Results 1 to 5 of 5
Thread: Help required for ABS coding.
    New User
    May 2018
    Hi.
    My name is Ronnie. New here on ross tech.
    Need a bit of help. Have a 2007 Seat Leon 2.0 TFSI. Purchased the car end of January. Car had quite bad damage. I run a full scan when i got the car.
    VIN: VSSZZZ1PZ7R091548   License Plate: LEON
    Mileage: 175950km-109330mi   Repair Order:
    Chassis Type: 1P (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: VSSZZZ1PZ7R091548   Mileage: 175950km-109330miles
       Part No SW: 1P0 907 115     HW: 8P0 907 115 B
       Component: 2.0l R4/4V TFSI     0040
       Revision: 5BH16---    Serial number: SEZ7Z0G3756072
       Coding: 030300031C070160
       Shop #: WSC 06441 785 00200
       VCID: 68D4B60A5B1E590F0F-803C
    9 Faults Found:
    008583 - Bank 1; System too Lean at Idle
                   P2187 - 004 -  - MIL ON
    001089 - EVAP Emission Control Sys
                   P0441 - 001 - Incorrect Flow - MIL ON
    001287 - Idle Control System RPM
                   P0507 - 001 - Higher than Expected. - Intermittent
                   P0300 - 002 -  - Intermittent
    000771 - Cylinder 3
                   P0303 - 002 - Misfire Detected - Intermittent
    000770 - Cylinder 2
                   P0302 - 002 - Misfire Detected - Intermittent
    000769 - Cylinder 1
                   P0301 - 008 - Misfire Detected - Intermittent
    000772 - Cylinder 4
                   P0304 - 002 - Misfire Detected - Intermittent
    008825 - Leak in Air Intake System
                   P2279 - 002 -
    Readiness: 0000 0001
       Part No SW: 02E 300 043 Q    HW: 02E 927 770 AE
       Component: GSG DSG         081 1309
       Revision: 04508010    Serial number: 00000702070353
       VCID: 2240E422FDA2735F91-8076
    17106 - Transmission Output Speed Sensor (G195)
                P0722 - 000 - No Signal - Intermittent
    18201 - Transmission Output Speed Sensor 2 (G196)
                P1793 - 000 - No Signal - Intermittent
       Revision: 00H11001
       Coding: 0004738
       VCID: 73EED16612D8AAD7AA-8026
       Part No: 1P0 907 044
       Component: ClimatronicPQ35 010 0502
       VCID: 69D2B30E4014600710-803C
    01273 - Fresh Air Blower (V2)
                010 - Open or Short to Plus
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
       Revision: 00H52000    Serial number: 00000004715857
       Coding: 818C0F2F00041000431D00000000000000017F075C4000
       VCID: 6CDCCA1A4FE6752F6B-8038
       Subsystem 1 - Part No: 1P0 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 070307 022  0601
       Coding: 00056208
       Shop #: WSC 06441
    10 Faults Found:
    00984 - Left Tail Light (M4)
    00985 - Right Tail Light (M2)
    01506 - Bulb for Rear Fog; Right (L47)
       Part No SW: 3C0 909 605 L    HW: 3C0 909 605 L
       Component: R4 AIRBAG VW8   030 2522
       Revision: 12030000    Serial number: 003B0P40NFYT
       Coding: 0021044
       VCID: 2F661D16BE70CE370E-807A
       Subsystem 1 - Serial number: 6332MSME17734B3E
       Subsystem 2 - Serial number: 6342MSME171A6A2B
       Subsystem 3 - Serial number: 6351HTS65JHC49G6
       Subsystem 4 - Serial number: 6361HTS6LNFKK3A7
    00532 - Supply Voltage B+
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
    01589 - Igniter for Head-Airbag; Passenger Side (N252)
       Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
       Component: J0527           636 0070
       Coding: 0012142
       VCID: 01028BAE58648847A8-8054
       Part No: 1P0 920 925 B
       Component: KOMBIINSTRUMENT VO3 0422
       Coding: 0002401
       Shop #: WSC 00606 067 57207
       VCID: 2E580012B97AC73F05-807A
       Part No SW: 1K0 907 530 K    HW: 1K0 907 951
       Component: J533__Gateway   H12 0170
       Revision:   H12       Serial number: 330010721902E6
       Coding: 3F3F034007000203
       Component: IMMO            VO3 0422
       Shop #: WSC 00137 211 56823
    01176 - Key
       Part No SW: 1T0 959 701 G    HW: 1K0 959 793 M
       Component: J386  TUER-SG FT    1130
       Revision: 31008001    Serial number: 00000017478103
       Coding: 0000688
       VCID: 3B7E39467A082297B2-806E
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.142 H07 1806
       VCID: 356A2F7E5C2CF4E744-8060
