Results 1 to 7 of 7
Thread: SKC From Bin File
    Mar 2018
    SKC From Bin File
    I wonder if someone can point me in the right direction
    I need to add another key to my sons 2010 Polo 6R as he's managed to lose one of them, I'll then use VCDS to code up the new key
    However my SKC retrieval tool is busted (long story...) I've used one of my other tools to read the bin file from the cluster but now need to figure out where the SKC is written in the hex file and then how to retrieve it, I can open the bin file in HxD but dont know which bytes its stored in.
    Does anyone know either what software could be used or how to decipher the bin file to extract the SKC, I realise I could get a locksmith to do me a key for around 80 but I love a challenge (which i'll probably regret later..)
    Thanks in advance
    Sunday,05,April,2020,14:52:57:17347
    VCDS Version: 20.4.0.1 (x64)
    VIN: WVWZZZ6RZBY203736   License Plate: PF60XXX
    Mileage: 156750km-97399mi   Repair Order:
    Chassis Type: 6R-VW25 (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 44 56
    VIN: WVWZZZ6RZBY203736   Mileage: 156750km-97399miles
    Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
       Part No SW: 03P 906 021 A    HW: 03P 906 021
       Component: R3 1.2l TDI   H04 9979
       Revision: 11001001    Serial number:
       Coding: 00114014000500080000
       Shop #: WSC 51498 001 1048576
       ASAM Dataset: EV_ECM12TDI03103P906021A 001024
       ROD: EV_ECM12TDI03103P906021.rod
       VCID: 2644570659A4CEB658-8072
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
       Component: ESP8.2i front H05 0001
       Revision: --------
       Coding: 230224E3416D00B5C42C24E582D700821100
       Shop #: WSC 00788 648 00255
       VCID: 071A3A82B26EF7BE43-8052
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
       Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
       Component: Man AC         02 0101
       Revision: 0002S 02
       VCID: 326CBB566D6CA216C4-8066
       Part No SW: 6R0 937 086 H    HW: 6R0 937 086
       Component: BCM PQ25 M++4 H46 0230
       Revision: BD046001    Serial number: 0392 003111860
       Coding: 24B029BF08A10000002008003D2B0CD00000410F60060000200000000000
       Shop #: WSC 124697 483 00190
       VCID: 418EE49AD8CA098E4D-8014
       Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  007 1621
       Serial number: KU0-KU005.01.1116569
       Coding: 08BC30
       Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  007 1621
       Serial number: KU0-KU007.01.1113261
       Coding: 08BC30
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10Airbag01X H09 0020
       Revision: --------    Serial number: 003GX00DDSH.
       Coding: 003158
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4A9CC3B6EDFCCAD69C-801E
       Serial number: 3575HRB405T0BI7U7OFA
       Serial number: 3585HRB404V0C15ID0E6
       Serial number: 3515RRB404V0AMH8CPVS
       Serial number: 3525RRB404T0AMH8KOKN
       Part No SW: 6R0 920 961 F    HW: 6R0 920 961 F
       Component: KOMBI         H04 0304
       Coding: 440200
       VCID: 397E8C7AB81A514E05-806C
       Part No SW: 6N0 909 901     HW: 6R0 937 086
       Component: GW-K-CAN TP20 0230
       Coding: 002100
       VCID: 70E8715EA3E0D006F2-8024
       Component: IMMO          H04 0304
       VCID: 6ADC63368D3C2AD6BC-803E
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 11230
       Shop #: WSC 00788
       VCID: 2F6AB222EA5E8FFEAB-807A
       Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
       Component: Radio RCD310  016 0049
       Revision: 01000000    Serial number: VWZ1Z2L0306610
       Coding: 0700040002
       VCID: 6BD266328AC633DEC7-803E
    00857 - CD Changer Unit (R41)
                        Reset counter: 190
                        Mileage: 156759 km
                        Date: 2014.08.27
                        Time: 02:18:05
    End-------------------------(Elapsed Time: 02:03)--------------------------
    Address 56,5M0 035 186 AA,recoded (Long Coding),from,0700040002,to,0500040002,(00788/648/00255),
    Moving to General VW/Audi Repair because the question doesn't involve VCDS.
    I will also point out that a PIN/SKC code is not sufficient to match a key to this car. Being a 2010 model with a UDS cluster/immo, I am near certain that it requires an Immo-4 challenge/response. The immo produces a challenge that changes with every cycle of the ignition (you can see this in Advanced ID) and the response must be calculated from this challenge. I would suppose that the PIN code is one of the inputs needed to generate the response from the challenge, but calculation is never done on the dealers' tool/software, only on VWAG's corporate servers, which makes reverse-engineering it rather difficult...
    I suspect the "locksmith tools" that can do key matching on these immos don't actually do it correctly, but use more crude methods that often produce undesired side effect such as a mangled ASAM ID.
  3. Likes GXCars liked this post
    Mar 2018
    Thanks Uwe,
    I was under the impression that all of the immo4 cars had a rolling code system just the transponder chips were different. I had the locksmith do one on a caddy which has the same protocol on the cluster as it was a 2012 van and he just logged in and matched up the key. I think I still have a scan and dont recall seeing anything amiss afterwards. I have a licensed odis but no Geko as its something I've not needed to do and its cost prohibtive for the odd one
    My other van had a butchered immo and I ended up having to get the ECU and cluster reflashed and new chips but this one is later so I'll have to dig a little more
    Ian
    Dallas (McKinney) ,TX ,USA
    Like UWE said Pin is useless on this car and VCDS will not be bale to do it.
    Also all data in bin file in encrypted and there is no way to decrypted it just like that , so you will not be bale to read any info even if you know where is the store.
    Just call your lock smith guy and let him do the job.
    Immobilizer/ECU
    /Cluster Programing (Used or NEW)
    email: marinmm2001@gmail.com , info@advancedcarelectronics.com
    https://www.advancedcarelectronics.com/
  6. Likes Uwe, GXCars liked this post
    Uwe, trust me , Immo challenge works different way. Mainly is relation ship between ECU and Cluster .
    Good example is 2006-2008 Passat has immo challenge and Key and EVL can be adopted with Pin only.
    In newer cars they just chnage Security Access and Pin is not only one that you need.
    I also was able to program key on 2010 Bentley Continental only with Pin.
    Immobilizer/ECU
  8. Likes GXCars liked this post
  9. #6
    Why not just duplicate transponder?
  10. Likes Jetta ,97, Uwe liked this post
  11. #7
    Jun 2014
    Poland
    agree
    now even device for clone chip cost 100-150 Euro
  12. Likes Jack@European_Parts, Uwe liked this post
