Results 1 to 6 of 6
Thread: Newbie: SRI Reset
    New User
    Apr 2019
    Newbie: SRI Reset
    Hey All.
    So far i have just used my VCDS to read error codes on the car - which is just the once.
    It is now time to reset a service light. The last Full service i did was back in June 2019, ifi recall, they did reset the servie light. Which has come on again.
    So, how do i find out why?
    Also how do tell if my car is on flexible or fixed service?
    Finally, do the results below look okay?
    Monday,06,April,2020,20:36:28:04239
    VCDS Version: 20.4.0.1 (x64)
    VIN: License Plate: **** *****
    Mileage: ###### Repair Order:
    VCDS Release 20.4.0: SRI Reset
    Control Module Part Number: 8T0 920 983 M Labels: .8T0-920-xxx-17.clb
    Component:KOMBIINSTR. H35 0556, Coding:33A7300002012600010000
    Channel Description Unit Current val. New val.
    02 Service Reminder Status 2 ---
    40 Distance since Service km x100 145 ---
    41 Time since Service Days 159 ---
    42 Minimum Distance to Service km x100 300 ---
    43 Maximum Distance to Service km x100 300 ---
    44 Maximum Time to Service Days 730 ---
    45 Oil Quality 1 ---
    47 Soot Quantity DIST x100 329 ---
    48 Thermal Load DIST x100 136 ---
    49 Minimum Time to Service Days 730 ---
    50 Basic Distance Value for Oil Change km x100 145 ---
    51 Basic Time Value for Oil Change Days 365 ---
    52 Basic Distance Value for Inspection km x100 190 ---
    53 Distance since Inspection km x100 56 ---
    54 Basic Time Value for Inspection Days 730 ---
    55 Time since Inspection Days 307 ---
    56 Day Counter Days 2598 ---
    Thanks in advance
    Craze: hmmm...... that's a unique and an very interesting way to introduce the vehicle for your question. Notwithstanding my assumption that you want to not disclose the VIN, please include a full (meaning, unedited) current auto-scan from the car - so we can see a total list of the equipment installed as context for the CAN Gateway module (the VIN can be blanked on your scan report before posting -if you want)
    Thank you
    PS: Or, as a relatively obscure forum member so eloquently said recently: HERE
  3. Likes Uwe, gokarty, PetrolDave, Dana liked this post
    New User
    Apr 2019
    Hi Don.
    Thanks for the response and apologies for missing the information
    I didn't know you needed that.
    Do I need to start a new thread with a scan of the car?
    I assume you mean this:
    Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: Release 19.6.2(x64) Data version: 20190930 DS308.0
    Dealer/Shop Name:
    Workshop Code: 000 00000 000000
    Self-Diagnosis Log
    Sunday,19,January,2020,12:42:54:04239
    VIN: License Plate:
    Mileage: 231010km-143542mi Repair Order:
    Chassis Type: 8T-AU48 (8R0)
    Scan: 01 02 03 05 08 09 0E 0F 15 16 17 19 37 42 44 46 52 53 56 5F
    62 72
    VIN: Mileage: 231010km-143542miles
    0F-Digital Radio -- Status: Cannot be reached 1100
    Self-Diagnosis Log
    Page 2
    VIN: License Plate:
    Address 01: Engine (J623-CJCA) Labels:. 03L-906-018-CGL.clb
    Part No SW: 03L 906 018 HT HW: 03L 906 018 JL
