Results 1 to 10 of 16
Thread: 2009 VW Tiguan transmission problem
    Mar 2018
    I need help I cant find a good mechanic in my are everyone its afraid of VW so I'm going to trying to fix it my self but I can't do that with help from this forum thank you
    last year I damage my rear main seal, the only problem was a very bad oil leak from the engine, my mechanic pull the engine out and took 4 months to put it back in the car after that the engine run and the car move for a few minutes before losing the transmittion, everything looks like its working besides that and the radio, I have check all the fuses, cables plugs connections grounds. but nothing there is no communication to the TCM.
    Chassis Type: 5N (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 4F 52 53 56 62
              65 72
    VIN: WVGAV75N89W000708   Mileage: 217190km-134955miles
    02-Auto Trans -- Status: Cannot be reached 1100
    44-Steering Assist -- Status: Malfunction 1010
    Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
       Part No SW: 06J 997 026 L    HW: 06J 906 026 AF
       Component: MED17.5 TFSI 2,0    0608
       Revision: AAH03---    Serial number: VWX7Z0H03NS048
       Coding: 0423010A19070160
       Shop #: WSC 49778 001 1048576
       VCID: 3D27C417E172BA23784-8068
    049409 - No Communication with Transmission Control Module
                   U0101 - 000 -  - MIL ON
                        Fault Status: 11100000
                        Fault Frequency: 20
                        Mileage: 217193 km
                        Time: 01:00:03
                        Temperature: 29.0C
                        Temperature: 30.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 12.192 V
    000257 - Mass Air Flow Sensor (G70)
                   P0101 - 000 - Implausible Signal
                        Mileage: 217193 km
                        Time: 00:22:34
                        RPM: 2731 /min
                        Load: 16.5 %
                        Temperature: 30.0C
                        Temperature: 29.0C
                        Voltage: 12.954 V
    Readiness: 0110 0101
    Address 02: Auto Trans
    Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
       Part No SW: 5N0 614 517 L    HW: 5N0 614 517 L
       Component: J104    C2 450 V2   0006
       Revision: --H11---    Serial number: 00000000890866
       Coding: 0002329
       Shop #: WSC 01324 785 00200
       VCID: 372BD63FC34E9073A28-8062
                        Fault Frequency: 73
                        Reset counter: 213
                        Mileage: 217193 km
                        Time: 00:00:15
                        Hex Value: 0x0000
                        Voltage: 11.75 V
                        Bin. Bits: 00011110
                        Count: 167
                        Hex Value: 0x0000
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Fault Frequency: 19
                        Reset counter: 213
                        Mileage: 217193 km
                        Time: 00:22:35
                        Hex Value: 0x0000
                        Voltage: 13.25 V
                        Bin. Bits: 00011110
                        Count: 233
                        Hex Value: 0x0000
                        Fault Frequency: 19
                        Reset counter: 213
                        Mileage: 217193 km
                        Time: 00:22:35
       Part No SW: 1K0 820 047 HJ    HW: 1K0 820 047 HJ
       Component: Climatic PQ35   141 1010
       Revision: 00141028    Serial number: 00000000000000
       VCID: 73B3222F97B63C535E0-8026
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
       Revision: 00H54000    Serial number: 01000007997389
       Coding: 118C8FA340041C0047190000140000000068F7475C400104390000000000
       VCID: 71BF2827EDAA0E43ACC-8024
       Subsystem 1 - Part No: 5N1 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 280108  012 0203
       Coding: 00038805
       Shop #: WSC 01324
    6 Faults Found:
    00532 - Supply Voltage B+
                        Reset counter: 253
                        Mileage: 217193 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 8.50 V
    01759 - Relay for Horn
                        Fault Status: 00100110
                        Reset counter: 253
                        Mileage: 217193 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.00 V
                        Reset counter: 253
                        Mileage: 217193 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 8.20 V
    02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                        Reset counter: 253
                        Mileage: 217193 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 11.55 V
    02384 - Windshield Wiper Motor Function Restricted due to Over-Voltage
                        Fault Status: 00100001
                        Reset counter: 253
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 9.05 V
                        Reset counter: 253
                        Mileage: 217193 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 11.75 V
       Revision: 00000000    Serial number: AUZ4Z7H0244285
       Coding: 0000100
       VCID: 3333E22FD7367C539E0-8066
                        Reset counter: 213
                        Mileage: 217193 km
                        Time: 00:00:59
       Part No SW: 5N0 959 655 B    HW: 5N0 959 655 B
       Component: J234__200 VW10 HI   1815
