Results 1 to 9 of 9
Thread: 2016 Toureag AdBlue Reset
    Aug 2018
    Ireland
    From customer:
    "Filled AdBlue with engine running about 2,000km ago. Light never went off"
    Cluster shows 550kms left to non-start. Customer says that has remained the same since he filled tank.
    I checked adaption channels but could not find SCR Lock reset.
    I *thought* I had full AutoScan but only saved this:
    Saturday,04,April,2020,17:45:09:34893
    VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4513.4
    VIN:    License Plate: ---
    Gateway Installation List:  7P6 907 530 M
    Address 01,7P1 907 401 F,channel IDE02332-Deactivate production mode,adapted from,00 00 00 ,to,00 00 00 ,
    Address 01,7P1 907 401 F,channel IDE00898-Fuel line filling,adapted from,0 ,to,0 ,
    Address 01,7P1 907 401 F,channel IDE00898-Fuel line filling,adapted from,0 ,to,1 ,
    Address 01,7P1 907 401 F,channel IDE00898-Fuel line filling,adapted from,1 ,to,0 ,
    I'm looking again tomorrow - is there anything simple I've missed?
    PS: No DTCs were stored in Engine PCM.
    Thank you,
    E.
    Somehow I don't think that tank should be filled while the engine is running?
    It should have Basic Settings like this:
    IDE04567 -- Resetting of SCR tank level detection
    IDE04730 -- Reset SCR lock
    Please have a look in your Scans sub-folder to see if there isn't a full scan there.
    Aug 2018
    Ireland
    Saturday,04,April,2020,17:46:59:34893
    VIN: WVGZZZ7PZGD013079   License Plate: ---
    Chassis Type: 7P-VW52 (7P6)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 52 53 55 56 5F 62
              65 72
    VIN: WVGZZZ7PZGD013079   Mileage: 158945km-98763miles
    Address 01: Engine (J623-CVVA)       Labels:. 059-907-401-V2.clb
       Part No SW: 7P1 907 401 F    HW: 7P0 907 401 K
       Component: 3.0TDI EDC17  H21 0001
       Revision: 56H21---
       Coding: 292A4012232601030000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM30TDI0117P1907401F 001002
       ROD: EV_ECM30TDI0117P1907311.rod
       VCID: 33331DF59BBDEC4F047-8066
    Address 02: Auto Trans (J217)       Labels: 0C8-927-755.clb
       Part No SW: 0C8 927 755 C    HW: 0C8 927 755
       Component: AL1000 AISIN  130 2881
       Coding: 010100011C008400000000000000000000000000
       ASAM Dataset: EV_TCMAL991031 003118
       ROD: EV_TCMAL991031_003.rod
       VCID: 313F17FD61A1DE5F76B-8064
    Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
       Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
       Component: MK25A         H37 0521
       Revision: --------    Serial number: 41765440362788
       Coding: 5B6B13C309252556DAF4C89A90DBA470F701
       ASAM Dataset: EV_MK25AXT 010001
       ROD: EV_ESPMK25A01000.rod
       VCID: 4CC16609E64393B765D-8018
       Part No SW: 4H0 907 064 GL    HW: 4H0 907 064 GL
       Component: BCM2 2.0      H37 0572
       Coding: 01B60010000000000000
       VCID: 79AFEFDDF9D1D61F8EB-802C
       Subsystem 1 - Part No SW: 7P6 959 754 AP    HW: 7P6 959 754 AP
       Component: FBSTOUAREGIDG  H08 0084
       Serial number: 3615000166651012
       Serial number: 3215000146478014
       Part No SW: 7P6 907 040 CK    HW: 7P6 907 040 CK
       Component: Klima 2 Zonen H23 1507
       Coding: B626000A90
       VCID: 7F5B01C5E775F82FB0F-802A
       Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
       Revision: 22020001    Serial number: 00001168799301
       Coding: 26000014D0345D010029400300005D4C431D470827010241000000000040110000000000000000
       VCID: 6A8DC0918C776D87771-803E
       Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
       Component: WWS    150729  033 0021
       Serial number: 90243401150903075804
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
       Component: RLFS  H10 0020
       Serial number: 20649402
       Coding: 025223
       Subsystem 3 - Part No SW: 7P6 941 431 AB    HW: 7P6 941 431 AB
       Component: E1 - LDS  H02 0040
       Serial number: 00000000001009150151
    Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
       Part No SW: 7P6 919 475 D    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0030
       Revision: --------    Serial number: 28261524603427
       Coding: 108504
       ASAM Dataset: EV_VW526ParkiAssis2 001013
       ROD: EV_VW526ParkiAssis2.rod
       VCID: 44D14E29CE135BF7ADD-8010
       Part No SW: 7P0 959 655 F    HW: 7P0 959 655 F
       Component: VW10Airbag01M H10 0044
       Revision: --------    Serial number: 003S800138MU
       Coding: 00000000000000000000000000000000314D
       ASAM Dataset: EV_AirbaVW10BPAVW526 002001
       ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
       Serial number: 3575LRB404T3COSABP0E
       Serial number: 3585LRB404R3COSA6HBB
       Serial number: 3517ARB40593ERQU8O43
       Serial number: 3527ARB405B3ERQULGMT
       Serial number: 3557BRB405D3HES44942
       Serial number: 3567BRB405F3HES4L9O%
       Part No SW: 4H0 953 568 P    HW: 7P6 953 507 AL
       Component: Lenks.Modul   H06 0010
       Revision: --------    Serial number: 01374OIF000AR
       Coding: 000015
       VCID: 40D94239DA8B47D7895-8014
       Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
       Component: E221__MFL-TAS  H05 0028
       Serial number: 0039537 TRW 20150820
       Part No SW: 7P6 920 883 B    HW: 7P6 920 883 B
       Component: Kombi         H13 0515
       Revision: 13240302    Serial number: 658090915592019
       Coding: 233731002B00000800000C
       ASAM Dataset: EV_KombiUDSRBVW526 001022
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 3D273BCDADF92A3FE23-8068
       Part No SW: 7P6 907 530 M    HW: 7P6 907 530 F
       Component: GW-CAN-L-MOST H13 6042
       Revision: --------    Serial number: 00000001971214
