Results 1 to 5 of 5
Thread: Secondary Air Pump fault - How to turn off?
    Mar 2020
    Grand Junction, CO, USA
    2003 Passat 1.8t. Is there a way to stop the ECU from having communication with the 2ndary air pump? Have replaced the pump and just keep getting fault codes.
    Saturday,04,April,2020,11:56:24:24553
    VCDS Version: 20.4.0.1 (x64)  HEX-V2 CB: 0.4508.4
    VIN: WVWPD63B13P380576   License Plate: 721WOB
    Mileage: 213640km-132749mi   Repair Order:
    VIN: WVWPD63B13P380576   Mileage: 213640km-132749miles
    Address 01: Engine        Labels: 06B-906-018-AWM.clb
       Part No SW: 4B0 906 018 DQ    HW:
       Component: 1.8L R4/5VT     G   0060
       Revision: 00000000    Serial number: VWZ7Z0C6952420
       Coding: 0016551
       Shop #: WSC 20108 444 102998
       VCID: 73B3D989C7A0D6035E0-5160
    16795 - Secondary Air Injection System
                P0411 - 002 - Incorrect Flow Detected - MIL ON
       Part No: 3B0 927 156 AH
       Component: AG5 01V 1.8l5VT USA 0810
       Coding: 0001104
       Shop #: WSC 00028 000 00000
       VCID: 6C81C2F59A9E09FB9FA-5160
       Part No: 4B0 614 517 P
       Component: ABS/ESP front       2330
       Coding: 04277
       Shop #: WSC 00028
       VCID: 2E0508FD6902BBEBF1E-51CE
       Part No: 1C0 909 605 C
       Component: 09 AIRBAG VW61 04   0003
       Coding: 12345
       Shop #: WSC 00028
       VCID: 2411EAD537CE01BB17A-513C
    Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
       Part No: 1J0 907 487 A
       Component: Lenkradelektronik   0005
       Coding: 00118
       Shop #: WSC 00028
       VCID: 2F3B15F96E08B2E3FA8-5184
       Part No: 3B0 920 927 B
       Component: KOMBI+WEGFAHRSP VDO V08
       Coding: 07235
       WVWPD63B13P380576     VWZ7Z0C6952420
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00028
       VCID: 70B9D685B3B6ED1BA32-513C
       Part No: 1C0 959 799 C
       Component: 08 Komfortgerát HLO 0003
       Coding: 00258
       Shop #: WSC 00028
       VCID: 372B2D9996587A23A28-4B1E
       Subsystem 1 - Part No: 1C1959801
       Component: 08 Tőrsteuer.FS KLO 0009
       Subsystem 2 - Part No: 1C1959802
       Component: 08 Tőrsteuer.BF KLO 0009
       Subsystem 3 - Part No: 1C0959811
       Component: 08 Tőrsteuer.HL KLO 0009
       Subsystem 4 - Part No: 1C0959812
       Component: 08 Tőrsteuer.HR KLO 0009
    Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
       Part No: 3B7 035 180 E
       Component:    Radio NP2        0008
       Coding: 04031
       Shop #: WSC 00028
       VCID: 221DECCD2DDA0F8B656-513C
    End----------(Elapsed Time: 04:16, VBatt start/end: 14.3V/14.3V)-----------
    No, you can't change its fault detection logic.
    Have you been here?
    http://wiki.ross-tech.com/wiki/index...5/P0411/001041
    There are a fair number of other things that can cause this fault besides a bad pump.
    Have you been here?
    See what deletes in the industry are causing as a sentiment as being an everyday normalcy?
    OP
    Can you clear all faults and re-post a new scan after the car idling for 1 minute please?
    Have you tried observation of the combi and vacuum lines to it or if the car has a notorious pervasive vacuum leak at L hose to booster?
    Is car modified with FOD programming?
    JPPSG
  5. Likes Uwe liked this post
    HQ
    Start the engine, let idle for 10 seconds, shut engine off. Turn ignition on, do not start engine. Connect to the ECM and do the Output Test... one of those test will be for the relay (J299) that in turn runs the pump. You should hear the pump pulsing on and off when this test is running. If so, great. If not... relay or S130 fuse issue?
    If the pump is running, then I'd check the vacuum line at the kombi valve, they are prone to splitting apart, so the kombi valve doesn't get enough vacuum to open it up, thus low air flow (incorrect flow).
    Jef
  8. Likes Fredrick Awuor liked this post
