Long Coding Advice for Passat B8 Instruments Control Module 17
free2beee
Australia
C?ID=394496
Hi everyone, thanks in advance to anyone who is able to assist,
On an auto scan of my car I found that the message "Control Module Incorrectly coded", see below:
   Part No SW: 3G0 920 751 A    HW: 3G0 920 751 A
   Component: KOMBI         301 6421
   Coding: 27A401186798000801887B0B1000000000000000
   Shop #: WSC 04174 123 61029
   VCID: 2313E9B0AB5FE2EFF47-8076
          U1014 00 [009] - -
                    Reset counter: 251
                    Mileage: 83672 km
                    Date: 2020.03.29
                    Time: 13:35:54
16776980 - Databus
          [PLA_Status_01 keine Kommunikation]
                    Reset counter: 251
                    Mileage: 83672 km
                    Date: 2020.03.29
                    Time: 13:35:54
QUESTION: Is it safe to change the Long Coding Manually for this module back to the original pre-fault coding by changing the two different byte codes in the following?:
Original with No Faults in Instruments Control Module 17
LONG CODING:
27 A4 01 18 67 88 00 08 01 88 6B 0B 10 00 00 00 00 00 00 00
88 Byte 5 10001000
6B Byte 10 01101011
Current with two faults as shown above and a different coding for the two items above.
LONG CODING
27 A4 01 18 67 98 00 08 01 88 7B 0B 10 00 00 00 00 00 00 00
98 Byte 5 10011000
7B Byte 10 01111011
gokarty
C?ID=401142
LONG CODING:
88 Byte 5 10001000
6B Byte 10 01101011
Is the original pre-fault coding that you listed for your own car? If so, what were you trying to achieve by changing byte 5 and byte 10?
Some more context would help
Also, please post a full Auto-Scan
[see this link]
free2beee
Australia
C?ID=394496
I had originally posted the autoscan in this post https://forums.ross-tech.com/showth...140-Highline-Diesel-(Australian-Model)-faults
The pre-fault coding as you put it is in my own car the one that is referred to in the first thread above.
Context,
I have only used pre-developed apps for modification of control modules through OBDEleven things like, show remaining fuel, autolock after x seconds when you leave the car taking your keys etc. I can give actual specifics if needed. These apps/adaptations are one click affairs and do not specify the long coding details.
It appears that the error came about after some of these apps were used and before I used the KUFATEC coding dongle to code for the retrofitted PLA3.0 I added to the car, as to the coding it did I am not sure other than to add the control module and parameters for PLA3.0.
Cheers
Andrew
There should be no harm in restoring coding values to "factory condition".
Don't even get me started on "apps" that make coding and adaptation changes to your car without telling you what they are, and without keeping some kind of log of what they actually did. :rolleyes:
free2beee
Australia
C?ID=394496
Hi Uwe,
Thanks for your advice. One of the reasons I went and purchased your VCDS Hex-V2 interface from the Australian distributor was to get more details on what actually was going on in the car before and after my PLA3.0 retrofit. As you have guessed I had purchased an OBDEleven Pro dongle prior to that and used some of its apps for my model, some worked and some didn't but the details are not explained at the App level. You can see the long coding etc in the interface if you look.
Basically I decided to look at the Long Coding of the Instruments/Dashboard 17 Control Module as it said the coding was not correct. So I compared the long coding of my backup taken by the OBDEleven and then looked at the Long Coding of Control Module 17 through the various changes I had implemented via Apps and also via the KUFATEC dongle that came with the retrofit.
The only discrepancy I could find is with those two bytes 88 to 98 and 6B to 7B but I could not find any text or explanation as to what that actually means. Hence my question, if there were not errors in that module when the Long Coding was set to the respective 88 and 6B then I should change them back using VCDS and it should eliminate the incorrectly coded error. Is my logic correct??
If it were my car, I would certainly try that.
Dana
Western PA, USA
I would reuse the entire known factory coding but if I had to take a guess Byte 5, Bit 4 (labeled Park/Steer Assist installed with VCDS) would be more likely than Byte 10, Bit 4 (Display 'Volume to be Replenished). 5/4 does NOT appear to be enabled in other Passat scans with Component: PLA 3.0
free2beee
Australia
C?ID=394496
Thanks I will give it a go and report back here. Note we are restricted from driving our cars here due to Covid-19 lockdown so I may not be able to do it and test it for a while.
free2beee
Australia
C?ID=394496
Changing Byte 10 back to original did not remove the fault(s)
I left Byte 5 the same as it concerns PLA Park Assist. It may be that because I added a new control module and connections for PLA3.0 (coded by the Kufatec coding dongle) that this is not expected by the Instruments Control Module.
