
       Part No SW: 7P0 907 379 E    HW: 7P0 907 379 A
       Revision: --------    Serial number: 432100010EC010
       Coding: 5B6B53C30B262F58DAF9CA97D0D7F4407700
       Shop #: WSC 31414 790 00001
       VCID: 3F8D9F0FA650C57E3B-806A
    818436 - Databus
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:47:15
                        Standard Freeze  Frame Dynamic: 00 3B 00 00 00 00 00 07 00 00 01 20 34
    337668 - Databus
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:47:15
                        Standard Freeze  Frame Dynamic: 00 3B 00 00 00 00 00 07 00 00 01 20 0E
       Part No SW: 4H0 907 064 AH    HW: 4H0 907 064 AH
       Coding: 05860000000000000000
       VCID: 6FED0F4FBEB075FEEB-803A
       Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Serial number: 2310000032123013
       Revision: AA000000    Serial number: 00001002082708
       Coding: 0018330000004201000001010101202020202121202020
       VCID: 3467C02397161626D6-8060
       Part No SW: 7P6 907 040 AJ    HW: 7P6 907 040 AJ
       Coding: 38D6007E60
       VCID: 7CF72803F7C61E665E-8028
    0519 - Positioning Motor for Left Indirect Vent Flap
              B12A1 31 [009] - No Signal
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:48:47
       Part No SW: 4H0 907 063 D    HW: 4H0 907 063 D
       Revision: 15012002    Serial number: 00000000709595
       Coding: 22001011D1B45D010021000380005D0C431C67080A000241800000020000
       Shop #: WSC 59434 001 1048576
       VCID: 2959215740D45BCE75-807C
       Serial number: 90243400101116055000
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
       Serial number: 10089124
       Coding: 035223
       Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
       Serial number: 00000000002910100508
       Subsystem 4 - Part No SW: 4H0 907 705 H    HW: 4H0 907 705 C
       Serial number: WA101803000000119127
       Coding: 010300
    Address 0E: Media Player 1 (R161)       Labels: None
       Part No SW: 4H0 035 108 B    HW: 4H0 035 108
       Revision: AA001001
       VCID: 1F4D3F8F0E90A57E1B-804A
    Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
       Part No SW: 7P6 919 475     HW: 7P6 919 475
       Revision: --------    Serial number: 38931031402002
       Coding: 518501
       VCID: 55A15DA7342C2F2E01-8000
    1112596 - Front Right Parking Aid Sensor
              B10FA 14 [009] - Open or Short to Ground
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:49:50
    1112340 - Front Right Center Parking Aid Sensor
              B10F9 14 [009] - Open or Short to Ground
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:49:50
    Address 11: Engine II (J624)       Labels:. 057-907-409-CKD.clb
       Revision: 52H17---
              U0235 00 [039] - -
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:46:18
                        Voltage terminal 30: 12.040 V
                        Cruise Control System (CCS): status-Bits 0-7: 00000000
    Address 13: Auto Dist. Reg
       Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
       Revision: --------    Serial number: 003JX000SDKU
       Coding: 000000000000000000000000000000003037
       VCID: 408F9CF3DBAEBA8642-8014
       Serial number: 3575LRB404P07EHK589K
       Serial number: 3585LRB405R085FME8AQ
       Serial number: 3515RRB404T053R4CHO-
       Serial number: 3525RRB404T053R4B140
       Serial number: 3555NRB405T0QBGIEOOZ
       Serial number: 3565NRB405P0QBGIL16+
       Part No SW: 4H0 953 568 B    HW: 7P6 953 507 G
       Component: Lenks.Modul   H07 0007
       Revision: --------    Serial number: 90815JD90001D
       Coding: 000C9D
       VCID: 326BC63B6D021816C4-8066
       Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
       Component: E221__MFL-TAS  H03 0027
       Serial number: 0012780
    Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
       Part No SW: 7P6 920 881 A    HW: 7P6 920 881 A
       Revision: 10240060    Serial number: 658211110593004
       Coding: 131733007F080008000004
       VCID: 3A7BEE1BBD72E0560C-806E
    16776960 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:51:57
    16776961 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:51:57
    Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
       Part No SW: 7P0 963 272 B    HW: 7P0 963 272 B
       Revision: 56005006    Serial number: 20101105111326
       Coding: 594200
       VCID: 3663FA2B816A0436E8-8062
    02251 - Heater Unit Locked
                        Mileage: 79873 km
                        Date: 2018.02.14
                        Time: 14:44:26
                        Temperature: 84.0°C
                        Temperature: 87.0°C