       Component:    KSG PQ35 G2  020 0203
       Coding: 998000005283CC7F0006050560085F86107880
       Shop #: WSC 19310 148 574531
       VCID: 030E81A642789A57BA-8056
       Subsystem 5 - Part No: 1P0 951 171
       Component: Innenraumueberw.010 4971
       Coding: 00000000
       Shop #: WSC 19310
       Subsystem 7 - Component:       NGS n.mounted
    00893 - Switch for Trunk Handle (E234)
       Part No SW: 1T0 959 702 G    HW: 1K0 959 792 M
       Component: J387  TUER-SG BT    1130
       Revision: 31008001    Serial number: 00000523378116
       Coding: 0000688
       VCID: 3C7C3A5A7F0625AFBB-8068
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
       Part No: 1P2 035 186 A
       Component: Radio BVX           0006
       Coding: 0040424
       VCID: 2B5E09068A68B21722-FFFE
       Part No SW: 1K0 959 703 N    HW: 1K0 959 795 H
       Component: J388   TUER-SG HL   1108
       Revision: 11006001    Serial number: 00000001309936
       Coding: 0000144
    01813 - Supply Voltage for Door Controller; Rear Left (J388)
    01554 - Motors for Central Locking; Rear Doors; Lock
       Part No SW: 1K0 959 704 N    HW: 1K0 959 794 H
       Component: J389   TUER-SG HR   1108
       Revision: 11006001    Serial number: 00000001273945
       Coding: 0000144
    01814 - Supply Voltage for Door Controller; Rear Right (J389)
    End---------------------(Elapsed Time: 03:12, udsna)-----------------------
    the ABS pump had to be replaced and i arranged for it to be done. The garage contacted me after a considerable time saying they couldnt fix the problem and gave me the car back. They have replaced the ABS pump but now im stuck.
    Here is the scan now.
    VIN: VSSZZZ1PZ7R091548   License Plate: LEON APRIL
    Mileage: 175980km-109348mi   Repair Order:
    VIN: VSSZZZ1PZ7R091548   Mileage: 175980km-109348miles
       Shop #: WSC 66565 257 00032
    Readiness: 0010 0001
       Part No: 1K0 907 379 D
       Coding: 0021126
       Shop #: WSC 06435 123 12345
       VCID: 336E11665258EAD76A-8066
                003 - Mechanical Failure
                014 - Defective
       Coding: 00056208
       Shop #: WSC 06441
       Coding: 0021044
       Coding: 0012142
       Coding: 0002401
    00003 - Control Module
       Coding: 0000688
       Coding: 00000000
       Shop #: WSC 19310
       Coding: 0000688
       Coding: 0040424
       VCID: 2B5E09068A68B21722-807E
    00856 - Radio Antenna
       Coding: 0000144
       Coding: 0000144
    End---------------------(Elapsed Time: 01:52, udsna)-----------------------
    Please help with any info that may help me.
    Many Many Thanks
    Ronnie.
    Is 1K0-907-379-D a suitable replacement for 1K0-907-379-AC ?
    Have you tried coding it the same as the old module?
    PS: Please Get Verified.
    New User
    May 2018
    yes. i have tried to code it as old unit. but wont accept that number. is the pump not compatable ?
    ronnie.
    Quote Originally Posted by rocket ron View Post
    That is indeed a question that should be asked. But I personally do not have access to a proper parts catalog, so I'm not in a position to answer it.
    Apr 2020
    ABS pump
    ronnie.
    I can't answer as to its compatibility, but I recently had an issue with my daughter's 2005 VW Passat 1.8T wagon.
    It started out with not so good brakes.
    I scanned the module and got an ABS pump fault code, my daughter convinced me that I couldn't fix it and to send it to an online repair service, so I did.
    Got it back install it and VCDS couldn't communicate with it. So while waiting for it to be repaired (again under warranty) I bought a used one, but I made it absolutely clear that the part numbers had to match, no if and, or buts.
    Installed, coded, and bled it, worked just fine. This all took time mind you, researching, searching, testing power & ground, scoping the CAN bus, buying the right module with manifold block which cost me less than the module repair which didn't work and was a waste of time.
    I didn't install the unit, just connected the module to the car, once it was coded, then I connected it to the brake lines.
    I'm not sure if this helps you any, just keep it in the back of your mind as you go through your issues.
    -rjgarciasr
