Results 1 to 5 of 5
Thread: I Can't stop the GPF regeneration service IDE12213
    Apr 2016
    Sweden
    I own a Skoda superb 2020 2.0 TSI 190hp with 5600km on the clock that have GPF and I am using the HEX-V2 interface.
    I accidentally start the command (IDE12213 - Particle filter service regeneration when driving ), under 01- engine, 04- basic settings, and couldn't stop it, so I drove the car and followed the regeneration recommendations from the owner manual, I used the advanced measuring values to watch the soot amount (IDE00434 soot mass calculated) after 30min drive the values went from 3137mg to 0mg.
    Now the problem is that I can't stop the particle filter service regeneration it's always on when I start the car, I disconnected the battery 10 min but it didn't help and I can't delete the fault code.
    Saturday,04,April,2020,10:44:24:59447
    VCDS Version: 20.4.0.1 (x64)  HEX-V2 CB: 0.4513.4
    VIN: TMBJM9NP3L70177XX   License Plate:
    Mileage: 5644km-3507mi   Repair Order:
    Chassis Type: NP-SK48 (3Q0)
    Scan: 01 02 03 05 06 08 09 10 13 14 15 17 18 19 23 2B 36 3C 42 44
              47 4B 52 5F 6C 6D 75 A5 BB BC D6 D7
    VIN: TMBJM9NP3L7017731   Mileage: 5644km-3507miles
    Address 01: Engine (J623-DKZA)       Labels: None
       Part No SW: 3G0 907 115     HW: 06K 907 309 B
       Component: R4 2.0l TFSI  H60 0002
       Revision: O1H60000
       Coding: 0425401A2464050B34000000000000000000000000000000
       Shop #: WSC 00033 790 00139
       ASAM Dataset: EV_ECM20TFS0113G0907115 001004
       ROD: EV_ECM20TFS011_VW37.rod
       VCID: 619E52ED51C729733CC-8034
    38433 - Particulart Filter Bank 1
              P1A91 00 [039] - Indicator Lamp Active
                        Mileage: 5644 km
                        Date: 2020.04.04
                        Time: 00:39:03
                        Coolant temperature: 70 �C
                        Intake air temperature: 46 �C
                        Voltage terminal 30: 12.160 V
                        Engine status: COENG_READY
    Readiness: 1110 0001
       Part No SW: 0GC 300 044 J    HW: 0GC 927 711 H
       Component: GSG DQ381     H06 2404
       Revision: 00H06V10
       ASAM Dataset: EV_TCMDQ381061 001
       ROD: EV_TCMDQ381061.rod
       VCID: 2F3AE4D55793CF03FA8-807A
       Part No SW: 5Q0 614 517 FA    HW: 5Q0 614 517 BR
       Component: ESC           H82 0190
       Revision: 00000000    Serial number: 62409000001951
       Coding: 1E077A9C31213B73477E060360C449785E8CDCE2600692753841F0F8D2A94A0B0003000012121212B835351919323200
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
       ROD: EV_Brake1UDSContiMK100IPB_038.rod
       VCID: 75B616BDF54FB5D3704-8020
       Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
       Component: VWKESSYMQB    037 1307
       Revision: 00037000    Serial number: 0526155244
       Coding: 0F20000723
       ASAM Dataset: EV_KessyHellaMQBAB 004052
       ROD: EV_KessyHellaMQBAB.rod
       VCID: 45D6A67DE52F6553204-8010
       Subsystem 1 - Part No SW: 3AA 962 243 G    HW: 3AA 962 243 G
       Component: GEB.F.Heckoef  H16 0903
       Serial number: 84620215
       Part No SW: 5Q0 959 760 E    HW: 5Q0 959 760 E
       Component: Sitzmemory    H09 0026
       Serial number: Y0007SH924743
       Coding: 0010000000000500018280808080000000008181000000D400
       ASAM Dataset: EV_SeatMemorPasseSide 002022
       ROD: EV_SeatMemorPasseSide.rod
       VCID: 3FDAB49587F33F836A8-806A
       Part No SW: 3V0 907 044 FF    HW: 3V0 907 044 FF
       Component: AC Automat    H34 4803
       Revision: 20K10000    Serial number: 00000B01430082
       Coding: 12010004004111011005104C0010502A
       ASAM Dataset: EV_ACClimaPrehVW37X 002027
       ROD: EV_ACClimaPrehVW37X_002_VW37.rod
       VCID: 7DA60E9DCD7FED93384-8028
       Subsystem 1 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
       Component: G238 _AQS  H30 0119
       Serial number: 89622532
       Subsystem 2 - Part No SW: 3V0 907 049 D    HW: 3V0 907 049 D
       Component: E265KlimaHeck  H02 0101
       Serial number:       06051501850797
       Part No SW: 5Q0 937 086 CF    HW: 5Q0 937 086 BR
       Component: BCM PQ37BOSCH 038 0303
       Revision: --------    Serial number: J53F1908190051
       Shop #: WSC 00033 790 00169
       ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
       ROD: EV_BCMBOSCH_020.rod
       VCID: 00587769BA8D807B532-8054
       Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: 48x LL 190701  032  0121
       Serial number: 00000001906240301345
       Coding: 165DDD
       Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
