Results 1 to 7 of 7
Thread: 2005 Bentley CGT with ABS Return Flow Pump code 0301 + 1316 and ABS Parking Brake CEL
    Apr 2020
    Florida, USA
    I have a 2005 Bentley Continental GT that recently had a dead battery. After a jump start the vehicle had the following two symptoms:
    At approximately 10 MPH
    1. Code 00301 - ABS Return Flow Pump
    2. Code 01316 - ABS Control Module
    3. The left dash lamp for ABS is illuminated
    4. The center dash lamp stating: "Brake Fault Stop Vehicle"
    So basically I have never seen an ABS or Parking Brake error until post jump start.
    Here is what I have done so far:
    1. Replaced both batteries
    2. Checked ABS fuses in Trunk and Steering Column
    3. Reset codes with ross-tech VCDS HEX-V2
    a. The codes and light clear and stay cleared until the vehicle reaches approximately 10 MPH
    4. I did re-center the steering wheel via the ross-tech procedure after the battery replacement. Its at 0 deg
    5. I removed and reconnected the ABS connector under the hood. (no science there)
    Here is what I see as my options:
    1. Ask for expert help here
    2.a Order a used ABS module. ~$500 ebay =>Will likely need to recode with VCDS
    OR
    2.b Send mine to be repaired for $150 (modulerepairpro)
    3. Take to indi shop. I am in Melbourne FL, no idea where to go. I have been doing everything myself up until now.
    4. Take it to the Bentley dealer in Orlando or West Palm
    Auto-Scan
     VAG Scan for ABS light after Gym dead battery jump start: 3/18/2020
    Thursday,19,March,2020,00:16:06:22108
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
    VCDS Version 19.6.2.2 (x64)  HEX-V2 CB: 0.4508.4
    VIN: SCBCR63W45C027930   License Plate:
    Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
    Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
              37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
    VIN: SCBCR63W45C027930   Mileage: 38970km-24214miles
    Address 01: Engine        Labels: 07C-906-018-BEB1.clb
       Part No: 07C 906 018 AR
       Component: BY-6.0L-TT      G  ™6521
       Revision: 15ˇTT       Serial number:  000-00008.12.
       Coding: 0000173
       VCID: 75B4E8CC29D4536FEA3-513D
    19475 - Valve for Exhaust Flap 1 (N321)
                P3019 - 004 - Open Circuit
    18331 - Please Check DTC Memory of ECU Number 2
                P1923 - 008 -
    Readiness: 0110 1101
       Part No SW: 09E 927 760 G    HW: GS1 904 1
       Component: AG6 09E 6.0L W12TT  1905
       Coding: 0000101
       Shop #: WSC 00083 000 00000
       VCID: 343215C8622E0A671DD-513D
    Address 03: ABS Brakes        Labels: 3W0-614-517-V1.lbl
       Part No: 3W0 614 517 D
       Component: ESP 5.7 4WD     H01 0021
       Coding: 0007878
       Shop #: WSC 24343 000 00000
       VCID: 36362FC074521877239-51F3
    00301 - ABS Return Flow Pump (V39)
       Part No SW: 3D0 909 135 R    HW: 5WK 470 26
       Component: 1S Kessy            6610
       Revision: 66105312    Serial number: VWZ3Z0D7296402
       Coding: 0143597
       VCID: 343215C8622E0A671DD-5161
    Address 06: Seat Mem. Pass        Labels: 3W0-959-759.clb
       Part No: 3W0 959 759 A
       Component:    CM Seat Pass.    0009
       Shop #: WSC 07402 106 59605
       VCID: 47C8520403B891FF48F-5161
    Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
       Part No: 3W0 035 008
       Component:    ZAB COCKPIT      0223
       Coding: 0400325
       VCID: 6A8ECBB0706A8C97771-5161
    Address 08: Auto HVAC        Labels: 3W7-907-040.clb
       Part No: 3W0 907 040 B
       Component: Climatronic BY614   0030
       VCID: 303A19D896363647795-5161
    Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
       Part No: 3D0 937 049 H
       Component: STG.Bordnetz        5101
       Coding: 0000107
       VCID: 2F381AA48B0829BF60F-5161
                010 - Open or Short to Plus
    Address 11: Engine II        Labels: 07C-906-018-BEB2.clb
       Revision: 23ˇTT       Serial number:  000-00008.12.
