Results 1 to 6 of 6
Thread: Function Restricted due to Missing Message
    Mar 2018
    What does 'Function Restricted due to Missing Message' mean at address 75 in scan below?
    Friday,03,April,2020,14:54:46:39636
    VCDS Version: 20.4.0.1 (x64)  HEX-V2 CB: 0.4508.4
    VIN: WVWZZZ3CZLE048230   License Plate:
    Chassis Type: 3C-VW48 (3Q0)
    Scan: 01 03 05 08 09 10 13 15 17 19 23 2B 42 44 52 5F 65 75 A5 CA
    VIN: WVWZZZ3CZLE048230   Mileage: 6906km-4291miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-DSRA)       Labels: None
       Part No SW: 05L 906 022 BJ    HW: 05L 907 309 B
       Component: R4 2.0l TDI   H30 9737
       Revision: E3H30---
       Coding: 011904120344050830000000000000000000000000000000
       Shop #: WSC 05311 115 00312
       ASAM Dataset: EV_ECM20TDI01105L906022BJ 006004
       ROD: EV_ECM20TDI01105L906022BJ_006_VW48.rod
       VCID: 70B9D7D03A2ABECBA32-8024
    Readiness: 0 0 0 1 1
       Part No SW: 5Q0 614 517 FA    HW: 5Q0 614 517 BR
       Component: ESC           H82 0190
       Revision: 00000000    Serial number: 62799000003903
       Coding: 0EECBA8F31243B744779060360C349705D8CDCE2600692713460F00850224A0B0003000012121212B835351919323200
       Shop #: WSC 00015 115 08193
       VCID: 75B7E6C445489BE3704-8020
       Part No SW: 3Q0 959 435 M    HW: 3Q0 959 435 M
       Component: VWKESSYMQB    027 1307
       Revision: 00027000    Serial number: 0529356985
       Coding: 002F0F0623
       ROD: EV_KessyHellaMQBAB.rod
       VCID: 44D14B005E12726B37A-8010
       Part No SW: 5G0 907 044 ER    HW: 5G0 907 044 ER
       Component: Climatronic   H04 2202
       Revision: 00001K10
       Coding: 1112011420011001111500008010D836
       ASAM Dataset: EV_ACClimaBHBVW37X 006150
       VCID: 7BA3F0FC636CCD93060-802E
       Air quality sensor:
       Part No SW: 5Q0 937 086 CE    HW: 5Q0 937 086 BQ
       Component: BCM PQ37BOSCH 038 0303
       Revision: --------    Serial number: J53F22091900EP
       ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
       ROD: EV_BCMBOSCH_020.rod
       VCID: 7F5B04EC7774D1B32A8-802A
       Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    190823  043  0607
       Serial number:         190913094057
       Component: RLHS  051  0206
       Serial number: SBY19M10D10H01M04S38
       Coding: 0008DD
       Component: E1 - LDS MQB  H01  0032
       Serial number: 11 10 2019  10001133
       Component: Sensor, DWA  005  0316
       Serial number: 000000000ZY192550TNA
       Subsystem 5 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
       Component: Sirene, DWA  004  0007
       Serial number: 00000000000000637664
       Steering Column Switch:
       Subsystem 7 - Part No SW: 5Q1 953 521 BC    HW: 5Q1 953 569
       Component: Lenks.Modul  H03  0170
       Serial number: 0100160920190C100917
       Part No SW: 5QA 919 294 G    HW: 5QA 919 294
       Component: PDC 8 Kanal   H08 0061
       Serial number: 000150058319278
       Coding: 0471051801
       Shop #: WSC 05311 115 00091
       ASAM Dataset: EV_EPHVA18AU3700000 009046
       VCID: 50F977509A6A9ECB832-8004
       Part No SW: 5Q0 907 572 R    HW: 3Q0 907 567 A
       Component: ACC BOSCH MQB H01 0771
       Coding: 2A0178C251FFC728949C812461400600000000000000000066
       ASAM Dataset: EV_ACCBOSCHVW416 003014
       ROD: EV_ACCBOSCHVW416_003.rod
       VCID: 46D55108682E407B29E-8012
       Part No SW: 3Q0 959 655 CP    HW: 3Q0 959 655 CP
       Revision: --------    Serial number: 003Z4PHKNN0L
       Coding: 98FCC0C0000000005C5400CF008840000065
       Shop #: WSC 05311 000 08193
       ROD: EV_AirbaVW21TS6VW48X.rod
       VCID: 0E45A92840DEC83BD1E-805A
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1040
       Serial number: 3G0857705B0277T01240
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1040
       Serial number: 3G0857706B0287T01049
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 454 002 208 19
       Serial number: 3570000000056A58FE3
       Subsystem 4 - Part No SW: -----------    HW: 454 002 108 19
       Serial number: 358000000002F328FE3Z
       Subsystem 5 - Part No SW: -----------    HW: 454 802 708 19
       Serial number: 35100FB788A19000000Z
       Subsystem 6 - Part No SW: -----------    HW: 454 802 708 19
       Serial number: 35200966B8A19000000R
       Subsystem 7 - Part No SW: -----------    HW: 454 802 108 19
       Serial number: 35500DD696319000000U
       Part No SW: 3G0 920 951 F    HW: 3G0 920 951 F
       Component: KOMBI         304 6700
       Coding: 27A401906684060001886A071001000880600000
       VCID: 2A0D05B8DC76841B2D6-807E
       Component: GW MQB High   442 4388
       Revision: --------    Serial number: 0000100722
       Coding: 030900045F087300F900425C080F00000001070000000000000000000000
       ROD: EV_GatewNF_VW37.rod
       Component: 5-01-14-01-04
       Subsystem 2 - Part No SW: 3G0 959 442 J    HW: 3G0 959 442 J
       Component: E221__MFL-PR6  H06 0110
       Serial number: PR6-0440036272190387
       Coding: 2C0B00
       Serial number: 758860030019100418D1
    Address 23: Brake Booster (J539)       Labels: None
       Part No SW: 3Q0 909 059 G    HW: 3Q0 909 059 A
       Component: EBKV          H06 0069
       Serial number: BPA085270919013
       Coding: 0102C500340000C618638C31000049922449920400
       ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