       Revision: 19013000    Serial number: 0039EPMAC1S
       Coding: 0012336
       VCID: 3C21C913FA68B32B4FA-8068
       Subsystem 1 - Part No: 5N0 959 339 A
       Component: BF-Gewichtsens. 001 0004
       Subsystem 2 - Serial number: 00000000000AJ6
       Subsystem 3 - Serial number: 0023.01.08000010000065005963
       Subsystem 4 - Serial number: 6500596333FTS640380188 63
       Subsystem 5 - Serial number: 80188 6343FTS685500208 63
       Subsystem 6 - Serial number: 00208 6353ETS6JDR8SVNP 63
       Subsystem 7 - Serial number: 8SVNP 6363ETS61DU8SVNP 63
       Subsystem 8 - Serial number: 8SVNP 6373JTS6VQM7SVNH 63
       Subsystem 9 - Serial number: 7SVNH 6383JTS6DFK7SVNH
       Subsystem 10 - Serial number: 7SVNH
       Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
       Component: J0527           752 0100
       Coding: 0012022
       VCID: 78A915038ED05F0B6B2-802C
    6 Faults Found:
    00576 - Terminal 15
    00884 - Ignition Switch (D) Terminal X
    01744 - Ignition Switch Terminal P (D)
    00002 - Transmission Control Unit
    00885 - Ignition Switch (D) Terminal 50
       Part No SW: 5N0 920 970 E    HW: 5N0 920 970 E
       Component: KOMBIINSTRUMENT VDD 1220
       Revision: V0004000    Serial number: VWX7Z0H03NS048
       Coding: 0007204
       Shop #: WSC 65536 645 577705
                        Fault Frequency: 97
                        Reset counter: 253
                        Mileage: 217193 km
                        Time: 00:00:48
                        Fault Frequency: 10
                        Reset counter: 253
                        Mileage: 217193 km
                        Time: 00:26:18
                        Reset counter: 253
                        Mileage: 217193 km
                        Time: 00:32:08
                        Fault Frequency: 100
                        Reset counter: 213
                        Mileage: 217193 km
                        Time: 00:00:14
       Part No SW: 1K0 907 530 N    HW: 1K0 907 951
       Component: J533  Gateway   H06 0052
       Revision:   H06 01    Serial number: 090108F2001720
       Coding: FD807F070013036002
       VCID: 323DE72B282C755B956-8066
                        Reset counter: 213
                        Mileage: 217193 km
                        Time: 00:02:34
                        Fault Status: 00110100
                        Reset counter: 253
                        Mileage: 217193 km
                        Time: 00:00:49
    00469 - Infotainment Databus in Single Wire Operation
                        Fault Status: 00101100
                        Reset counter: 253
                        Mileage: 217193 km
                        Time: 20:00:19
       Part No SW: 1K6 919 879     HW: 1K6 919 879
       Component: Kompass         001 0003
       Revision: 00001000    Serial number: 1225223T2LJZ03
       VCID: 7DA70417A1F27A23384-8028
       Component: IMMO            VDD 1220
       Shop #: WSC 05087 444 84550
       Part No SW: 5N0 959 701     HW: 5N0 959 701
       Component: Tuer-SG         006 1205
       Coding: 0001205
       VCID: 72BD272BE8AC355B556-8026
    00100 - Drivers Interior Locking Button (E308)
       Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.285 0802
       Revision: 1AH03831    Serial number: 00102850078101
       Coding: 0000258
       Shop #: WSC 00001 028 00001
       VCID: 3B23CA0FFF66B413460-806E
    02546 - Steering Limit Stop
                        Fault Status: 11100101
                        Reset counter: 213
                        Mileage: 217193 km
                        Time: 02:24:10
                        (no units): 4.0
                        Voltage: 11.60 V
                        Reset counter: 213
                        Mileage: 217193 km
                        Time: 02:24:13
                        (no units): 4.0
                        Steering Angle: 0.00
                            Not OK
                        (no units): 5
       Coding: 1380078852832C1B0904058FB0880F0488DCA0
       Shop #: WSC 05087 444 59276
       VCID: 045171F3C2180BEB77A-8050
                        Reset counter: 253
                        Fault Status: 00110111
                        Reset counter: 253
    Address 4F: Centr. Electr. II (J533)       Labels:. 1K0-907-532.clb
       Part No SW: 1K0 907 532     HW: 1K0 907 951
       Coding: 050B0500
       VCID: 66954B7BD864D9FBC9E-8032
       Component: J245EE19SKB12  H01 0220
       Subsystem 2 - Part No SW: 8R0 959 591     HW: 8R0 959 591
       Component: J394EE16SKB09  H01 0170
       Part No SW: 5N0 959 702     HW: 5N0 959 702
       Coding: 0001204
       Part No SW: 5N0 907 801 B    HW: 5N0 907 801 B
       Component: J540 EPB3  VW-09384 0005
       Revision:   H08       Serial number: 00000000029329
       Coding: 0000057
       VCID: 2E05F35B3C1451BBF1E-807A
    03200 - Switch for Electric Parking Brake (E538)
                012 - Electrical Fault in Circuit - MIL ON
                        Fault Status: 11111100
                        Reset counter: 213
                        Voltage: 11.50 V
                        Count: 10
                        Hex Value: 0x0861
                        Hex Value: 0x0088
                        Hex Value: 0x1010
    16352 - Control Module - Electrical Error
                014 - Defective - MIL ON
                        Fault Status: 11101110
                        Reset counter: 213
