Front left Abs sensor (G47)
Cobie90
C?ID=311736
Hey Tech fam,
I've been having problems with trying to get my abs sensor to read. Its saying implausible signal. Which I've changed the axle and also the wheel bearing and a brand new Abs sensor it still won't read though. I was wondering if anyone know if it's something dealing with the computer are a fuse I need to check(if so what location). Are is there anyway I can check if the wire is bad with VCDS. Thanks to anyone that can help me out. My scan is below.
Thursday,02,April,2020,09:54:33:05661
VIN: WAUKGAFB7AN036515   License Plate:
Mileage: 200540km-124609mi   Repair Order:
Chassis Type: FB-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 47 4C 4F 52 53 55
          56 5F 62 6C 72
VIN: WAUKGAFB7AN036515   Mileage: 200540km-124609miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (CCA)       Labels:. 06E-907-551-CAJ.clb
   Part No SW: 4F1 910 551 D    HW: 4F1 907 551
   Component: 3.0l V6 TFSI        0050
   Revision: --H06---    Serial number:
   Coding: 0105000A190F0120
   Shop #: WSC 08175 444 103843
   VCID: 2412E4F0D2DA9EFB17A-8070
               U1017 - 000 -
                    Fault Frequency: 55
                    Mileage: 200232 km
                    Date: 2020.03.28
                    Time: 17:25:57
                    RPM: 1344 /min
                    Mass Air / Rev.: 103.6 mg/str
                    Temperature: 64.5°C
                    Bin. Bits: 00000010
                    Load: 8.6 %
   Part No SW: 4F9 910 156 A    HW: 09L 927 156 C
   Component: AG6 09L 3,0TFSI USA 0010
   Revision: --H04---    Serial number:        4539555
   Shop #: WSC 02325 785 00200
   VCID: 2A0E0AC8B0FE488B2D6-807E
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 AL    HW: 4F0 614 517 BA
   Component: ESP8 quattro    H03 0060
   Coding: 0020921
   VCID: 6E86C6D84C9664ABB1E-803A
                    Fault Frequency: 47
                    Reset counter: 225
                    Mileage: 200232 km
                    Date: 2020.03.28
                    Time: 18:16:45
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0021
                    Hex Value: 0x419D
                    Hex Value: 0x00FF
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                    Reset counter: 214
                    Mileage: 200232 km
                    Date: 2020.03.28
                    Time: 18:31:40
                    Hex Value: 0x0E00
                    Hex Value: 0x4312
                    Hex Value: 0x0006
                    Hex Value: 0x37AC
                    Hex Value: 0x00FF
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 E
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602501421794
   Coding: 0000007
   Shop #: WSC 02324 785 00200
   VCID: 2514F9F4D9E067F3004-8070
   Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
   Component: KLIMABETAETIGUNGH30 0080
   Revision: 00000076    Serial number: 00000030563599
   Coding: 0524326
   Shop #: WSC 02335 785 00200
   VCID: 1D64D114F1B0AF33584-8048
   Part No SW: 4F0 910 279 Q    HW: 4F0 907 279 A
   Component: ILM Fahrer      H24 0340
   Coding: 0139123
   VCID: 372823BC734CE563A28-8062
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H10 0040
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
            010 - Open or Short to Plus
                    Fault Status: 01111010
                    Reset counter: 225
                    Mileage: 170616 km
                    Date: 2019.01.24
                    Time: 17:58:00
                    Reset counter: 225
                    Mileage: 170616 km
                    Date: 2019.01.24
                    Time: 17:58:00
                    Fault Status: 01111011
                    Reset counter: 225
                    Mileage: 170616 km
                    Date: 2019.01.24
                    Time: 17:57:00
                    Reset counter: 225
                    Mileage: 170616 km
                    Date: 2019.01.24
                    Time: 17:57:00
00156 - Control Circuit for Windshield Washer Pump
