Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Long Coding Advice for Passat B8 Instruments Control Module 17
    May 2017
    NETech is right. Byte 5 bit 4 PLA is for PLA2.0 and that needs to be unchecked with PLA3.0.
    PLA3.0 bit is byte 13 bit 0 as NETech wrote.
    So uncheck byte5 BIT 4 and check byte 13 bit 0.
    If you use the experimental coding option it shows you the labels for byte 13 as well. Normal label file does not have the explanation for that byte.
    This is a correct coding for your instrument cluster
    27A401186788000801886B0B1001000000000000
  2. #12
    Mar 2020
    Australia
    Are you 100% sure, that the kufatec dongle changed coding in [17] Byte 5 Bit 4 ?
    Is it kufatec product Item no. 41780-1 you have installed ?
    What manual coding/change with a tester, is explained in kufatec instructions
    Out of 246 Control units I have in Autoscan files with Part Number SW: 3G0 920 7xx, none have this bit active.
    As Dana wrote, I would try to remove Byte 5 Bit 4, then Bus rest etc.
    Is the DTC gone ?
    You can also test coding in [17], Byte 13 Bit 0
    Hi NETech, I am not sure that what the Kufatec dongle changed with the coding, I will go through my backup of coding prior to the dongle being used to try to work that out. I can certainly change the Byte 5 Bit 4 and see if a) the DTC is gone and b) that the Park Assist/Pilot from Kufatec still works and report back. I will have a look at Byte 13 Bit 0.
    Thanks for your input I appreciate it.
    Andrew
  3. #13
    Mar 2020
    Australia
    I have now sent Kufatec at their request my VCDS scan and the Dongle Code KTC File. Hopefully they will be able to confirm what the correct coding is from the dongle and if that needs any further adjustment.
  4. #14
    Mar 2020
    Australia
    Problem solved, Kufatec analysed my scan and their dongle code and concluded the same as advised here the key CHANGE being Byte 13 Bit 0 must be activated.
    Part No SW: 3G0 920 751 A HW: 3G0 920 751 A
    Component: KOMBI 301 6421
    Coding: 27A401186788000801886B0B1001000000000000
    Shop #: WSC 04174 123 61029
    VCID: 2313E9B0AB5FE2E36E0-8076
    May 2017
    NEtech and I told you so already. Didn't you see that I posted you a working code earlier and what NEtech wrote?
  6. Likes PetrolDave, Uwe, Fredrick Awuor, jhnbssll liked this post