                        Voltage: 12.60 V
                            Ctrl. Pause
                        Error Code: 8
                        Temperature: 4.0°C
                        RPM: 654 /min
                            No
       Part No SW: 7P6 907 530 D    HW: 7P6 907 530
       Revision: --------    Serial number: 00000000056177
       Coding: 0001037D00
       VCID: 3979F117B874EB4E05-806C
       Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
       Serial number: 00000000005659328394
    5701 - High Beam Assistant Control Module
              U1070 00 [009] - No Communication
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:52:53
                        Voltage terminal 30: 11.9 V
                        Voltage terminal 15: 11.8 V
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
    4365 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [009] - -
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:52:53
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    Address 20: High Beam Assist.
    Address 28: HVAC, Rear (E265)       Labels:* None
       Part No SW: 7P6 907 049 F    HW: 7P6 907 049 F
       Coding: 0000000000
       ROD: EV_AirCondiHeck_VW52.rod
    0092 - Local Databus
              U1030 00 [009] - Electrical Malfunction
                        Fault Frequency: 19
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 11:02:03
    Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
       Part No SW: 7P0 907 553 K    HW: 7P0 907 553 K
       Revision: 00000000    Serial number: 00000103130040
       Coding: 15210001
    0840 - Comfort limitation
              C10D7 00 [137] - -
                        Fault Frequency: 75
                        Reset counter: 1
                        Mileage: 661248 km
                        Date: 2068.03.22
                        Time: 25:04:60
                        Default: 00
                        Default: 70
                        Default: 00
    12656679 - Databus
                        Fault Frequency: 75
                        Reset counter: 1
                        Mileage: 661248 km
                        Date: 2068.03.22
                        Time: 25:04:60
                        Default: 00
                        Default: 70
                        Default: 00
       Revision: AA000000    Serial number: 00001002194790
       Coding: 00183B0000004201000001010101202020202121202020
    Address 3C: Lane Change        Labels: Redir Fail!
       Part No SW: 7P6 907 566     HW: 4H0 907 566
       Revision: 00H03000    Serial number: 6PZ 010 316-01
       Coding: 0010151
       VCID: 7EF3220B29DA0C7670-802A
       Subsystem 1 - Part No: 7P6 907 568
       Subsystem 2 - Serial number: 6PZ 010 316-21
       Subsystem 3 - Serial number: 5F28.10.1000H010003C520137˙
       Subsystem 4 - Serial number: 520137˙
       Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
       Revision: --------    Serial number: 0000107831282
       Coding: 011D1620DE00459205080003
       VCID: 3B75EB1FBA48D95E17-806E
    03297 - Switch in Lock Cylinder; Driver Side
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 74
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 11:00:05
                        Reset counter: 74
                        Mileage: 80407 km
                        Date: 2020.04.06
                        Time: 11:54:51
       Revision: 00002001    Serial number: 0137645683
       Coding: 019A1E2028B91095832006202F0000000000000000000000000000000000
       Subsystem 1 - Part No: 7P6 951 171
       Subsystem 3 - Part No SW: 7P0 959 591     HW: 7P0 959 591
       Serial number:     WOO1083540
       Coding: 191100
       Subsystem 4 - Part No SW: 7P0 959 591 A    HW: 4H0 959 591
       Serial number:     WOO1073381/
       Coding: 191100
    01319 - Control Module for Distance Control (J428)
                        Reset counter: 74
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 10:59:28
       Revision: --------    Serial number: 0000110083759
       Coding: 011D1620DE00459205080000
       Part No SW: 7P0 907 801 D    HW: 7P0 907 801 D
       Revision: 00000000    Serial number: A10A2000368
       Coding: 01040000
       ROD: EV_ParkbA7.rod
       VCID: 3467C0239F161626D6-8060
       Slave 1:
       Slave 3:
    0024 - No Basic Setting
              B2010 00 [009] - -
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:55:52
                        Voltage: 11.8 V
    12656679 - Databus
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:55:37
                        Voltage: 11.8 V
    Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
