What does 'Function Restricted due to Missing Message' mean at address 75 in scan below?
Friday,03,April,2020,14:54:46:39636
VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWZZZ3CZLE048230 License Plate:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 03 05 08 09 10 13 15 17 19 23 2B 42 44 52 5F 65 75 A5 CA
VIN: WVWZZZ3CZLE048230 Mileage: 6906km-4291miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DSRA) Labels: None
Part No SW: 05L 906 022 BJ HW: 05L 907 309 B
Component: R4 2.0l TDI H30 9737
Revision: E3H30---
Coding: 011904120344050830000000000000000000000000000000
Shop #: WSC 05311 115 00312
ASAM Dataset: EV_ECM20TDI01105L906022BJ 006004
ROD: EV_ECM20TDI01105L906022BJ_006_VW48.rod
VCID: 70B9D7D03A2ABECBA32-8024
Readiness: 0 0 0 1 1
Part No SW: 5Q0 614 517 FA HW: 5Q0 614 517 BR
Component: ESC H82 0190
Revision: 00000000 Serial number: 62799000003903
Coding: 0EECBA8F31243B744779060360C349705D8CDCE2600692713460F00850224A0B0003000012121212B835351919323200
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 75B7E6C445489BE3704-8020
Part No SW: 3Q0 959 435 M HW: 3Q0 959 435 M
Component: VWKESSYMQB 027 1307
Revision: 00027000 Serial number: 0529356985
Coding: 002F0F0623
ASAM Dataset: EV_KessyHellaMQBAB 004052
ROD: EV_KessyHellaMQBAB.rod
VCID: 44D14B005E12726B37A-8010
Part No SW: 5G0 907 044 ER HW: 5G0 907 044 ER
Component: Climatronic H04 2202
Revision: 00001K10
Coding: 1112011420011001111500008010D836
ASAM Dataset: EV_ACClimaBHBVW37X 006150
VCID: 7BA3F0FC636CCD93060-802E
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 086 CE HW: 5Q0 937 086 BQ
Component: BCM PQ37BOSCH 038 0303
Revision: -------- Serial number: J53F22091900EP
ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
ROD: EV_BCMBOSCH_020.rod
VCID: 7F5B04EC7774D1B32A8-802A
Subsystem 1 - Part No SW: 3G2 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 190823 043 0607
Serial number: 190913094057
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: SBY19M10D10H01M04S38
Coding: 0008DD
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 11 10 2019 10001133
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY192550TNA
Subsystem 5 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000637664
Steering Column Switch:
Subsystem 7 - Part No SW: 5Q1 953 521 BC HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0100160920190C100917
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058319278
Coding: 0471051801
Shop #: WSC 05311 115 00091
ASAM Dataset: EV_EPHVA18AU3700000 009046
VCID: 50F977509A6A9ECB832-8004
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 R HW: 3Q0 907 567 A
Component: ACC BOSCH MQB H01 0771
Coding: 2A0178C251FFC728949C812461400600000000000000000066
ASAM Dataset: EV_ACCBOSCHVW416 003014
ROD: EV_ACCBOSCHVW416_003.rod
VCID: 46D55108682E407B29E-8012
Part No SW: 3Q0 959 655 CP HW: 3Q0 959 655 CP
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z4PHKNN0L
Coding: 98FCC0C0000000005C5400CF008840000065
Shop #: WSC 05311 000 08193
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 0E45A92840DEC83BD1E-805A
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1040
Serial number: 3G0857705B0277T01240
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1040
Serial number: 3G0857706B0287T01049
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 002 208 19
Serial number: 3570000000056A58FE3
Subsystem 4 - Part No SW: ----------- HW: 454 002 108 19
Serial number: 358000000002F328FE3Z
Subsystem 5 - Part No SW: ----------- HW: 454 802 708 19
Component: SideSensor_Dr 301 0148
Serial number: 35100FB788A19000000Z
Subsystem 6 - Part No SW: ----------- HW: 454 802 708 19
Component: SideSensor_Pr 301 0148
Serial number: 35200966B8A19000000R
Subsystem 7 - Part No SW: ----------- HW: 454 802 108 19
Component: FrontSensor_D 304 0149
