Results 1 to 3 of 3
Thread: 6R polo ABS coding help
    Mar 2017
    Ireland
    I have got 6R polo,the ABS has been replaced by other garage to second hand.
    The guy gave me the old original ABS unit,
    The original has AB letters but the "new" has S letter.
    The coding string copy does not work. Even I can see the HW are the same only the SW level is different.
    Tuesday,07,April,2020,13:12:32:17963
    VCDS Version: 20.4.0.1 (x64)
    VIN: WVWZZZ6RZAU010372   License Plate: 10MO 448 ORI
    Mileage: 268640km-166925mi   Repair Order:
    Chassis Type: 6R-VW25 (6N0)
    Scan: 01 03 09 15 17 19 25 44 56
    VIN: WVWZZZ6RZAU010372   Mileage: 268640km-166925miles
    Address 01: Engine (CGP)       Labels: 03E-906-033-AZQ.lbl
       Part No SW: 03E 906 023 AL    HW: 03E 906 023 L
       Component: SIMOS91 1.2l 4V     4523
       Revision: --H04---    Serial number:
       Coding: 0000031
       Shop #: WSC 00000 000 31414
       VCID: 69D3D4F2433FC9CEB5-5120
    Readiness: N/A
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
       Part No SW: 6R0 907 379 AB    HW: 6R0 907 379 AB
       Component: ABS8.2 front  H03 0001
       Revision: --------
       Coding: 200200E3006E00B2042800E900D300000000
       Shop #: WSC 31414 790 31414
       VCID: 7EF997AEEDB15E7670-802A
    01201 - ABS Pump Supply Voltage
                        Fault Status: 11100000
                        Reset counter: 41
                        Mileage: 268615 km
                        Date: 2014.08.26
                        Time: 00:02:05
                        Hex Value: 0x0005
                        Hex Value: 0x0000
                        Hex Value: 0x32A0
                        Hex Value: 0x05B5
                        Hex Value: 0x00FF
                        Hex Value: 0x007F
                        Hex Value: 0x7E00
                        Hex Value: 0x0000
                        Reset counter: 83
                        Mileage: 268615 km
                        Date: 2014.08.29
                        Time: 00:14:42
                        Hex Value: 0x0005
                        Hex Value: 0x0000
                        Hex Value: 0x33A0
                        Hex Value: 0x1398
                        Hex Value: 0x00FF
                        Hex Value: 0x007F
                        Hex Value: 0x7F00
                        Hex Value: 0x0000
       Part No SW: 6R0 937 086 B    HW: 6R0 937 086 B
       Component: PQ25 BCM      H09 0025
       Revision: BD009001    Serial number: 9953A236090484
       Coding: 24B02BBF08A10000002000003D2B0CD00040410F600400002000
       VCID: 3B7F5EBABA238B5E17-806E
       Subsystem 1 - Part No SW: 6R0 959 802 H    HW: 6R0 959 802 H  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  003 0803
       Serial number: KU0-KU020.08.0911349
       Coding: 08BC30
       Subsystem 2 - Part No SW: 6R0 959 801 K    HW: 6R0 959 801 K  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  003 0803
       Serial number: KU0-KU014.08.0911506
       Coding: 08BC30
       Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
       Component: VW10Airbag00E H09 0018
       Revision: --------    Serial number: 003DW0061BK0
       Coding: 003045
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4281235ED5C9FA9654-8016
       Serial number: 3572SRB400009A11035U
       Serial number: 3582SRB40000993D2A27
       Serial number: 3516GRB402F9BPVMOCCL
       Serial number: 3526GRB401N9NI6CVBPI
       Part No SW: 6R0 920 860 A    HW: 6R0 920 860 A
       Component: KOMBI         H23 0110
       Coding: 140200
       Shop #: WSC 31414 790 50316
       VCID: 3261739E65694A16C4-8066
       Part No SW: 6N0 909 901     HW: 6R0 937 086 B
       Component: GW-K-CAN TP20 0025
       Coding: 002300
       VCID: 70E5B996A3E53806F2-8024
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H23 0110
       Part No: 6R0 423 156 A
       Component: LenkhilfeTRW        V275
       Coding: 10150
       Shop #: WSC 31414
       VCID: 2E5967EEED516EF6A0-807A
       Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
       Component: Radio RCD310  013 0036
       Revision: 01000000    Serial number: VWZ1Z2I6819507
       Coding: 0500040002
       VCID: 6BDFAEFA8AC3DBDEC7-803E
    00856 - Radio Antenna
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 43
                        Mileage: 268645 km
                        Date: 2014.08.29
                        Time: 00:03:40
    End-------------------------(Elapsed Time: 01:56)--------------------------