       Coding: 0000173
       Part No: 3D0 909 601 E
       Component: 0P Airbag 8.4E+ H10 0936
       Coding: 0012368
       VCID: 2514F88CD9F463EF9A3-5161
    Address 16: Steering wheel        Labels: 3D0-953-549.lbl
       Part No: 3D0 953 549 D
       Component: Lenksšulenmodul     3401
       Coding: 0000012
       VCID: 2E0607A08C0220B76B9-5161
    Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
       Part No: 3W0 920 841
       Component: KOMBIINSTRUMENT RB8 0514
       Coding: 0023203
       Shop #: WSC 07360 106 174048
       VCID: 72BED3D058BA4457CF1-5161
       Part No: 6N0 909 901
       Coding: 0000006
       Shop #: WSC 24343 000 104857
       VCID: 70BAD9D856B67647395-5161
    Address 34: Level Control        Labels: 3D0-907-553-V1.clb
       Part No: 3W0 907 553
       Component: LUFTFDR.-CDC- 3C1V0 7014
       Coding: 0015500
       VCID: 77A8E2C433D8217FF8F-5161
    Address 36: Seat Mem. Drvr        Labels: 3W0-959-759.clb
       Part No: 3W0 959 760 A
       Component:    CM Seat Driver   0008
       Shop #: WSC 24343 000 1048576
       VCID: 3FD84AE45B68D93FF0F-5161
    Address 37: Navigation        Labels: None
       Part No: 3W0 919 887 A
       Component:    NAVIGATION       0168
       Coding: 0400000
       VCID: 45D4580C39B483EFBA3-5161
    Address 38: Roof Electronics        Labels: None
       Part No: 3W0 907 135 C
       Component: Dachmodul           0703
       Coding: 0000157
       VCID: 36362FC074521877239-5161
    Address 46: Central Conv.        Labels: 3D0-959-933.lbl
       Part No: 3D0 959 933 F
       Component: 1X HSG              0101
       Coding: 0000032
       Shop #: WSC 03167 104 53710
       VCID: 333016D467200D5F047-4B01
       Subsystem 1 - Part No: 3W1 959 701
       Component: Tuersteuergeraet FS 0702
       Subsystem 2 - Part No: 3W1 959 702
       Component: Tuersteuergeraet BF 0702
       Subsystem 3 - Part No: 3W3 959 703
       Component: Tuersteuergeraet HL 0702
       Subsystem 4 - Part No: 3W3 959 704
       Component: Tuersteuergeraet HR 0702
       Subsystem 5 - Part No: 7L0 907 719
       Component:    Neigungssensor   0020
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No: 3W0 035 456 C
       Component: 12K-AUDIOVERST      4121
    Address 53: Parking Brake        Labels: 3W0-907-801.clb
       Part No SW: 3W0 907 801 H    HW: 3W0 907 801 H
       Component: EPB  BC7H0300   HC7 0300
       Coding: 0022401
       Shop #: WSC 07692 107 66393
       VCID: 3B203EF44F70C51FDC7-5161
                        Reset counter: 169
                        Voltage: 13.35 V
                        Count: 228
    Address 54: Rear Spoiler        Labels: 1C0-959-733.lbl
       Part No: 1C0 959 733 H
       Component: Heckspoiler         0002
       VCID: 303A19D893363647795-51CF
    Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
       Part No: 3W1 955 023 C
       Component: WischeX
       Shop #: WSC 00000 725 65552
    Address 71: Battery Charger        Labels: 3D0-915-181.lbl
       Part No: 3D0 915 181 C
       Component: Batteriemanagement  2700
       VCID: 2310E694D7C09DDFF47-5161
       Part No: 3W0 919 283
       Component: 02 Einparkhilfe     0203
       VCID: 7AAEFBF000CA3C17871-5161
    Address 77: Telephone        Labels: None
       Part No: 3W0 035 729 E
       Component: Telefon             0119
       VCID: 392C24FC454CF70FCEB-5161
    End----(Elapsed Time: 07:58, VBatt start/end: 11.7V/11.7V. VIgn 0.0V)------
  2. Likes Uwe, Jack@European_Parts liked this post
  3. #2
    Hi and welcome.
    Have you been here?
    http://wiki.ross-tech.com/wiki/index.php/00301
    It seems the return flow pump is more likely the problem than the ABS module.
    Option 1 is what I would take, at least for a few days, and today is Sunday, meaning some of the regulars here aren't around.
    Nov 2014
    New Zealand
    There may be an output test in the ABS module that will run the pump, so you could check if it actually functions.
    I know in the MK60 units, they can clog up, because they are hardly ever used and the brushes create a carbon mess in there.
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
    Apr 2020
    Florida, USA
    Yes. Read it completely.
    I believe the return flow pump is part of the ABS assembly. I think its one piece.
    Apr 2020
    Florida, USA
    Quote Originally Posted by NZDubNurd View Post
    That is a great idea. Anyone know the procedure to do this from VCDS? Or another way?
    Apr 2020
    Florida, USA
    I have decided to replace the ABS unit. I ordered one from a wrecked car on eBay for $280 new they are $3000
    Apr 2020
    Florida, USA
    I replaced the ABS controller, just the black part. It was very tight and required removing the power steering Reservoir and the driver side soft intake hose. It took 2 hours.
    Then I recoded it per the Bentley ABS instructions here. Another 30 min.
    It did fix the issue.
    Summary; Jumpstarting my Bentley blew up the ABS controller. replacing it with a used one from eBay fixed the issue but it did have to be recoded
  9. Likes Uwe, Jack@European_Parts liked this post
