Results 1 to 9 of 9
Thread: VLAND Headlight Upgrade Problems MK6 Golf
    Apr 2020
    I know this subject has been brought up before but everyone seems to be having different problems with these lights. Here we go anyway.
    I've fitted a set of VLAND head & tail lights to my MK6 TDI. Really happy with the way they look but I am running into issues. The dash warning light seems to be a normal issue that I believe can be fixed with a small change to the long coding on VCDS. (Central Elec line 18). saying that I am brand new to VCDS so i'm not sure exactly what I need to do to remove the warning light. Can anyone offer some advice? When I load line 18, VCDS gives me a warning and doesn't allow me to change the binary code.
    On a (I think) different fault, the dipped headlights aren't working on either side of the headlights. The DRL, indicators and full beam work fine. You can hear the internal shutter moving in the headlight unit.Ii have read in a couple of threads that the plug may be wired wrong. Again, any advice on this would be great.
    Thanks in advance
    Apr 2020
    Ive added below an autoscan of the car. (Sorry forgot in the first post)
    Friday,03,April,2020,17:25:22:56767
    VIN: #2332   License Plate:
    Mileage: 203250km-126293mi   Repair Order:
    Chassis Type: 1K-VW36 (1K0)
    VIN: WVWZZZ1KZAP142332   Mileage: 203250km-126293miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 B    HW: 03L 906 023 A
       Component: 1,6l R4 CR td H23 5863
       Coding: 00114014030500080000
       Shop #: WSC 00028 028 00023
       ASAM Dataset: EV_ECM16TDI02103L906023B 001005
       ROD: EV_ECM16TDI02103L906023A_001.rod
       VCID: 2517F7E0556CDDDF9A3-8070
    Readiness: 1010 0000
       Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
       Revision: 00H30001
       Coding: 133B200D092600FCC80E04E7901B0081300000
       Shop #: WSC 00028 028 00001
       VCID: 78A9EE94B2DE9037F15-802C
       Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000000002
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 6D87CFC0CD1C259F123-8038
              B10AB F0 [009] - Too Low
                        Reset counter: 54
                        Mileage: 154521 km
                        Date: 2018.06.08
                        Time: 15:41:57
       Part No SW: 1K0 937 084 B    HW: 1K0 937 084 B
       Component: BCM PQ35  B   103 0575
       Revision: 00103 AG
       Coding: 40180A3A9025180044000080000000E443010088524D8160648000200000
       VCID: 2D070FC00D1CE59F523-8078
       Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 25021  21  0512
       Coding: 009795
    6 Faults Found:
    01800 - Light Switch (E1)
                        Reset counter: 163
                        Mileage: 202580 km
                            Term 15 Off
                        Voltage: 12.70 V
                            Term 50 Off
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 21
                        Reset counter: 130
                        Mileage: 203255 km
                        Date: 2014.08.24
                        Time: 00:00:37
                        Voltage: 11.25 V
                            Term 50 Off
                        Fault Frequency: 21
                        Reset counter: 130
                        Mileage: 203255 km
                        Date: 2014.08.24
                        Time: 00:00:44
                        Voltage: 12.40 V
                            Term 50 Off
                        Fault Frequency: 16
                        Reset counter: 130
                        Mileage: 203255 km
                        Date: 2014.08.24
                        Time: 00:00:48
                        Voltage: 13.65 V
                            Term 50 Off
                        Fault Frequency: 21
                        Reset counter: 130
                        Mileage: 203255 km
                        Date: 2014.08.24
                        Time: 00:00:48
                        Voltage: 13.65 V
                            Term 50 Off
                        Fault Status: 00101110
                        Reset counter: 170
                        Mileage: 203255 km
                        Date: 2014.08.24
                        Time: 04:20:10
                        Voltage: 12.10 V
                            Term 50 Off
       Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
       Component: AirbagVW10    037 0606
       Serial number: 003FKD04J4XP
       Coding: 00003133
       Shop #: WSC 01383 790 00063
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3B233198C3E87B2FDC7-806E
       Serial number: 3572MSME31186350ZZZK
       Serial number: 3582MSME626F6150ZZZZ
       Serial number: 3512QSME3E22520AZZZT
       Serial number: 3522QSME1A22517DZZZX
       Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
       Component: J0527           053 0111
       Coding: 0000004
       VCID: 03538978F718C3EFD47-8056
       Part No SW: 5K0 920 960 N    HW: 5K0 920 960 N
       Component: KOMBI         H04 0308
       Coding: 470B00
       VCID: 38292E94F2DE5037315-806C
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H07 0112
       Revision:   H07 01    Serial number: 020310F2001592
       Coding: E9801F06000202000001
       VCID: 698FBBD0F57439BF7EB-803C
       Component: IMMO          H04 0308
       VCID: 6A8DC4DCFCF232A7771-803E
       Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
       Component: Tuer-SG         009 2138
       Coding: 0000564
       VCID: 333319B8E738B36F047-8066
       Part No: 1K0 909 144 J
       Revision: 00H17000
       VCID: 313F13B01D24817F76B-8064
       Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
       Coding: 0000564
       VCID: 34311AA4E236B4571DD-8060
    Address 56: Radio
    End----------(Elapsed Time: 00:47, VBatt start/end: 12.1V/12.1V)-----------
    Oct 2014
    As your byte 18 is currently 00, it's probably better to use another tool (VCP/ODIS-e) to both backup the current lighting config and tweak it for the new lights.
  4. Likes PetrolDave liked this post
    Apr 2020
    I take it those are different diagnostic systems? Is there no way to adjust it using VCDS? I bought it so I could carry out tweeks like this when I needed to?
    Oct 2014
    You can certainly use VCDS to change byte 18 but in your case, I wouldn't suggest doing so...
    As the value is 00, this means the true value has been masked by VW or more likely, none of the byte 18 options are correct for your car. Instead, VW set the value to 00 and then set the lighting config directly in the EEPROM. Be warned, if you change byte 18, you cannot restore the original light config by changing it back to 00! It will continue using whatever lighting config you last set...
    If you're very lucky, one of the byte 18 values will be correct for your car with the aftermarket lights. This is very unlikely and given you won't be able to restore the stock configuration afterwards, I really wouldn't suggest trying.
    As VCDS is primarily a diagnostic tool, unfortunately, it doesn't offer direct access to the BCM EEPROM to edit the lighting config.
    Have you contacted VLAND for advice as they seem to advertise both as 'plug and play'? Hopefully you won't need to mess with byte 18...
  7. Likes Uwe, PetrolDave, SilentService liked this post
    Apr 2020
    Ah that makes a lot more sense, I will contact VLAND and see if they offer any advice. Just so i'm aware, which software (VCP/ODIS-e) would you recommend for accessing the BCM EEPROM? Just in case it comes to that. At least I can have a look at it.
    Really appreciate the help and advice. I'l post on here if I get any results
    Oct 2014
    ODIS-e is a dealer level tool so although garages/individuals can buy it, it's likely to be prohibitively expensive for a single for a single job.
    VCP is 3rd party tool and is closer to VCDS in cost. It has a built in editor for the lighting config but it's probably best to only use the backup/restore functions and use something like VAGhelper (again, 3rd party) to tweak the settings.
    A better plan might be to find someone local-ish with the right tools once the covid lockdown has passed in the UK. If you're in the East of England, drop me a PM
  10. Likes Uwe liked this post
  11. #8
    Apr 2020
    I'm assuming that either of these programmes will require a different cable to my VCDS one? You might be right, it's going to be less of a pain and cheaper to get someone who knows what they're doing to take a look. Appreciate all the help 👍
  12. #9
    Oct 2014
    Correct, your VCDS cable won't work for either VCP or ODIS. Each requires it's own specific cable
