Results 1 to 3 of 3
Thread: Audi A1 ESP9.0i Incorrectly Coded
    Aug 2019
    Hi
    After a small accident in the left rear corner the ABS coding was lost. I have restored the coding but I can't deal with the error:
    1245 - Control Module Incorrectly Coded
    U1014 00 [024] - -
    [VAR_Checking_AllradPlausibilityError]
    I will be grateful for any information about this error.
    Regards
    Saturday,04,April,2020,14:15:25:31001
    VIN: WAUZZZ8X1HB101824   License Plate: AUDI A1(2)
    Mileage: 19940km-12390mi   Repair Order:
    Chassis Type: 8X-AU21 (8U0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F
    VIN: WAUZZZ8X1HB101824   Mileage: 19940km-12390miles
    Address 01: Engine (J623-CHZB)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04C 906 026 AK    HW: 04C 907 309 AE
       Component: R3 1.0l TFS   H26 3583
       Revision: W1H26---
       Coding: 00110012230401080000
       Shop #: WSC 00046 412 00000
       ASAM Dataset: EV_ECM10TFS01104C906026AK 002012
       ROD: EV_ECM10TFS01104C906026AK_002.rod
       VCID: 6A8DC28F6CF878C7771-803E
    4660 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [039] - -
              [ABS brake control moduleRead out DTC]
                        Mileage: 19944 km
                        Date: 2020.04.04
                        Time: 14:13:18
                        Coolant temperature: 37 °C
                        Intake air temperature: 13 °C
                        Voltage terminal 30: 11.803 V
                        Outside air temperature: 16 °C
                        Absolute intake pressure: 101 kPa abs
                        Engine torque: 0.0 Nm
                        Fuel level: 19.00 l
                        Oxygen sensor bank 1 sensor 1: specified value: 1.0000
    Readiness: 1110 0001
       Part No SW: 6C0 907 379 S    HW: 6R0 907 379 BA
       Component: ESP9.0i       H04 0006
       Serial number: 08510084170503
       Coding: 34DF708B8D2333C1491C306B00552C0EB1CC920C0013E2090F00
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
       VCID: 3FDB43DB47FA2D6FF0F-806A
    6 Faults Found:
    0048 - Databus
              [ComScl_mDaempfer_1_Timeout]
                        Reset counter: 150
                        Mileage: 19944 km
                        Date: 2020.04.04
                        Time: 14:13:15
    1242 - Databus
              U1121 00 [137] - Missing Message
              [ComScl_mAllrad_1_Timeout]
                        Reset counter: 150
                        Mileage: 19944 km
                        Date: 2020.04.04
                        Time: 14:13:15
    0943 - ABS/ESP Control Module
              U10C5 00 [137] - No or Incorrect Basic Setting
              [IISOEMCalibrationError]
                        Reset counter: 145
                        Mileage: 19943 km
                        Date: 2020.03.02
                        Time: 00:02:50
    0625 - Display for Tire Pressure Monitoring
                        Reset counter: 150
                        Mileage: 19944 km
                        Date: 2020.04.04
                        Time: 14:13:14
    1149 - Implausible Data Received from Steering Angle Sensor Module (G85)
              U0428 00 [137] - -
              [Scl_LWI_SensorNotCalibrated]
                        Reset counter: 150
                        Mileage: 19944 km
                        Date: 2020.04.04
                        Time: 14:13:15
              U1014 00 [024] - -
              Intermittent - Confirmed - Not Tested Since Memory Clear
                        Reset counter: 190
                        Mileage: 19944 km
                        Date: 2020.04.04
                        Time: 13:58:22
       Part No SW: 8XA 820 045 A    HW: 8XA 820 045 A
       Component: J301  Manuell       0031
       Revision: 00H0206S    Serial number: 00303006495064
       Shop #: WSC 00046 000 00000
       VCID: 45D7513329A677BFBA3-8010
    Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
       Part No SW: 8X0 907 063 AF    HW: 8X0 907 063 AF
       Component: BCM PQ35  M   113 0821
       Revision: AB113821
       Coding: 08000A2CB805F100A05841E00104015443FB290A00EF4922DC0087830041
       VCID: 005980277A049297C95-8054
       Subsystem 1 - Part No SW: 8U0 955 559 D    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