    Tuesday,07,April,2020,12:49:46:17963
    VIN: WVWZZZ6RZAU010372   License Plate: 10M0448
       Coding: 0000031
    Readiness: N/A
       Part No SW: 6R0 907 379 S    HW: 6R0 907 379 AB
       Revision: --------
       Shop #: WSC 13765 790 00017
       VCID: 4E99076E1D910EF6C0-801A
                        Reset counter: 43
                        Mileage: 268644 km
                        Date: 2014.08.29
                        Time: 19:28:17
                        Hex Value: 0x0005
                        Hex Value: 0x0000
                        Hex Value: 0x3213
                        Hex Value: 0x148D
                        Hex Value: 0x00FF
                        Hex Value: 0x007F
                        Hex Value: 0x7F00
                        Hex Value: 0x0000
    00532 - Supply Voltage B+
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 43
                        Mileage: 268644 km
                        Date: 2014.08.29
                        Time: 19:33:07
                        Hex Value: 0x0005
                        Hex Value: 0x0001
                        Hex Value: 0x3224
                        Hex Value: 0x0371
                        Hex Value: 0x00FF
                        Hex Value: 0x007F
                        Hex Value: 0x7E00
                        Hex Value: 0x0000
       Coding: 08BC30
       Coding: 08BC30
       Coding: 003045
       Coding: 140200
       Coding: 002300
       Coding: 10150
       Shop #: WSC 31414
    Address 56: Radio        Labels: None
       VCID: 55ABE802BC477D2E01-FFFE
    No Faults Found
    End-------------------------(Elapsed Time: 05:47)--------------------------
    Thank you.
    Since the hardware part number of both of these modules is the same ("HW: 6R0 907 379 AB"), as is the software level ("0001"), one might speculate that the different software part numbers imply that these two modules have different applications. You might want check whether the "S" part is appropriate for this car.
    PS: Moving to Car Repair Support.
  3. Likes Magus, PetrolDave liked this post
    Vehicle Identification No. WVWZZZ6RZAU010372
    Model Polo
    PO
    Date of production 31.10.2009
    Model year 2010
    Sales type 6R12B4
    Engine Code CGPB
    Transmission Code LNR
    Part Information
    PART NUMBER DESCRIPTION REMARK MODEL
    6R0 907 375 AD Control unit for ABS 6R0 614 117 T
    6R0 907 375 AD
    PR-7K0
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PA Standard wheel bolts
    Vehicle class differentiation units/platform components 0DF Vehicle class differentiation - 6R0- for build status Europe
    tail pipe 0P0 Rear exhaust tailpipe (standard)
    Hill start assist UG0 Without hill start assist/hill descent control/comfort driving assist
    Emission standard 7MG Emission standard EU5
    Trailer hitch 1D0 Without trailer hitch
    airbag 4UF Airbag for driver and front passenger with front passenger airbag deactivation
    Aktivkohlebehälter / Ottopartikelfilter 1E1 Activated carbon canister
    Aerials 8ZH Antenna for AM/FM reception, "diversity"
    Exterior mirror setting 6XD Exterior mirrors, power-adjustable/ heated
    Interior light in driver compartment 9GA Interior light with contact switches on the doors
    Left exterior mirror 5SJ Left exterior mirror, convex
    Right exterior mirror 5RV Right exterior mirror, aspherical
    "Multimedia"video/DVD/notebook connection 9WL Jack for external audio source
    Equipment levels A8C Comfort equipment
    Brake type in rear 1KM Drum brakes in rear
    batteries J1P Battery 220 A (44 Ah)
    Brake type, front 1ZG Disc brakes in front (Geomet D)
    Components with special surface 6FF Exterior mirror housing and various attachments colour coded to vehicle
    Controls (steering wheel/steering column) 4LA Without control element
    Beverage holders 4M0 Without beverage holder
    Dashboard illumination 7V1 Standard dashboard illumination
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0A build parts set without county specific documentatio
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AC Anti-lock brake system (ABS)
    Owner's manuals 0VF Information kit in English
    Brake pad wear indicator 9U0 Without brake pad wear indicator
    Heated washer nozzles 9T0 Without heated washer nozzles
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    Chrome package QJ0 Without aluminum/chrome work package
