Could use some help with these codes
psychobabble
C?ID=10563
Full auto scan below. Purchased a new fuel filler cap to address the EVAP code. Unsure about how to address the others. 2015 A4 2.0. Thanks!!
 Saturday,04,April,2020,09:55:38:25945
VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUFFAFL0FN007071   License Plate:
Mileage: 87640km-54456mi   Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 44 46 47 52 53 56 62
          72 77
VIN: WAUFFAFL0FN007071   Mileage: 87640km-54456miles
Address 01: Engine (DET-CPMB)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 N    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0005
   Revision: ECH09---
   Coding: 4A2A0013242600062000
   Shop #: WSC 28594 002 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115N 001006
   ROD: EV_ECM20TFS0118K5907115N.rod
   VCID: 3D32119DAC14F76E29-8068
          U1113 00 [032] - -
          U1113 00 [032] - -
10530 - EVAP System
                    Mileage: 87599 km
                    Date: 2020.03.29
                    Time: 16:58:26
                    Engine speed: 1303.50 /min
                    Normed load value: 25.5 %
                    Coolant temperature: 9 °C
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 12.981 V
                    selected gear-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
                    Calculated reducing transmission intervention torque: 1000.0 Nm
                    Engine torque: 66.5 Nm
                    Required RPM at idle speed: 1300.0 /min
   Part No SW: 8K0 927 158 AD    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H18 1003
   Revision: --H18---
   VCID: 78BCC089C3B612463A-802C
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Coding: 2D1D1801
   Shop #: WSC 02391 785 00200
   VCID: 095AB54DA05C1BCE55-805C
   Part No SW: 8K0 907 064 JM    HW: 8K0 907 064 JM
   Component: BCM2 2.0      H14 0650
   Coding: 0D814040000000000000
   VCID: 0444A479877E46A626-8050
   Serial number: 0214000122810004
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01050720140840
   Coding: 6480208000
   VCID: 77BEC3B5C6A81D3E33-8022
   Part No SW: 8K0 907 063 DF    HW: 8K0 907 063 DF
   Revision: 06016001    Serial number: 00000848619902
   Coding: 26000091863CAFC00000480300003D0D0F1C530822090221000008004000030100000000000000
   VCID: 76A0CEB1C1A2643628-8022
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA190514  H18 0461
   Serial number: 1405140701515
   Coding: 004577
   Serial number: 22832275
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002306140588
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555RB3YS03
   Serial number: 8E898737000000000001
   Part No SW: 8K0 959 655 Q    HW: 8K0 959 655 Q
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NDD126FVL
   Coding: 303844354730383131304A55304C384B3053
   Shop #: WSC 61842 001 1048576
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4BD64F45E2A049DEA7-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R140000GEEC
   Serial number: 6334MSME463C2629H
   Serial number: 6344MSME464B4C09O
   Serial number: 6352QSME0A473048D
   Serial number: 6362QSME7D42236CR
   Serial number: 63732SME043F565E8
   Serial number: 63832SME01432940N
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NFQ000RZ
   Coding: 000016
   VCID: 48DC7049FBD6A2C68A-801C
   Part No SW: 8K0 920 951 E    HW: 8K0 920 951 E
   Component: KOMBIINSTR.   H09 0564
   Revision: 00200000    Serial number: ZA159Z17F
   Coding: 8B9609000301D705020000
   VCID: 322832A16D4A3816C4-8066
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0060
   Revision: 1V090029    Serial number: 2941V1461502C2
   Coding: 80C303FF00
   Serial number: 5758963703
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   VCID: 393A058DB03CCB4E05-806C
   Component: MEM-FS        H06 0077
   Revision: AA000000    Serial number: 00000107326068
   Coding: 00581B00000000000000
   VCID: 3B361F85BA00F95E17-806E
   Component: TSG FA        H09 0305
   Coding: 011C13204E00410001
   VCID: 56E0AE312162043608-8002
   Part No SW: 8K0 909 144 J    HW: 8K0 909 144 B
   Component: RCEPS         H40 0509
   Revision: 00001000    Serial number: 0021703596
   Coding: 100000000001
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 383C00898336D246FA-806C
   Revision: 00002001    Serial number: 0340452329
   Coding: 0106023A00FA400580B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000857582
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
   Part No SW: 8T1 035 223     HW: 8T1 035 223
   Component: DSP Prem      H05 0040
   Revision: 00005001    Serial number: 94803031363004
   Coding: 0203010302
   VCID: 6C94ECD98FEEAEE6CE-8038
   Component: TSG BF        H09 0305
   VCID: 55E2A93D3C640F2E01-8000
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000472946
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A381A81BD3AC0560C-806E
70912 - Left Parking Brake Motor Voltage Supply
          C100D 13 [008] - Electrical Malfunction
