Results 1 to 4 of 4
Thread: DRL with main beam - Mk4 Caddy
    Jun 2019
    Middlesbrough, UK
    I have a 2016 caddy with standard halogen headlights. As standard it uses the sidelight as a DRL, however it switches these off whenever you turn the main beam on, is there a way to code these to stay on together?
    VCDS Version: 19.6.0.4
    VIN: WV1ZZZ2KZGX129361   License Plate:
    Mileage: 99780km-62000mi   Repair Order:
    Chassis Type: 2K-VN35 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61
    VIN: WV1ZZZ2KZGX129361   Mileage: 99780km-62000miles
    Address 01: Engine (J623-DFSD)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 016 GT    HW: 04L 907 309 K
       Component: R4 2,0L EDC   H20 1774
       Revision: 8AH20---
       Coding: 0111001204250D090000
       Shop #: WSC 35110 790 50316
       ASAM Dataset: EV_ECM20TDI01104L906016GT 001003
       ROD: EV_ECM20TDI01104L906016GR_001_VN35.rod
       VCID: 010988A0907CCB4798-8054
    Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Component: ESC           H05 0132
       Revision: 00000000    Serial number: 40886000000195
       Coding: 1079409B9264A4870878027C498325E37900F0
       ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
       VCID: 3F8D4E58A6087DB7AE-806A
       Part No SW: 1K8 907 044 BE    HW: 1K8 907 044 BE
       Component: Climatronic   H07 0405
       Revision: 00001K04
       Coding: 051000C003
       ROD: EV_ClimaAutoBasis_VW32.rod
       VCID: 73E5D268DAC0E9D79A-8026
       Part No SW: 5K0 937 085 AD    HW: 5K0 937 085 AD
       Component: BCM PQ35 B+   122 0183
       Revision: BB122001
       Coding: 451A583A8025086A088800829000006403010008420F8160648087000041
       Shop #: WSC 35110 377 00190
       VCID: 75E1EC70DCB4F7E7B4-8020
       Subsystem 1 - Part No: 2K2 955 119 D  Labels: 1KX-955-119.CLB
       Component: Wischer 11031  26  0512
       Coding: 009795
       Part No SW: 1K8 919 465     HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0479
       Revision: --------    Serial number: 39291607700760
       Coding: 0001050001
       ASAM Dataset: EV_EPHVA14VW364GP00 001006
       ROD: EV_EPHVA14VW364GP00_VW36.rod
       VCID: 76E3EB7CC9B2FCFFBD-8022
       Part No SW: 2K5 959 655 B    HW: 2K5 959 655 B
       Component: VW10Airbag00K H08 0018
       Revision: --------    Serial number: 003V10000R2L
       Coding: 00000000000000000000000000000000304B
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       VCID: 3B753A48B210619782-806E
       Serial number: 3497ARB405L3UHHSG9OU
       Serial number: 3507ARB405H3P9AA61H+
       Part No SW: 5K0 953 521 GD    HW: 5K0 953 569 BE
       Component: LENKS.MODUL   018 0230
       Revision: FF010042    Serial number: 20160322301513
       Coding: 5080160010
       ROD: EV_SMLSNGVOLWSR8C.rod
       VCID: 74E7D174DFCEEEEF83-8020
       Part No SW: 2K5 920 976 A    HW: 2K5 920 976 A
       Component: KOMBI         H04 1009
       Coding: 7808001200
       VCID: 346711749F4EAEEF43-8060
       Part No SW: 7N0 907 530 BE    HW: 7N0 907 530 AL
       Component: J533  Gateway H58 1673
       Revision:   H58       Serial number: 280316F1001277
       Coding: 357431
       VCID: 74E7D174D7CEEEEF83-8020
       Component: IMMO          H04 1009
       VCID: 6ADBCF0C8D0A281F29-803E
       Part No SW: 2K5 959 701     HW: 2K5 959 701
       Component: Tuer-SG         009 2144
       Coding: 0131632
       VCID: 71E9D86068DCDBC768-8024
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 140    3501
       Revision: 00H22000
       VCID: 39792040702C538790-806C
       Part No SW: 2K5 959 702     HW: 2K5 959 702
       Coding: 0131632
       VCID: 72EBD76C6DDAE0DF91-8026
       Part No SW: 5C0 035 680 C    HW: 5C0 035 680 C
       Component: MU-S-ND-ER    H22 0245
       Serial number: VWZAZ2S5043963
       Coding: 063307013C00000011111101008808001F01008600200100CF
       ROD: EV_MUStd4CTSAT_SK26.rod
       VCID: 2149E82030BC2B47B8-8074
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
       Component: Batt.regelung H58 1673
       Coding: 030F1873
       VCID: 71E9D860A8DCDBC768-8024
       Subsystem 1 - Part No SW: 1K0 915 181 K    HW: 1K0 915 181 K
       Component: J367-BDM  H07 0223
       Serial number: 33082G26408761771085
    End-------------------------(Elapsed Time: 02:27)--------------------------
  2. Likes Dana liked this post
  3. #2
    I don't see an obvious way to do that.
    It's probably possible by editing the lighting configuration data in the EEPROM, but not with VCDS.
  4. Likes Dana liked this post
  5. #3
    United States
    Uwe's probably correct but I spotted this in Byte 13, Bit 4: LC,13,4,Seitenmerkierungsleuchten ber Fernlichtausgang
    It might be interesting to see what that does but do NOT play with Byte 18 (that can be a nasty one and your original value is not shown).
  6. Likes Uwe liked this post
  7. #4
    VCDS Distributor AINils's Avatar
    Apr 2020
    Germany (AIB)
    I can confirm Dana and Uwe, Byte 18 should be not for interest, becuause you can damage yout light settings. As Uwe told you, its possible during editing EEPROM.