    General operating permit, alterations C02 Operating permit, alteration
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    Roof insert/convertible top 3FA Without roof insert (standard roof)
    Suspension system in rear 1JP Rear shock absorption
    Suspension system in front G09 Shock absorption in front
    Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
    Installation differentiation for components 0EM Installation differentiation for transmission MQ 200 -- vehicle components --
    Theft protection system 7AA Electronic immobilizer
    Scuff plates 7M5 Without impact protection film for door sill
    Park distance control 7X0 Without park distance control
    Electric interface for external use UF0 Without electric interface
    Manufacturing sequence differentiation 0FV South Africa manufacturing sequence
    Vehicle type AZ0 Vehicle with production equipment
    window regulator 4R2 Window regulators, front electric, rear mechanical
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL1 Extended pedestrian protection measures
    Pedal cluster VF0 Standard pedal cluster
    Headlight activation 9I0 Low beam as daytime running light
    Fresh air intake for passenger compartment (with particulate filter) 2V1 dust-pollen filter
    Antifreeze 1C1 Antifreeze up to -25 degree Celsius tolerance up to -30 degree C
    Interior noise suppression measures 3W0 Without additional noise suppression measures for passenger compartment
    Alternators 8GD Alternator 90 A
    Weight category rear axle 0YC Weight range 3 installation control only, no requirement forecast
    Weight category front axle L53 Suspension range 53 installation control only, no requirement forecast
    Base engine T70 3-cylinder SI engine 1.2 l unit 03E.A (aluminum)
    Luggage netting/pocket on backrest(s) 4U0 Without luggage nets/pockets on backrests
    Luggage compartment cover 3U1 Folding trunk cover
    cruise control system 8T0 Without cruise control system (CCS)
    Luggage compartment lighting 9E1 Luggage compartment lighting
    Luggage compartment trim 5A6 Full nonwoven luggage compartment trim
    Transmission specifications G0C 5-speed manual transmission
    Cruise control system and speed limiter 6Y0 without speed warning system
    Brackets 3P1 Bracket for first aid kit and warning triangle
    handle for hand brake lever 6PA Hand brake lever handle in plastic
    Rear window wiper and washer system 8M1 Rear window wiper washer system with intermittent wipe
    Rear axle 0N2 Heavy-duty rear axle
    Molded headliner 6NA Unsplit molded headliner
    Rear seats 3NB Rear seat bench/backrest, completely folding
    Heating and air-conditioning system 9AA Manually controlled heater
    Headlamps 8BF Halogen headlamp for driving on the left
    Customized installation FC0 Without customized installation
    Interior light in footwell 6T0 Without interior light in footwell
    Instrument clusters U0C Instrument cluster with tachometer, clock and km/h speedometer
    Instrument panel 4N2 Standard dashboard (Leather trimmed minor gauges + Ipod drawer)
    Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror, dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K8G Hatchback
    Luggage compartment floor covering 6SC Luggage compartment floor covering in needle-punched nonwoven
    Refrigerator 1W0 Without refrigerator/glove compartment cooling system
    Climatic zones 0Y1 Standard climatic zones
    Rear head restraints 3Q6 Three rear head restraints
    Head restraints 3J1 Hight-adjustable head restraints for front seats
    Fuel tank treatment 2LA Fuel tank without special material treatment
    Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
    Fuel systems 1A3 Petrol injector fuel system with return-free injection system and modified injection pressure
    Body measures 5C6 Additional measures for the body
    Radiator grille 6KA Radiator grille
    Rear license plate carrier 6P1 Rear license plate carrier (ECE)
    Front license plate carrier 6W1 Front license plate carrier (large)
    Paint preservative/transit coating 5K7 Transport protection film (minimum protection) with additional transport protection measures
    Rear cargo area 3GA Without luggage compartment floor
    Steering system arrangement L0R Right-hand drive
    Reading lamp 8S0 Without reading light
    steering 1N2 Servo steering, elect./hydraulic
    Backrest release 3H0 Without backrest release for front seats
    Air duct, front area VK0 Air duct, standard