                    Reset counter: 76
                    Mileage: 79845 km
                    Date: 2019.09.04
                    Time: 10:41:31
                    Voltage terminal 30: 12.0 V
                    Internal Fault ID: 26
                    Network management state: normal
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: On
                    Terminal 15 status: OFF
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    General Inspection Function: not active
                    Internal Parking Brake state: No enabling
                    Status of parking brake button: Not operated
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
71168 - Right Parking Brake Motor Voltage Supply
          C100E 13 [008] - Electrical Malfunction
                    Reset counter: 76
                    Mileage: 79845 km
                    Date: 2019.09.04
                    Time: 08:20:24
                    Voltage terminal 30: 12.4 V
                    Internal Fault ID: 27
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
   Part No SW: 8R1 035 186 Q    HW: 8R1 035 186 Q
   Component: Con3 Sirius   H09 0471
   Revision: 00000003    Serial number: AUZ5Z6N2058285
   Coding: 040300020101850043D9070800
   VCID: 43C66765C2F0819E5F-8016
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
                    Fault Frequency: 6
                    Reset counter: 111
                    Mileage: 86053 km
                    Date: 2020.03.02
                    Time: 16:14:42
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010C13204000210001
   VCID: 59FAA50D507C2B4E25-800C
   Component: TSG HR        H07 0305
   Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005381916
   Coding: 0010370
   VCID: 3E3016916912EC7630-806A
End----(Elapsed Time: 01:42, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Are you actually experiencing an MIL or performance limitation?
Can you please post the OBD2 mode data too in main VCDS screen 0x33 mode 01-01, 3, 7 & 9?
psychobabble
C?ID=10563
Is this what you are looking for?
Saturday,04,April,2020,20:01:15:25945
Mode 01 - PID 01 : Readiness  --  Address 7E8
Number of DTCs stored: 0  --  MIL Status: MIL OFF
Misfire monitoring:  Passed
Fuel System:  Passed
Comprehensive Components:  Passed
Catalyst monitoring:  Passed
Heated catalyst monitoring: Not installed.
Evaporative system monitoring:  Passed
Secondary air system monitoring: Not installed.
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring:  Passed
Oxygen sensor heater monitoring:  Passed
Exhaust Gas Recirculation:  Passed
Mode 01 - PID 01 : Readiness  --  Address 7E9
Misfire monitoring: Not installed.
Fuel System: Not installed.
Catalyst monitoring: Not installed.
Evaporative system monitoring: Not installed.
Oxygen sensor monitoring: Not installed.
Oxygen sensor heater monitoring: Not installed.
Exhaust Gas Recirculation: Not installed.
Saturday,04,April,2020,20:01:59:25945
Mode 03: Emission related fault codes
Address 7E8: No fault code found.
Address 7E9: No fault code found.
Saturday,04,April,2020,20:01:35:25945
Saturday,04,April,2020,20:02:14:25945
Mode 07: Pending emission related fault codes
Saturday,04,April,2020,20:02:43:25945
Type 02 - VIN : WAUFFAFL0FN007071 (Address E8)
Type 04 - Calibration ID : 8K5115N 0005AVCB (Address E8)
Type 04 - Calibration ID : 8K0158AD100321   (Address E9)
Type 06 - Calibration Verification Number : FE64ECCA (Address E8)
Type 06 - Calibration Verification Number : 420C9225 (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 536
    Ignition cycle count : 1347
    Conditions completion count / Specified conditions encountered count
         Catalyst monitor bank 1 : 639 / 536
         Catalyst monitor bank 2 : 0 / 0
         O2 Sensor monitor bank 1 : 574 / 536
         O2 Sensor monitor bank 2 : 0 / 0
         EGR-VVT monitor : 911 / 536
         AIR monitor : 0 / 0
         EVAP monitor : 85 / 132
         Secondary O2 Sensor monitor bank 1 : 432 / 536
         Secondary O2 Sensor monitor bank 2 : 0 / 0
Type 0A - Controller Name : ECM-EngineControl (Address E8)
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
psychobabble
C?ID=10563
I realized I didn't answer your questions. No MI and I don't believe any performance limitation. The car is new to me, as is the 2.0 engine. I've always had V6s. And thank you for your help!
The two "Intermittent - Not Confirmed" faults in the ECU are not a real worry.
Fix the EVAP code.
Clear the faults in 53-Parking Brake and see if the come back. The time/date stamps on 'em are from last year and the fault frequency is quite low. They may be an artifact of some kind of work being done then.
psychobabble
C?ID=10563
Ok, I’ll replace the gas cap and clear. Thanks a bunch for your advice
Before changing gas cap inspect filler neck for debris and o-ring on cap then lube the o-ring with light coat of Vaseline and run LDP test or generate readiness script.