I noted also in my look through the modules that many PLA/Park Assist bits were not selected and that RHDrive was selected in some but not other modules. I went through and selected all that I could testing after each coding change. Same errors popped up except in ABS it came up no faults and the faults in reported then popped up in the Central Electrics.
See below:
Wednesday,15,April,2020,15:38:58:41391
VIN: WVWZZZ3CZGE1XXXXX   License Plate:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 52 5F 6C A5
          CF
VIN: WVWZZZ3CZGE1XXXXX   Mileage: 83725km-52024miles
Address 01: Engine (J623-DFCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
   Component: R4 2,0L EDC   H23 1195
   Revision: B4H23---
   Coding: 011D0032046505083000
   Shop #: WSC 05311 115 00318
   ASAM Dataset: EV_ECM20TDI01104L906026FN 002001
   ROD: EV_ECM20TDI01104L906026FN_002_VW48.rod
   VCID: 7BA3F1D0736F7A23060-802E
   Part No SW: 0D9 300 041 J    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4906
   Revision: 06253104    Serial number: TFK01510270727
   Shop #: WSC 05311 115 00089
   ROD: EV_TCMDQ250021.rod
   VCID: 1F1BE5408737C6034A8-804A
   Revision: 00000000    Serial number: 63185000000703
   Coding: 0EEC928F34230B6E077A060041C64970492CD0E0608292F51862F03AC2A9
   Shop #: WSC 17873 123 50804
   ROD: EV_Brake1UDSContiMK100IPB_034.rod
   VCID: 7AADF4D47C55432B1D6-802E
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0710
   Revision: 00036000    Serial number: 0385786377
   Coding: 0F00100F03
   ASAM Dataset: EV_KessyHellaMQBAB 004032
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3A2D34D43CD5832B5D6-806E
   Part No SW: 5G0 907 044 BG    HW: 5G0 907 044 BG
   Component: Climatronic   H04 1202
   Revision: 00001K10
   Coding: 1112010430210000111550401210180A
   ASAM Dataset: EV_ACClimaBHBVW37X 005137
   ROD: EV_ACClimaBHBVW37X_005_VW37.rod
   VCID: 6D87CF883D1BE493884-8038
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Part No SW: 5Q0 937 086 AJ    HW: 5Q0 937 086 AJ
   Revision: --------    Serial number: 86581111151510
   Coding: 03011B46C2C102FF07A04094B11007281880000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 025D8C3414850BEB456-8056
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    150801  043 0607
   Serial number:         150930150330
   Component: RLHS  037 0059
   Serial number: S4Y15M11D19H15M36S17
   Coding: 90A8DD
   Light switch:
   Subsystem 3 - Part No SW: 3G0 941 633     HW: 3G0 941 633
   Serial number: 15 06 2015  10000699
   Serial number: 000000000ZY1527208K0
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000033891458
540693 - Databus
                    Reset counter: 254
                    Mileage: 83725 km
                    Date: 2020.04.15
                    Time: 15:35:39
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Serial number: 000308417618339
   Coding: 0371167851
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 50F9767C8A69297B832-8004
   Component: ACC BOSCH MQB H04 0192
   Coding: 320467D251FFC728949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001008
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 34311AEC1EB1755B87A-8060
   Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003STPPAKVGF
   Coding: 98FCC0C0000000005C540000008800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5B05C0677766032A8-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 111 15
   Serial number: 3576U00000065689971G
   Subsystem 2 - Part No SW: -----------    HW: 454 000 111 15
   Serial number: 3586U000000ED489971V
   Subsystem 3 - Part No SW: -----------    HW: 454 800 211 15
   Serial number: 3516R5962C5080000003
   Subsystem 4 - Part No SW: -----------    HW: 454 802 410 15
   Serial number: 3526R6E93BC08000000K
   Subsystem 5 - Part No SW: -----------    HW: 454 801 610 15
   Serial number: 3556V18CCC108000000I
   Part No SW: 3Q0 953 521 B    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20151021400459
   Coding: 0810
   Shop #: WSC 00015 115 00001
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 2F3B1580F7975683FA8-807A
   Coding: 27A401186798000801886B0B1000000000000000
   VCID: 2313E9B0AB5FE2E36E0-8076
          U1014 00 [009] - -
                    Reset counter: 254
                    Mileage: 83725 km