       Component: RLHS  051  0206
       Serial number: S4Y19M08D06H11M28S31
       Coding: 00084D
       Steering Column Switch:
       Subsystem 4 - Part No SW: 5Q1 953 521 DH    HW: 5Q1 953 569 C
       Component: Lenks.Modul  H33  0170
       Serial number: 0100160720190C300915
       Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Component: SysNameFanLin  014  0101
       Serial number: ESE0546069
       Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Serial number: ESE0652618
       Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Serial number: ESE0652724
       Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Serial number: ESE0546845
       Part No SW: 5QA 919 294 G    HW: 5QA 919 294
       Component: PDC 8 Kanal   H08 0061
       Serial number: 000150058319247
       Coding: 0471155851
       ASAM Dataset: EV_EPHVA18AU3700000 009046
       VCID: 50F887292A6DB0FB832-8004
       Part No SW: 5Q0 907 572 R    HW: 3Q0 907 567 A
       Component: ACC BOSCH MQB H01 0771
       Coding: 32057FD25DFFC728949C812481400600000000000000000046
       ASAM Dataset: EV_ACCBOSCHVW416 003014
       ROD: EV_ACCBOSCHVW416_003.rod
       VCID: 46D4A171D8296E4B29E-8012
       Serial number: 04081941350062
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 3828DF89A2DD08BBAB2-806C
       Part No SW: 5Q0 959 655 CA    HW: 5Q0 959 655 CA
       Component: AirbagVW21    008 0403
       Serial number: 003FPR5MNL4G
       Coding: 98FCC0C0000000005C5400CF004800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
       VCID: 015E726DB18789735CC-8054
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1040
       Serial number: 3V0857701C0242T00737
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1040
       Serial number: 3V0857702C0242T00910
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 002 708 19
       Serial number: 357000000006735C3F3Q
       Subsystem 4 - Part No SW: -----------    HW: 480 000 109 19
       Serial number: 3580000000044520DF3J
       Subsystem 5 - Part No SW: -----------    HW: 480 402 708 19
       Component: SideSensor_Dr  005 6149
       Serial number: 3510001A4F0A2E12F399
       Subsystem 6 - Part No SW: -----------    HW: 480 402 308 19
       Component: SideSensor_Pr  005 6149
       Serial number: 3520001C2F240027F51X
       Subsystem 7 - Part No SW: -----------    HW: 480 402 308 19
       Component: FrontSensor_D  005 6149
       Serial number: 3550001C2F240029130L
       Part No SW: 3V0 920 790 D    HW: 3V0 920 790 D
       Component: KOMBI         502 4191
       Coding: 05AD091A7F8C00080188770B1001000880000000
       ASAM Dataset: EV_DashBoardVDDMQBA0 001042
       ROD: EV_DashBoardVDDMQBA0_VW37.rod
       Part No SW: 5Q0 963 272 K    HW: 5Q0 963 272 K
       Component: STH-MQB       008 0080
       Coding: 9309
       ASAM Dataset: EV_AuxilParkiHeateWOS 002018
       VCID: 3E24C99180F9368B61E-806A
       Component: R64 D208L  004 0402
       Serial number: 00000000000000808324
       Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
       Component: GW MQB High   521 5388
       Serial number: 27081910520842
       Coding: 030100047F085900BB1002DE980F00010001070000000000000000000000
       Shop #: WSC 00033 790 00178
       ASAM Dataset: EV_GatewNF 013026
       ROD: EV_GatewNF_VW37.rod
       VCID: 70B827A98A2D90FBA32-8024
       Component: 4-01-09-01-04
       Subsystem 2 - Part No SW: 3V0 919 719 H    HW: 3V0 919 719 H
       Component: E221__MFL-PR6  H03 0180
       Serial number: 000000000B0385230819
       Serial number: 2137632305
    Address 23: Brake Booster (J539)       Labels: None
       Part No SW: 3Q0 909 059 G    HW: 3Q0 909 059 A
       Component: EBKV          H06 0069
       Serial number: BPA085240819013
       Coding: 0102C500340000C618638C31000049922449920400
       ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
       ROD: EV_BrakeBoostG2BoschVW48X_011_SK48.rod
       VCID: 3B22C08593EB23A3460-806E
       Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
       Component: ELV-MQBB      H05 0020
       Serial number: 19000203284016
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_AU37.rod
       VCID: 3332E8A5BBBBEBE39E0-8066
       Serial number: Y0007SH924139
       Coding: 001000020000050001C280808080000000008181000000D400
       ASAM Dataset: EV_SeatMemorDriveSide 002022
    Address 3C: Lane Change (J1086)       Labels:* None
       Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
       Component: HRE3_Kl15_Mst H06 0149
       Serial number: 00000523956564
       Coding: 52954640
       ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
       ROD: EV_HREntryHellaGen3Kl15.rod
