Results 1 to 5 of 5
Thread: DPF Pressure Sensor
    Mar 2020
    DPF Pressure Sensor
    Skoda Octavia 2.0Tdi 140 CR. 2012
    Posted previously about problems with DPF Regeneration and still trying to sort out the issue. However going back to having work done on the turbo plus a new Lambda Sensor and a new Pressure Sensor did a bit rooting around and found this about a G450 Pressure Sensor?
    https://forums.ross-tech.com/showthr...ressure-sensor
    Called the garage, unfortunately the guy I needed is not available at the moment but the one I spoke with about 'logging it to the ECU' reckoned they didn't need it so probably not done.
    So my question is, does it need setting up on the ECU and if so how? Is it similar to the thread mentioned?
    2012 Skoda Octavia II Estate 2.0Tdi 140PS Manual
    2015 Skoda Octavia III Estate 2.0Tdi 4 x 4 150PS Manual
    2017 VW Sharan 2.0Tdi SE Bluemotion 163PS Manual
    2019 Seat Alhanbra 2.0Tdi LUX Ecomotive 150PS Manual
    Quote Originally Posted by Ronnie.Vincent View Post
    Almost certainly.
    Hard to say. The thread you linked to above has an older, non-UDS ECU. Without seeing what ECU the car in question has, we can only speculate.
  3. Likes Dana liked this post
    Mar 2020
    Hi Uwe, thanks. Even though it's been fitted and ran can it still be logged into the ECU? An different post about the Pressure Sensor said it was a 'One Time Only' and if it was ran would 'adopt' the previous settings?
    Also here is a 'snapshot' from a scan on the vehicle, does this give any indication of the ECU fitted?
    Address 01: Engine (J623-CFHC) Labels:. 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 C HW: 03L 906 018 BR
    Component: R4 2.0l TDI H24 9978
    Revision: 42H24--- Serial number:
    Coding: 00190012042500080000
    Shop #: WSC 22007 210 00000
    ASAM Dataset: EV_ECM20TDI01103L906018C 003008
    ROD: EV_ECM20TDI01103L906018C.rod
    VCID: 2A0D056D4C7D279B2D6-807E
    Firmware update needed 9981 or higher?
  6. Likes Dana, Uwe liked this post
    United States
    That looks like this car, and if so, I'd want to make sure the cause of the EGR fault codes was resolved because the DPF system may not regen properly while driving.
    In regards to Jack's research - I came up with SWL 9981 as well but I wasn't able to locate the RoW market Skoda TPI number. If you happen to have that EDC flash updated on the dealer level please ask them to put the TPI number or SVM code on your repair order so you can pass that along to us.
    As far as the new DPF pressure sensor is concerned, that appears to be Basic Setting:
    [*IDE01772*] Adaptation of diff. pressure sensor particulate filter
    If that alone doesn't reset the Advanced Measuring Values you may also want to try BS:
    [*IDE00468*] Resetting of learned values of difference pressure sensor
    If you need further assistance please post the Auto-Scan and a pair of Measuring block function maps for review. I believe a Key On, Engine Off map -and- another map with the engine running at Idle would be best.
  8. Likes Uwe, Jack@European_Parts liked this post