       Coding: 000D07AD00
       ASAM Dataset: EV_GatewVW526UDS 001007
       ROD: EV_GatewUDS_VW52.rod
       VCID: 42DD4831D40755C79F1-8016
       Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
       Component: Batt_Sensor  H07 0190
       Serial number: 42241338565701608256
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
       Serial number: 15251001006011200181
    16384 - Function Restriction due to Driver Fatigue Recognition
              B130E 00 [008] - -
              [Funktionseinschraenkung Pausenempfehlung]
                        Reset counter: 17
                        Mileage: 158382 km
                        Date: 2020.04.01
                        Time: 15:40:25
                        Voltage terminal 30: 14.7 V
                        Voltage terminal 15: 14.8 V
                        Control Module temperature: 28 °C
                        System status: Terminal 15 on
                        Engine running: On
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
       Component: MEM-FS        H08 0156
       Revision: AA000000    Serial number: 00000162080825
       Coding: 0078130000004001000001010101202020202121202020
       VCID: 34311EE99E33EB771DD-8060
       Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
       Component: TSG FA        H02 0306
       Revision: --------    Serial number: 0000165516935
       Coding: 011D0620DE01451005080002
       VCID: 7AADF0D1FCD7DD07871-802E
       Revision: 00002001    Serial number: 0377484496
       Coding: 011B1620A8B9008083200624000000000000000000000000000000000000
       Subsystem 1 - Part No: 7P6 951 172
       Component: Sensor, DWA  005 0502
       Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
       Component: TSG BF        H02 0306
       Revision: --------    Serial number: 0000165540233
       Coding: 011D0620DE01451005080000
       VCID: 48C95A19F2BB7F97415-801C
       Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
       Component: EPB           H51 1201
       Revision: 00000000    Serial number: C1591300578
       Coding: 01040100
       ROD: EV_ParkbA7.rod
       VCID: 363524E188CFF967239-8062
       Slave 3:
       Coding: 01AE02000B000200
       ROD: EV_HeadlRegulAFSMQBMLB.rod
       VCID: 3FDB41C5A7F5382FF0F-806A
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0005
       Coding: B00000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0005
       Coding: B00000
       Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
       Component: Radio U DAB   H60 0150
       Revision: AB001007    Serial number: 109I 0F2502937
       Coding: 010105020100000003
       VCID: 2B030595430DB48F4C7-807E
       Part No SW: 7P6 035 670 K    HW: 7P6 035 670 A
       Component: H-BNT-EU      H41 0934
       Revision: --------    Serial number: 603I.0F7522084
       Coding: 010101050040E1ED41000B0E00000003500401030000000000
       VCID: 3D273BCDAD792A3FE23-8068
       Subsystem 1 - Part No: 7P6 060 884 A
       Component: EUR 2015  2102
       Subsystem 2 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
       Component: DU8 SV Touch  H56 0046
       Serial number: VWZ8Z9RGF009KD
       Subsystem 3 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
       Component: CD-Database  6208
       Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
       Component: TSG HL        H03 0306
       Revision: --------    Serial number: 0000165391508
       Coding: 011804200001251005080000
    Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
       Part No SW: 7P6 907 273 L    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0003
       Serial number: 30000000024778
       ASAM Dataset: EV_RDKBERU30 005005
       ROD: EV_RDKBERU30_005.rod
       VCID: 45D7532DC52962FFBA3-8010
       Component: TSG HR        H03 0306
       Revision: --------    Serial number: 0000165381197
    End----------(Elapsed Time: 01:47, VBatt start/end: 12.1V/12.1V)-----------
    Aug 2018
    Ireland
    You're correct. Manual says to have engine off. Also a sticker beside AdBlue filler. But customer ignored it
    Quote Originally Posted by BavarianCare View Post
    You can take a horse to water ............
  6. Likes BavarianCare liked this post
    Aug 2018
    Ireland
    Finally this customer called back and with latest VCDS it did have the option.
    Can somebody explain exactly the following and what they do?
    IDE04730-Reset SCR Lock (this is what I used and it put out light, however I did not add fluid)
    IDE04567-Resetting of SCR tank level detection (I did not do this reset)
    In measuring values it indicated full AdBlue tank - but it is not?
    Do these tanks have a level sensor or does the DDE 'estimate' based on reset?
    What I'm thinking is that I've reset SCR with a half tank and now DDE will overestimate the AdBlue remaining.
    Also, I cannot find an option in cluster to show remaining AdBlue distance.
    Thanks in advance.
    Our 2015 T'reg does not have anything resembling a real DEF tank level sensor or indication. I doubt this 2016 is any different in that respect. Fill it at every oil change an it's all good, but we generally don't go more than 7500 miles between oil changes with it.
    I've yet to figure out how the ECU determines that it's close to empty.
  9. Likes BavarianCare liked this post
  10. #8
    Aug 2018
    Ireland
    Thanks Uwe.
    My 'guess' is that reset of tank level should be done with full DEF tank.
    Reset of SCR lock is just to reset the light?
    Check of SCR efficiency I really do not know enough even to guess
  11. #9
    Aug 2018
    Ireland
    I found this Ozzie website:
    https://chiptuning.com.au/how-to-res...2011-vag-ecus/
    Are they correct?