                    Date: 2020.04.15
                    Time: 15:36:39
16776980 - Databus
                    Reset counter: 254
                    Mileage: 83725 km
                    Date: 2020.04.15
                    Time: 15:36:39
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 09111510800334
   Coding: 030300345F087300FB0002581C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 79AFEBD87953483314C-802C
   Serial number: 29150002186110075451
   Coding: 2CFFFF
   Serial number: 1488858203
   Analog clock:
   Component: Analoguhr  209 2002
   Serial number: 15000154107005
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD3F821230073ACC-8024
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 B    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0230
   Revision: --------
   Coding: 44C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   VCID: 372B2DE00FC79E43A28-8062
   Serial number: 220815BHM11588
   Coding: 00351A208001020000000000
   VCID: 43D349304B1FC2E30E0-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002557486
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  125 1063
   Coding: 9303
   VCID: 44D14A2C4E11C5DB37A-8010
   Serial number: 011015BIU19426
   Coding: 003510208001020000000000
   VCID: 42DD4C345405CBEB056-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002560819
   Coding: 050000
   Part No SW: 3G0 035 045 G    HW: 3G0 035 045
   Component: MU-H-N-RW     H50 0343
   Serial number: A688J0FB000689
   Coding: 02840108FF00000051510001000828001F0204C601200102DF
   VCID: 221DECB4B445EBEB656-8076
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU30423C
   Subsystem 2 - Part No SW: V03 959 806 FQ    HW: -----------
   Component: ROW 2019/2020  --- 0079
   Component: Gracenote2  --- 4008
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H07 0100
   Coding: 0184010162002017000040
   Shop #: WSC 05311 000 00197
   ROD: EV_CamSysRVRVCPANAMQBAB_005.rod
   VCID: 77ABEDE04F475E43628-8022
   Part No SW: 3Q0 980 654 C    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0023
   Serial number: 12111511K20116
   Coding: 000408010000010100022346C050410084000E000020
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 B    HW: 3Q0 907 590
   Revision: --------
   Coding: 44C002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
End----------(Elapsed Time: 02:05, VBatt start/end: 12.3V/12.4V)-----------
NEtech
C?ID=56995
Are you 100% sure, that the kufatec dongle changed coding in [17] Byte 5 Bit 4 ?
Is it kufatec product Item no. 41780-1 you have installed ?
What manual coding/change with a tester, is explained in kufatec instructions
Out of 246 Control units I have in Autoscan files with Part Number SW: 3G0 920 7xx, none have this bit active.
As Dana wrote, I would try to remove Byte 5 Bit 4, then Bus rest etc.
Is the DTC gone ?
You can also test coding in [17], Byte 13 Bit 0
downtime
C?ID=280813
NETech is right. Byte 5 bit 4 PLA is for PLA2.0 and that needs to be unchecked with PLA3.0.
PLA3.0 bit is byte 13 bit 0 as NETech wrote.
So uncheck byte5 BIT 4 and check byte 13 bit 0.
If you use the experimental coding option it shows you the labels for byte 13 as well. Normal label file does not have the explanation for that byte.
This is a correct coding for your instrument cluster
27A401186788000801886B0B1001000000000000
free2beee
Australia
C?ID=394496
Is the DTC gone ?
Hi NETech, I am not sure that what the Kufatec dongle changed with the coding, I will go through my backup of coding prior to the dongle being used to try to work that out. I can certainly change the Byte 5 Bit 4 and see if a) the DTC is gone and b) that the Park Assist/Pilot from Kufatec still works and report back. I will have a look at Byte 13 Bit 0.
Thanks for your input I appreciate it.
Andrew
free2beee
Australia
C?ID=394496
I have now sent Kufatec at their request my VCDS scan and the Dongle Code KTC File. Hopefully they will be able to confirm what the correct coding is from the dongle and if that needs any further adjustment.
free2beee
Australia
C?ID=394496
Problem solved, Kufatec analysed my scan and their dongle code and concluded the same as advised here the key CHANGE being Byte 13 Bit 0 must be activated.
Coding: 27A401186788000801886B0B1001000000000000
