VCDS user error
ag13
C?ID=223721
2019 gli somewhere I lost the small icon for cruise control on as well as the speed the cruise control is set to. Cruise control does work but I can no longer see what speed it is set to. This occurred after I did multiple changes via vcds. The usual changes to a new GLI. I think it happened after I did the off-road display on the radio. I did reverse that but still no luck. The error codes are displaying. Help please.
And if all else fails, reverse all changes. You should have logs of them as described here.
ag13
C?ID=223721
Here you go,
Tuesday,07,April,2020,09:12:27:39340
VIN: 3VW6T7BU0KM271356   License Plate:
Mileage: 1266km-786mi   Repair Order:
Chassis Type: BU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 2B 32 3C 42 44 52 5F A9
VIN: 3VW6T7BU0KM271356   Mileage: 1266km-786miles
Address 01: Engine (J623-DKFA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 092500124424012F3000
   Shop #: WSC 00066 790 00385
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001004
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: 3C21322D46E23D2B4FA-8068
Readiness: 1110 1101
   Part No SW: 0GC 300 020 G    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2403
   Revision: 00H06V09
   ASAM Dataset: EV_TCMDQ381061 001
   ROD: EV_TCMDQ381061.rod
   VCID: 2615F045A86E97FB09E-8072
   Part No SW: 5Q0 614 517 EB    HW: 5Q0 614 517 BR
   Component: ESC           H82 0108
   Revision: 00000000    Serial number: 52469000001787
   Coding: 70FB6BA15027216D857A020560C9A90ED60A84A1400695761041F059D2894B0B0000000012121212B835351919323200
   Shop #: WSC 00066 790 00167
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 75B7E7092548AC63704-8020
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0523758099
   Coding: 132C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004052
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D757C935287CE3204-8010
   Part No SW: 5GM 907 044 P    HW: 5GM 907 044 P
   Component: Climatronic   H04 2009
   Revision: 00001K04
   Coding: 0102000420011800100400001211100C
   ASAM Dataset: EV_ACClimaBHBVW37X 006148
   VCID: 51FF7399F160A0438CC-8004
   Part No SW: 5Q0 937 087 BB    HW: 5Q0 937 087 BB
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C86424091901DE
   Shop #: WSC 00066 790 00294
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7CA1F22D0662FD2B0FA-8028
   Subsystem 1 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0206
   Serial number: SBY19M07D29H09M38S11
   Coding: 0018DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521 AS    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300220920190C200907
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 3300008111FFC428949C810500301600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   VCID: 44D14ACD3E1245EB37A-8010
   Part No SW: 5Q0 959 655 BM    HW: 5Q0 959 655 BM
   Component: AirbagVW21    008 0403
   Serial number: 003FGM05RR3W
   Coding: 8CCCFC00000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 0C41A2ED56C2CDAB3FA-8058
   Occupant Detection:
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH00000000000CAUMRI
   Coding: 30344A
   Subsystem 2 - Part No SW: -----------    HW: 480 001 208 19
   Serial number: 357000000007E1408E3N
   Subsystem 3 - Part No SW: -----------    HW: 480 001 208 19
   Serial number: 358000000000186D5E3N
   Subsystem 4 - Part No SW: -----------    HW: 480 403 107 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001A0F051DC1E904
   Subsystem 5 - Part No SW: -----------    HW: 480 402 007 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001B8F20CA12A95A
   Subsystem 6 - Part No SW: -----------    HW: 480 400 309 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001BAF20D05566FG
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 309 19
   Component: FrontSensor_P  005 6149
   Serial number: 3560001BAF20D0556264
   Part No SW: 17A 920 840 A    HW: 17A 920 840 A
   Component: KOMBI         252 2700
   Coding: 01A5011A2788CF0502882F095000000020000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   VCID: 211FE359C14070C37CC-8074
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5366
   Serial number: 01101900842080
   Coding: 030100047F085900FB0002E91C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85C865401E9FBBB1E-803A
   Component: 0-00-0d-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AD    HW: 5G0 959 442 AD  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29190001321420059236
   Coding: 29FFFF
   Serial number: 7822916800
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000217737016
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F131991A0C043ECC-8064
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H55 8043
   Serial number: HA1-00017.05.19
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52FD7C95F466DB5BB56-8006
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0148
   Serial number: 11230017556919
   Coding: 5294C620
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
   VCID: 392F2B3949D0080354C-806C
   Part No SW: 5Q4 959 393 M    HW: 5Q4 959 393 F
   Component: TSG FS        006 0247
   Serial number: 50038927600317
   Coding: 003C1B200000028000000000
   Shop #: WSC 01383 790 50316
   ROD: EV_DCU2DriveSideMAXHKLO.rod
   VCID: 4DC76FE9ED5884A3E84-8018
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000004280899
   Coding: 011000
   Part No SW: 5QN 909 144 B    HW: 5QN 909 144 A
   Component: EPS_MQB_ZFLS  507 5082
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
21760 - Databus
          [HCA_01 Botschaft - CAN-Timeout]
                    Reset counter: 20
                    Mileage: 1266 km
                    Date: 2020.04.07
                    Time: 09:09:49
                    Motor status: 00
                    Supply voltage: 12.00 V
                    Temperature: 32.0 °C
                    KFC: 55
                    KFA: 00 00
                    Environmental conditions: 5F
                    uioUdNotFilt_xdu16: 11.92 V
                    uAdSensI_SwitchedKl30_xdu16: 11.89 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
   Part No SW: 5Q4 959 392 M    HW: 5Q4 959 392 F
   Component: TSG BFS       006 0247
   Serial number: 54038927302581
   Coding: 003C13200600028000000000
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   VCID: 4CC162ED16428DABFFA-8018
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000004246980
   Coding: 091000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 17A 035 868     HW: 17A 035 868
   Component: MU-E--ER      695 8742
   Serial number: 09091900021175
   Coding: 02630100BE00000041220001001000009F0000D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW37.rod
   VCID: 678BBD416FE44EF3F28-8032
   Part No SW: 5G0 907 159 F    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0004
   Serial number: 190704201548
End----(Elapsed Time: 01:20, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)-----
Nothing strikes me as obvious in the scan.
ag13
C?ID=223721
Found it on the first try. I appeared to have selected adaptive cruise control and that is what deactivated the symbols. Thanks for the info on the changes history!