    Component: R4 2.0l TDI H25 9977
    Revision: 45H25---
    Coding: 0A034012232401080000
    Shop #: WSC 46703 001 1048576
    ASAM Dataset: EV ECM20TDI01103L906018HT 003008
    ROD: EV ECM20TDI01103L906018HT.rod
    VCID: 03022E508A059757BA-8056
    4807 - EGR System
    P0401 00 [104] - Insufficient Flow
    Fault Frequency: 18
    Mileage: 230023 km
    Date: 2020.01.04
    Time: 21:44:03
    Engine speed: 1162.00 /min
    Normed load value: 27.1 %
    Vehicle speed: 46 km/h
    Coolant temperature: 80 °C
    Intake air temperature: 13 °C
    Voltage terminal 30: 14.640 V
    Air mass: specified value: 283.2 mg/stroke
    Air mass: actual value (mg/stroke): 415.9 mg/stroke
    EGR Solen.val.: actual value: 15.92 %
    Throttle valve adapter: actual value: 26.62 %
    Charge air pressure specified value: 1042 hPa
    Charge air pressure: actual value: 1140 hPa
    Mean injection quantity: 8.20 mg/stroke
    Readiness: 0 1 0 0 0
    Self-Diagnosis Log
    Page 3
    VIN: License Plate:
    Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
    Part No SW: 8K9 927 155 A HW: 0AW 927 156 K
    Component: 0AW 20TDI RdW H05 0001
    Revision: --H05--- Serial number: 0000001585
    Coding: 000002
    Shop #: WSC 06325 000 00000
    ASAM Dataset: EV TCMVL381 A02432
    ROD: EV TCMVL381.rod
    VCID: 3A7C93B4BD4F169FA9-806E
    Part No SW: 8K0 907 379 CG HW: 8K0 907 379 CG
    Component: ESP8 front H09 0100
    Coding: 171544
    VCID: 0008215C93138C4FA7-8054
    Part No SW: 8K0 907 064 GB HW: 8K0 907 064 FB
    Component: BCM2 2.0 H12 0633
    Coding: 01B44040000000000000
    VCID: 76E44784C1D7B2FF8D-8022
    Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
    Component: FBSAUDIB8 IDG H71 0083
    Serial number: 0513000010155010
    Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
    Serial number: 2313000021399005
    Self-Diagnosis Log
    Page 4
    VIN: License Plate:
    Part No SW: 8K2 820 043 AJ HW: 8K2 820 043 AJ
    Revision: D1000000 Serial number: 01150220130789
    Coding: 342402E000
    VCID: 71EE7498A8B995C758-8024
    Part No SW: 8K0 907 063 DD HW: 8K0 907 063 DD
    Component: BCM1 1.0 H16 0103
    Revision: 04016001 Serial number: 00000549150902
    Coding: 290000308034A7E01E81000300001F1F009D420827080201000008004000020000000024000000
    Shop #: WSC 06325 123 12345
    VCID: 74E07D8CD7ABA0EFB3-8020
    Subsystem 1 - Part No SW: 8T2 955 119 D HW: 8J2 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 140213 H13 0080
    Serial number: SWF13020145100
    Coding: 00FD11
    Component: G397 RLFS H06 0002
    Serial number: 20993713
    Coding: 02005D
    Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
    Component: E1 - LDS H03 0031
    Serial number: 00000000000802130845
    Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ Hum Sensor H03 0003
    Serial number: ED380296000000000001
    00471 - Control Module for Elect. Regulated Dampers (J250)
    Reset counter: 88
    Mileage: 229799 km
    Date: 2020.01.01
    Time: 14:06:03
    Self-Diagnosis Log
    Page 5
    VIN: License Plate:
    Address 0E: Media Player 1 (R41) Labels: Redir Fail!
