ME17 ecu mk6 gti
racofuy
New Zealand
C?ID=197081
Another oddball question, anyone have a pin out for this ecu?
I'm wanting to find out if it has a dedicated pin for A/C on like the earlier me7.5 does.
I don't have the luxury of an A/C control panel to communicate via CAN.
iichel
Netherlands, eastern part
C?ID=284912
Perhaps a scan would be helpful, to see the exact hardware in your car (might depend on model year etc) :)
Spacewalker
Poland
C?ID=159607
CAN only
ECU is more smart , can measure more data via CAN
racofuy
New Zealand
C?ID=197081
CAN only
Thanks for your reply, I was afraid this might be the case, is there any way to replicate A/C on message to the ECU?
Engine and ECU plus can gateway and central electrics are retro fitted to older car. Cannot install climatic panel.
A/C system is from Golf 3 but would like to find a way to tell ECU to run cooling fans.
I have discovered that disconecting the MK6 outside air temp sensor will run the fans, but at full speed which is not ideal.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Good luck with that , that is like trying to install Wind10 on 20 years old PC.