       Coding: 012A00104F000200
       Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
       Coding: 190000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Coding: 130000
              U1014 00 [137] - -
                        Reset counter: 74
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 17:22:39
    5276401 - Power Output Module for Right Headlamp
              C1082 F1 [137] - Incorrectly Coded
                        Reset counter: 74
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 17:22:39
    13705992 - Databus
                        Reset counter: 115
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 17:22:39
    13705995 - Databus
                        Fault Frequency: 37
                        Reset counter: 115
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 17:22:39
       Part No SW: 4G0 035 053 A    HW: 4G0 035 053
       Revision: AB001007    Serial number: 050K-0A7529641
       Coding: 010005020100000001
       VCID: 1C3708831F86BE66FE-8048
       Part No SW: 7P6 035 670     HW: 7P6 035 670
       Revision: --------    Serial number: 478KB0A7526649
       Coding: 010100050040EBEF79102B0E00000003F0040101
       VCID: 72EB063BAD82581604-8026
       Subsystem 1 - Part No: 8R0 060 884 R
       Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
       Serial number: VWZ8Z9K2800GBJ
       Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
                        Reset counter: 74
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 10:55:02
                        Bin. Bits: 00000000 00100000
                        Bin. Bits: 00001000 00000000
                        Bin. Bits: 00000000 00000000
       Revision: --------    Serial number: 0000110119070
       Coding: 011C16200000259005080000
       VCID: 3A7BEE1BB572E0560C-806E
       Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
       Serial number: 10000000016059
    8402177 - System Switched Off
              C106D 00 [009] - -
                        Reset counter: 39
                        Mileage: 79872 km
                        Date: 2018.03.14
                        Time: 12:24:58
    Address 69: Trailer (J345)       Labels: Redir Fail!
       Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
       Revision: 5A001001    Serial number: 00008200796325
       Coding: 0100000000000000
    Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
       Part No SW: 7P6 907 441 D    HW: 7P6 907 441 D_
       Revision: 11001001    Serial number: 82330010114871
       Coding: 0100000001010000010102000000
    9616922 - Supply Voltage for Front Surroundings Camera
              B1284 14 [009] - Open or Short to Ground
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:56:14
                        Voltage terminal 30: 11.8 V
    9616433 - Video Signal Line for Front Surroundings Camera
              B1278 01 [009] - Electrical Failure
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:56:14
    9616790 - Front Surroundings Camera
              B127C 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:56:14
    10489856 - No Basic Setting
              B2010 00 [009] - -
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:56:14
       Part No SW: 7P6 959 107     HW: 7P6 959 107
       Revision: 09145444    Serial number: 310000028
       Coding: 0533314003
       Revision: --------    Serial number: 0000110119376
       Part No SW: 7P6 907 217 A    HW: 7P6 907 217
       Coding: ED070000
       VCID: 387FF413837EF246FA-806C
       Slave 1:
       Subsystem 1 - Part No: 7P6 907 658
       Serial number: 000000003020741_1011
    0723 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 115
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 10:57:09
                        Outside air temperature: -41.5 °C
                        Voltage terminal 15: 12.1 V
                        Control Module temperature: 31.0 °C
    0724 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 74
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 10:57:09
    Address 8B: Adaptive Cruise 2        Labels:. 4H0-907-561.clb
       Part No SW: 7P6 907 541 A    HW: 7P6 907 541
       Revision: J428     Serial number: 00000000000000
       Coding: 05
    10 Faults Found:
    94720 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:59:16
                        Control Module temperature: 25 °C
                        Voltage terminal 15: 0.000 V
    95232 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 15:02:58
                        Control Module temperature: 26 °C
    95488 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:57:33