       ROD: EV_BrakeBoostG2BoschVW48X_011_VW41.rod
       VCID: 3B2330FC23EC0D93460-806E
       Serial number: 19000256970006
       ROD: EV_ELVMarqMQBA0_VW37.rod
       VCID: 333318DC0BBCC5D39E0-8066
       Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
       Component: TSG FS002 0325
       Serial number: YE007SI309168
       Coding: 00350A20D001028000001000
       ROD: EV_DCU2DriveSideMAXHKLO.rod
       VCID: 49CF5A347930AF03C4C-801C
       Subsystem 1 - Part No SW: 5Q4 959 811 H    HW: 5Q4 959 811 H
       Serial number: 00000000000013263331
       Coding: 0D0000
       Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
       Component: EPS_MQB_ZFLS  130 1082
       Coding: 911F0000
       Shop #: WSC 00015 115 00312
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 74B1DBC04E3282EB47A-8020
    Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
       Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
       Component: TSG BFS002 0325
       Serial number: YE007SI40229D
       Coding: 00350020DC01028000001000
       ROD: EV_DCU2PasseSideMAXHKLO.rod
       VCID: 48C95F30623A560BDB2-801C
       Subsystem 1 - Part No SW: 5Q4 959 812 H    HW: 5Q4 959 812 H
       Serial number: 00000000000013349501
       Coding: 050000
       Part No SW: 3G5 035 820     HW: 3G5 035 820
       Component: MU-O-ND-EU    H12 0152
       Serial number: VWZAZ2W1159028
       Coding: 24810008000020000000000000000000000000000000000000
       ASAM Dataset: EV_MUOIMQB 001001
       ROD: EV_MUOIMQB_VW48.rod
       VCID: 619FA294E1C007433CC-8034
       Serial number: 30000000339166
       ROD: EV_RDKBERU30_006_VW37.rod
       VCID: 34311BC00EB2C2EB87A-8060
       Part No SW: 5WA 035 284     HW: 5WA 035 284
       Component: OCUGen3High   H20 0083
       Serial number: 0000000907VIQS3
       Coding: 024810001968AC209005460160002607
       ASAM Dataset: EV_OCUGen3High 002115
       ROD: EV_OCUGen3High_002_VW37.rod
       VCID: 0353881C1B9CB5534E0-8056
    7170 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Multi Function Display (0x0F) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                        Reset counter: 40
                        Mileage: 6906 km
                        Date: 2020.04.03
                        Time: 14:52:43
                        Voltage terminal 30: 11.8 V
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 2Q0 980 653     HW: 2Q0 980 653
       Component: MQB MFK 3.0   H11 1027
       Serial number: E33417011192890
       Coding: 00000808114C4020109E00001020000000410000000000000000000000000000
       ASAM Dataset: EV_MFK3ValeoMQB 005035
       ROD: EV_MFK3ValeoMQB_005_VW27.rod
       VCID: 72BDDDD834268CDB556-8026
       Part No SW: 4K0 907 594 AD    HW: 4K0 907 594
       Coding: 708000748101
       ROD: EV_SunRoofCONTIAU736_009_VW37.rod
       VCID: 76B5E1C8584E90FB79E-8022
    End----(Elapsed Time: 01:46, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    Quote Originally Posted by 32110 View Post
    In the UK the telematics has been disabled by instruction of VW.
    FoRT jyoung8607's Avatar
    Cincinnati, OH
              U1111 00 [008] - -
                        Reset counter: 40
                        Mileage: 6906 km
                        Date: 2020.04.03
                        Time: 14:52:43
    75 - Telematics is in charge of the Audi Connect telematics features on your vehicle. The fault means the module couldn't carry out some unspecified part of its job role because some CAN message it expected did not arrive. In this case, it's a BAP message to what I believe is your infotainment unit, or possibly instrument cluster. BAP is German for "operating and display protocol", basically when a given control module needs to interact with a human, it talks to something in the car with a UI (like the infotainment or cluster) using the BAP protocol to display info and alerts, show menus, get settings, retrieve driver profile info, etc etc.
    Four days ago that conversation broke down. Battery voltage was pretty low so I'd hazard a guess the car went to sleep. It's not unknown to see comms disruption faults like that if the battery is run down very low, or the infotainment unit is rebooted manually, etc. It's not a physical fault, and unless it happens again there's not even anything to troubleshoot further. I'd clear it and not worry about it further if I were you.
    Silence gives consent.
  4. Likes Eric, Uwe, Dana liked this post
    Mar 2018
    Thanks jyoung8607 for the detailed explanation. The scan was made when the engine was not running. I note your point about the battery voltage but this is typical over several scans that I have performed with engine not running. A scan taken with engine running showed a voltage of 14.6V at the end of the scan. This is a November 2019 Passat so would have thought the battery should be in excellent condition so don't know why the voltage is so low when engine not running. I have run the clear DTCs several times but this fault always reappears.
    Mar 2018
    PetrolDave, Are you sure that telematics is disabled in the UK as I have managed to clear this fault?
    Many owners have reported on various websites that dealers have told them that VAG have disabled telematics in the UK for an unconfirmed reason - that's all I know.
  8. Likes Dana liked this post