       VCID: 392EDA8D99D711B354C-806C
    Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
       Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
       Component: TSG FS        007 0485
       Serial number: 0000386785688
       Coding: 001D8920DE00028000001100
       ROD: EV_DCU2DriveSideMAXHKLO.rod
       VCID: 4DC69E5D3D5F9D13E84-8018
    Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
       Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
       Component: MQB_VWBS_GEN2 212 2211
       Serial number: 956015 00
       Coding: 0100001100400110
       ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
       ROD: EV_SteerAssisVWBSMQBGen2.rod
       VCID: 2B02F0C5638BB323D60-807E
       Part No SW: 81A 035 223     HW: 81A 035 223
       Component: MIB2_amp_P_SK H10 0410
       Revision: 00000001    Serial number: SKZ8Z1KJE088CPI
       Coding: 0384020000AA002FAA0000000000
       ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
       ROD: EV_AMPMst16C5Gen2ALPI.rod
       VCID: 59EE7A0D7997F1B374C-800C
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
       Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
       Component: FCM MQB Low   003 0367
       Serial number: 30081910522662
       Coding: 00000007090008EA06003D13010000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 003003
       ROD: EV_MultiModulContiVW48X_003_VW27.rod
       VCID: 372ADCB5AFC307C3A28-8062
    Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
       Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
       Component: TSG BFS       007 0485
       Serial number: 0000387281960
       Coding: 001D8120DE00028000001100
       ROD: EV_DCU2PasseSideMAXHKLO.rod
       VCID: 4CC09359C645941BFFA-8018
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
       Part No SW: 565 035 874     HW: 565 035 874
       Component: MU-S-ND-ER    H41 0477
       Serial number: SKZAZ2W1000861
       Coding: 03840201000000004111000200080A002F020BE4012004008E
       ROD: EV_MUStd4CTSAT_VW37.rod
       VCID: 5BE2600573AB03A3660-800E
       Subsystem 1 - Part No SW: 3V0 919 605 D    HW: 3V0 919 605 D
       Component: ABT_Std-2_Nav  H53 8130
       Serial number: SKZ6ZHW2433346
       Subsystem 2 - Part No SW: 5L0 051 236 BJ    HW: -----------
       Component: ECE AS 2020  --- 1310
       Component: RVC Compact   H18 0231
       Coding: 04840201A2002017000040
       ROD: EV_CamSysRVRVCPANAMQBAB.rod
       Part No SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0271
       Revision: --------    Serial number: A2-C737-6291-8
       Coding: 0D08
       VCID: 48C8AF49D23D783BDB2-801C
       Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
       Component: OCULowMQBLGE  H19 0825
       Revision: --------
       Coding: 03840201EA421A0D3F1CBE000045400382E608
       ASAM Dataset: EV_OCULowMQBLGE 004049
       ROD: EV_OCULowMQBLGE_004_VW25.rod
       VCID: 3D26CE9D8DFF2D93784-8068
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 2Q0 980 653     HW: 2Q0 980 653
       Component: MQB MFK 3.0   H11 1027
       Serial number: E33417008192380
       Coding: 0002088811684028B09F10001030008001230000000000000000000000000000
       ASAM Dataset: EV_MFK3ValeoMQB 005035
       ROD: EV_MFK3ValeoMQB_005_VW27.rod
       VCID: 72BC2DA18421A2EB556-8026
       Part No SW: 8W0 959 595 M    HW: 8W0 959 595 J
       Component: TSG HFS       010 0384
       Serial number: 0000387080564
       Coding: 001C81208000028000001100
       VCID: 56F471310889DECB59E-8002
       Component: TSG HBFS      010 0384
       Serial number: 0000387075326
       Part No SW: 992 941 571 AA    HW: 992 941 571 A
       Component: LED1L         H08 9002
       ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
       ROD: EV_LLPGen3LKEBODPO68X_SK48.rod
       Component: LED1R         H08 9002
       ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
    End----------(Elapsed Time: 02:08, VBatt start/end: 12.3V/12.3V)-----------
    Any one knows how I can stop the regeneration service?
    Thanks in advance.
    How does one "accidentally" initiate a Basic Setting?
    I do not know what is involved in bring this routine to completion.
    Apr 2016
    Sweden
    Accidentally means that I pushed the "Run button" when I shouldn't, that can happen if someone is getting distracted
    Maybe try to start Basic Setting "Stationary particle filter service regeneration"
    Apr 2016
    Sweden
    Thank you for your answer!
    i tried that but I get a message in red color stating that option is not available, maybe because "Particle filter service regeneration when driving" is running.