    Load edge protection 2P1 Plastic loading edge protection
    Lumbar support 7P0 Without lumbar support in seat backrests
    steering wheels 1ME Steering wheel
    Speaker installation 8RL 6 speakers (passive)
    Steering column systems 2C5 Axial and vertical adjustable steering column
    Air cleaner (engine) 1L0 Standard air cleaner
    Headlight range control 8Q1 Headlight range control
    Center armrest 6E0 Without center armrest in front
    Multi-function display/trip computer 9Q0 Without multi-function display/ trip computer
    Engine cooling 8Z5 not hot country
    Engine specifications DG3 3-cylinder SI engine 1.2 l/44 kW port fuel injection base engine is T70
    Left vanity mirror 4SC Left vanity mirror with cover
    Right vanity mirror 4TC Vanity mirror, right, with cover
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TD Rear fog light for driving on the left
    Front fog lamp/additional headlamp 8WA Without fog lights
    Rear of platform module base 4P2 Rear floor panel module, type 3
    Platform group class 7PA Platform group class 1
    Hubcaps 1NC Wheel trims
    Wheels C0D Steel wheels 5J x 14
    Radios 8AE Radio "RCD310 MP3"
    Smoker's/non-smoker's package 9JD Smoker's package, ashtray in front
    Tire pressure monitoring system 7K0 Without tyre pressure monitor
    tire HK9 Tires 175/70 R14 84T
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G2 Steel spare wheel with original equipment tire
    Restraint systems, front 4QV 3-point seat belts in front, with electric pretensioner and height adjustment
    PB1 Electric comfort package
    PJW Steel spare wheel with original equipment tire
    RGB "RCD 310" 4 x 20 W, 6 speakers
    W4A 4-door incl. mechanical window lifts, rear
    Side airbag 4X1 Side airbag in front
    Gearshift knob/handle 6Q1 Gearshift knob/handle in plastic
    Special labels/plates 0SS Labels in English and French
    Tail lamp assemblies 8SG Rear combination lamps, standard design (type 2)
    Seat belt check 9P3 Seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE label
    Center rear seat belts 3C7 3-point seat belt for center rear seat
    Gearshift boot/cover 6R1 Leatherette gearshift boot
    seat covers N0V Seat trim covers in fabric
    Seat adjustment 3L2 Manual height adjustment for right front seat
    seat heater 4A0 without seat heater
    Start-stop system/regenerative braking 7L3 Without start-stop system without regenerative braking
    Horns 8Y4 High-tone horn
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    power outlet 7B2 12 volt socket in luggage compartment
    Bumper 2JF Painted bumpers
    Rear stabilizer bar 0BA Without rear stabilizer
    Front stabilizer bar 0AQ Front stabilizer bar
    Drawers under front seats QN0 Without drawers under front seats
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
    Special approval measures 3M0 Without special measures
    Nameplate set 0NB Nameplate set in basic style
    Mass damper for steering wheels 1Q0 steering wheel without balance weight
    Door and lid locking system 4K3 Central locking w/ radio remote control, interior controls and SAFELOCK
    Type approval countries/countries with special requirements B10 Type approval country Ireland
    Carrier frequency for remote control 5D1 Carrier frequency 433.92 to 434.42 Mhz
    Door and side trim panels 4AP door and side trim panels
    doors 0A2 4 doors
    TV reception/digital radio reception QV0 Without TV reception/digital radio reception
    Speedometer cable and seal 8CC Speedometer sensor without seal (electronic speedometer sensor)
    Identification plates 1EX Special identification label for EC for M1 passenger vehicles
    Delivery equipment 2A0 Without delivery equipment
    First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
    Front seats Q1A Standard seats in front
    Telephone / telematics 9W0 Without car phone preparation/ installation
    LongLife Service Regime QG1 LongLife Service Regime
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Washer fluid level indicator 8W0 without washer water level indicator
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TA without floor mats
    Additional body panels, side 6EA Without additional side body covers (stone guard)
    Additional child seat anchors 3B3 Child seat anchors
    Zündanlaß/Schloß-Sperrsystem/ Elektrische Lenksäulenverriegelung 0RA Without ignition/starter switch locking system
  5. Likes Dana, Magus, Uwe liked this post