       Component: G397_RLS  H06 0004
       Serial number: 50120466
       Coding: 02005D
       Subsystem 2 - Part No: 8X0 951 177 A
       Component: Sensor, DWA 0  005 0002
       Subsystem 3 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
    02914 - Sensor 1 for Trunk/Hatch Closed (G525)
                        Reset counter: 150
                        Mileage: 19944 km
                        Date: 2020.04.04
                        Time: 14:13:13
                        Voltage: 11.85 V
                            Term 50 On
    Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
       Part No SW: 8XA 959 655 A    HW: 8XA 959 655 A
       Component: Airbag10.41   H08 0011
       Revision: --------    Serial number: 003NZ0054BYT
       Coding: 30314539313130323430554A305238584153
       ASAM Dataset: EV_Airba1041BPAAU210 001018
       ROD: EV_Airba1041BPAAU210.rod
       VCID: 59EF8D43B99EE35FEEB-800C
       Serial number: 3554VRB405D4PF78G07I
       Serial number: 3575HRB401859KNEBP8V
       Serial number: 3585HRB401C596KS6H8K
       Rear Impact Crash Sensor:
       Serial number: 3515ZRB401C59HKKDOVS
    Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
       Part No SW: 8X0 953 521 AE    HW: 5K0 953 569 BD
       Component: LENKS.MODUL   018 0230
       Revision: FF010018    Serial number: 20170504200299
       Coding: 1084004000
       ROD: EV_SMLSNGVOLWSR8C.rod
       VCID: 7F5B03DB077AED6FB0F-802A
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Serial number: 30 03 2017  C0060370
    Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
       Part No SW: 8XA 920 980 D    HW: 8XA 920 980 D
       Component: KOMBI_MEDIUM  H05 0530
       Coding: 41DE01
       ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
       VCID: 51FF7563E16EAB1F16B-8004
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8U0 907 468 AQ    HW: 8U0 907 468 G
       Component: GAT 4CAN 1L M H13 0090
       Revision: 1P170044    Serial number: 4441P174200165
       Coding: FBCF1A57000100010153
       VCID: 117FB563216EEB1F56B-8044
       Subsystem 1 - Part No SW: 6C0 915 181 D    HW: 6C0 915 181 D
       Serial number: 1437423804
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
       Serial number: 170206000000000004D6
                        Reset counter: 150
                        Mileage: 19944 km
                        Date: 2020.04.04
                        Time: 14:13:13
                        Bin. Bits:    10111
                        Voltage: 11.90 V
                        Count: 6
       Component: IMMO          H05 0530
       Coding: 000002
       ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 F    HW: 8X0 959 793 F
       Component: TSG FA        H11 0415
       Coding: 011802204001000100
       VCID: 50F97067EAE4A217195-8004
       Part No SW: 6R2 909 144 AM    HW: 6R2 909 144 E
       Component: EPS_TRW_ALow  323 3142
       Serial number: CH5C0262
       Coding: 000700
       ASAM Dataset: EV_SteerAssisUDSTRW 016134
       ROD: EV_SteerAssisUDSTRW.rod
       VCID: 03538F2B6B92898FD47-8056
    1094656 - Steering angle sensor
                        Reset counter: 150
                        Mileage: 19944 km
                        Date: 2020.04.04
                        Time: 14:13:14
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 F    HW: 8X0 959 792 F
       Component: TSG BF        H11 0415
       VCID: 4FFB731BF7DABDEF00F-801A
       Part No SW: 8XA 035 192 F    HW: 8XA 035 192 A
       Component: RMC Nav Plus  H62 0186
       Coding: 01010000004051070023000103010000000000
       VCID: 4BC3670B03C281CF6C7-801E
       Subsystem 1 - Part No SW: 8X0 919 603 B    HW: 8X0 919 603 B
       Component: DU6 Basic  H43 0084
       Serial number: 9462E 0H3136565
    End----(Elapsed Time: 00:52, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
    Aug 2016
    The Hague, NL
    I cannot really say why, because this is a big big guess, but try this please:
    33DF288B492333C1091C106B0055cc1492CC900C0005cb090F00
    Last edited by Uwe; 04-06-2020 at 09:41 AM. Reason: CODE tags because the forum software puts spurious spaces in otherwise.
  3. Likes Marekkgb, Uwe, Fredrick Awuor liked this post
    Aug 2019
    Thanks. I will try soon