                    Reset counter: 225
                    Mileage: 177884 km
                    Date: 2019.05.01
                    Time: 16:22:00
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 1574C9340580F773904-8040
Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 R    HW: 4F0 959 655 H
   Component: Airbag AU1042 H06 0160
   Revision: --------    Serial number: 003FA0012RDS
   Coding: 303142373034303030314A55304C34463053
   ROD: EV_Airba10AURB4.rod
   VCID: 36362EB878C61C6BB9E-8062
   Subsystem 1 - Part No SW: 4F0 910 339 B    HW: 4F0 959 339 B
   Component: BF-Gewichtss.  H03 0060
   Serial number: 5810000R0000003W4J
   Serial number: 3574SRB400009FDD0ABV
   Serial number: 3584SRB400009F94E27L
   Serial number: 3516HRB402VC0AS50SV6
   Serial number: 3526HRB402VC0AS4OKNE
   Serial number: 3554NRB40000517EBB79
   Serial number: 3564NRB4000051197E1Z
12583424 - Powertrain Databus
          U0002 00 [008] - No Communications
          [High Speed CAN Communication Bus no signal/communication]
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026092900003
   Coding: 0012141
   VCID: 2708F3FCA3EC75E3328-8072
Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 983 H    HW: 4F0 920 983 H
   Component: KOMBIINSTR.   H08 0144
   Revision: 00000000    Serial number: CN450YEA9
   Coding: 8BD60A050B00CF05020201
   Shop #: WSC 02391 823 56573
   VCID: 313C1DA491283B53ECC-8064
   Part No SW: 4F0 907 468 M    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0035
   Revision: LB100029    Serial number: 2900L09A1700BA
   Coding: 000303
   VCID: 392C25844958F31354C-806C
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790931568
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001010017085
   Coding: 00581B00004011110000
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000102168472
   Coding: 011F57204E40410001
   VCID: 46D65E7808A68CEB29E-8012
   Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
   Component: Komfortgeraet   H29 0250
   Revision: 02500029    Serial number: 01229654010000
   Coding: 4618269
   VCID: 353429B469401773B04-8060
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 035 223 P    HW: 4F0 035 223 P
   Component: BOSE G3 C6    H01 0100
   Revision: AG001300    Serial number: 00000000041814
   Coding: 05000000
   VCID: 290CF5C4B9F8439324C-807C
   Part No SW: 4F0 910 274 A    HW: 4F0 907 274
   Component: J793  RKA+      H02 0100
   Revision: 00000506    Serial number: 00005061074829
   Coding: 0623301
   VCID: 221EE2E8C8CE90CB656-8076
01679 - ABS Wheel Speed Signal; Front Left
            012 - Electrical Fault in Circuit - MIL ON
                    Fault Status: 11101100
                    Reset counter: 178
                    Mileage: 193297 km
                    Date: 2019.12.17
                    Time: 19:23:42
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0007
                    Voltage: 13.50 V
                    Temperature: 6.0°C
                    (no units): 42.0
                    Fault Status: 11101101
                    Reset counter: 225
                    Mileage: 159565 km
                    Date: 2009.06.02
                    Time: 17:09:59
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0007
                    Voltage: 13.40 V
                    Temperature: 33.0°C
                    (no units): 255.0
                    Fault Status: 00101101
                    Reset counter: 254
                    Mileage: 199272 km
                    Date: 2009.06.02
                    Time: 00:19:28
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 12.20 V
                    Temperature: 30.0°C
                    (no units): 0.0
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000509539
   Coding: 0002014
   VCID: 5EE69618BC36F42B01E-800A
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000102131826
   VCID: 45D4597435A087F3204-8010
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000222
   Shop #: WSC 02145 785 00200
   VCID: 211CEDE4CDC88BD37CC-8074
                    Reset counter: 9
                    Mileage: 159560 km