    Part No SW: 8X0 035 110 C HW: 8X0 035 110
    Component: CDC-MP3-Pana H41 0490
    Revision: 00000008
    VCID: 2D56A8E87401B1273C-8078
    Address 0F: Digital Radio
    Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
    Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
    Serial number: 003KFD989TDX
    Coding: 30533938363030303030554A305238543053
    ASAM Dataset: EV AirbaECUVWAUDI010 003010
    ROD: EV AirbaECUVWAUDI010 003_AU48.rod
    VCID: 4898F97CF3A3740F2F-801C
    Serial number: 6334MSME7665266DO
    Serial number: 6344MSME78655546K
    Serial number: 6352QSME3E2C1574P
    Serial number: 6362QSME712B0456E
    Serial number: 63732SME49292962%
    Serial number: 63832SME5C2B20560
    Self-Diagnosis Log
    Page 6
    VIN: License Plate:
    Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
    Component: Lenks.Modul H02 0171
    Revision: 00000000 Serial number: 20130215000428
    Coding: 000036
    VCID: 4FAAD2601ECDA3376E-801A
    Component: E221 - MFL H03 0004
    Part No SW: 8T0 920 983 M HW: 8T0 920 983 M
    Component: KOMBIINSTR. H35 0556
    Revision: 00100000 Serial number: UUW323G2E
    Coding: 33A7300002012600010000
    VCID: 4898F97CFBA3740F2F-801C
    Self-Diagnosis Log
    Page 7
    VIN: License Plate:
    Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
    Component: GW-BEM 4CAN-M H11 0055
    Revision: 1Y060027 Serial number: 2741Y131290170
    Coding: 80CF07FF00
    VCID: 4A9CC374E5AF861F39-801E
    Serial number: 6754938901
    Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
    Component: J532 DCDCStab H17 0042
    Serial number: 13042001600021200181
    02230 - Digital Radio (DAB) (R147)
    Reset counter: 88
    Mileage: 229799 km
    Date: 2020.01.01
    Time: 14:06:08
    Bin. Bits: 11111
    Voltage: 14.50 V
    Count: 6
    Bin. Bits: 10000
    Reset counter: 88
    Mileage: 229799 km
    Date: 2020.01.01
    Time: 14:06:08
    Bin. Bits: 11111
    Voltage: 14.50 V
    Count: 6
    Bin. Bits: 10000
    Self-Diagnosis Log
    Page 8
    VIN: License Plate:
    Address 37: Navigation
    Part No SW: 8T0 959 793 Q HW: 8T0 959 793 F
    Component: TSG FA H09 0304
    Coding: 011002624001450005
    VCID: 57BA2A00261DEBF7B6-8002
    Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
    Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
    Component: RCEPS H37 0507
    Revision: 00001000 Serial number: 0026221517
    Coding: 100000000001
    Shop #: WSC 06324 000 00000
    ASAM Dataset: EV RCEPSAU48X 008014
    ROD: EV RCEPSAU48X 008.rod
    VCID: 3460BD8C9F2BE0EF73-8060
    Revision: 00002001 Serial number: 0300863779
    Coding: 013B062220B90000802004368000000F
    Self-Diagnosis Log
    Page 9
    VIN: License Plate:
    Part No SW: 8T0 959 792 Q HW: 8T0 959 792 H
    Component: TSG BF H08 0304
    Coding: 011002224C01450005
    Shop #: WSC 12345 123 61029
    VCID: 56A427042117D2FFAD-8002
    Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
    Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
    Component: EPB-4 H01 0003
    Revision: -------- Serial number: 30000000011898
    ASAM Dataset: EV ParkiBrake 001027
    ROD: EV ParkiBrake AU48.rod
    VCID: 387889BC8343048F5F-806C
    Part No SW: 4G0 035 056 G HW: 4G0 035 056
    Component: Radio U STD H60 0121
    Revision: AB001007 Serial number: 230BY0D7583564
    Coding: 010003020100000001
    VCID: 254650C82CF18967F4-8070
    Self-Diagnosis Log
    Page 10
    VIN: License Plate:
    Part No SW: 8R2 035 666 B HW: 8R2 035 666 C
    Component: H-BN-EU H45 0639
    Revision: -------- Serial number: 206B/0D7518686
    Coding: 13010104000681ED07808F5E00000403E40000020200000000
    VCID: 387889BC8B43048F5F-806C
    Subsystem 1 - Part No: 8R0 060 884 AR
    Component: ECE 2013 1505
    Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
    Component: DU7 High H42 0104
    Serial number: A130BP0D2655633
    Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
    Component: E0380 Bedient H02 0030
    Serial number: 00000001414782
    Component: CD-Database 4949
    Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
    Component: TSG HL H07 0304
    Coding: 010002224001450005
    VCID: 59BE2C385009FD8780-800C
    Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
    Component: TSG HR H07 0304
    End-------------------------(Elapsed Time: 03:55)--------------------------
    That's better than nothing, but it's certainly not ideal. Please don't use the [Print] function in VCDS to post data here. Please just post the native text VCDS produces. You can grab it from your Scans sub-folder.
    Based on "Oil Quality" being set to 1, it appears your car is set to Fixed intervals. But the rest of the values don't match that; for example both Minimum and Maximum Distance to Service are set to 30,000 km, which strikes me as implausibly long for fixed intervals. 30,000 km is the maximum allowed on flexible intervals, but even then the minimum should should 15,000.