    38912 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:57:33
    38656 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:57:33
    21760 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:57:33
    77312 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:57:33
    77568 - Function Restricted due to Missing Message(s)
              U1111 00 [000] - -
                        Reset counter: 75
                        Mileage: 80407 km
                        Date: 2020.04.08
                        Time: 14:57:33
    0000 - ROD - Unknown Error Code
              - 00 [000]
              - 00 [009]
    Address 8E: Image Processing (J851)       Labels:| 7P6-907-107.clb
       Part No SW: 7P6 907 107 A    HW: 7P6 907 107
       Serial number: 000040192709107
       Coding: 0AA03E000000
       ROD: EV_BTR_002.rod
       VCID: 3663FA2B896A0436E8-8062
    0012 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 111
                        Mileage: 80262 km
                        Date: 2018.08.29
                        Time: 05:11:32
                        Outside air temperature: 11.0 °C
                        Voltage terminal 15: 7.9 V
                        Control Module temperature: 12.0 °C
    0045 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Fault Frequency: 21
                        Reset counter: 115
                        Mileage: 80175 km
                        Date: 2018.07.08
                        Time: 09:26:51
                        Outside air temperature: 11.5 °C
                        Control Module temperature: 24.0 °C
    0046 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Fault Frequency: 19
                        Reset counter: 71
                        Mileage: 80175 km
                        Date: 2018.07.08
                        Time: 09:26:51
       Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
       Coding: 006606000317037F00033811594097000000
       Shop #: WSC 00001 790 00001
       ROD: EV_RGS_L_VW52.rod
       VCID: 3169C9376004230EBD-8064
    12583680 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 74
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 10:50:12
    12583693 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 74
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 10:50:12
    12584197 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 115
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 10:50:12
              U1101 00 [009] - Active
                        Reset counter: 74
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 10:50:12
       Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
       Coding: 00660600031F037F00033811594097000000
       ROD: EV_RGS_R_VW52.rod
       VCID: 326BC63B65021816C4-8066
              U1111 00 [009] - -
                        Reset counter: 74
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 10:49:33
              U1111 00 [009] - -
                        Reset counter: 74
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 10:49:33
              U1113 00 [008] - -
                        Reset counter: 115
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 10:49:33
                        Reset counter: 74
                        Mileage: 80407 km
                        Date: 2020.04.05
                        Time: 10:49:33
    End-------------------------(Elapsed Time: 07:10)--------------------------
  6. Likes Uwe, Jack@European_Parts, Dana liked this post
    OK, moving this to Car Repair Support.
    So looking at that scan, a lot of "Missing Message" faults. These are not surprising since your 13 - Auto Dist. Reg and your 20 - High Beam Assist modules are both off-line. Have you got wiring diagrams for this vehicle yet?
    is the PSI sensor signal line clear?
    Have you tried chemical removal or manual remediation of the DPF yet and verify the PSI sensor is working or reporting properly by correlating to other bank with mighty vac?
    Did you know some have had good luck with a reverse flow enema using emulsifiers injected up the tail pipes and empty out forward OXS with a block plate installed to stop ingress to engine and turbo charger?
  10. #8
    Apr 2020
    I have the reparaturleitfaden electrische anlage in pdf, but am not the best in reading those diagrams. Can i upload pdf's to the forum?
  11. #9
    Have you been here?
    https://forums.ross-tech.com/showthread.php?2884
    No, they are copyrighted material.
  12. Likes Jack@European_Parts liked this post
  13. #10
    Apr 2020
    I bought 2 bottles of dpf cleaner to throw in the tank, and am going to try that first.