                        Voltage: 11.50 V
                        Count: 42
                        Hex Value: 0x0171
                        Hex Value: 0x0088
                        Hex Value: 0x1010
    16366 - Control Module - Internal Malfunction; CPU 2
                        Reset counter: 213
                        Voltage: 11.50 V
                        Count: 41
                        Hex Value: 0x1171
                        Hex Value: 0x0008
                        Hex Value: 0x1010
                        Fault Status: 11110100
                        Reset counter: 213
                        Mileage: 217193 km
                        Voltage: 11.40 V
                        Count: 75
                        Hex Value: 0x1271
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    02434 - Supply Voltage for Control Module for Left Channel
                        Fault Status: 00101001
                        Fault Frequency: 12
                        Reset counter: 213
                        Voltage: 11.90 V
                        Count: 16
                        Hex Value: 0x1171
                        Hex Value: 0x0008
                        Hex Value: 0x1010
       Component: Radio PM6       019 0035
       Revision: 00019000    Serial number: VWZ5Z7G2197521
       Coding: 0040401
       VCID: 290F004705FA368324C-807C
                        Reset counter: 253
                        Mileage: 217193 km
                        Time: 14:34:06
       Part No SW: 5N0 959 703 A    HW: 5N0 959 703 A
       Component: Tuer-SG         006 1301
       Coding: 0001168
       Shop #: WSC 01324 785 1012552
       VCID: 3537DC37D9426263B04-8060
       Coding: 0100101
       Part No SW: 5N0 959 704 A    HW: 5N0 959 704 A
       Coding: 0001168
       VCID: 3635DB3BC444697BB9E-8062
    End----(Elapsed Time: 01:44, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
    Dallas (McKinney) ,TX ,USA
    Please clear all codes and re post full auto scan , lets see what will come back.
    09-Cent. Elect has lost of codes , need to see are they any will go away.
    Also Transmission not communicating at all, that why you have problem.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
    Poor B+ battery/ground connections should be checked first and why battery is at 8 volts should be sorted along with fuses observed!
    I sure hope when the seal was done you addressed crankcase PCV that most likely caused this leak or faulty know fuel system issues?
    Did you request full dealer work history and if all campaigns were done plus submit complaint to NHTSA for these issues & that should be more than a voluntary BS recall or service action?
  4. Likes Dana liked this post
    Mar 2018
    Quote Originally Posted by Jetta ,97 View Post
    Thank you for your help, I called the dealer and order the ignition switch this morning
    VIN: WVGAV75N89W000708   License Plate: NONE
    Mileage: 217190km-134955mi   Repair Order: 2
              65 72
                        Fault Frequency: 25
                        Mileage: 217193 km
                        Time: 01:00:03
                        Temperature: 29.0C
                        Temperature: 30.0C
                        Voltage: 12.192 V
                        Mileage: 217193 km
                        Time: 00:22:34
                        RPM: 2731 /min
                        Load: 16.5 %
                        Temperature: 30.0C
                        Temperature: 29.0C
                        Voltage: 12.954 V
       Coding: 0002329
                        Fault Frequency: 78
                        Reset counter: 213
                        Mileage: 217193 km
                        Time: 00:00:15
                        Hex Value: 0x0000
                        Voltage: 11.75 V
                        Bin. Bits: 00011110
                        Count: 167
                        Hex Value: 0x0000
                        Fault Frequency: 25
                        Reset counter: 213
                        Mileage: 217193 km
                        Time: 00:22:35
                        Hex Value: 0x0000
                        Voltage: 13.25 V
                        Bin. Bits: 00011110
                        Count: 233
                        Hex Value: 0x0000
                        Fault Frequency: 25
                        Reset counter: 213
                        Mileage: 217193 km
                        Time: 00:22:35
       Coding: 00038805
       Shop #: WSC 01324
    6 Faults Found:
                        Reset counter: 253
                        Mileage: 217193 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 8.50 V
                        Reset counter: 253
                        Mileage: 217193 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.00 V
                        Reset counter: 253
                        Mileage: 217193 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 8.20 V
                        Reset counter: 253
                        Mileage: 217193 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 11.55 V
                        Reset counter: 253
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 9.05 V
                        Reset counter: 253
                        Mileage: 217193 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 11.75 V
       Coding: 0000100
                        Reset counter: 213
