Results 1 to 3 of 3
Thread: PTU/Gearbox Do they share fluid? 6 speed Quattro
    Feb 2020
    Good morning,
    I just replaced the Clutch in my 2008 Audi TT 3.2L and was wandering if the Gearbox oil also fills up the PTU? When I removed the Starboard (right) CV axle mount gear from the PTU it also slid into the gear box so I would assume it shares the fluid.
    Thanks,
    Curtiss
    16.4905 S, 151.7375 W
    In a 2008 Audi TT the follow should be used:
    Transmissions -
    Manual (02Q) fluid: (2.3L), use [G 052 171 A2]*
    Automatic (02E) fluid: New fill (6.9L), use [G 052 182 A2]*
    Final Drive (Front/Rear) -
    All-wheel drive/Bevel box/Differential/Gearbox, etc (quattro): (0.9L), use [G 052 145 S2]*
    Haldex Clutch: New fill (0.85L), use [G 055 175 A2]*
    * All part numbers are for reference only, trust but verify!
    Hope this helps,
    drpeter
  3. Likes Uwe, Fredrick Awuor liked this post
    Feb 2020
    Thank you for the input.
  5. Likes DrPeter liked this post