    How long have you owned this car? It seems someone has buggered up these settings, as well as the coding. Byte 9 of the cluster's coding indicates it's set to "Germany (D) / Left-Hand-Drive (LHD) OR Not Specified". That doesn't seem correct. Is this really a LHD car? Because some of the other coding bits seem to show it set up for the UK.
    PS: Please Get Verified.
    New User
    Apr 2019
    Hey Don.
    Thanks for the quick reply.
    Thanks for pointing the scans folder - duly noted.
    Does the below work better - or do you need the file attached?
    Also, is below the ideal of what you need - or is there something else? - I appreciate your assistance, so would like to make it as easy as possible for you.
    I have had the car just coming up to 1 year from Last April. January was the first time I looked into scanning the codes after it got a Fault (on the EGR valve if I recall).
    The car is certainly a UK spec right-hand drive Auto.
    How do I correct the coding info?
    Thanks again.
    Sunday,19,January,2020,12:41:23:04239
    VCDS Version: 19.6.2.0 (x64)
    VIN: WAUZZZ8###########   License Plate:
              62 72
    VIN: WAUZZZ8###########   Mileage: 231010km-143542miles
       Revision: 45H25---
       ASAM Dataset: EV_ECM20TDI01103L906018HT 003008
       ROD: EV_ECM20TDI01103L906018HT.rod
    4807 - EGR System
                        Fault Frequency: 18
                        Mileage: 230023 km
                        Date: 2020.01.04
                        Time: 21:44:03
       Coding: 000002
       ASAM Dataset: EV_TCMVL381 A02432
       ROD: EV_TCMVL381.rod
       Coding: 171544
       Coding: 342402E000
       Coding: 00FD11
       Coding: 02005D
                        Reset counter: 88
                        Mileage: 229799 km
                        Date: 2020.01.01
                        Time: 14:06:03
       Revision: 00000008
       Coding: 000036
       Coding: 80CF07FF00
                        Reset counter: 88
                        Mileage: 229799 km
                        Date: 2020.01.01
                        Time: 14:06:08
                        Bin. Bits:    11111
                        Voltage: 14.50 V
                        Count: 6
                        Bin. Bits:    10000
                        Reset counter: 88
                        Mileage: 229799 km
                        Date: 2020.01.01
                        Time: 14:06:08
                        Bin. Bits:    11111
                        Voltage: 14.50 V
                        Count: 6
                        Bin. Bits:    10000
       ROD: EV_RCEPSAU48X_008.rod
       ROD: EV_ParkiBrake_AU48.rod
    p.s. Will work on getting verified asap. My paperwork is at my flat in Leeds and I am stuck down in Hertfordshire due to Covid.
  7. Likes Uwe liked this post
    Quote Originally Posted by CrazeUK View Post
    Yes, much better, thank you.
    OK, I located two other scans of cars with the exact same Instrument Cluster. Both seem to be UK cars, and both have the same 00 value in Byte 9. So it's possible that the documentation we have for that byte is no applicable to this particular cluster, and I'm going to recommend against messing with it.
    Now regarding the Service Reminder, here's what I would do if this car were mine: Wait 5,000 more km, because then it's due for an oil change anyway. Once that has been done, I would do the following:
    [SRI Reset]
    Wait for VCDS to read the channels again.
    From the Operation drop-down, choose "Change to fixed Intervals (Rest of World)" (*)
    [Perform SRI]
    Wait for VCDS to modify the channels.
    [Done, Go Back]
    Cycle the ignition.
    [SRI Reset]
    From the Operation drop-down, choose "Fixed Oil Service Reset (Rest of World)"
    [Perform SRI]
    [Done, Go Back]
    (*) I would not use "Change to fixed Intervals (Great Britain)" because that assumes the values are in miles and yours aren't.
    You shouldn't need any paperwork. There should be a "short" serial number that starts with HC7 and is followed by five more numbers on the interface itself. That and the "long" serial number from the About screen in VCDS (plus your contact info) are all that's required.
  9. Likes PetrolDave, CrazeUK, Dana liked this post