                    Date: 2009.06.02
                    Time: 17:09:59
                    Voltage: 12.73 V
                    Count: 236
   Part No SW: 4L0 910 357     HW: 4L0 907 357
   Component: AFS 1           H01 0060
   Coding: 0000026
   VCID: 698CB5C475788393E4C-803C
   Subsystem 1 - Part No: -----------
   Component: AFS-Modul links
   Subsystem 2 - Part No: -----------
   Component: AFS-Modul rechts
02071 - Local Databus
                    Fault Status: 11100100
                    Reset counter: 13
                    Mileage: 159565 km
                    Date: 2009.06.02
                    Time: 16:19:41
00496 - Sensor for Vehicle Leveling; Front
                    Reset counter: 82
                    Mileage: 191374 km
                    Date: 2019.11.10
                    Time: 21:08:59
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335J-097535137
   Coding: 020000010000000000
   VCID: 1D64D114FDB0AF33584-8048
   Part No SW: 4E0 035 664 A    HW: 4E0 035 664 A
   Component: H-BN-NA       H45 0042
   Revision: --------    Serial number: 488J/097520192
   Coding: 010200000002E1FE41000304EF6300030000
   VCID: 221EE2E8C4CE90CB656-8076
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
   Component: DU7 High  H43 0306
   Serial number: 9356JX091091752
   Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 T
   Component: Bedienteil MM  H01 0060
   Serial number: 00000001422512
   Subsystem 4 - Part No: 8R0 906 961 A
   Component: CD-Database  1293
   Revision:             Serial number: 0000009496373
   Coding: 010E57204040220001
   VCID: 43D0476C3B94B9C30E0-8016
   Part No SW: 4F0 910 441 D    HW: 4L0 907 441 B
   Revision: --H03---    Serial number: 525PA8-J9925BW
   Coding: 1000304
   Revision:             Serial number: 0000009496374
End----------(Elapsed Time: 01:48, VBatt start/end: 13.9V/14.1V)-----------
PetrolDave
Westbury, UK
C?ID=1423
Where did you get the new ABS sensor from, is it a genuine VW part or a Chinese Replacement Auto Part?
Run an overlay yet to test the tracks?
VCDS can't check wiring, time for DVOM and test lights.
Cobie90
C?ID=311736
Ok have to look up what that is. To find the problem. Could you tell me what implausible signal means?
It means the control module is seeing something from the sensor, but what it's seeing is not within the expected range.
Cobie90
C?ID=311736
Any ideas on what I can do to fix the problem. I just replaced the wheel hub,axle, and abs sensor. Do you think its defective and the magnetic ring on the wheel hub isn't sending the information right?
P.S: this is my 2nd time replacing the abs sensor and it always read implausible signal.
Cobie90
C?ID=311736
It is the genuine audi part got it from there website. Unless they are selling Chinese knock offs
What part number ABS sensor, hub and axle was installed did you install?
Did you count the reluctor teeth or could you in comparison of the old and new?
Cobie90
C?ID=311736
The hub and axle came off of rock auto exactly the same fitting and part numbers as audiusa website and I ordered the sensor from audi website it seld so I could rule it out being a chinese knock off
Are you dismissing me because that is what it sounds like? :rolleyes:
Than did you carry on and run the needed electrical tests as aforementioned yet?
Cobie90
C?ID=311736
No I'm not dismissing you i want the light gone off asap because it have my traction, abs and ,tire light on.
How do I go by running the electrical test?
You can do whatever it is you like when querying the RTFB you have freewill don't you, however, would it not be wise to verify the parts are indeed correct by comparison of old to new first and based on microfiche not a sub vendor before you compound things?
FOD suspect until you do that is why JPPSG
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Cobie90
C?ID=311736
Cobie90
C?ID=311736
See how RTFB is bold, green and underlined? On this forum that means if you hover your mouse over it an explanation will appear in a pop-up :thanks:
Ok I was on my phone I'm about to log into my computer