                        Mileage: 217193 km
                        Time: 00:00:59
       Coding: 0012336
       Coding: 0012022
    6 Faults Found:
    00576 - Terminal 15
       Coding: 0007204
                        Fault Frequency: 97
                        Reset counter: 253
                        Mileage: 217193 km
                        Time: 00:00:48
                        Fault Frequency: 10
                        Reset counter: 253
                        Mileage: 217193 km
                        Time: 00:26:18
                        Reset counter: 253
                        Mileage: 217193 km
                        Time: 00:32:08
                        Fault Frequency: 106
                        Reset counter: 213
                        Mileage: 217193 km
                        Time: 00:00:14
                        Reset counter: 213
                        Mileage: 217193 km
                        Time: 00:02:34
                        Reset counter: 253
                        Mileage: 217193 km
                        Time: 00:00:49
                        Reset counter: 253
                        Mileage: 217193 km
                        Time: 20:00:19
       Coding: 0001205
       Coding: 0000258
                        Reset counter: 213
                        (no units): 4.0
                        Voltage: 11.60 V
                        Reset counter: 213
                        Mileage: 217193 km
                        Time: 02:25:52
                        (no units): 4.0
                            Not OK
                        (no units): 14
                        Reset counter: 253
                        Reset counter: 253
       Coding: 050B0500
       Coding: 0001204
       Coding: 0000057
                        Reset counter: 213
                        Voltage: 11.50 V
                        Count: 10
                        Hex Value: 0x0861
                        Hex Value: 0x0088
                        Hex Value: 0x1010
                        Fault Status: 00101110
                        Reset counter: 253
                        Voltage: 11.50 V
                        Count: 42
                        Hex Value: 0x0171
                        Hex Value: 0x0088
                        Hex Value: 0x1010
                        Reset counter: 253
                        Voltage: 11.50 V
                        Count: 41
                        Hex Value: 0x1171
                        Hex Value: 0x0008
                        Hex Value: 0x1010
                        Reset counter: 213
                        Mileage: 217193 km
                        Voltage: 11.40 V
                        Count: 75
                        Hex Value: 0x1271
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                        Fault Frequency: 12
                        Reset counter: 213
                        Voltage: 11.90 V
                        Count: 16
                        Hex Value: 0x1171
                        Hex Value: 0x0008
                        Hex Value: 0x1010
       Coding: 0040401
                        Reset counter: 253
                        Mileage: 217193 km
                        Time: 14:34:06
       Coding: 0001168
       Coding: 0100101
       Coding: 0001168
    End----(Elapsed Time: 01:51, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
    UMMMM why the ECU lights up?
    Please explain this madness method hypothesis?
    Mar 2018
    I cant explain it don't know, that is why I'm here there must be a broken wire somewhere when they pull the engineand no i didn't go to the dealer, they asked me $3500 US dollars to change the seal so i when to a local mechanic and now the vehicle don't move
    You have very low voltage at Central electronic module,I do not think your Ignition switch is the problem, Hold on to that.
    Do me favor , start car and see is it charging at all or it has only 12V at battery?
    If not charging I think I know what is the problem, tell me that first?
    Coding: 118C8FA340041C0047190000140000000068F7475C40010439 0000000000
    Coding: 00038805
    Shop #: WSC 01324
    6 Faults Found:
    Reset counter: 253
    Mileage: 217193 km
    Date: 2005.09.13
    Time: 31:63:63
    Voltage: 8.50 V
    Immobilizer/ECU
  9. Likes Uwe, Dana, Fredrick Awuor liked this post
  10. #8
    Mar 2018
    Before I started the engine 12.23 volts after the engine stars 12.99 it took about 10 seconds to go up to 13.03, thank you
  11. #9
    Did you check the mini harness from ignition switch to 0x16 for burn down?
    Is the transmission plugged in?
    Did you check wiring down the 0x44 steering rack for connectivity?
    Coding: 0012022
    6 Faults Found:
    00576 - Terminal 15
  12. #10
    Mar 2018
    I checked all the connectors going to the transmission, they all connected good nothing lose there, and it was never removed or unplug before, I also check all the harness in the steering column and ignition lock but i decided to order a new ignition switch and harness just in case. ( wiring down the 0x44 steering ) where is this under the vehicle? the steering rack failed and was replaced this was a few days before the rear main seal, electric steering is working good now but the yellow light is on, i believe it was not program correctly but the car drove ok after that, i need to check wiring down the 0x44 steering