Serial number: 35500DD696319000000U
Part No SW: 3G0 920 951 F HW: 3G0 920 951 F
Component: KOMBI 304 6700
Coding: 27A401906684060001886A071001000880600000
ASAM Dataset: EV_DashBoardVDDMQBAB 009069
VCID: 2A0D05B8DC76841B2D6-807E
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 442 4388
Revision: -------- Serial number: 0000100722
Coding: 030900045F087300F900425C080F00000001070000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW37.rod
Component: 5-01-14-01-04
Subsystem 2 - Part No SW: 3G0 959 442 J HW: 3G0 959 442 J
Component: E221__MFL-PR6 H06 0110
Serial number: PR6-0440036272190387
Coding: 2C0B00
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1051
Serial number: 758860030019100418D1
Address 23: Brake Booster (J539) Labels: None
Part No SW: 3Q0 909 059 G HW: 3Q0 909 059 A
Component: EBKV H06 0069
Serial number: BPA085270919013
Coding: 0102C500340000C618638C31000049922449920400
ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
ROD: EV_BrakeBoostG2BoschVW48X_011_VW41.rod
VCID: 3B2330FC23EC0D93460-806E
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 19000256970006
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 333318DC0BBCC5D39E0-8066
Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 F
Component: TSG FS002 0325
Serial number: YE007SI309168
Coding: 00350A20D001028000001000
ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
ROD: EV_DCU2DriveSideMAXHKLO.rod
VCID: 49CF5A347930AF03C4C-801C
Subsystem 1 - Part No SW: 5Q4 959 811 H HW: 5Q4 959 811 H
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000013263331
Coding: 0D0000
Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1082
Coding: 911F0000
Shop #: WSC 00015 115 00312
ROD: EV_SteerAssisMQB_015.rod
VCID: 74B1DBC04E3282EB47A-8020
Address 52: Door Elect, Pass. (J387) Labels:* Redir Fail!
Part No SW: 5Q0 959 592 K HW: 5Q0 959 592 F
Component: TSG BFS002 0325
Serial number: YE007SI40229D
Coding: 00350020DC01028000001000
ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
ROD: EV_DCU2PasseSideMAXHKLO.rod
VCID: 48C95F30623A560BDB2-801C
Subsystem 1 - Part No SW: 5Q4 959 812 H HW: 5Q4 959 812 H
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000013349501
Coding: 050000
Part No SW: 3G5 035 820 HW: 3G5 035 820
Component: MU-O-ND-EU H12 0152
Serial number: VWZAZ2W1159028
Coding: 24810008000020000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001001
ROD: EV_MUOIMQB_VW48.rod
VCID: 619FA294E1C007433CC-8034
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000339166
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 34311BC00EB2C2EB87A-8060
Address 75: Telematics (J949) Labels:* None
Part No SW: 5WA 035 284 HW: 5WA 035 284
Component: OCUGen3High H20 0083
Serial number: 0000000907VIQS3
Coding: 024810001968AC209005460160002607
ASAM Dataset: EV_OCUGen3High 002115
ROD: EV_OCUGen3High_002_VW37.rod
VCID: 0353881C1B9CB5534E0-8056
7170 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Multi Function Display (0x0F) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
Reset counter: 40
Mileage: 6906 km
Date: 2020.04.03
Time: 14:52:43
Voltage terminal 30: 11.8 V
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 2Q0 980 653 HW: 2Q0 980 653
Component: MQB MFK 3.0 H11 1027
Serial number: E33417011192890
Coding: 00000808114C4020109E00001020000000410000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005035
ROD: EV_MFK3ValeoMQB_005_VW27.rod
VCID: 72BDDDD834268CDB556-8026
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4K0 907 594 AD HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 708000748101
ASAM Dataset: EV_SunRoofCONTIAU736 009011
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 76B5E1C8584E90FB79E-8022
End----(Elapsed Time: 01:46, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
